Wednesday,19,October,2016,18:42:29:39394
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
VIN: 3VWC17AU2GM517860 License Plate:
Mileage: 7147km-4440mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75
VIN: 3VWC17AU2GM517860 Mileage: 7147km-4440miles
Address 01: Engine (J623-CXBB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3F873DEFA6E45EBA85-806A
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
ROD: EV_TCMAQ250031_VW31.rod
VCID: 0717E50FBEB4D67AFD-8052
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 53345000000435
Coding: 04FA6AA124210973007F020681C3292056249000408194B400400050C002
Shop #: WSC 01383 790 50316
VCID: 4B9F193FE25CF21A19-801E
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 235
Mileage: 6800 km
Date: 2016.10.13
Time: 11:12:08
Revision: 00021000 Serial number: 0381142691
Coding: 030C1C
VCID: 3A714CFBBDC67B92B2-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020004100100000000000010000002
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 4689280BF93E0F72C6-8012
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Reset counter: 242
Mileage: 5027 km
Date: 2016.10.04
Time: 12:24:44
Voltage terminal 30: 12.9 V
Outside air temperature: 28.5 °C
Air distribution flap: actual value: 221
Air distribution flap: actual value: 72.0 %
Air distribution flap: specified value: 47
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86580111150438
Coding: 00511A464041A27969E44000001407001800000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 7AF18CFBFD46BB92F2-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150812 043 0581
Serial number: 160113075324
Coding: 1E4DFF
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M11D26H23M31S18
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000FDNT800000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000FDMS600000
Coding: 191800
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Reset counter: 242
Mileage: 6999 km
Date: 2016.10.16
Time: 08:41:00
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Fault Frequency: 30
Reset counter: 239
Mileage: 6638 km
Date: 2016.10.10
Time: 14:30:55
Serial number: 003GCR03MZUJ
VCID: 4797250FFE34167A3D-8012
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH00000000000439RNQ
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 002 110 15
Serial number: 35700000000814CCA61Q
Subsystem 3 - Part No SW: ----------- HW: 480 002 110 15
Serial number: 35800000000D1DCC371Z
Subsystem 4 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3510002AB1D3F97290EJ
Subsystem 5 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3520002B71CF1D22013.
Subsystem 6 - Part No SW: ----------- HW: 480 401 010 15
Serial number: 3550002A51CCEA02F0EO
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 010 15
Serial number: 3560002A51CCEA02F06H
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151021501479
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 040DF2038F82FD6298-8050
Part No SW: 5G1 920 840 A HW: 5G1 920 840 A
Component: KOMBI 242 6420
Coding: 03A5111AA980CF0502087E001000000000000000
VCID: 254B8F872478E46AEF-8070
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 25111510803678
Coding: 0901000830085900FB00000A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti_013.rod
VCID: 79F393F7F840B08AFB-802C
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
Component: E221__MFL-DC1 H16 0101
Serial number: 29150001545520065326
Coding: 31FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0111854
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000220563001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346D62C39FA28DE268-8060
Component: TSG FS 020 0041
Serial number: 02121506050ANJ
Coding: 003A13200000020000000000
VCID: 438F311FCA0C3A5AE1-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000002425948
Coding: 011000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 8102
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 448D3203CF023D62D8-8010
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA014RA5
VCID: 6DDBB7A7BC081C2A67-8038
Component: TSG BFS 020 0041
Serial number: 20111506050CZO
Coding: 003A13200C00020000000000
VCID: 4281341BD5163352EA-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000002251843
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 061A00000B000400
VCID: 40853E13DB1A2142FC-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 027302000000000051220002001808001F0106F4012001000B
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CDDBAA38712152270-8038
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES01133
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 146
Mileage: 4577 km
Date: 2016.09.23
Time: 15:26:27
Voltage terminal 30: 13.5 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
B11CF 53 [009] - Deactivated
Reset counter: 146
Mileage: 4577 km
Date: 2016.09.23
Time: 15:27:05
Voltage terminal 30: 13.6 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Not available
SDARS_tuner_status_2-Antenna current: 131 mA
SDARS_tuner_status_2-Reception quality: weak_signal
SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 05
SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 05
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Component: OCULowMQBUS 007 0568
Coding: 02730202C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 04:19)--------------------------
