Audi Q3 TPMS enabling
somedude
Yuengling Country
C?ID=306296
Hello everybody,
I have a 2017 Q3 base model.
The main reason I got the HEX-V2 is to enable TMPS.
My Pontiac had it 10 years ago and it was the real TMPS not the fake ABS relative speed one.
I tried to enable it though VCDS following some instructions on the web, by enabling the green menu first.
That didn't work, 5F, Channel 06 remains at 0 even though I tried to set it to 1 and it said OK.
I also found some instructions on the ABS module, but my part isn't known to VCDS so I didn't dare to do it blindly.
That called for byte 16, bit 2, which won't even show up as a checkbox for my part.
Not to mention that my byte 16 was 0x04, which I think means bit 2 is already set.
I could really use some directions on how to achieve this goal.
A kind mechanic at the dealer looked up my PR codes and said it could be enabled by "third party" tools, but no dealer will do it because that is how they distinguish between "models". In other words, you don't pay, you don't get it, even though.... anyway... enough ranting.
Soooo, I am wondering if there is a solution to this.
I do have the 1AT ABS, but the other part is unknown to VCDS.
I posted my scan on the pre-sales forum, but I will post it here as well.
Thank you for any suggestions and please let me know if any other info is needed.
Thursday,20,April,2017,17:51:05:35103
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
VIN: WA1ECCFSXHR0xxxxx   License Plate:
Mileage: 1960km-1217mi   Repair Order:
Chassis Type: FS (8U0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 5F 62 6D 72
VIN: WA1ECCFSXHR0xxxxx   Mileage: 1960km-1217miles
Address 01: Engine (CCT)       Labels: None
   Part No SW: 8U0 907 115 L    HW: 8U0 907 115 J
   Component: 2.0l R4/4V TFSI  06 0002
   Revision: PAH05---    Serial number:
   Coding: 0123010A190F01A0
   Shop #: WSC 00049 770 00119
   VCID: 40DA496FE68B52F76D9-8014
   Part No SW: 09G 927 750 NL    HW: 09G 927 750 NL
   Component: AQ 250 6F           2696
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 00049 770 00131
   VCID: 084A914F8E3BAAB7659-805C
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CJ
   Component: ESC-EBC460iV1 H12 0013
   Serial number: A01DDR6
   Coding: 42FF269F492143702077420964C592C20424D000508B4883
   Shop #: WSC 00049 770 00154
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71BCDCAB91218B7FD27-8024
   Part No SW: 8U0 820 047 G    HW: 8U0 820 047 G
   Component: J255  Klima Man     0030
   Revision: 00H02001    Serial number: 00000000000000
   VCID: 392C248B8551033F2A7-806C
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 AG    HW: 8X0 907 063 AG
   Component: BCM PQ35  M   113 0821
   Revision: AB113821
   Coding: AF000A0FA80336C4A4184BC121440D4D50FF66AA016F9523E40A06840045
   Shop #: WSC 00049 770 00015
   VCID: 015C8C6BA1019BFF227-8054
   Subsystem 1 - Part No SW: 8U1 955 119     HW: 8U1 955 119
   Component: WWS316 161110  H38 0090
   Serial number:         161202235421
   Coding: 0047F7
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50080466
   Coding: 02006E
   Subsystem 3 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
01134 - Alarm Horn (H12)
                    Reset counter: 75
                    Mileage: 82 km
                    Date: 2017.03.19
                    Time: 11:47:58
                    Voltage: 9.10 V
                        Term 50 On
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655 A    HW: 8U0 959 655 A
   Component: AirbagVW-AU10 H53 0723
   Serial number: 003LQD12VCBY
   Coding: 303932313231413130304A55304C38553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 002001
   ROD: EV_AirbaAU10SMEAU316_002.rod
   VCID: 45D4587BF52977DF5EF-8010
   Subsystem 1 - Part No SW: 8U0 959 339     HW: 8U0 959 339
   Component: BF-Gewichtss.  H02 0020
   Serial number: 5810000R160000FXJ7
   Component: S.Sens.Fahr.V
   Serial number: 3574MSME7953485BZZZ4
   Component: S.Sens.Beif.V
   Serial number: 3584MSME1D644B5CZZZ9
   Serial number: 3516KSME4A652040ZZZK
   Serial number: 3526KSME056E0F40ZZZY
   Subsystem 6 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME490E1140ZZZZ
   Subsystem 7 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3565USME58121140ZZZP
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 501 D    HW: 5K0 953 569 AL
   Revision: FF010018    Serial number: 20161215100521
   Coding: 1984204000
   VCID: 3B203E8383ED312F38B-806E
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Serial number: 09 12 2016  C0014777
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 930 H    HW: 8U0 920 930 H
   Component: KOMBI_MEDIUM  H05 0540
   Coding: 32CF00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3C223D9F86E33617311-8068
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 AS    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0090
   Revision: 1R190044    Serial number: 4441R16B3002B7
   Coding: F3460A5A050B0D610253
   VCID: 1370B623CB7D196F80B-8046
   Subsystem 1 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS11.403  H03 0004
   Serial number: 0000FST001BLWSL00000
   Coding: 101E00
   Subsystem 2 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 33342I01145831018801
   Subsystem 3 - Part No SW: 8U0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS11.403  H03 0004
   Serial number: 0000FST001BLWTM00000
   Coding: 001E00
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00015.11.16
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 52FE73273467D067CBD-8006
   Component: IMMO          H05 0540
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H11 0415
   Coding: 011E03200000000000
   VCID: 55F4883B0509C75F2EF-8000
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.377 1501
   Revision: 1BH04843    Serial number: 00163140160701
   Coding: 0000258
   VCID: 42DE4367E88740E77BD-8016
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H11 0415
   VCID: 54F2753F0EF3DE57D91-8000
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 161206-0002-130
   Coding: 16C7A41010022400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 44D2457FFE134ED7491-8010
   Part No SW: 8U1 035 187 B    HW: 8U1 035 187 A
   Component: RMC Cnct Sir  H62 0170
   Coding: 01000600028051070023000102010000010000
   VCID: 382A218FB25B1A37D59-806C
   Subsystem 1 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H43 0018
   Serial number: AUZ8ZDGCS038WS0
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010E03200000000000
   VCID: 4FF87A5327D5BD8FE43-801A
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
   Component: HDSG-Modul    H02 0552
   Revision: 15001001    Serial number: 328601189
   Coding: 183307C102
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 3D24309B9DF93F1F06F-8068
   Component: TSG HR        H08 0415
End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.5V)-----------
Moving to Tweaks since this isn't a physical retrofit.
Plenty of VW/Audi cars had "real" TPMS 10 or more years ago as well -- and we constantly get people begging us to help them disable it because they're too cheap to replace the sensors in the wheels that the batteries have gone dead in, or they didn't have the foresight to order their aftermarket (winter or performance) wheel and tire set with sensors. Oh, and the technology didn't exist back then to meet the standards using wheel speed measurements alone, so the manufacturers had no choice in how to implement it.
I don't have data for how to do it on that ABS module either. Maybe someone else does. It might be useful to google up other scans from that ABS system, particularly from cars that are known to have ABS from the factory.
somedude
Yuengling Country
C?ID=306296
Thank you Uwe,
I wasn't bashing the ABS based TPMS, my wife's Tiguan has it and it's fine, plus, like you said, it has the benefit of working with the winter tires as well.
I was simply showing my disappointment that a car in this price range doesn't have it enabled, as I suspect it has everything it needs to do it internally.
From this scan:
... looks like the part number is the one I have to search for: 5N0 614 109 CJ, right?
Or is it the Component: ESC-EBC460IV1?
Quick question, if I scan a car, will the VIN be used up?
I know someone with a loaded Q3 that I could scan.
I could probably also go into the coding and look at the individual settings if their VIN won't be used up.
From what I noticed, my VIN was registered when I tried to make changes and not when scanning, but I just wanted to be certain. I only have a 3 VIN licence and two VAG cars, so I would like to save the third for the near future... :-)
Thank you for your help.
GaryM
Oxford, UK
C?ID=226919
A VIN doesn't get used up by the HEX-V2 when scanning a car unless you you do an optical bus diagnostic scan. The actions that use up a VIN are listed in the following post...
The following posts on here contain Auto-Scans that show the same ABS Brakes (J104) controller as your car (both posts are by the same owner). Might be worth PM'ing the owner and asking if he/she has TPMS enabled on their car. The car has a different long coding value for the J104 to what you have on your car...
NEtech
C?ID=56995
You can try if this coding in [03-ABS] is accepted:
42FF269F492143702077420964C592C20424D500508B4883
and change coding in [17-Instrument] to:
32CF01
Probably also activate marker at [4C] in Gateway list coding for [19-CAN Gateway]
For [5F-Information Electr.] I am very unsure if this is correct, to activate a menu, if that it is possible at all:
0100060002C051070023000102010000010000
somedude
Yuengling Country
C?ID=306296
Thank you very much, Gentlemen, for the info and the suggestions.
And apologies to NEtech, for my assumption of gender if I got it wrong. :)
I will try and report back.
D-Dub
US 2014 GTI Drivers Edition/DSG
C?ID=272151
Hello everybody,
You are talking about individual sensors in each wheel right? like @ https://www.amazon.com/Replacement-...System-TPMS-Sensors/b?ie=UTF8&node=2201764011
Before you get too far down this rabbit hole, you better confirm that your wheels actually have those sensors, because most likely if the factory did not enable that feature there is no way in heck they are going to spend the money to put sensors in the wheels that are not even going to be enabled.
No amount of vcds tweaks is going to enable tpms for sensors that are not there, nor enable functionality in the TPMS module that does not exist.
My 2014 gti loaded didn't even have actual tpms sensors, I just assume that all or most all modern VAG vehicles also use the ABS based tpms and do not include sensors or the module to use sensors.
It all comes down to cost savings, why would VAG spend the extra money when they have systems that work nearly as well for cheaper.
somedude
Yuengling Country
C?ID=306296
Thanks Bro, but I'm not that stupid. :)
Yes, my Pontiac had the Schrader valve sensors, but I know most recent cars have the ABS based indirect TMPS.
This is what I was hoping to enable here.
And when I was complaining about the cost I meant that for the price I paid, and with a very good chance that the hardware supports it, they could have enabled it from the factory. It is a safety feature after all.
somedude
Yuengling Country
C?ID=306296
32CF01
NEtech, Thank you VERY much for the codes!!!
Here is the scoop, I tried this with the beta version of VCDS.
After changing byte 18 for ABS from D0 to D5, I didn't see any change.
But after enabling TMPS, which was a labeled checkbox for byte 03 for Instrument, my TPMS icon briefly flashed on the speedometer!!!
I think that's a major step forward and I am very appreciative for the codes.
I think I will even deflate one tire to test it out and then fill it with air instead of argon, I am that optimistic about this!!!
The menu in 5F, which I assume was intended to enable the tire pressure reset in the MMI menu, didn't work.
I even tried a reset of MMI with the three buttons, to no avail.
I presume that TPMS can be reset with VCDS, in order to "learn" the current pressure, but it would be nice to enable the MMI menu.
I will continue to search the web, as I remember seeing something somewhere.
If I do, I will post details, especially if successful.
Thanks again, if I ever make it to Denmark, I will bring you a six-pack of some good Canadian brewskies.
D-Dub
C?ID=272151
OK gotcha.
I thought TPMS was mandatory everywhere, but maybe not in canada?
I really can't imagine that any 2017 vehicle would not include tpms, even if there is no 'interface' for it in your MMI.
Anyway, good luck in your search I hope you are able to enable it if it is indeed not already.
somedude
Yuengling Country
C?ID=306296
Thank you, D-Dub, I think I just managed to do it, see post above yours.
I was in the same boat - why wouldn't they enable it if the hardware supports it?!?!?
Now I just need to find a way to enable the reset menu in MMI.
I just found a post that says the green menu can't be enabled on the non-NAV radios, which is what I have.
I am still hopeful that it can be enabled through VCDS.
NEtech
C?ID=56995
Please when you (and a lot of other people) look in the forums, look carefully what is written about models, year, software etc.
Your link describes an Audi A3 (8V), it is not like your Audi Q3, it uses for example UDS protocol (Like what your [03-ABS] is using) in [5F].
Have you tried what I wrote ?
somedude
Yuengling Country
C?ID=306296
Hello NEtech,
Please have a look at my post #9 on the previous page. :)
I am very grateful to you for your help, but it seems to me you only read the last post and not my previous reply. So I can't be mad at you. :D
In short, yes, I know cars are different, but I am hanging on to every bit of information right now. Additionally, while I learn the lingo and how this works, everything that looks relevant is peaking my interest.
And yes, I tried what you said and it partially worked.
My beer offer still stands... :)
Thank you very much. Please see my reply on page 1, post #9
somedude
Yuengling Country
C?ID=306296
There was a post that just disappeared, with info on the non-MMI radio.
I don't have code 56- Radio on my car, probably the reason for the post being removed.
rlarsen
Copenhagen, Denmark
C?ID=78998
Yes, correct - it was nor relevant to you after all
rlarsen
Copenhagen, Denmark
C?ID=78998
Hello everybody,
Maybe you need the new label file Dana did in this thread - http://forums.ross-tech.com/showthread.php?9876-2017-Audi-Q7-Developer-Mode ??
NEtech
C?ID=56995
Sorry, saw only new replies on page 2.
Did you activate [4C] in [19] Gateway list coding ?
Can you please post an new Autoscan, after driving some days.
If the Byte 18 is correct for TMPS, then D5 should be for PR-code 7K6 and D7 should be for PR-code 7K1
42FF269F492143702077420964C592C20424D700508B4883
I suggested 7K6 because that has US model 2017, older model years (European) use 7K1.
You could try D7, if there is no indication of TMPS after driving some days.
Do you have some active adaption channels and measurement values, regarding TMPS ?
somedude
Yuengling Country
C?ID=306296
Sorry, I was so excited seeing the TPMS icon light up, I totally missed that step for module 19.
Would you mind providing details, I can't figure out what marker 4c means.
Total newbie here, when you say "indication of TPMS" after driving, does that mean driving with an underinflated tire?
And your final question, regarding adaptations, I have no idea what that means. I didn't make any other changes. I will try to read up on measurements, sounds like something in VCDS.
Thank you very much for taking the time to help me.
Once this is complete, I will summarize it in a new post with step by step, for the benefit of others.
