VCDS is pulling the following fault on radiator fan (#2).
I had local shop to a brief "inspection" and they could not find issue.
Can I ignore this fault or should I find a new shop?
I must say that the right-hand radiator fan is running excessively after ignition OFF following routine driving around town (when looking in engine bay from front bumper).
Any insight would be appreciated. Thanks -GA
Wednesday,13,September,2017,10:37:47:06705
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Chassis Type: 5N-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F 52
53 55 56 62 65 6C 72 77
VIN: WVGBV7xxxxxx Mileage: 113490km-70519miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 997 026 M HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 0609
Revision: AAH03--- Serial number: VWX7Z0I13N47SF
Coding: 0423010A190F0160
Shop #: WSC 32343 001 1048576
VCID: 3E2637076C7616E7696-806A
006472 - Control Module 2 for Cooling Fan
P1948 - 000 - Output Short Circuit - Intermittent
Fault Frequency: 107
Mileage: 110412 km
Time: 15:58:27
RPM: 3005 /min
Load: 51.0 %
Speed: 76.0 km/h
Temperature: 96.0°C
Temperature: 55.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.462 V
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 41
Mileage: 110626 km
Time: 17:46:58
RPM: 2290 /min
Load: 45.1 %
Speed: 70.0 km/h
Temperature: 93.0°C
Temperature: 47.0°C
Absolute Pres.: 840.0 mbar
Voltage: 13.716 V
Part No SW: 09G 927 750 KM HW: 09G 927 750 KM
Component: AQ 250 6F 1394
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 06569FE774268E27616-8052
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000001758093
Coding: 0002332
VCID: 392C241B755831DF5C4-806C
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 133 1213
Revision: 00133024 Serial number: 00000000000000
VCID: 6D84C04B71905D7F80C-8038
Revision: 00H54000 Serial number: 00000009375772
Coding: F78C8FA340041C004719000014000000002AF7475C400125420000000000
VCID: 333016335734CB8F968-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 130209 012 0203
Coding: 00038805
Shop #: WSC 01357
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 180209 046 0204
Coding: 00208933
Shop #: WSC 01357
Part No SW: 5N0 959 655 K HW: 5N0 959 655 K
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E3P0NNBFV
Coding: 0012336
VCID: 45D458EB09A0453F28C-8010
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000003HGX
Subsystem 3 - Serial number: 0028.01.090000100000660084ÿ†63
Subsystem 4 - Serial number: 660084ÿ†6332MTS667090069 ÿ†63
Subsystem 5 - Serial number: 90069 ÿ†6342MTS687430099 ÿ†63
Subsystem 6 - Serial number: 30099 ÿ†6351HTS6E67QV5KR ÿ†63
Subsystem 7 - Serial number: QV5KR ÿ†6361HTS6US8006KR ÿ†63
Subsystem 8 - Serial number: 006KR ÿ†63727TS6N4I106KR ÿ†63
Subsystem 9 - Serial number: 106KR ÿ†63827TS6KM4TV5KJ ÿ
Subsystem 10 - Serial number: TV5KJ ÿ
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 055 0111
Coding: 0001332
VCID: 7AAEFB1730DEFAC715E-802E
Component: E0221 002 0030
Part No SW: 5N0 920 970 F HW: 5N0 920 970 F
Component: KOMBIINSTRUMENT VDD 2422
Revision: V0005000 Serial number: VWX7Z0I13N47SF
Coding: 0007204
Shop #: WSC 01357 067 57207
VCID: 3432152F523ACCB78F2-8060
Part No SW: 1K0 907 530 T HW: 1K0 907 951
Component: J533 Gateway H06 0071
Revision: H06 01 Serial number: 090109F2000655
Coding: FD83FF07504613006002
VCID: 382A211F4E5228D7A3A-806C
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4BC06ED32FC4B34FFE8-801E
Component: IMMO VDD 2422
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667359650
VCID: 2616FF6798E6AE27016-8072
Part No SW: 5N0 959 760 A HW: 5N0 959 760 A
Component: MEM-FS H04 0032
Revision: AA000000 Serial number: 00001001220546
Coding: 20581300000044440011
VCID: 382A211F425228D7A3A-806C
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 E
Component: RNS-MID H61 4366
Revision: AB001001 Serial number: VWZ6Z7L9337042
Coding: 04050002010000A7000B
Shop #: WSC 09003 957 00200
VCID: 2A0E0B578CFE8A4725E-807E
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V11 8407
Reset counter: 103
Mileage: 110400 km
Time: 15:47:42
01550 - Signal for Reverse Gear
Reset counter: 230
Mileage: 110407 km
Time: 14:43:53
01523 - Microphone for Telephone (R38)
Reset counter: 103
Mileage: 110407 km
Time: 14:43:57
Part No SW: 5N0 959 701 C HW: 5N0 959 701 C
Component: Tuer-SG 008 2005
Coding: 0005567
VCID: 3534282B5940D5BFB8C-8060
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.097 0502
Revision: 1AH02271 Serial number: 00083450053202
Coding: 0000258
00566 - Steering Assistance Operation
Fault Status: 11101000
Reset counter: 38
Mileage: 94733 km
Time: 00:03:38
Hex Value: 0x5301
Hex Value: 0x4301
Hex Value: 0x1B01
Hex Value: 0x5601
Hex Value: 0x4601
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 1B80078852834C7F7F02058FB0888F0C88DCA0
VCID: 72BED33768AE82875DE-8026
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0316
Revision: -------- Serial number: BP218187354288
VCID: 6788B2635FEC772FFA0-8032
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 6696BF6758666E27C16-8032
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Part No SW: 5N0 959 702 C HW: 5N0 959 702 C
Coding: 0005566
VCID: 36362F274446DEA7B16-8062
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H09 Serial number: 00000000193006
Coding: 0000057
VCID: 2E060747BC16E667F96-807A
Component: AFS-Steuergeraet 0142
Coding: 1352902
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000020
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000020
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 103
Mileage: 110400 km
Time: 15:47:42
Reset counter: 230
Mileage: 110407 km
Time: 14:43:53
Reset counter: 103
Mileage: 110407 km
Time: 14:43:57
Part No SW: 5N0 959 703 C HW: 5N0 959 703 C
Component: Tuer-SG 007 2001
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 37282223434C27AFAA0-8062
Component: RDK 0453
Coding: 0100101
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 HW: 5N0 907 441
Component: J772__Rearview 0021
Revision: 00H05000 Serial number: PA8 J920072
Coding: 0100010
VCID: 6C82CD4F4A8A5477972-8038
02203 - Audio / Video Input 1
Fault Status: 00101011
Reset counter: 143
Mileage: 113473 km
Reverse OFF
Count: 3
Part No SW: 5N0 959 704 C HW: 5N0 959 704 C
Coding: 0001168
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662355233
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2708F2639F6CB72F3A0-8072
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 221
Mileage: 110153 km
Time: 00:55:33
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
