Running Very bad... Possible Injector???
Jonesy
Ireland
C?ID=236509
Hi guys I have a 2016 Octavia running very poor. lots of white smoke.
Looks and sounds very similar to a bad injector......
When I go into VCDS [01Engine] [Measuring Blocks] is shaded out? Am I doing something wrong or is there another way of viewing injection quantity?
Full autoscan below
Sunday,06,October,2019,15:20:05:13475
Dealer/Shop Name: Jonesy
VIN: TMBBG7NE1G0111121   License Plate: OCTAVIA
Mileage: 179008km-111230mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE1G0111121   Mileage: 179008km-111230miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2506
   Revision: 22004001
   Coding: 01114012430519090000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79AFED00095A18FF8E9-802C
16408 - Actuator Module for Turbocharger 1
          P00AF 00 [167] - Stuck
                    Mileage: 179008 km
                    Date: 2019.10.04
                    Time: 15:17:43
                    Engine speed: 1610.00 /min
                    Normed load value: 99.2 %
                    Vehicle speed: 43 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.164 V
                    Turbine actuator 1 bank 1: posit.feedback - Spec.value: 97.21 %
                    Turbine actuator 1 bank 1: posit.feedback - Act.value: 60.46 %
                    Turbine actuator 1 bank 1: posit.feedback - Offset closed: -0.30 %
                    Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt: 2.145 V
                    Accelerator pedal travel: raw value: 65.68 %
Readiness: N/A
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 52705000000661
   Coding: 1A078A911421096D0078060241C4245851289000608224F200430070C002
   Shop #: WSC 73430 031 00063
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 4BC367C813465A6F6C5-801E
   Part No SW: 5E0 820 047 M    HW: 5E0 820 047 M
   Component: AC Manuell    H05 1202
   Revision: 00001K07
   Coding: 01110104000100001000000000400000
   ASAM Dataset: EV_ACManueBHBVW37X 003129
   VCID: 2C010454B6887D5745F-8078
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 24
                    Mileage: 179003 km
                    Date: 2019.10.03
                    Time: 15:51:04
                    Outside air temperature: 14.0 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 22.7 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061527300310
   Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 074B9BF84FAE7E0F88D-8052
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150822  041 0570
   Serial number:         150913035736
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY152170D5F
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000033605408
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPLDBYRG
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F7BB3D827DE264F40D-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 210 15
   Serial number: 3576U0000007178DE61M
   Subsystem 2 - Part No SW: -----------    HW: 454 002 909 15
   Serial number: 3586U000000E5398761J
   Subsystem 3 - Part No SW: -----------    HW: 454 802 709 15
   Serial number: 3516RD2998508000000A
   Subsystem 4 - Part No SW: -----------    HW: 454 802 709 15
   Serial number: 3526R87218108000000Z
   Subsystem 5 - Part No SW: -----------    HW: 454 801 208 15
   Serial number: 3556V2DE30C08000000G
   Part No SW: 5Q0 953 521 L    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151010500634
   Coding: 0600
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3B23370843E6EAEFDC5-806E
   Part No SW: 5E0 920 921 B    HW: 5E0 920 921 B
   Component: KOMBI         123 6420
   Coding: 272402002100A600010808001000000000000000
   VCID: 2313EF68DB56B22FF45-8076
   Part No SW: 5Q0 907 530 AD    HW: 5Q0 907 530 D
   Component: GW MQB Low    126 1223
   Revision: --------    Serial number: 0004039439
   Coding: 030000040F087300EB000048080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 73B3DF282B3662AFC45-8026
   Subsystem 2 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001510100558
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 0000170391512
   Coding: 001000208001040100001100
   VCID: 45D751F03522AC1FBA1-8010
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 0103
   VCID: 44D14CF43E189517ADF-8010
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 0000169901283
   Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
   Component: MU-S-D-ER     H24 0245
   Serial number: SKZAZ2R8850053
   Coding: 03730100FF00000011111201008800002F0200C60120010000
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 2D0709508D92745F521-8078
   Subsystem 1 - Part No SW: 5E0 919 605 H    HW: 5E0 919 605 H
   Component: ABT_Std-2  H41 1028
   Serial number: SKZ8Z9RBS00WNZ
End----------(Elapsed Time: 01:17, VBatt start/end: 13.0V/13.1V)-----------
Jonesy
Ireland
C?ID=236509
👍 thanks for the response
Color me confused. The ECU has a fault code telling you that the turbo actuator is stuck. Why do you think the your problem is due to injector(s)?
Why no misfire codes?
Compression check & leak down?
Fuel PSI leak down?
Has exhaust manifold ports been measured for temp comparison to quickly isolate a dead cold zyl?
Is the turbo stuck on or off and is ECU modified with FOD?
Fuel quality?
JPPSG.....
Jonesy
Ireland
C?ID=236509
Thanks Uwe,
When idling it's extremely rough... Puffing out white smoke. I just want to see injection quantity and rule injector(s) in or out. The Injectors can be done under warranty here if they have failed. 👍
Jonesy
Ireland
C?ID=236509
Fuel PSI leak down?
Fuel quality?
JPPSG.....
Thanks Jack,
I've seen the mechanical side of these injectors fail before and not throw up misfire codes.
Il run the few checks you suggest later and report back.👍
Fuel quality is good.
I did see the shear off bolts holding the ECU in place had been out before so that might suggest some kind of tampering.....
You do realize that injection quantity cannot really be measured; it is calculated based on their on times and the fuel pressure.
Your ECU has:
IDE00472 -- Mean injection quantity
It also has a plethora of other injection related data in the Advanced Measuring values, but I'm not sure exactly what you want to look at. Type "Inject" into the search/filter box take a look at what's available.
Supreme beings love mechanical tests that qualify any Quantum orbit............. :rolleyes:
krason
Slovakia
C?ID=284503
check hose to vacuum i had a same problem
Jonesy
Ireland
C?ID=236509
Boost issue is sorted, the actuator was stuck.
Car now runs rough and smokey when cold but once it's running 3 or 4 mins it runs fine.
Cylinder 1 seems to be operating 20°c lower than the other 3 cylinders.
I'm gonna have injectors checked & Tested and see what that shows.
Jonesy
Ireland
C?ID=236509
Had all 4 injectors checked Ultra Sonic cleaned and flushed out, Diesel shop gave me a bottle of (VW recommended) fuel additive and tells me my problem will be gone after a bit of driving with the additive. 👍
So injectors being mechanically plugged or stuck open & leaking and no misfire codes, who would of thought that even possible?
Magical chemicals to rescue the FOD?
Does your region use ethanol base or blended fuels too?
:p
Since he has a diesel engine, I rather doubt there is ethanol in the fuel he's using. ;)
Huh......But what about bio-diesel?
https://en.wikipedia.org/wiki/Biofuel_in_the_United_States
In e-diesel blends, standard diesel fuel (such as US No. 2) is typically blended with up to 15% (by volume) of ethanol using an additive package that helps maintain blend stability and other properties—most importantly cetane number and lubricity. The additive package may comprise from 0.2% to 5.0% of the blend.
https://www.agriland.ie/farming-news/wartime-measures-needed-to-ignite-biofuel-industry-in-ireland/
Jonesy
Ireland
C?ID=236509
I've done nothing different but had injectors cleaned and ran about half a tank of fuel with the additive and the car is now running 100%
Thanks again to anyone that offered help 👍
pinaki1234
Canada
C?ID=359430
Thanks again to anyone that offered help ��
Just curious - which additive is it? I am using a TDI in India where the diesel quality is poor and is always under the terror of an injector issue. Thanks in advance.
Jonesy
Ireland
C?ID=236509
G 001790M3
That's the part number. Put it into Google and it will show u the additive.
€15 for a bottle in VW dealer here in Ireland 👍
