- Sep 11, 2018
- 11
- 11
- New Zealand
- C?ID=178402
Hi Everyone,
I picked up an '07 Q7 a few months ago. Someone has done a poor job of installing face lift headlights and tail lights, so please disregard the light faults (this is on the list of things to resolve)
A couple of days ago the central locking stopped working. After looking at the scan, I am thinking it is a faulty/failed battery that is causing the issues. Looking at module 061 and blocks 1, 4 and 10, the voltage of the battery with the engine off is only 11.65V. With the engine on I get a good 14.3V at the alternator and 46A, so it looks to me that the alternator is working ok, but the battery is not holding a full charge.
The above indicates to me that a failed battery is causing systems to shut down and cause my central locking to stop working. Ergo, a new battery should fix the issue.
However, the car is doing a couple of other weird things, which don't seem to me to line up with the idea that systems are shutting down. When you turn the ignition off and remove the key, the MMI stays on, the tail lights stay on (if auto-lights are on), the power windows continue to operate and the steering lock does not activate, almost as if the car has not recognised the removal of the key from the ignition. Over the last couple of days we have had to manually turn everything on/off to make sure the battery isn't further drained. I'm worried that the battery might be a symptom of some other fault, rather than the cause. Some sort of fault with the ignition switch causing systems to stay on, draining the battery etc.
Any thoughts on whether I am wasting my money replacing the battery first? Do the symptoms described sound like issues related to a battery failing, or is the low battery voltage a symptom in and of itself? Any thoughts or insights would be greatly appreciated.
Thanks.
Thanks.
Saturday,20,April,2019,19:56:19:35988
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4L78D018907 License Plate: HYQ360
Mileage: 173950km-108087mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 37 42 46 47 4F 52
55 56 61 62 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L78D018907 Mileage: 173950km-108087miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 R HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0020
Revision: --H04--- Serial number:
Coding: 0011779
Shop #: WSC 31414 790 00001
VCID: 3169068CA8A5CEC262-8064
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 04079F5847978B6AF9-8050
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0099473
VCID: 2959EEEC8075B602AA-807C
Reset counter: 204
Mileage: 173701 km
Date: 2019.04.14
Time: 09:55:57
Count: 64
Count: 8261
Count: 128
Count: 39680
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500866926
Coding: 0000147
VCID: 63C5BCC4A2D92C52A0-8036
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
00956 - Key 2
Fault Status: 00110010
Reset counter: 40
Mileage: 173011 km
Date: 2019.03.15
Time: 08:03:16
01176 - Key
Fault Frequency: 8
Reset counter: 223
Mileage: 173943 km
Date: 2019.04.20
Time: 14:02:03
Reset counter: 200
Mileage: 173679 km
Date: 2019.04.13
Time: 08:14:56
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 L HW: 4E0 035 729 A
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 387H2077556485
Coding: 0002002
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000838279
Subsystem 3 - Serial number: 0116.08.070000000100010294ÿ
Subsystem 4 - Serial number: 010294ÿ
Part No SW: 4L0 910 043 HW: 4L0 820 043 E
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000127582
Coding: 0001110
VCID: 61C9B6CCB8C53E42B2-8034
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0003121
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H10 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Fault Status: 01101011
Reset counter: 183
Mileage: 167276 km
Date: 2018.09.16
Time: 11:37:00
Reset counter: 183
Mileage: 167276 km
Date: 2018.09.16
Time: 11:37:00
01494 - Bulb for Parking Lamps; Left (M1)
Reset counter: 183
Mileage: 173948 km
Date: 2019.04.20
Time: 18:47:00
01498 - Bulb for Parking Lamps; Right (M3)
Reset counter: 183
Mileage: 173948 km
Date: 2019.04.20
Time: 19:06:00
Fault Status: 00100111
Fault Frequency: 39
Reset counter: 223
Mileage: 173588 km
Date: 2019.04.07
Time: 15:27:00
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H45 0350
Revision: 00045006 Serial number: AUZ5ZBG1226503
VCID: 1D31CA3CC43D5AA2D6-8048
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 70 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D03DRUL
Coding: 0014128
VCID: 2E531DF0B99BD13A7F-807A
Subsystem 1 - Serial number: 6332QSME360C400FF
Subsystem 2 - Serial number: 6342QSME360D072DK
Subsystem 3 - Serial number: 6352QSME3850294DL
Subsystem 4 - Serial number: 6362QSME36070F1FP
Subsystem 5 - Serial number: 63734SME386D7A3BJ
Subsystem 6 - Serial number: 63834SME36521637Z
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90026072020007
Coding: 0102142
VCID: 275DE8D496618072BC-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 930 T
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 73Y52XV87
Coding: 3649758
Shop #: WSC 00070 067 57207
VCID: 2345FCC4E2596C52E0-8076
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
Coding: 0000001
VCID: 60CFB3C8B3CF374ABD-8034
01412 - Glow-Plug with Flame Monitoring (Q8)
008 - Implausible Signal
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B077268415
Coding: F55BFE7770720200
VCID: 2D511AFCB49DAA2246-8078
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 275DE8D456618072BC-8072
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H50 1050
Revision: 00000000 Serial number: 399H 077585023
Shop #: WSC 00070 824 83289
VCID: 306F0388A3AFC7CA6D-8064
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 C HW: 4L0 959 793 C
Component: TSG FA H21 0150
Coding: 0000539
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0040
Revision: 0040 --- Serial number: 01060471200000
Coding: 7602317
Shop #: WSC 06111 109 68793
VCID: 33650C8452B9FCD210-8066
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4L0 910 223 H HW: 4L0 035 223 C
Component: DSP-AU716-RD H07 0250
Revision: S0600000
Coding: 030100
VCID: 2959EEEC4075B602AA-807C
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Fault Status: 00101011
Fault Frequency: 12
Reset counter: 223
Mileage: 168317 km
Date: 2018.11.05
Time: 09:18:55
Voltage: 11.70 V
Temperature: 18.0°C
Bin. Bits: 00000011
Reset counter: 223
Mileage: 172095 km
Date: 2019.02.10
Time: 10:03:02
Voltage: 11.90 V
Temperature: 32.0°C
Bin. Bits: 00000011
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000243224
Coding: 0011001
VCID: 5EB38D3089BB01BA8F-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 792 C HW: 4L0 959 792 C
Component: TSG BF H21 0150
Coding: 0000539
VCID: 2F6D00F4BE91D83274-807A
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000021
Subsystem 1 - Part No: NOSUBSYSTEM
Component: AFS-Modul links
Subsystem 2 - Part No: NOSUBSYSTEM
Component: AFS-Modul rechts
02071 - Local Databus
Fault Status: 11100100
Reset counter: 183
Mileage: 167272 km
Date: 2018.09.16
Time: 11:37:02
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388H$077640682
Coding: 0000001
00532 - Supply Voltage B+
Reset counter: 223
Mileage: 165837 km
Date: 2018.08.21
Time: 17:52:37
Fault Frequency: 229
Reset counter: 223
Mileage: 165837 km
Date: 2018.08.21
Time: 17:20:29
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000019134
VCID: 2541E2DCEC6D92628E-8070
Component: von VA0 0708091116
Coding: 344630393135313035442056413030373038303931313136
Mileage: 167353 km
Date: 2018.09.20
Time: 17:23:36
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 C HW: 4L0 959 795 C
Component: TSG HL H21 0150
VCID: 326B0980ADA3F5DA1B-8066
02111 - Motor for Window Regulator
Fault Status: 01100101
Reset counter: 123
Mileage: 173369 km
Date: 2019.03.30
Time: 15:17:47
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000707130329
Shop #: WSC 12336 024 394758
VCID: 3663359041CBE9FA37-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7740ZN
Coding: 1021101
VCID: 2447FFD8E7576B6A99-8070
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H24 0290
Revision: --H24001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7D7F84F07632A11-8038
Subsystem 3 - Serial number: RD18.08.07--H24001001B0135ÿ
Subsystem 4 - Serial number: 1B0135ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003019119-----
Coding: 0003591
VCID: 2643E5D0916B997A87-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE16_SKB09H10 0200
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE16_SKB09H10 0200
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 C HW: 4L0 959 794 C
Component: TSG HR H21 0150
Fault Status: 01101000
Fault Frequency: 99
Reset counter: 183
Mileage: 171223 km
Date: 2019.01.23
Time: 06:18:38
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06320721501491
Coding: 0221046
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005006264
Coding: 0010900
VCID: 2A5B11E08573BD1AA3-807E
End-------------------------(Elapsed Time: 03:07)--------------------------
