Audi Q7 Battery Replacement?
TreeCrusher
New Zealand
C?ID=178402
Hi Everyone,
I picked up an '07 Q7 a few months ago. Someone has done a poor job of installing face lift headlights and tail lights, so please disregard the light faults (this is on the list of things to resolve)
A couple of days ago the central locking stopped working. After looking at the scan, I am thinking it is a faulty/failed battery that is causing the issues. Looking at module 061 and blocks 1, 4 and 10, the voltage of the battery with the engine off is only 11.65V. With the engine on I get a good 14.3V at the alternator and 46A, so it looks to me that the alternator is working ok, but the battery is not holding a full charge.
The above indicates to me that a failed battery is causing systems to shut down and cause my central locking to stop working. Ergo, a new battery should fix the issue.
However, the car is doing a couple of other weird things, which don't seem to me to line up with the idea that systems are shutting down. When you turn the ignition off and remove the key, the MMI stays on, the tail lights stay on (if auto-lights are on), the power windows continue to operate and the steering lock does not activate, almost as if the car has not recognised the removal of the key from the ignition. Over the last couple of days we have had to manually turn everything on/off to make sure the battery isn't further drained. I'm worried that the battery might be a symptom of some other fault, rather than the cause. Some sort of fault with the ignition switch causing systems to stay on, draining the battery etc.
Any thoughts on whether I am wasting my money replacing the battery first? Do the symptoms described sound like issues related to a battery failing, or is the low battery voltage a symptom in and of itself? Any thoughts or insights would be greatly appreciated.
Thanks.
Saturday,20,April,2019,19:56:19:35988
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4L78D018907   License Plate: HYQ360
Mileage: 173950km-108087mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 37 42 46 47 4F 52
          55 56 61 62 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L78D018907   Mileage: 173950km-108087miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 R    HW: 4L0 907 401
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H04---    Serial number:
   Coding: 0011779
   Shop #: WSC 31414 790 00001
   VCID: 3169068CA8A5CEC262-8064
   Part No SW: 09D 927 750 FS    HW: 09D 927 750 FS
   Component: AL 750 6A           1000
   Revision: 00H64000    Serial number:
   Coding: 0000504
   VCID: 04079F5847978B6AF9-8050
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099473
   VCID: 2959EEEC8075B602AA-807C
                    Reset counter: 204
                    Mileage: 173701 km
                    Date: 2019.04.14
                    Time: 09:55:57
                    Count: 64
                    Count: 8261
                    Count: 128
                    Count: 39680
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500866926
   Coding: 0000147
   VCID: 63C5BCC4A2D92C52A0-8036
   Subsystem 1 - Part No: 4F0 910 131 A
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0040
00956 - Key 2
                    Fault Status: 00110010
                    Reset counter: 40
                    Mileage: 173011 km
                    Date: 2019.03.15
                    Time: 08:03:16
01176 - Key
                    Reset counter: 223
                    Mileage: 173943 km
                    Date: 2019.04.20
                    Time: 14:02:03
                    Reset counter: 200
                    Mileage: 173679 km
                    Date: 2019.04.13
                    Time: 08:14:56
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 L    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 387H2077556485
   Coding: 0002002
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000838279
   Subsystem 3 - Serial number: 0116.08.070000000100010294ÿ
   Subsystem 4 - Serial number: 010294ÿ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 E
   Revision: 00---012    Serial number: 00000000127582
   Coding: 0001110
   VCID: 61C9B6CCB8C53E42B2-8034
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0003121
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H10 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 183
                    Mileage: 167276 km
                    Date: 2018.09.16
                    Time: 11:37:00
                    Reset counter: 183
                    Mileage: 167276 km
                    Date: 2018.09.16
                    Time: 11:37:00
                    Reset counter: 183
                    Mileage: 173948 km
                    Date: 2019.04.20
                    Time: 18:47:00
                    Reset counter: 183
                    Mileage: 173948 km
                    Date: 2019.04.20
                    Time: 19:06:00
                    Fault Status: 00100111
                    Fault Frequency: 39
                    Reset counter: 223
                    Mileage: 173588 km
                    Date: 2019.04.07
                    Time: 15:27:00
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045006    Serial number: AUZ5ZBG1226503
   VCID: 1D31CA3CC43D5AA2D6-8048
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D03DRUL
   Coding: 0014128
   VCID: 2E531DF0B99BD13A7F-807A
   Subsystem 1 - Serial number: 6332QSME360C400FF
   Subsystem 2 - Serial number: 6342QSME360D072DK
   Subsystem 3 - Serial number: 6352QSME3850294DL
   Subsystem 4 - Serial number: 6362QSME36070F1FP
   Subsystem 5 - Serial number: 63734SME386D7A3BJ
   Subsystem 6 - Serial number: 63834SME36521637Z
   Revision: 00H02000    Serial number: 90026072020007
   Coding: 0102142
   VCID: 275DE8D496618072BC-8072
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 930 T
   Component: KOMBIINSTR. M73 H21 0240
   Revision: 00700000    Serial number: 73Y52XV87
   Coding: 3649758
   Shop #: WSC 00070 067 57207
   VCID: 2345FCC4E2596C52E0-8076
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 815 071 D
   Component: Heizgeraet      H08 0080
   Revision: 0000000C    Serial number: 00000009014264
   VCID: 60CFB3C8B3CF374ABD-8034
01412 - Glow-Plug with Flame Monitoring (Q8)
02251 - Heater Unit Locked
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B077268415
   Coding: F55BFE7770720200
   VCID: 2D511AFCB49DAA2246-8078
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 275DE8D456618072BC-8072
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H50 1050
   Revision: 00000000    Serial number: 399H 077585023
   Shop #: WSC 00070 824 83289
   VCID: 306F0388A3AFC7CA6D-8064
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 C    HW: 4L0 959 793 C
   Component: TSG FA          H21 0150
   Coding: 0000539
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0040
   Revision: 0040 ---    Serial number: 01060471200000
   Coding: 7602317
   Shop #: WSC 06111 109 68793
   VCID: 33650C8452B9FCD210-8066
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0250
   Revision: S0600000
   Coding: 030100
   VCID: 2959EEEC4075B602AA-807C
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00101011
                    Fault Frequency: 12
                    Reset counter: 223
                    Mileage: 168317 km
                    Date: 2018.11.05
                    Time: 09:18:55
                    Voltage: 11.70 V
                    Temperature: 18.0°C
                    Bin. Bits: 00000011
                    Reset counter: 223
                    Mileage: 172095 km
                    Date: 2019.02.10
                    Time: 10:03:02
                    Voltage: 11.90 V
                    Temperature: 32.0°C
                    Bin. Bits: 00000011
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000243224
   Coding: 0011001
   VCID: 5EB38D3089BB01BA8F-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 792 C    HW: 4L0 959 792 C
   Component: TSG BF          H21 0150
   Coding: 0000539
   VCID: 2F6D00F4BE91D83274-807A
   Coding: 0000021
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Part No: NOSUBSYSTEM
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 183
                    Mileage: 167272 km
                    Date: 2018.09.16
                    Time: 11:37:02
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Revision: 00000000    Serial number: 388H$077640682
00532 - Supply Voltage B+
                    Reset counter: 223
                    Mileage: 165837 km
                    Date: 2018.08.21
                    Time: 17:52:37
                    Fault Frequency: 229
                    Reset counter: 223
                    Mileage: 165837 km
                    Date: 2018.08.21
                    Time: 17:20:29
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000019134
   VCID: 2541E2DCEC6D92628E-8070
   Component: von VA0  0708091116
   Coding: 344630393135313035442056413030373038303931313136
            000 -  -  - Intermittent
                    Mileage: 167353 km
                    Date: 2018.09.20
                    Time: 17:23:36
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 795 C
   Component: TSG HL          H21 0150
   VCID: 326B0980ADA3F5DA1B-8066
02111 - Motor for Window Regulator
                    Fault Status: 01100101
                    Reset counter: 123
                    Mileage: 173369 km
                    Date: 2019.03.30
                    Time: 15:17:47
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000707130329
   Shop #: WSC 12336 024 394758
   VCID: 3663359041CBE9FA37-8062
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7740ZN
   Coding: 1021101
   VCID: 2447FFD8E7576B6A99-8070
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H24 0290
   Revision: --H24001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7D7F84F07632A11-8038
   Subsystem 3 - Serial number: RD18.08.07--H24001001B0135ÿ
   Subsystem 4 - Serial number: 1B0135ÿ
   Revision: AAH05061    Serial number: 003019119-----
   Coding: 0003591
   VCID: 2643E5D0916B997A87-8072
   Component: J_245_EE16_SKB09H10 0200
   Component: J_394_EE16_SKB09H10 0200
   Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 C    HW: 4L0 959 794 C
   Component: TSG HR          H21 0150
                    Fault Frequency: 99
                    Reset counter: 183
                    Mileage: 171223 km
                    Date: 2019.01.23
                    Time: 06:18:38
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06320721501491
   Coding: 0221046
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005006264
   Coding: 0010900
   VCID: 2A5B11E08573BD1AA3-807E
End-------------------------(Elapsed Time: 03:07)--------------------------
DrPeter
16.4905° S, 151.7375° W
- You may not be wasting your money (or time), especially if the battery was already replaced once before and they did NOT adapt the replacement battery to the vehicle, now the system thinks there is a 12 year old battery in there. And if the battery is about 12 years old and is an AGM, it maybe time for a new one.
It is not necessary to use a Audi Battery, you can use an exact replacement size/ratings battery and when you adapt the new battery, just keep the values the same except change the battery serial number by a digit, that way the battery management system know there is a new battery which is of the same ratings.
Battery Replacement
Hope this helps,
drpeter
How quickly does the battery voltage drop after you shut down the ignition?
If you've driven the car for a while, meaning the battery is presumably well-charged, and it drops below 12.0V quickly, either the battery is shot, or there's excessive resistance in the leads to it.
Have you checked the condition of the battery terminals? Have you tried charging the battery using a separate charger and then monitoring its voltage afterward without applying any load to it?
TreeCrusher
New Zealand
C?ID=178402
Battery Replacement
Hope this helps,
drpeter
Thanks for the quick response guys. Out of interest, how can you see the battery is 12 years old? That doesn't surprise me as it has a genuine battery in it and there is no way the guy I bought it off would have installed a genuine battery. When I l saw the battery was genuine it made me think it must be pretty old.
Yes, have checked the terminals etc. and everything looks tight and clean. It basically drops below 12v straight away, although we don't really drive it that far. I will go for a drive now for a good half hour and check the voltage then. Your suggestion to charge the battery externally was on my list, but I don't own a battery charger, so was tossing up about buying a charger versus just going straight to the new battery.
I'll check the voltage after a drive this morning and if it quickly drops below 12v I'll replace the battery. I'll post back with what I find.
Cheers,
We cannot. But based on what you posted there, it looks like the car thinks it's the original one.
You could go to [Applications] -> [History Data], select module 61, and click [Start]. When VCDS finishes (not long), click [Save] and post the data here.
Given how hard modern cars are on a battery, and how important the battery is, you should. Everyone should.
TreeCrusher
New Zealand
C?ID=178402
I went for a longer drive this morning and the voltage dropped pretty quickly after turning the car off so I replaced the battery. The new battery is definitely stronger, with the voltage holding above 12v for longer after shut down, but unfortunately the battery was not to source of the issues.
Below lists some of the symptoms/observations:
-When I insert/remove the key from the ignition there is no change in state of the vehicle. The steering lock doesn't engage/disengage the MMI stays on, lights stay on etc.
-Central locking does not work from the remote
-If you wait for the cabin light to turn off, pushing the unlock button on one of the keys causes the cabin light to turn back on (indicating the keys are actually communicating with the car)
-If I undertake the tests in module 05, I can get the key ignition lock to click on and off, but I cannot get the steering lock to actuate.
-With the new battery the battery voltage is 12.05v in module 061 (after working on it for a while with the engine off), but the supply voltage to the ignition in module 05 is only 11.6v. Could this be an issue with the ignition, or perhaps an earthing issue, or is this normal?
-in the advanced block measuring in module 05 it states the locking voltage to the steering lock as being 0.28v, but then states the minimum locking voltage as being 7.2v.
It seems to me that the car is not sensing the keys being inserted/removed, although I am lost as to the reason for this. Also, the fact I cannot get the steering lock to activate using the output test in module 05, seems to indicate some potential issue there.
Below is a couple of screen shots, an updated log after the battery replacement and the history data log. Again, I appreciate any thoughts or hints on what could be going on.
Cheers.
Tuesday,23,April,2019,21:06:25:35988
Mileage: 174130km-108199mi   Repair Order:
VIN: WAUZZZ4L78D018907   Mileage: 174130km-108199miles
   Coding: 0011779
   Coding: 0000504
   Revision: 00H30001
   Coding: 0099473
   Coding: 0000147
01176 - Key
                    Reset counter: 231
                    Mileage: 174058 km
                    Date: 2019.04.23
                    Time: 16:01:42
   Coding: 0002002
   Coding: 0001110
   Coding: 0003121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 191
                    Mileage: 174056 km
                    Date: 2019.04.23
                    Time: 15:54:00
                    Reset counter: 191
                    Mileage: 174056 km
                    Date: 2019.04.23
                    Time: 15:54:00
                    Reset counter: 191
                    Mileage: 174056 km
                    Date: 2019.04.23
                    Time: 15:56:00
                    Reset counter: 231
                    Mileage: 174060 km
                    Date: 2019.04.23
                    Time: 17:24:00
                    Reset counter: 191
                    Mileage: 174132 km
                    Date: 2019.04.23
                    Time: 20:50:00
   Coding: 0014128
   Coding: 0102142
   Coding: 3649758
   Revision: 00000000
   Coding: 0000539
   Coding: 7602317
   Revision: S0600000
   Coding: 030100
   Coding: 0011001
   Coding: 0000539
   Coding: 0000021
                    Reset counter: 191
                    Mileage: 174056 km
                    Date: 2019.04.23
                    Time: 15:54:57
   Component: von VA0  0708091120
   Coding: 344630393135313035442056413030373038303931313230
   Coding: 1021101
   Coding: 0003591
                    Reset counter: 190
                    Mileage: 174060 km
                    Date: 2019.04.23
                    Time: 16:16:28
   Coding: 0221046
   Coding: 0010900
End-------------------------(Elapsed Time: 03:04)--------------------------
Control Module Part Number: 4L0 910 181 A
  Component and/or Version: J0644 BEM       H12 0690
           Software Coding:
            Work Shop Code: WSC 06111
                      VCID: 2541E2DCEC6D92628E-FFFE
           Additional Info: 4F0915105D  von VA0  0708091120
           Additional Info: Geraet 68793
History Data
Record 1/18: No-load voltage underranging
2000-01-01,00:00:00*0000*000**
2000-01-01,00:00:00*0000*000*00000***
Record 2/18: No-load current overranging
2000-01-01,00:00:00*0000*00.00*000**
2000-01-01,00:00:00*0000*00.00*000*00000***
Record 3/18: Energy-critical vehicle states
00.00*00.00*+00.00*00*00*+0000*+00000*000000*2000-01-01,00:00:00*0-0-0-0-0-0*00.0*00.0*000.0*00*00*00*000**
Record 4/18: Shut-off stage history
1*2*-14.61*33*2019-04-21,09:54:54*0-0-0-0-0-0*00.0**
2*0*-05.65*36*2018-09-20,17:30:03*0-0-0-0-0-0*00.0**
1*0*-05.43*36*2018-09-20,17:23:36*0-0-0-0-0-0*00.0**
2*5*-00.03*09*2018-09-08,10:28:39*0-0-0-0-0-0*00.0**
1*5*-05.09*09*2018-09-08,09:26:50*0-0-0-0-0-0*00.0**
6*7*+04.42*00*2018-09-08,08:35:38*0-0-0-0-0-0*01.1**
3*7*-07.19*00*2018-09-08,08:36:07*0-0-0-0-0-0*01.1**
5*7*-10.96*00*2018-09-08,08:36:06*0-0-0-0-0-0*01.1**
1*2*-06.91*34*2018-09-08,08:32:44*0-0-0-0-0-0*01.1**
1*2*-06.97*37*2018-09-08,08:29:13*0-0-0-0-0-0*01.0**
1*2*-08.48*37*2018-09-08,08:27:11*0-0-0-0-0-0*01.0**
1*2*-73.57*39*2018-09-08,08:24:01*0-0-0-0-0-0*01.0**
2*2*-04.95*40*2018-09-08,08:21:18*0-0-0-0-0-0*01.0**
1*2*-08.79*40*2018-09-08,08:19:38*0-0-0-0-0-0*01.0**
Record 5/18: Battery change history
001*0708091116*2019-04-23,00:00:00*+00006*-9999**
000*0708091116*2000-01-01,00:00:00*+00000*+0000**
000*----------*2000-01-01,00:00:00*+00000*+0000**
Record 6/18: Energy balances (last 5 trips)
+000.3*000.0**
+000.3*000.0**
+000.3*000.0**
+002.7*000.7**
+004.0*000.9**
Record 7/18: Energy balances (last 5 standing times)
-002.4*001.4**
-000.3*000.0**
-000.2*000.0**
-000.2*000.0**
-000.3*000.0**
Record 8/18: Battery manipulation (e.g. charging)
+008.1*002**
Record 9/18: Battery aging
0000.0*0000.0
Record 10/18: Dynamic energy management
00.0*00.0
Record 11/18: Recuperation
0000.00*0000.00*0000.00*0000.00
Record 12/18: Start-Stop
00.00*00.00*00.00*00.00
Record 13/18: Sporadic alternator faults
0000.0*0000.0
Record 14/18: Small battery for hybrid vehicle
00.0*00.0
Record 15/18: Local activ.
00*99*03*00*00
Record 16/18: Vehicle energy balance
00*00*01*00*00
Record 18/18: Date reprogramming in instrument cluster
15**
2011-12-14,09:00:00*2000-01-01,12:00:00**
2008-12-17,17:00:00*2008-12-17,20:00:00**
2007-11-05,14:00:00*2007-12-06,14:00:00**
2007-07-21,05:00:00*2007-10-08,12:00:00**
2000-01-01,12:00:00*2007-05-16,12:00:00**
Mika_M
C?ID=183725
I had these exact symptoms in my A3 8V. Reason was, ignition lock was somehow physically stuck in such a way that it did not register key being taken out. Car thinks the key is still inserted and leaves MMI on and won't let you lock the doors with remote.
I had the entire ignition lock replaced (under warranty, luckily) and no problems after that. Maybe you are experiencing the same issue? Try to wiggle the key while pulling it out to see if that helps? In my case, it did. Also, when I took out the key and MMI stayed on, I could often turn it off by hitting ignition lock firmly with my fist. :D
EDIT: If there is a measuring value for this key in/out detection, maybe that would tell something. But I do not know if such thing exists in your car or not.
Wouldn't hurt to install a solar charger to maintain the thing when it sits either.
Change the battery anyway.........
TreeCrusher
New Zealand
C?ID=178402
Mike, you nailed it, thank you. If I get really aggressive with the key I can make it sense the key removal and then all works normally. There is obviously something mechanical in the ignition switch that is faulty. I’ll replace and report back.
TreeCrusher
New Zealand
C?ID=178402
Hi again everyone,
I purchased a replacement ignition and installed it and it problems are fixed.
A few points for anyone undertaking this repair:
-The ignition is a simple plug and play replacement
-No coding required
-The ignition is not specific to the key, so can just replace and not worry about keys etc.
-An ignition from a C6 A6 also works (That's where I got my replacement from)
Below is a picture of my ignition module with the part number shown.
Thanks to everyone for their time and help.
