Hello, I am trying to set some lane assist coding and adaptations with my VCDS 16.8.4 and USB HEX CAN.
I am having trouble setting
44 - Steering Assistance
Heading Control Assistant>Active | Byte 2>Bit 7
I get "Error 31 - Request out of range"
Also, for adaptations, many don't return a value at all in the following:
A5 - Frt Sens. Drv. Assist
BAP Personalization = Set Value to “Not Activated”
Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting”
System mode, lane depart. warn, = Set Value to “Selection via menu”
Switch-on condition, lane depart. warn. = Set value to “On”
Here's a recent autoscan:
Thursday,22,December,2016,16:55:25:11002
VCDS Version: 16.8.4.2 (x64)
VIN: WA1LAAF75HD031084 License Plate:
Chassis Type F7 (8W6)
Scan: 01 02 03 06 08 09 15 16 17 19 36 3C 42 44 52 5F 6C 6D 81 A5
BB BC
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 4M0 907 551 A HW: 06E 907 425
Component: 3.0l V6 TFSI H10 0003
Revision: --H10---
Coding: 2A2A00320526010D74280000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TFS0214M0907551A 001005
ROD: EV_ECM30TFS0214M0907551A.rod
VCID: 2D5A99967C3BC42A52-8078
Readiness: 0000 0100
Address 02: Auto Trans Labels: 0BK-927-156.clb
Part No SW: 4M0 927 158 L HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H03 1006
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 3D7AA9D6AC5B54AAE2-8068
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Coding: 28AA149C30A50A97919E589900815292E6269A14280C50891A004A49676459
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K_AU73.rod
VCID: 458AC136C48B1C6ABA-8010
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-BFS 008 0031
Serial number: 00000219028079
Coding: 001410000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
VCID: 76E876FAC9EDC7F2E3-8022
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 4M0 820 043 R HW: 4M0 820 043 R
Component: Klima Zone 3 H52 0093
Coding: 6608090C5148000D10200280000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 346C8CF29F1195E21D-8060
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001056027
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0005
Serial number: 5688884800PAG0FSA002
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: Klima Heck H40 0073
524289 - Rear Left Seat Heater
B1117 01 [024] - Electrical Failure
Reset counter: 56
Mileage: 105 km
Date: 2016.12.03
Time: 12:45:10
Voltage terminal 30: 12.16 V
Outside air temperature: 9.50 °C
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07500363E0081CCD410D871458AE9CB911033D01900000000000000020001A0108690122025709
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 02001A2A9525EB52DF-8056
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C
Component: WWS536 160728 043 0893
Serial number: 89555300401621000676
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62260016
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 28 06 2016 00467354
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z1T2002
Coding: 350000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20160901093259 00252
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE113061612010736
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 4M0 947 135 CP HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00192820
Electrically Adjustable Steering Column:
Subsystem 8 - Part No SW: 4M0 907 705 A HW: 4M0 907 705 A
Component: J866-EVLS-SG H03 0080
Serial number: WA125166000024851175
Coding: 020100
Subsystem 9 - Part No SW: 4M0 925 301 A HW: 4M0 925 301 A
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000073451
Address 15: Airbags (J234) Labels: None
Part No SW: 4M0 959 655 A HW: 4M0 959 655 A
Component: Airbag10.44 H71 0086
Serial number: 003M500122XP
Coding: AECCFCC000800000A0F00033C24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_AU73.rod
VCID: 3972BDC6B873688ACE-806C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705E0263Q00264
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706E0260Q00762
Coding: 88001B
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J160005Q9OE0L
Subsystem 4 - Part No SW: ----------- HW: 442 060 709 16
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00AD1FB75D2337H
Subsystem 5 - Part No SW: ----------- HW: 442 060 709 16
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00B91FB75D2A43J
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 006 16
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A3211FA269264
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 706 16
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700A920A0003342O
Subsystem 8 - Part No SW: ----------- HW: 442 0C3 108 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500992172482A1C6
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C3 108 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500992172483A195
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 410 201 708 16
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800B12042361F24M
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GM HW: 4M0 907 129 GM
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 010215269023F04AC6-8054
Address 17: Instruments (J285) Labels: None
Part No SW: 4M0 920 890 B HW: 4M0 920 890 B
Component: FBenUSA H15 0302
Coding: 08E600C12888CF05022369601800000008000000
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736.rod
VCID: 2F66839E7637B63A60-807A
Part No SW: 8W6 907 468 C HW: 8W6 907 468 C
Component: Gateway H27 1298
Revision: 4P060005 Serial number: 0584P273016917
Coding: 0301000100000E4054070000005900304C120007000000000175078E00000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491.rod
VCID: 4A90F20AED95F31257-801E
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20160912141934 00943
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7163711404
8519683 - Energy Management Active
U140B 00 [008] - -
Fault Frequency: 86
Reset counter: 54
Mileage: 93 km
Date: 2016.11.19
Time: 13:08:53
EM_vehicle_state: 00 00
Static current shutdown level: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Component: MEM-FS 008 0031
Serial number: 00000219260707
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
Address 3C: Lane Change (J769) Labels: None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
Part No SW: 4M0 959 793 G HW: 4M0 959 793 C
Component: TSG FS 009 0052
Serial number: 0000218303542
Coding: 001F9B005E001080000120B0
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 4280DA2AD5A52B529F-8016
196660 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 73
Mileage: 436 km
Date: 2016.12.29
Time: 10:19:15
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4M0 909 144 G HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0004
Serial number: 0000067956
Coding: 90000001000100
ASAM Dataset: EV_EPSVWBSAU736 008020
ROD: EV_EPSVWBSAU736_008_AU49.rod
VCID: 336E8FEE9A1F92DA04-8066
Part No SW: 4M0 959 792 G HW: 4M0 959 792 C
Component: TSG BFS 009 0052
Serial number: 0000218331376
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 4182D526D0A3304A86-8014
Part No SW: 4M0 035 880 B HW: 4M0 035 880
Component: MU-P-LNS-US 052 0692
Serial number: A289I0G7519522
Coding: 01370602FF0A000053220001041A00102F001BE501700904FE
VCID: 2B5E978E422FCA1A4C-807E
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9GJ402WZ3
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 15091600000000000395
Component: Gracenote2--- --- 3009
7223 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 76
Mileage: 507 km
Date: 2016.12.29
Time: 14:15:07
Voltage terminal 30: 14.9 V
BAP-BAP_Function_ID: 15
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG003310
Coding: 02350602BA0FA10008404004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 30937146100000
Coding: 0030
VCID: 4894C802F399010241-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20160913002822
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2854688253D9E102A1-807C
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H14 0042
Coding: 0407030600000201022023A2A50000B400F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
1123671 - Fog mode active
C118E 00 [008] - -
Reset counter: 75
Mileage: 551 km
Date: 2016.12.29
Time: 16:52:39
Control Module temperature: 12 °C
Voltage terminal 15: 14.70 V
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 4M0 959 795 G HW: 4M0 959 795 C
Component: TSG HFS 009 0052
Serial number: 0000217733975
Coding: 000F9B0000001080400020A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 448CDC32CFB12562AD-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 009 0052
Serial number: 0000217734425
ROD: EV_DCU2RearPasseMAXHCONT.rod
End-------------------------(Elapsed Time: 04:54)--------------------------
