Just replaced a clock spring control module due to various faults with the vehicle and I hoping it would also resolve the cruise control issue.
I am unsure if I currently have the correct coding or if it may be a switch fault.
Below is a fault code report from vcds:imageshack
Monday,07,January,2019,10:30:24:06086
VCDS Version: 18.9.0.2 (x64)
VIN: WVWZZZAUZEP534346 License Plate: R666GFE
Mileage: 95353km-59249mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP534346 Mileage: 95353km-59249miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5518
Revision: 84H22---
Coding: 01250012036505092000
Shop #: WSC 00028 028 00301
ASAM Dataset: EV_ECM16TDI01104L906021N 002009
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 306FCE156B3495CA65-8064
17165 - Databus
U1123 00 [047] - Received Error Message
Mileage: 95350 km
Date: 2019.01.07
Time: 09:12:16
Engine speed: 979.00 /min
Normed load value: 31.8 %
Vehicle speed: 7 km/h
Coolant temperature: 42 °C
Intake air temperature: 48 °C
Voltage terminal 30: 14.480 V
ACC variants-Bits 0-7: 2
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 128
ACC variants (coding)-Bits 0-7: 3
Acceleration: 0.176 m/s²
17284 - Implausible Data Received from Body Control Module (Central Electric)
U0422 00 [038] - -
Fault Frequency: 23
Mileage: 95350 km
Date: 2019.01.07
Time: 09:08:43
Engine speed: 0.00 /min
Coolant temperature: 67 °C
Intake air temperature: 58 °C
Voltage terminal 30: 12.040 V
Limitation: accelerator pedal: 111.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 1
selected gear-Bits 0-7: 0
18875 - Cruise Control Switch (E45)
P0568 00 [047] - Implausible Signal
Mileage: 95350 km
Date: 2019.01.07
Time: 09:08:48
Intake air temperature: 52 °C
Voltage terminal 30: 11.700 V
Cruise control switch actuation-Bits 0-7: 32
Acceleration: 0.000 m/s²
17166 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Fault Frequency: 25
Mileage: 95350 km
Date: 2019.01.07
Time: 09:12:17
Coolant temperature: 63 °C
Intake air temperature: 60 °C
Cruise control switch actuation-Bits 0-7: 33
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 046 HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5110
Revision: 00043014 Serial number: CU501310157799
Shop #: WSC 00028 028 00024
ROD: EV_TCMDQ200021_VW31.rod
VCID: 77FD3509CEDA82F2E4-8022
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 6273300000005D
Coding: 04FA8AA124230970037A060441C92520512490C06082A4F3F842F078C202
VCID: 7CF72A25F7FCA1AA89-8028
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 02120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 3561FF019456B0E236-8060
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 N HW: 5Q0 937 086 N
Component: BCM PQ37BOSCH 026 0095
Revision: -------- Serial number: 86581410130024
Coding: 03001842C24102730BA44080B10403281000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: 45818FC1C4B62062A6-8010
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130915 042 0551
Serial number: 130923005652
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M10D13H00M45S31S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132462VT7
Serial number: 00000000000027951481
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231328501193
Coding: 0071051011
ASAM Dataset: EV_EPHVA18AU3700000 002019
VCID: 3B75E939B2726692C0-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H04 0150
Serial number: 09101376510141
Coding: 001C1300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
0108 - Steering Column Control Module
B105D 00 [009] - -
Fault Frequency: 89
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:55:53
Control Module temperature: 34 °C
Voltage terminal 15: 14.5 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1090 - Databus
Fault Frequency: 21
Reset counter: 45
Mileage: 95353 km
Date: 2019.01.07
Time: 09:55:40
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:55:40
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR00U3K/
Shop #: WSC 00028 028 00059
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F0DDD29E6EABAB2AC-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677B24091350410
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676B23091371178
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 509 13
Serial number: 357670000004979C8D04
Subsystem 4 - Part No SW: ----------- HW: 480 002 509 13
Serial number: 3586700000084460FD0-
Subsystem 5 - Part No SW: ----------- HW: 480 400 910 13
Serial number: 3516502C51171FE4102%
Subsystem 6 - Part No SW: ----------- HW: 480 401 510 13
Serial number: 3526502AF1171FE4719M
Subsystem 7 - Part No SW: ----------- HW: 480 400 410 13
Serial number: 3556502A91142C80E348
Part No SW: 5Q0 953 569 A HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: -------- Serial number: 20181002500130
Coding: 6E10
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C77EA25B77C61AAC9-8068
B1149 13 [009] - Open Circuit
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:57:19
Ubat 30 Voltage: 12.70 V
Ignition State: On
Terminal 15: 11.90 V
A/D #1: 97.25 %
A/D #2: 65.49 %
A/D #3: 0.00 %
229131 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:57:19
Ignition State: On
A/D #1: 96.86 %
A/D #2: 96.86 %
A/D #3: 0.00 %
229147 - Cruise Control Switch
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:57:19
Ignition State: On
A/D #1: 97.25 %
A/D #2: 0.00 %
A/D #3: 0.00 %
229160 - Cruise Control Switch
B1154 29 [009] - Signal Implausible
Reset counter: 5
Mileage: 95353 km
Date: 2019.01.07
Time: 09:57:19
Ignition State: On
A/D #1: 96.86 %
A/D #2: 100.00 %
A/D #3: 0.00 %
Part No SW: 5G0 920 971 A HW: 5G0 920 971 A
Component: KOMBI 353 2210
Coding: 27A412082780260001882A01040000
VCID: 2959237148EEE402A2-807C
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 Q
Component: GW MQB High 212 2163
Revision: -------- Serial number: 28051310800072
Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3F8D9D29A66A7AB2EC-806A
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H15 0038
Serial number: 27130001659820073402
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 1476811403
Part No SW: 5Q4 959 393 B HW: 5Q4 959 393 B
Component: TSG FS 009 0014
Serial number: 0000069256338
Coding: 003002208001048000001000
VCID: 428B94DDD598175A83-8016
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000003004594
Coding: 0D0000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41899BD1D09E0C429A-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000078171063
Coding: 003000208E01048000801000
VCID: 438591D9CA821E5288-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003018434
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C01410130074
Coding: 02730200FF00000021111201002800001F0100060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F4D3DA906AA1AB2CC-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H51 0022
Serial number: VWZ8Z9NJ701XJR
End-------------------------(Elapsed Time: 04:43)--------------------------
Address 01: DTCs cleared
Address 13: DTCs cleared
Address 16: DTCs cleared
Address 16: Steering wheel (5Q0 953 569 A)
11:01:59
IDE00356-IDE00355 Cruise Control System (CCS): switch position-Cruise Control System (CCS): status ERROR
IDE00356-MAS00125 Cruise Control System (CCS): switch position-Cruise control system OFF
IDE00356-MAS00128 Cruise Control System (CCS): switch position-Distance Regulation not activated
IDE00356-MAS00320 Cruise Control System (CCS): switch position-Main switch Engaged ON
IDE02695-IDE01268 Front wiping: front washing-Windshield wiper not activated
IDE02695-MAS02338 Front wiping: front washing-Windshield wiper: intermittent stage Stage 1
IDE02695-MAS02339 Front wiping: front washing-Windshield washer system not activated
