Hello from Iowa! First Scan - Fault Code P0113 - Assistance Please
tncrom
Iowa, USA
C?ID=296177
Hello, It was really cold here a couple of weeks ago and the car threw CEL with a flashing glow plug light. It's now a permanent fixture on the dash and the car has no power. Anyone that could help, guide me to the location of the suspect part or troubleshooting of the issue? THanks in advance. :)
2013 Passat TDI NMS
Chris
Wednesday,11,January,2017,20:29:26:09958
VCDS Version: 17.1.0.0  HEX-V2 CB: 0.4334.4
Data version: 20170106 DS267.0
VIN: 1VWBN7A37DC147817   License Plate:
Mileage: 132780km-82505mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A37DC147817   Mileage: 132780km-82505miles
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 DD    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H24 8400
   Revision: 71H24---    Serial number:
   Coding: 00190012042400000000
   Shop #: WSC 02394 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906012DD 004008
   ROD: EV_ECM20TDI01103L906012DD.rod
   VCID: 698CB72F49FB8C2F981-803C
5282 - Intake Air Temp. Sensor (G42)
          P0113 00 [175] - Signal too High
                    Mileage: 132779 km
                    Date: 2017.01.06
                    Time: 16:51:18
                    Engine speed: 832.00 /min
                    Normed load value: 49.4 %
                    Coolant temperature: 44 °C
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 14.680 V
                    Exhaust gas temperature sensor 4: 91.8 °C
                    Specified value of low pressure exhaust flap: 100.00 %
                    Actual value of low pressure exhaust flap: 99.99 %
                    Low-pressure exhaust flap: offset closed: 0.78 %
                    Low-pressure exhaust flap: status-Bit 0: 0
                    Low-pressure exhaust flap: status-Bit 16: 8
                    Low-pressure exhaust flap: status-Bit 24: 55
                    Low-pressure exhaust flap: status-Bit 8: 66
                    Exhaust flap: actual value: 4299.8 mV
Readiness: 1 1 0 1 1
   Revision: 00H31001
   Coding: C54BC0F549260001A31303E592200042A71000
   Shop #: WSC 09003 957 00200
   VCID: 7DA4F37F2DF3008F449-8028
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 561 907 426 C    HW: 561 907 426 C
   Component: AC Manuell    H02 0202
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1B60DDE7D327AEBFDAD-804E
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0068
   Revision: BH021001
   Coding: 6F200E18902B08D408880001160004480071008650801560648060000C70
   VCID: 43D045870B97B67F72D-8016
                    Reset counter: 43
                    Mileage: 132780 km
                    Date: 2017.01.06
                    Time: 17:05:00
                    Voltage: 14.20 V
03189 - Bulb for Side Marker Light; Front Right
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 3
                    Mileage: 91225 km
                    Date: 2015.12.16
                    Time: 11:23:38
                    Voltage: 14.20 V
   Serial number: 003MWM01ULFH
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B4EB5F154358CF0C9-8020
   Serial number: 6940000Y130000U5SU0L
   Coding: 303044
   Serial number: 3572MSME0C161474ZZZS
   Serial number: 3582MSME4B43037BZZZ.
   Serial number: 3516KSME0F695E23ZZZ0
   Serial number: 3526KSME46352B23ZZZQ
   Serial number: 3556LSME090A6B21ZZZX
   Serial number: 3566LSME13087321ZZZK
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20130411300345
   Coding: 008A140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 76B6EC53084553D7053-8022
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   VCID: 1C62DEFBD629A987D37-8048
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 17051303290876
   Coding: 461000
   VCID: 76B6EC5308C553D7053-8022
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R4FM006
   Coding: 0000002
   VCID: 6390A507A757D67F52D-8036
   Component: IMMO          H07 0705
   VCID: 6A8EC8234CFD873791B-803E
   Revision: 13110009    Serial number: 0006668691
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE09DE793A7EEBF1AD-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630130520151514
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 37282157434FEADFDE5-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 00000008
   VCID: 6FB8D937779F621FC65-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Revision: 15110009    Serial number: 0006672956
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE29EFB96A9E987137-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130513083014
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 17
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3464462
   Coding: 0500040004000B
   VCID: 6492A61BAE59D147AB7-8030
            000 -  -
                    Reset counter: 61
                    Mileage: 58070 km
                    Date: 2015.03.16
                    Time: 07:09:44
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664540338
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2E38637CDDF7B721B-806E
End----------(Elapsed Time: 00:54, VBatt start/end: 11.6V/11.9V)-----------
                    Mileage: 132779 km
                    Date: 2017.01.06
                    Time: 16:51:18
   Revision: 00H31001
   Revision: 00001K01
   Coding: 0010001002
   Revision: BH021001
                    Reset counter: 43
                    Mileage: 132780 km
                    Date: 2017.01.06
                    Time: 17:05:00
                    Voltage: 14.20 V
                    Reset counter: 3
                    Mileage: 91225 km
                    Date: 2015.12.16
                    Time: 11:23:38
                    Voltage: 14.20 V
   Coding: 00005033
   Coding: 303044
   Coding: 008A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 0000002
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 00000008
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 17
            000 -  -
                    Reset counter: 61
                    Mileage: 58070 km
                    Date: 2015.03.16
                    Time: 07:09:44
End----------(Elapsed Time: 00:53, VBatt start/end: 14.5V/14.6V)-----------
                    Mileage: 132779 km
                    Date: 2017.01.06
                    Time: 16:51:18
   Revision: 00H31001
   Revision: 00001K01
   Coding: 0010001002
   Revision: BH021001
                    Reset counter: 43
                    Mileage: 132780 km
                    Date: 2017.01.06
                    Time: 17:05:00
                    Voltage: 14.20 V
                    Reset counter: 3
                    Mileage: 91225 km
                    Date: 2015.12.16
                    Time: 11:23:38
                    Voltage: 14.20 V
   Coding: 00005033
   Coding: 303044
   Coding: 008A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 0000002
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 00000008
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
                    Reset counter: 17
            000 -  -
                    Reset counter: 61
                    Mileage: 58070 km
                    Date: 2015.03.16
                    Time: 07:09:44
End----------(Elapsed Time: 00:52, VBatt start/end: 14.6V/14.6V)-----------
VCDS Release 17.1.0:  SRI Reset
Control Module Part Number: 561 920 970 E       Labels:  5K0-920-xxx-17.clb
Component:KOMBI         H07 0705, Coding:231E01
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Status                                                     Reset                                                           ---
IDE00510-ESI: distance driven from inspection                                                           ESI: distance driven from inspection                            3900 km                                                         ---
IDE00511-ESI: time from inspection        ESI: time from inspection                                       56 d                                                            ---
IDE00515-ESI: oil quality        ESI: oil quality                                                poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: soot entry                                                 0 km                                                            ---
IDE00518-ESI: thermal load        ESI: thermal load                                               0 km                                                            ---
IDE01153-SIA: maximum value of distance to service                                                      SIA: maximum value of distance to service                       16100 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA: maximum value of time to service                           372 d                                                           ---
        FIX: Max. distance until next mileage-related inspection        ---                                                             ---
        FIX: Maximum time until next time-dependent inspection          ---                                                             ---
        FIX: Distance covered since last mileage-dependent inspection    ---                                                             ---
        FIX: Time since last time-dependent inspection                  ---                                                             ---
          P0113 00 [167] - Signal too High
                    Mileage: 132782 km
                    Date: 2017.01.11
                    Time: 20:38:30
                    Engine speed: 845.00 /min
                    Normed load value: 47.5 %
                    Coolant temperature: 36 °C
                    Exhaust gas temperature sensor 4: 85.7 °C
                    Low-pressure exhaust flap: offset closed: 0.85 %
Readiness: 0 0 0 1 1
   Revision: 00H31001
   Revision: 00001K01
   Coding: 0010001002
   Revision: BH021001
                    Reset counter: 3
                    Mileage: 132782 km
                    Date: 2017.01.11
                    Time: 20:38:52
                    Voltage: 12.95 V
   Coding: 00005033
   Coding: 303044
   Coding: 008A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 0000002
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 00000008
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
            000 -  -
                    Reset counter: 3
                    Mileage: 132782 km
                    Date: 2017.01.11
                    Time: 20:38:51
End----------(Elapsed Time: 00:53, VBatt start/end: 12.9V/12.4V)-----------
From the Freeze-Frame data... " Intake air temperature: -40 °C".. That's usually indicative of an open circuit to that sensor. Check wiring, check resistance of sensor.
tncrom
Iowa, USA
C?ID=296177
Thanks Uwe. I had wondered about that -40C reading also. Might you know where the G42 sensor is located? Or anyone else might know? Thanks again. Chris
Hi Chris,
A 1 day subscription to NAR erWin might be worthwhile if you have wiring issues. Those links are available here: http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Side note, that IAT -40 °C reading looks like an open or short rather than a faulty sensor. I'm guessing open ckt is -40 and shorted is +140 (or +50).
According to diagram # 5/10 (diagram 5, page 10) GX9 - Intake manifold sensor includes both G31 - Charge air pressure sensor -and- G42 - Intake air temperature sensor so you are looking for a 4 wire component. It should be in the air duct/pipe south of the throttle body, very close to cooling fans and the rad support in the front of the car.
If all looks well there the diagram shows a T10g (10-pin connector) in between the yellow G42 signal wire and the EDC. I think that's a black D shaped on the driver's frame rail, behind the driver side headlight.
Vehicle Identification No. 1VWBN7A37DC147817
Model new passat
PA
Date of production 12.06.2013
Year 2013
Sales type A32372
Engine Code CKRA
Transmission Code NGB
tncrom
Iowa, USA
C?ID=296177
Thanks so much Dana. I'll give an update once I have one.
tncrom
Iowa, USA
C?ID=296177
Hi,...
Took the G42 and G31 Combo sensor out of the car today, and ohm'd out the pins. Pin #2 was open line to the other three pins. I'm thinking this may indicate the o/l causing the -40C reading. I have a part on the way, and will provide another update once it's installed. Thanks again -- I'm encouraged this may be the culprit.
Chris
tncrom
Iowa, USA
C?ID=296177
Mein Auto lebt noch!
I replaced the sensor and have no codes. Took a quick test drive and drove beautifully again. Thanks Dana and Uwe!
Chris
