16 reg. Car is fitted with CD player with satnav,but the satnav is not enabled. How do I go about enabling the sat nav, with vcds if this is possible.
Meaningless to anyone not in the UK, i.e. most of us. And even if one knows what it means, it does not reflect the model year with any degree of certainty.16 reg.
Wednesday,04,December,2019,09:01:58:42542
VCDS Version: 19.6.2.0
VIN: TRUZZZFV7G1030000 License Plate: BT16XJG
Mileage: 27419km-17037mi Repair Order: harveys
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
VIN: TRUZZZFV7G1030000 Mileage: 27419km-17037miles
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 264 HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1900322404010B3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0208S0906264 001003
ROD: EV_ECM18TFS0208S0906264.rod
VCID: 76E3377DC96113FF8D-8022
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [032] - Signal too High
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [032] - Implausible Signal
15072 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Readiness: 0010 0001
Part No SW: 8S0 907 379 D HW: 8S0 907 379 D
Component: ESC H42 0522
Revision: 00000000 Serial number: 60676000000370
Coding: 11AA108D1A9C15A940910064C291830640880858A8020043C16002
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 428B9BADD529FF5FF1-8016
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0398911045
Coding: 000F0F1620
VCID: 3979FC41B8FFBC87A0-806C
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 047 HW: 8S0 820 047
Component: AC Manuell el H05 0030
Revision: 20009000 Serial number: 16010000009000
Coding: 410040000011100000
ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
ROD: EV_AirCondiMAPrehAU33x.rod
VCID: 70EF0165AB053DCF57-8024
Operating and display unit 2 for air conditioning:
Subsystem 1 - Part No SW: 8S0 820 360 D HW: 8S0 820 360 D
Component: E775 BuA_2 H06 0010
Serial number: 00000000000000006056
Operating and display unit 3 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 360 C HW: 8S0 820 360 C
Component: E776 BuA_3 H06 0010
Operating and display unit 4 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 360 E HW: 8S0 820 360 E
Component: E777 BuA_4 H06 0010
262914 - Refrigerant Pressure
B10AB F0 [008] - Too Low
Fault Frequency: 20
Reset counter: 192
Mileage: 25035 km
Date: 2019.10.23
Time: 04:32:36
Outside air temperature: 4.5 °C
Engine speed: 1533.00 /min
Compressor current: actual value: 0.00 A
Temperature after evaporator: 6.8 °C
Refrigerant pressure: 1.8 bar
System run time-Engine running time: 1 s
System run time-Terminal 15 on: 2 s
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061607901866
Coding: 07054C42C201067D03044004B31807A80880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 04075DB58FBD316F83-8050
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 151217 038 0371
Serial number: 00000001512140304805
Coding: 1BC7F7
Subsystem 2 - Part No SW: 8U0 955 559 D HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0004
Serial number: 50047158
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 06 01 2016 00000551
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY1120001SN
Serial number: 00000000000065418027
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39291607400086
Coding: 0000040001
VCID: 3C77E555B7CD89AFBB-8068
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number: 003M7R01AVU2
Coding: 88CCF0C00C8000005C5000CFC0C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4D91B8911C7730271C-8018
Subsystem 1 - Part No SW: ----------- HW: 480 002 903 16
Serial number: 35700000000272817A1A
Subsystem 2 - Part No SW: ----------- HW: 480 002 903 16
Serial number: 35800000000662817A1E
Subsystem 3 - Part No SW: ----------- HW: 480 010 402 16
Component: SideSensor_Dr 004 0108
Serial number: 351001A05D2D12333E92
Subsystem 4 - Part No SW: ----------- HW: 480 401 411 16
Serial number: 3550002C122E8E13A220
Front Sensor Passenger:
Subsystem 5 - Part No SW: ----------- HW: 480 401 111 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B91D3F98222AF
Pedestrian Protection Center:
Subsystem 6 - Part No SW: ----------- HW: 480 402 002 16
Component: PedP_Sensor_C 001 6149
Serial number: 2300002AF1F93A3102E4
Subsystem 7 - Part No SW: ----------- HW: 480 002 405 17
Serial number: I0M0000000014371242L
Subsystem 8 - Part No SW: ----------- HW: 480 002 405 17
Serial number: I0N000000000F2E8A42A
Part No SW: 8S0 907 129 AF HW: 8S0 907 129 AF
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335PCN00754
Coding: 0008
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_050.rod
VCID: 7EF32F5DE1515BBFD5-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 A HW: 8S0 920 790 A
Component: FBenRDW H35 0265
Coding: 24050110298006000120A8809000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 377DFA798EEBAAF756-8062
Part No SW: 8S0 907 468 C HW: 8S0 907 468
Component: GW MQB TT3 012 0246
Revision: -------- Serial number: 22031610802300
Coding: 030100042F025A004B000268080000000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 011003
ROD: EV_GatewContiAU33X_011.rod
VCID: 408F91A5DB25ED4FE7-8014
Subsystem 2 - Part No SW: 8S0 951 523 B HW: 8S0 951 523 B
Component: J453 MFL H07 0002
Serial number: 20160317062959 00824
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 4265879103
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000046403005
Coding: 0100000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E90461A00F34C758-8024
Component: TSG FS 020 0041
Serial number: 100216EB905902
Coding: 001042224001040100001402
VCID: 43859EA9CA33F657FA-8016
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
Component: TSG BFS 020 0041
Serial number: 060216EB404786
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 03DE00102B200200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 3663F77D89E153FF4D-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Part No SW: 8S0 035 020 F HW: 8S0 035 020
Component: MU-H-ND-EU 043 0413
Serial number: A580C0GB004262
Coding: 013304013C00000011111101000A00002F0000E3007000001A
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 2B55D60942A31E1722-807E
Multimedia Operating Unit:
Subsystem 1 - Part No SW: 8S0 919 614 L HW: 8S0 919 614 L
Component: ControlUnit_H H22 0136
Serial number: APVAK118011600010015
Compact Disc Database:
Subsystem 2 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1011
Part No SW: 8S0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 160224200023
End-------------------------(Elapsed Time: 04:31)--------------------------
Google Maps/Nav on your phone is free.As petroldave said SWaP
You need ODIS and online connection.
I priced one a little while ago it was about £2000 for the activation!![]()
OP - do you have either Android Auto or Apple CarPlay enabled?Google Maps/Nav on your phone is free.![]()
The crazy thing is the Audi A3 activation for the same infotainment system is around £300Google Maps/Nav on your phone is free.
