2009 VW Tiguan SEL -- Radiator Fan Faults
gads1
C?ID=310555
VCDS is pulling the following fault on radiator fan (#2).
I had local shop to a brief "inspection" and they could not find issue.
Can I ignore this fault or should I find a new shop?
I must say that the right-hand radiator fan is running excessively after ignition OFF following routine driving around town (when looking in engine bay from front bumper).
Any insight would be appreciated. Thanks -GA
Wednesday,13,September,2017,10:37:47:06705
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
Chassis Type: 5N-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F 52
          53 55 56 62 65 6C 72 77
VIN: WVGBV7xxxxxx   Mileage: 113490km-70519miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 026 M    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    0609
   Revision: AAH03---    Serial number: VWX7Z0I13N47SF
   Coding: 0423010A190F0160
   Shop #: WSC 32343 001 1048576
   VCID: 3E2637076C7616E7696-806A
006472 - Control Module 2 for Cooling Fan
               P1948 - 000 - Output Short Circuit - Intermittent
                    Fault Frequency: 107
                    Mileage: 110412 km
                    Time: 15:58:27
                    RPM: 3005 /min
                    Load: 51.0 %
                    Speed: 76.0 km/h
                    Temperature: 96.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.462 V
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 41
                    Mileage: 110626 km
                    Time: 17:46:58
                    RPM: 2290 /min
                    Load: 45.1 %
                    Speed: 70.0 km/h
                    Temperature: 93.0°C
                    Temperature: 47.0°C
                    Absolute Pres.: 840.0 mbar
                    Voltage: 13.716 V
   Part No SW: 09G 927 750 KM    HW: 09G 927 750 KM
   Component: AQ 250 6F           1394
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 06569FE774268E27616-8052
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000001758093
   Coding: 0002332
   VCID: 392C241B755831DF5C4-806C
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 6D84C04B71905D7F80C-8038
   Revision: 00H54000    Serial number: 00000009375772
   Coding: F78C8FA340041C004719000014000000002AF7475C400125420000000000
   VCID: 333016335734CB8F968-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 130209  012 0203
   Coding: 00038805
   Shop #: WSC 01357
   Component: RLS     180209 046  0204
   Coding: 00208933
   Shop #: WSC 01357
   Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E3P0NNBFV
   Coding: 0012336
   VCID: 45D458EB09A0453F28C-8010
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 00000000003HGX
   Subsystem 3 - Serial number: 0028.01.090000100000660084ÿ†63
   Subsystem 4 - Serial number: 660084ÿ†6332MTS667090069 ÿ†63
   Subsystem 5 - Serial number: 90069 ÿ†6342MTS687430099 ÿ†63
   Subsystem 6 - Serial number: 30099 ÿ†6351HTS6E67QV5KR ÿ†63
   Subsystem 7 - Serial number: QV5KR ÿ†6361HTS6US8006KR ÿ†63
   Subsystem 8 - Serial number: 006KR ÿ†63727TS6N4I106KR ÿ†63
   Subsystem 9 - Serial number: 106KR ÿ†63827TS6KM4TV5KJ ÿ
   Subsystem 10 - Serial number: TV5KJ ÿ
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           055 0111
   Coding: 0001332
   VCID: 7AAEFB1730DEFAC715E-802E
   Component: E0221           002 0030
   Part No SW: 5N0 920 970 F    HW: 5N0 920 970 F
   Component: KOMBIINSTRUMENT VDD 2422
   Revision: V0005000    Serial number: VWX7Z0I13N47SF
   Coding: 0007204
   Shop #: WSC 01357 067 57207
   VCID: 3432152F523ACCB78F2-8060
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 090109F2000655
   Coding: FD83FF07504613006002
   VCID: 382A211F4E5228D7A3A-806C
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4BC06ED32FC4B34FFE8-801E
   Component: IMMO            VDD 2422
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667359650
   VCID: 2616FF6798E6AE27016-8072
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001220546
   Coding: 20581300000044440011
   VCID: 382A211F425228D7A3A-806C
   Part No SW: 3C0 035 684 J    HW: 3C0 035 684 E
   Component: RNS-MID       H61 4366
   Revision: AB001001    Serial number: VWZ6Z7L9337042
   Coding: 04050002010000A7000B
   Shop #: WSC 09003 957 00200
   VCID: 2A0E0B578CFE8A4725E-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V11  8407
            000 -  -
                    Reset counter: 103
                    Mileage: 110400 km
                    Time: 15:47:42
01550 - Signal for Reverse Gear
                    Reset counter: 230
                    Mileage: 110407 km
                    Time: 14:43:53
01523 - Microphone for Telephone (R38)
                    Reset counter: 103
                    Mileage: 110407 km
                    Time: 14:43:57
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0005567
   VCID: 3534282B5940D5BFB8C-8060
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.097 0502
   Revision: 1AH02271    Serial number: 00083450053202
   Coding: 0000258
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 38
                    Mileage: 94733 km
                    Time: 00:03:38
                    Hex Value: 0x5301
                    Hex Value: 0x4301
                    Hex Value: 0x1B01
                    Hex Value: 0x5601
                    Hex Value: 0x4601
   Part No SW: 1K0 959 433 DA    HW: 1K0 959 433 DA
   Component:    KSG PQ35 RDK 052 0225
   Coding: 1B80078852834C7F7F02058FB0888F0C88DCA0
   VCID: 72BED33768AE82875DE-8026
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0316
   Revision: --------    Serial number: BP218187354288
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 6788B2635FEC772FFA0-8032
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6696BF6758666E27C16-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0005566
   VCID: 36362F274446DEA7B16-8062
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000193006
   Coding: 0000057
   VCID: 2E060747BC16E667F96-807A
   Component: AFS-Steuergeraet    0142
   Coding: 1352902
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
            000 -  -
                    Reset counter: 103
                    Mileage: 110400 km
                    Time: 15:47:42
                    Reset counter: 230
                    Mileage: 110407 km
                    Time: 14:43:53
                    Reset counter: 103
                    Mileage: 110407 km
                    Time: 14:43:57
   Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
   Component: Tuer-SG         007 2001
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 37282223434C27AFAA0-8062
   Component:    RDK              0453
   Coding: 0100101
   Part No SW: 5N0 907 441     HW: 5N0 907 441
   Component: J772__Rearview      0021
   Revision: 00H05000    Serial number:    PA8 J920072
   Coding: 0100010
   VCID: 6C82CD4F4A8A5477972-8038
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 143
                    Mileage: 113473 km
                        Reverse OFF
                    Count: 3
   Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
   Coding: 0001168
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662355233
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 2708F2639F6CB72F3A0-8072
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 221
                    Mileage: 110153 km
                    Time: 00:55:33
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
gads1
C?ID=310555
The One
Australia
C?ID=277442
Do all the fans work?
gads1
C?ID=310555
my apologies for ignorance. what are the uses for each of the front two Tiguan fans.
example: if I'm standing in front of car looking into engine bay. there are two fans -- the fan on LEFT is slightly smaller in Diameter vs the right. The Larger fan on right is one I've seen in operation (and also runs as part of standard cool-down following ignition OFF).
any insight would be appreciated. thanks -GA
NostraJackAss
The RTFB will show the fuse identifiers in the WD.......yeah I would find another shop!
Spin the fans manually and check the radiator for a blockage or obstruction of air flow.
gads1
C?ID=310555
Hello and thanks for msg. This continues to be an ongoing concern for me (primary fan making a HUGE racket every time I shut down Tiguan).
I did not realize I could test the fan electronics with VCDS. I found this nugget via comment section on HumbleMechanic youtube videos.
01-Engine/Output tests/scroll to fan1 test.
both fans do spin up with no surprises. nice and smooth. no odd sounds.
This is Tiguan SEL with dual-climate. I understand that does make a difference on the wiring and use for fans.
At least I know the smaller fan works.
the problem: I understood for various forums that "smaller" fan is supposed to run when A/C is on. I'm not sure if this basic test applies to all Tiguans -- even those with dual-climate?
For example: the smaller fan does NOT run when A/C is on.
NostraJackAss
It is most likely that the fans are damaged from being run out or have poor/insufficient grounds to them...........very common since being made of poor quality parts, starting in the year 2000>.
The smaller fan is to come on when the controller sees the need for step up speed while AC ON when the car becomes hot.
