Can I tell the health of my EGR valve from a freeze frame?
G Man
C?ID=205677
Hi Folks,
Car (2011 Audi A3 8p 2l TDI) went into limp mode the other week and VCDS shows up two fault codes for the EGR valve - auto scan below.
Does the freeze frame information let you troubleshoot much further without removing the EGR valve for a visual inspection?
Thanks,
G
Monday,20,February,2017,16:49:14:25115
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
Mileage: 133620km-83027mi   Repair Order:
Chassis Type: 8P (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 62 72 77
   Mileage: 133620km-83027miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AB    HW: 03L 906 018 AG
   Component: R4 2.0l TDI   H24 9979
   Revision: 41H24---    Serial number: AUX7Z0K5FN60P2
   Coding: 00190012040501080000
   Shop #: WSC 62225 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018AB 003012
   ROD: EV_ECM20TDI01103L906018AB.rod
   VCID: 6ADBC2DD8D1DF2115D-803E
4891 - EGR Valve (N18)
          P0403 00 [032] - Malfunction
                    Mileage: 132598 km
                    Date: 2017.02.02
                    Time: 13:44:36
                    Engine speed: 841.00 /min
                    Normed load value: 20.4 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.700 V
                    Unlearning counter according OBD: 13
                    Air mass: actual value (mg/stroke): 444.8 mg/stroke
                    EGR Vacuum Regulator Solenoid Valve: activation: 100.00 %
                    EGR solenoid valve: actual value: 84.28 %
                    EGR valve: offset closed: 6.12 %
                    Actuator for high pressure EGR: status-Bit 0: 00000000
                    Actuator for high pressure EGR: status-Bit 16: 00010000
                    Actuator for high pressure EGR: status-Bit 24: 00110111
                    Actuator for high pressure EGR: status-Bit 8: 00000111
                    High press EGR actuator: actual unconditioned volt val: 1288.2 mV
4892 - EGR Valve (N18)
                    Mileage: 132598 km
                    Date: 2017.02.02
                    Time: 13:44:35
                    Engine speed: 831.00 /min
                    Normed load value: 19.6 %
                    Voltage terminal 30: 14.660 V
                    Air mass: actual value (mg/stroke): 271.4 mg/stroke
                    EGR Vacuum Regulator Solenoid Valve: activation: 15.00 %
                    EGR solenoid valve: actual value: 53.39 %
                    Actuator for high pressure EGR: status-Bit 16: 00000000
                    High press EGR actuator: actual unconditioned volt val: 2214.8 mV
   Revision: 00H31001
   Coding: 1342401209220003C80F02EC901F0092380800
   Shop #: WSC 06314 000 00000
   VCID: 7BF5F799FA877B99B6-802E
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0170
   Revision: 000155      Serial number: 8P0820043BM
   VCID: 78FFE8950BB15081DB-802C
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
   Component: BCM PQ35  M   110 0653
   Revision: 00110 AF
   Coding: 4E000A2FA005F0C0207041E00400095C42DE2BAA204DD12AE4008F840041
   Shop #: WSC 06314 123 12345
   VCID: 3F8D4389AE1FA7B9DA-806A
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 3 - Part No: 1K8 951 605 B
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 122
                    Mileage: 126334 km
                    Date: 2016.11.09
                    Time: 09:10:00
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003JU002FEKH
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 52AB7A3D058D5AD105-8006
   Serial number: 3572DRB40000DB88D8CG
   Serial number: 3582DRB40000DBD0A0B2
   Serial number: 35128RB400006317F1EM
   Serial number: 35228RB4000063057B5D
   Serial number: 35547RB40000642E14CN
   Serial number: 35647RB40000642AD36P
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004012
   VCID: 4683566D31C5F67199-8012
   Component: E0221           H06 0030
   Part No SW: 8P0 920 983     HW: 8P0 920 983
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2245K002001131
   Coding: 0260428
   Shop #: WSC 01183 210 94666
   VCID: 77FDEBA906AF5FF9D2-8022
00003 - Control Module
                    Fault Status: 01100101
                    Mileage: 126334 km
                    Date: 2016.11.09
                    Time: 08:46:38
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 290511F1003442
   Coding: 352103
   VCID: 377D2BA9862F9FF912-8062
   Revision: D0H02002    Serial number: AUX7Z0K5FN60P2
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0131764
   VCID: 49995D5120DB190974-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 233    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 34671CA5575974E137-8060
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0131764
   VCID: 4A9B625D25DD12117D-801E
   Part No: 8P3 907 357 B
   Coding: 0000013
   VCID: 3C7734857F09BCA1FF-8068
   Part No SW: 8P0 035 186 AB    HW: 8P0 035 186 AB
   Component: R Concert2+     H03 0293
   Revision: 00H03000    Serial number: AUZ1Z3L2310596
   Coding: 0710101
   VCID: 72EBDABD6DCD3AD1E5-8026
                    Fault Status: 00100001
                    Reset counter: 66
                    Mileage: 132954 km
                    Date: 2017.02.09
                    Time: 18:12:57
   Component: Batt.regelung H43 1620
   Coding: F30B185A
   VCID: 71E9D5B1A8CB01C91C-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370557710
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131216
   Shop #: WSC 06314 000 1012544
   VCID: 428B4A7D1DEDCA51B5-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131216
   VCID: 43854F7902F7C359BE-8016
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005402571
   Coding: 0001222
   VCID: 356121A15C236DE900-8060
End-------------------------(Elapsed Time: 02:22)--------------------------
At the time of taking the auto scan:
IDE00586   Deviation of exhaust gas recirculation rate -0.8 %
  IDE01361   Exhaust gas recirculation (EGR) cooler pump: specified value 93.82 %
  IDE01363-ENG104207   Exhaust gas recirculation: shut-off conditions-Bit 0 11110101
  IDE01363-ENG102612   Exhaust gas recirculation: shut-off conditions-Bit 16 00000000
  IDE01363-ENG101717   Exhaust gas recirculation: shut-off conditions-Bit 24 00000000
  IDE01363-ENG101796   Exhaust gas recirculation: shut-off conditions-Bit 8 00000111
  IDE03383   Exhaust mass flow of EGR 18.1 kg/h
Nice first post. Coherent description of problem, Auto-Scan in code tags, measuring value data. :thumbs:
Now if you were to Get Verified, we could move this to the Car Repair section. ;)
G Man
C?ID=205677
Thanks, Uwe.
I'm working away from home this week so once I get back to my cable I will get registered and update this thread.
Thanks,
G
G Man
C?ID=205677
I registered today.
G
G Man
C?ID=205677
No thoughts on this, folks?
I can guess the answer could be no.
G
Gone But Not Forgotten
Have you checked N18 for function in outputs if supported and the actual EGR basic setting tests in VCDS?
G Man
C?ID=205677
I believe I ran the EGR test and this completed fine. I can't recall the exact name of the test but it verified the valve closed > open > closed.
I'll check the N18 for function.
Thanks,
G
Study the N18 in WD too is advised.........this way you are familiar with circuit or shared tracks.
MartinsX
Riga, Latvia
C?ID=268515
I have couple customers driving 1,6 and 2l CR TDI engines, that have got EGR related fault codes only once. After clearing codes all EGR tests were successful and fault never comes back. Why fault was registered, that only one time - I don't know.
From my experience EGR modules for those engines start to fail constantly at mileages 200-250k km. Then excentric mechanism mowing valve stem is worn and it's time to replace EGR module.
Here is why Martin,
The rear OXS sensor becomes contaminated & at the flapper valve with carbon.
This sensor when disrupted can act sporadically and even more so here due to our shit fuels.
This sensor is what is used to determine whether or not the EGR readings are proper.....most often it reads a false positive of rich, so it opens the EGR longer and commences to pile up ash making them stick open eventually for cars driven short trip.
Then sometimes the OXS just needs to be taken out and cleaned with sodium hydroxide and rinsed with distilled water, further cleaned with a propane torch.
Cars which are driven with MIL on will require even more manual remediation of carbon and ash as problem progresses.
MartinsX
Riga, Latvia
C?ID=268515
Tnx, Jack! Nice explanation! ;)
