Audi tt Satnav enable
Radiosolutions
C?ID=178437
16 reg. Car is fitted with CD player with satnav,but the satnav is not enabled. How do I go about enabling the sat nav, with vcds if this is possible.
Radiosolutions
C?ID=178437
here is scan attached. been looking into this and been told unit in glovebox is fitted with satnav on this vehicle. just needs to be activated.
Wednesday,04,December,2019,09:01:58:42542
VCDS Version: 19.6.2.0
VIN: TRUZZZFV7G1030000   License Plate: BT16XJG
Mileage: 27419km-17037mi   Repair Order: harveys
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: TRUZZZFV7G1030000   Mileage: 27419km-17037miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1900322404010B3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208S0906264 001003
   ROD: EV_ECM18TFS0208S0906264.rod
   VCID: 76E3377DC96113FF8D-8022
15170 - Engine Oil Temp. Sensor (G8)
          P0198 00 [032] - Signal too High
15171 - Engine Oil Temp. Sensor (G8)
          P0196 00 [032] - Implausible Signal
15072 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
Readiness: 0010 0001
   Part No SW: 8S0 907 379 D    HW: 8S0 907 379 D
   Component: ESC           H42 0522
   Revision: 00000000    Serial number: 60676000000370
   Coding: 11AA108D1A9C15A940910064C291830640880858A8020043C16002
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 428B9BADD529FF5FF1-8016
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0398911045
   Coding: 000F0F1620
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   VCID: 3979FC41B8FFBC87A0-806C
   Part No SW: 8S0 820 047     HW: 8S0 820 047
   Component: AC Manuell el H05 0030
   Revision: 20009000    Serial number: 16010000009000
   Coding: 410040000011100000
   ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
   ROD: EV_AirCondiMAPrehAU33x.rod
   VCID: 70EF0165AB053DCF57-8024
   Operating and display unit 2 for air conditioning:
   Subsystem 1 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
   Component: E775 BuA_2  H06 0010
   Serial number: 00000000000000006056
   Operating and display unit 3 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
   Component: E776 BuA_3  H06 0010
   Operating and display unit 4 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
   Component: E777 BuA_4  H06 0010
262914 - Refrigerant Pressure
          B10AB F0 [008] - Too Low
                    Fault Frequency: 20
                    Reset counter: 192
                    Mileage: 25035 km
                    Date: 2019.10.23
                    Time: 04:32:36
                    Outside air temperature: 4.5 °C
                    Engine speed: 1533.00 /min
                    Compressor current: actual value: 0.00 A
                    Temperature after evaporator: 6.8 °C
                    Refrigerant pressure: 1.8 bar
                    System run time-Engine running time: 1 s
                    System run time-Terminal 15 on: 2 s
   Serial number: 01061607901866
   Coding: 07054C42C201067D03044004B31807A80880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04075DB58FBD316F83-8050
   Subsystem 1 - Part No SW: 8S2 955 119 B    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 43x RL 151217  038 0371
   Serial number: 00000001512140304805
   Coding: 1BC7F7
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50047158
   Coding: 00005D
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 06 01 2016  00000551
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1120001SN
   Serial number: 00000000000065418027
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291607400086
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3C77E555B7CD89AFBB-8068
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R01AVU2
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4D91B8911C7730271C-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 002 903 16
   Serial number: 35700000000272817A1A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 903 16
   Serial number: 35800000000662817A1E
   Subsystem 3 - Part No SW: -----------    HW: 480 010 402 16
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A05D2D12333E92
   Subsystem 4 - Part No SW: -----------    HW: 480 401 411 16
   Serial number: 3550002C122E8E13A220
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 111 15
   Serial number: 3560002B91D3F98222AF
   Pedestrian Protection Center:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 002 16
   Serial number: 2300002AF1F93A3102E4
   Subsystem 7 - Part No SW: -----------    HW: 480 002 405 17
   Serial number: I0M0000000014371242L
   Subsystem 8 - Part No SW: -----------    HW: 480 002 405 17
   Serial number: I0N000000000F2E8A42A
   Part No SW: 8S0 907 129 AF    HW: 8S0 907 129 AF
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335PCN00754
   Coding: 0008
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 7EF32F5DE1515BBFD5-802A
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8S0 920 790 A    HW: 8S0 920 790 A
   Component: FBenRDW       H35 0265
   Coding: 24050110298006000120A8809000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 377DFA798EEBAAF756-8062
   Part No SW: 8S0 907 468 C    HW: 8S0 907 468
   Component: GW MQB TT3    012 0246
   Revision: --------    Serial number: 22031610802300
   Coding: 030100042F025A004B000268080000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011003
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 408F91A5DB25ED4FE7-8014
   Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
   Component: J453 MFL  H07 0002
   Serial number: 20160317062959 00824
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 4265879103
   Serial number: 16000046403005
   Coding: 0100000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E90461A00F34C758-8024
   Serial number: 100216EB905902
   Coding: 001042224001040100001402
   VCID: 43859EA9CA33F657FA-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   Serial number: 060216EB404786
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03DE00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 3663F77D89E153FF4D-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 020 F    HW: 8S0 035 020
   Component: MU-H-ND-EU    043 0413
   Serial number: A580C0GB004262
   Coding: 013304013C00000011111101000A00002F0000E3007000001A
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 2B55D60942A31E1722-807E
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Component: ControlUnit_H  H22 0136
   Serial number: APVAK118011600010015
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
   Part No SW: 8S0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 160224200023
End-------------------------(Elapsed Time: 04:31)--------------------------
TBAx
C?ID=287144
What makes you assume the car has a satnav installed?
Radiosolutions
C?ID=178437
audi dealer says its possible, and also companys out there they they can do it by just sending them the unit out of glovebox. dealer says all audi tt new cars are equipped with the satnav.just needs activating.
PetrolDave
Westbury, UK
C?ID=1423
In most cases this would be a SWaP function which either requires a FEC code or a firmware hack...
DGMotors
C?ID=57532
As petroldave said SWaP
You need ODIS and online connection.
I priced one a little while ago it was about £2000 for the activation! :cry:
Google Maps/Nav on your phone is free. :cool:
PetrolDave
Westbury, UK
C?ID=1423
OP - do you have either Android Auto or Apple CarPlay enabled?
I recently had a Toyota Corolla rental car, the Toyota map app wasn't enabled but Apple CarPlay was so I just used Apple Maps :thumbs:
DGMotors
C?ID=57532
The crazy thing is the Audi A3 activation for the same infotainment system is around £300
Ive tried the A3 one on the TT and it doesn't work
don't know why they charge a premium for the TT??
Nav on your phone is the best option.
