Channel numbers for dual ECU C6 S6
Greg5OH
C?ID=112138
Hello, would someone be able to provide me the channel number (I assume same number for both ECUs) for short and long term fuel trims. This is for a 2007 S6
Specifically need to monitor idle and full load trims on Bank 1 and 2, which are both on pass side, 3 and 4 being on driver side.
Have B1S1 lean and B2S1 rich codes pop up. All new lambda sensors, suspect bad injectors or air leak?
Bruce
Near Philadelphia, PA, USA
Have you looked in advanced measuring values? the PIDs are shown in a drop down list.
2007 should be pretty standard:
Long-term in MVB 032, Short-term in 033.
Greg5OH
C?ID=112138
Advanced measure values has always been greyed out for me, on every single dual ECU car (multiple S8 and S6s)
Bruce
on some older modules, that is the case. Uwe has given you the fuel trim block numbers you need.
