Fault Codes and cruise control not working.
smc123
C?ID=184186
Just replaced a clock spring control module due to various faults with the vehicle and I hoping it would also resolve the cruise control issue.
I am unsure if I currently have the correct coding or if it may be a switch fault.
Below is a fault code report from vcds:imageshack
Monday,07,January,2019,10:30:24:06086
VCDS Version: 18.9.0.2 (x64)
VIN: WVWZZZAUZEP534346   License Plate: R666GFE
Mileage: 95353km-59249mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP534346   Mileage: 95353km-59249miles
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5518
   Revision: 84H22---
   Coding: 01250012036505092000
   Shop #: WSC 00028 028 00301
   ASAM Dataset: EV_ECM16TDI01104L906021N 002009
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 306FCE156B3495CA65-8064
17165 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 95350 km
                    Date: 2019.01.07
                    Time: 09:12:16
                    Engine speed: 979.00 /min
                    Normed load value: 31.8 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 42 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 14.480 V
                    ACC variants-Bits 0-7: 2
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 128
                    ACC variants (coding)-Bits 0-7: 3
                    Acceleration: 0.176 m/s²
17284 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [038] - -
                    Fault Frequency: 23
                    Mileage: 95350 km
                    Date: 2019.01.07
                    Time: 09:08:43
                    Coolant temperature: 67 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 12.040 V
                    Limitation: accelerator pedal: 111.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 1
                    selected gear-Bits 0-7: 0
18875 - Cruise Control Switch (E45)
          P0568 00 [047] - Implausible Signal
                    Fault Frequency: 7
                    Mileage: 95350 km
                    Date: 2019.01.07
                    Time: 09:08:48
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 11.700 V
                    Cruise control switch actuation-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
17166 - Cruise Control Switch (E45)
          P0568 00 [039] - Implausible Signal
                    Fault Frequency: 25
                    Mileage: 95350 km
                    Date: 2019.01.07
                    Time: 09:12:17
                    Coolant temperature: 63 °C
                    Intake air temperature: 60 °C
                    Cruise control switch actuation-Bits 0-7: 33
   Part No SW: 0CW 300 046     HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5110
   Revision: 00043014    Serial number: CU501310157799
   Shop #: WSC 00028 028 00024
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 77FD3509CEDA82F2E4-8022
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6273300000005D
   Coding: 04FA8AA124230970037A060441C92520512490C06082A4F3F842F078C202
   VCID: 7CF72A25F7FCA1AA89-8028
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 02120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 3561FF019456B0E236-8060
   Part No SW: 5Q0 937 086 N    HW: 5Q0 937 086 N
   Component: BCM PQ37BOSCH 026 0095
   Revision: --------    Serial number: 86581410130024
   Coding: 03001842C24102730BA44080B10403281000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 45818FC1C4B62062A6-8010
   Component: WWS    130915  042 0551
   Serial number:         130923005652
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y13M10D13H00M45S31S1
   Coding: 00A8DD
   Serial number: 000000000ZY132462VT7
   Serial number: 00000000000027951481
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231328501193
   Coding: 0071051011
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B75E939B2726692C0-806E
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 09101376510141
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
0108 - Steering Column Control Module
          B105D 00 [009] -  -
                    Fault Frequency: 89
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:55:53
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1090 - Databus
                    Fault Frequency: 21
                    Reset counter: 45
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:55:40
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:55:40
   Component: AirbagVW20    014 0386
   Serial number: 003MLR00U3K/
   Shop #: WSC 00028 028 00059
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F0DDD29E6EABAB2AC-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B24091350410
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B23091371178
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 509 13
   Serial number: 357670000004979C8D04
   Subsystem 4 - Part No SW: -----------    HW: 480 002 509 13
   Serial number: 3586700000084460FD0-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 13
   Serial number: 3516502C51171FE4102%
   Subsystem 6 - Part No SW: -----------    HW: 480 401 510 13
   Serial number: 3526502AF1171FE4719M
   Subsystem 7 - Part No SW: -----------    HW: 480 400 410 13
   Serial number: 3556502A91142C80E348
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20181002500130
   Coding: 6E10
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C77EA25B77C61AAC9-8068
          B1149 13 [009] - Open Circuit
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:57:19
                    Ubat 30 Voltage: 12.70 V
                    Ignition State: On
                    Terminal 15: 11.90 V
                    A/D #1: 97.25 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
229131 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:57:19
                    Ignition State: On
                    A/D #1: 96.86 %
                    A/D #2: 96.86 %
                    A/D #3: 0.00 %
229147 - Cruise Control Switch
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:57:19
                    Ignition State: On
                    A/D #1: 97.25 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
229160 - Cruise Control Switch
          B1154 29 [009] - Signal Implausible
                    Reset counter: 5
                    Mileage: 95353 km
                    Date: 2019.01.07
                    Time: 09:57:19
                    Ignition State: On
                    A/D #1: 96.86 %
                    A/D #2: 100.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G0 920 971 A    HW: 5G0 920 971 A
   Component: KOMBI         353 2210
   Coding: 27A412082780260001882A01040000
   VCID: 2959237148EEE402A2-807C
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 Q
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 28051310800072
   Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3F8D9D29A66A7AB2EC-806A
   Component: E221__MFL-DC1  H15 0038
   Serial number: 27130001659820073402
   Coding: 2DFFFF
   Serial number: 1476811403
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000069256338
   Coding: 003002208001048000001000
   VCID: 428B94DDD598175A83-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003004594
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41899BD1D09E0C429A-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000078171063
   Coding: 003000208E01048000801000
   VCID: 438591D9CA821E5288-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003018434
   Coding: 050000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C01410130074
   Coding: 02730200FF00000021111201002800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4D3DA906AA1AB2CC-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ701XJR
End-------------------------(Elapsed Time: 04:43)--------------------------
Address 01: DTCs cleared
Address 13: DTCs cleared
Address 16: DTCs cleared
                Address 16: Steering wheel  (5Q0 953 569 A)
11:01:59
  IDE00356-IDE00355   Cruise Control System (CCS): switch position-Cruise Control System (CCS): status ERROR
  IDE00356-MAS00125   Cruise Control System (CCS): switch position-Cruise control system OFF
  IDE00356-MAS00128   Cruise Control System (CCS): switch position-Distance Regulation not activated
  IDE00356-MAS00320   Cruise Control System (CCS): switch position-Main switch Engaged ON
  IDE02695-IDE01268   Front wiping: front washing-Windshield wiper not activated
  IDE02695-MAS02338   Front wiping: front washing-Windshield wiper: intermittent stage Stage 1
  IDE02695-MAS02339   Front wiping: front washing-Windshield washer system not activated
If you would Get Verified we could put this in the real Car Repair Support section instead of General (where it really doesn't belong).
smc123
C?ID=184186
Just done the verification, Sorry for posting in wrong section.
Great. Moving this to Car Repair Support now.
smc123
C?ID=184186
Bumping Thread. Any Ideas anyone?
Dana
Western PA, USA
Check the saved scan prior to replacing address 16 but I think it would have been coded to: 0D00
Dana
Western PA, USA
P.S. On MQB/Mk7 based cars the MFSW is a slave of address 19. For that reason CCS isn't enabled via 16 coding.
Coding: 2DFFFF
I'll admit, the LCH can be confusing of you don't know that. I changed the LCH text from / to:
O44VqdhVY5t-aw2luzE-Czui5pzsdg8rxb60EO7llgoZCAmtyBcwObHNKkAcgFLoLVF3g9w-l01bcXKY3Sk0VqIQQLkgjfEyB5AXsBIYC05InGLuAt2tcCEZPJ4zDKEZ0mn8YxRWFTYIYbZM9GjbyvcmO60yCjhwuvX-BzF7oR3yZ7-vyLPRXvgI4U6Bm3RBrqKeKbCHeVCjABAtT47UvSxhMK0ppMiGewRbeCqGW5OiLo8qoQx4AR4FxAishRA_3cvIcQrQ1SV5JC40S9NHoySWp80HVcGqeQPwO_sehe0kSOaDSvM-jo1MVfLhyqd0OsocAjAJrroABvUGe4YyfiXNjTnGQxEzEKqc2miDvQ9Oxb6akJMXa2r54TjrZwrSaP2wstju-zeUKfsIaIlLqDCGdSSOHlwwRLfpT8-WhxrEEYhgTi7EqK9I54PuXisSYHocozw9eUKU81KPHZ8k2eyDkBxFzzo3cbhIT-hv_0hUFwOeUptdSzlISCWaUtS2514Ho37JwMDq5TqTjW0jvVCB1tTK_HH0NnNs7Rx7bPwCmNwWfbitVxIWIaHh2NMfhlCUQ24HihxXwxUlnbk9qBmxRxz-Nutm--cqANVE7awP5Z-2QEgFvUpwY9WYh513yMNVCqRdlw2cAIPncbx2-fhZQA=w648-h644-no
We might revise that exact text before it goes into the next VCDS version but hopefully it add clarity because "Cruise Control NOT installed" isn't exactly crystal clear.
smc123
C?ID=184186
Thanks for the reply, How would I go about activating it as all I changed was the air bag clock spring.
Would I do this in the air bag ecu, as I assumed it may of been the steering wheel ecu where this coding is done?
Also the image you attached isn't loading.
smc123
C?ID=184186
Would this be address 16 to code TO 0D00? Unfortunately my someone else scanned to vehicle prior to me and then changed the part. They didn't use vcds to scan it so I have no history on the previous coding.
Dana
Western PA, USA
Hmm, that Google image loads in FF and Chrome but IE isn't showing it on a Win 7 PC. This is the direct URL https://photos.app.goo.gl/8iEFJcRs6So1bqkd9
Address 16: Steering wheel (J524) is the new module so that's what I'd try coding to 0D00 if the factory coding isn't known.
smc123
C?ID=184186
Thank you for your reply and picture.
As the vehicle has adaptive cruise control would this be the correct coding?
(The control for cruise is on the steering wheel)
If so I assume your picture would suggest that the "E221 MFSW slave" handles the request for cruise control as opposed to the "16-Steering Wheel module "
Dana
Western PA, USA
Yeah, my coding should be correct based on Automatic trans scans with ACC from good baseline cars.
I re-worded that to read "Cruise Control NOT installed -or- Cruise Control handled by E221 MFSW slave of J533". If there aren't any objections that will make it to the next dataversion. (It didn't make it to Release 18.9.1 this afternoon).
smc123
C?ID=184186
Okay just to update.
Coding 0D10 was a Error 31 coding rejected out of range.
I managed to code to OE10 but have the following error code.
The wiper washer stick front and rear does operate and now so does the cruise control now.
Also I no longer have loads of data bus errors so prehaps the other code may have been preexisting
Thursday,17,January,2019,09:28:40:06086
                Address 16: Steering wheel       Labels: 5Q0-953-549.clb
Control Module Part Number: 5Q0 953 569 A    HW: 5Q0 953 569 A
  Component and/or Version: Lenks.Modul   075 0235
           Software Coding: 0E10
            Work Shop Code: WSC 01286 386 08256
              ASAM Dataset: EV_SMLSVALEOMQB 001016 (VW37)
                    Reset counter: 24
                    Mileage: 96248 km
                    Date: 2019.01.17
                    Time: 09:18:26
                    Ubat 30 Voltage: 11.50 V
                    Ignition State: On
                    Terminal 15: 10.70 V
                    A/D #1: 97.25 %
                    A/D #2: 20.78 %
                    A/D #3: 0.00 %
