Enabling aux heater to heat engine and passenger compartment
markkuvuo
I'm trying to disable the shut off valve of the aux heater on my 2015 VW Sharan and 2009 VW Touareg in order to enable the aux heater to preheat the engine also with the passenger compartment. I have found that it may be done by changing the value of correct adaptation channel but I have hard time trying to find instructions for the correct procedure. Could you please specify what is the correct adaptation channel number that I need alter?
iichel
Netherlands, eastern part
C?ID=284912
maybe start with an autoscan to show us the equipment on both cars. see my signature for how to post an autoscan.
markkuvuo
Thank you for your reply, here you go.
Sharan:
Touareg:
markkuvuo
I'm sorry, I didn't know the software was not a legal copy, it belonged to my friend who helped me with this coding. Thank you for your help and sorry for the mistake.
markkuvuo
Hopefully this makes up my mistake, I bought a genuine HEX-V2 interface. The Sharan I got coded, it was an easy task. How ever when coding the Touareg, there is no coding helper in the VCDS so I don't know which byte and bit to alter. I try to code the aux heater without the N279 valve installed. Should this old thread with a bad start to be abandoned and should I post a new thread?
Here is the complete autoscan.
Saturday,10,March,2018,15:27:53:50709
VIN: WVGZZZ7LZ9D031775   License Plate: TREG2
Mileage: 118180km-73433mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 18 19 22 28 32 34 36 37 3C
          46 47 55 56 65 68 69 6D 6E 76 77
VIN: WVGZZZ7LZ9D031775   Mileage: 118180km-73433miles
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 N    HW: 7L0 907 401 H
   Component: 3.0TDI EDC17A104AG  0060
   Revision: 14H02---    Serial number: VWX3Z0H3832908
   Coding: 04210023591F0E68
   Shop #: WSC 29831 136 182583
   VCID: 3634D19EE45B1CE7984-5184
   Part No SW: 09D 927 750 JK    HW: 09D 927 750 JK
   Component: AL 750 6A           1469
   Revision: 00H75000    Serial number:
   Coding: 0004456
   Shop #: WSC 31414 790 00001
   VCID: 00587746F61F6257728-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0006530
   VCID: 46D4A15E94EB8C67084-8012
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: 2G Kessy            6850
   Revision: 00H22071    Serial number: VWX3Z0H3832908
   Coding: 0147688
   VCID: 2A0CF5EE20B348070CC-807E
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77AA1C9AA38125EF432-8022
   Part No: 7L6 907 044 AH
   Component: CLIMAtronic 2+2     4334
   Coding: 0001030
   VCID: 7AAC05AE909338873CC-802E
   Subsystem 1 - Part No: 7L6 907 049 F
   Component: CLIMAtronic FOND    0503
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2002
   Revision: -0004---    Serial number: --------------
   Coding: 600004003B321E000000000000000000
   VCID: 00587746F64F6257728-8054
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 7L6 907 567 B    HW: 7L6 907 567 B
   Component: AC201  RDW 1    031 0391
   Revision: 00031000    Serial number: 00000000033159
   Coding: 0010000
   VCID: 3D26CEB2C13DCFBF59E-8068
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3R VW8T       0250
   Revision: 92012025    Serial number: 0039P006WLPZ
   Coding: 0013138
   Part No: 7L6 953 549 G
   Component: J527                3601
   Coding: 0011222
   VCID: 43D2B84AA7D9B94F2FA-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 890 C    HW: 7L6 920 890 C
   Component: J285 KOMBI-INST.    9533
   Revision: KHH06V37
   Coding: 0007101
   Shop #: WSC 14344 002 1048576
   VCID: 3828DFA6EE5FEA978A8-806C
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Part No: 7L6 819 008 H
   Component: Standheizung E1MAC  0425
   Coding: 0000000
   VCID: 3B22C0AADF69C18F67A-806E
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 890 C
   Component: J533  GW-K-CAN TP20 9533
   Coding: FFEEFFBFCB056002
   VCID: 70B82786C6AF72D7828-8024
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 015E7242FD156B5F7D6-5184
Address 28: HVAC, Rear
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 D
   Component: SG-Quersperre       5023
   VCID: 392EDAA2D545F39F756-5184
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A2CC5AED043F8877CC-5160
   Component: Sitzverstellung     0703
   VCID: 77AA1C9AA3D125EF432-5160
Address 37: Navigation
   Part No SW: 7L6 907 566 B    HW: 7L6 907 566 A
   Component: J0769_SWA_MasterH10 0070
   Revision: 00H10000    Serial number: 6PZ 009 014-01
   Coding: 0010151
   VCID: 3C20C3B6DA27C6B76E0-8068
   Subsystem 1 - Part No: 7L6 907 568 B
   Component: J0770_SWA_Slave_H08 0070
   Subsystem 2 - Serial number: 6PZ 009 014-21
   Subsystem 3 - Serial number: 3F05.12.0800H0800000010466ÿ
   Subsystem 4 - Serial number: 010466ÿ
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   Shop #: WSC 29831 136 60816
   VCID: 40D8B746B69FA257328-4B00
   Subsystem 1 - Part No: 7L0 959 701 P
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 P
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
   Subsystem 5 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 7L6 035 466 C    HW: 7L6 035 466 C
   Component: DSP 10 Kanal        0020
   Revision: 00H05001    Serial number: 75835000549604
   VCID: 3430EB96F2370EF7A60-8060
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0136
   Coding: 1288323
   VCID: 3B22C0AADF29C18F67A-806E
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000019
   Coding: 00000019
   Part No SW: 7L6 035 680 C    HW: 7L6 035 680 B
   Component: RNS-MID       H04 5238
   Revision: AB001001    Serial number: VWZ6Z7J5007025
   Coding: 0E050002010000210000
   Shop #: WSC 29831 136 86498
   VCID: 323CED8E042300C7B4C-8066
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
03138 - Input AUX IN
                    Reset counter: 235
                    Mileage: 118181 km
                    Date: 2018.03.10
                    Time: 15:16:06
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Component: J0502 RDK           0006
   Revision: 00004006    Serial number: 00000900013771
   Coding: 264900566B688C000000000000
   VCID: 3A2CC5AED013F8877CC-806E
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392EDAA2D555F39F756-806C
   Component: RLS     081208 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D9.lbl
   Part No SW: 7L0 907 383 M    HW: 7L0 907 383 M
   Component: J345  Anhaenger     0050
   Revision: 4C006002    Serial number: 00000116069690
   Coding: 0016521
   VCID: 3E24C9BECC3BD4A7404-806A
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------042820
   Coding: 0122110
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AE    HW: 7L6 919 044 AE
   Component: J702  Dachdisplay   0401
   Revision: --30006S    Serial number: 00000000103540
   VCID: 7AAC05AE90D338873CC-802E
   Part No: 7L0 919 283 F
   Component: 0M Einparkhilfe     1108
   VCID: 392EDAA2D515F39F756-806C
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.31.6      H24 0225
   Shop #: WSC 21977 142 74100
   VCID: 3E24C9BECC7BD4A7404-806A
End----(Elapsed Time: 03:36, VBatt start/end: 11.9V/11.9V. VIgn 11.7V)-----
Verified, forum status adjusted, and released from the Hall of Shame. :thumbs:
I've never played with those fuel-fired heaters because they're not offered here, but I'm fairly confident that others on your side of the pond will chime in.
markkuvuo
Thanks to google translator I managed to figure out the coding that controls the N279 valve and succeeded. I found a German forum (http://www.touareg-freunde.de/showt...-zB-Unterspannungsabschaltung-Touareg-7L-2008) and I changed the suggested Adaptation channel 4 value from 1 to 0. This morning after 20 min use of Webasto the engine coolant temp was +30 celsius while the engine oil temp was -7 celsius, so the engine pre-heat function works now.
Dana
Western PA, USA
Thanks! The exact text may change in the future but I added this to our English file in CH 004:
Engine Preheating
Opening the N279 solenoid to allow the engine to preheat while the
Auxiliary Heater is on may be possible via this Adaptation channel.
0 = Factory Configuration (passenger compartment heated)
1 = Engine also heated
P.S. I have a sneaking suspicion this may also apply to #18 modules using lbls files such as 8R0-265-105.clb and 7H0-819-008.lbl .. but that's purely speculation based on Component data. I'm certainly no expert in this area - but wanted to toss that out there if someone else wants to experiment.
markkuvuo
You are welcome. Just to clarify, the value 1 was factory configuration (passenger compartment). 0 was the new value to heat also engine.
Channel 3 Factory configuration 0 (Heater unlock)
Channel 4 Factory configuration 1
Channel 5 Factory configuration 0
Channel 6 Factory configuration 0
Channel 7 Factory configuration 105
Channel 8 Factory configuration 0
Channel 9 Factory configuration 1
Channel 4 Engine preheating
1 = Factory Configuration (passenger compartment heated)
0 = Engine also heated
Channel 7 Aux heating switch-off voltage
value / 10 V = switch-off voltage
Default 105 = 10,5 V
Max number to be saved 120 = 12,0 V
Dana
Western PA, USA
Thanks for correcting my mix up!
NEtech
C?ID=56995
Has your coding for the aux heater maybe changed, after you changed channel 04 ?
