Hello everyone,
Sorry for asking for help again so soon.
Car is a 2006 A6 with the 3.2FSI, completely stock.
Over the course of the spring I did a lot of very short-distance driving, until one day it started shaking during idle, stalling on hills, etc.
Everything involved in this has seemed very strange:
-Upon cold start, it runs like a clock. No misfires, sounds great, idles @ 1200-1400ish, drops back down to 800-850ish and continues running smoothly.
-Lambda reads rich in VCDS, and gas smell is obvious outside of the car.
-As the engine begins to warm up, the car starts to almost "stutter" a little bit, and you can feel it in the seats. Start getting a slow, somewhat consistent misfire in cylinder 4, sometimes 5.
-Once car is warm, misfires get worse than ever, and are primarily focused on cylinder 6 with the least amount on 4.
-Car seems to mostly smooth out as revs climb. You can't feel the misfires nearly as much, but VCDS still notices some.
-Misfires get worse and RPM drops when I turn the A/C on to max
-Misfires get significantly worse and car goes into limp mode when put in reverse
-The left exhaust pipe seems to give a smooth, cool, consistent "put-put-put" kind of exhaust, while the right exhaust pipe is hot, has almost no flow, and the "put-put" part is not so well defined.
Scan shows no fault codes related to O2 sensors or fuel trim or anything, however the measuring blocks show very unsettling values. Screenshots at the bottom.
Additionally, I am aware the scan shows the P0346 code, however I believe that to be a separate issue, as it has been there for just over a year (since I had the timing done).
And here are a couple of screenshots: http://imgur.com/a/C4bM5
What I've tried so far:
-Rotated coil packs (Bank 1 -> Bank 2). No Difference.
-Rotated spark plugs (Bank 1 -> Bank 2). Engine ran significantly worse. Almost wouldn't run at all. Replaced spark plugs, and idle is now smoother, however the problems still slowly creep back as described above.
If anyone has any advice on things to try, measuring blocks to check, really just anything, it would be very much appreciated.
Thanks!
Friday,23,September,2016,17:27:22:42751
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WAUDH74FX6N****** License Plate: 09/23
Mileage: 220530km-137030mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 72 77
VIN: WAUDH74FX6N161417 Mileage: 220530km-137030miles
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 06906 444 53830
VCID: 2B555CC28AA3CF1A2B-807E
P1653 - 008 -
Fault Status: 01101000
Mileage: 220537 km
Date: 2005.09.22
Time: 09:11:20
RPM: 2240 /min
Mass Air / Rev.: 305.2 mg/str
Temperature: 12.0°C
Overrun
Load: 37.3 %
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - MIL ON
Fault Status: 11100001
Mileage: 220537 km
Date: 2005.09.22
Time: 09:11:26
RPM: 1856 /min
Mass Air / Rev.: 310.7 mg/str
Temperature: 12.0°C
Part Throttle
Bin. Bits: 00010000
000772 - Cylinder 4
P0304 - 007 - Misfire Detected - MIL ON
Fault Status: 10100010
Mileage: 220537 km
Date: 2005.09.22
Time: 09:12:14
RPM: 832 /min
Mass Air / Rev.: 299.8 mg/str
Temperature: 24.0°C
Idle
Time: 51.2 s
000774 - Cylinder 6
P0306 - 007 - Misfire Detected - MIL ON
Mileage: 220537 km
Date: 2005.09.22
Time: 09:12:14
RPM: 832 /min
Temperature: 24.0°C
Idle
Time: 51.2 s
000773 - Cylinder 5
P0305 - 007 - Misfire Detected - MIL ON
Mileage: 220537 km
Date: 2005.09.22
Time: 09:12:14
RPM: 832 /min
Temperature: 24.0°C
Idle
Time: 51.2 s
P0300 - 006 - - MIL ON
Fault Status: 10100001
Mileage: 220537 km
Date: 2005.09.22
Time: 09:12:14
RPM: 832 /min
Temperature: 24.0°C
Idle
Time: 51.2 s
Readiness: 0110 0101
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 4153468
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 2643ADF69141F272F4-8072
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H05 0090
Coding: 0020895
VCID: 2D5152DAB4B7C12A35-8078
Reset counter: 18
Mileage: 220537 km
Date: 2005.09.20
Time: 12:00:13
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x00FF
Fault Status: 00101101
Reset counter: 58
Mileage: 220537 km
Date: 2005.09.20
Time: 12:08:16
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0025
Hex Value: 0x01AC
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000375346
Coding: 0000011
Shop #: WSC 91429 999 105108
VCID: 63C5F4E2A2F3475AD3-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303CL067517950
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 2149BEEAF86F154A81-8074
Component: Bedienteil MMIC6H09 0060
Subsystem 2 - Serial number: 00000001307885
Subsystem 3 - Serial number: 0105.05.090000000100010763ÿ
Subsystem 4 - Serial number: 010763ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0170
Revision: 00000030 Serial number: 00000030102936
Coding: 0524326
VCID: 5BB5CC029A837F9A9B-800E
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Coding: 0014123
VCID: 2A5B59C68559D612D0-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
01498 - Bulb for Parking Lamps; Right (M3)
Reset counter: 18
Mileage: 220536 km
Date: 2005.09.23
Time: 15:35:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7269746
VCID: 1B358C02DA033F9A5B-804E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F3017804
VCID: 285FA3CE9B55E402C6-807C
Reset counter: 18
Mileage: 220537 km
Date: 2005.09.20
Time: 12:06:53
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0B4GCU
Coding: 0013878
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0D16203A$
Subsystem 3 - Serial number: 6342CSME100D370B/
Subsystem 4 - Serial number: 6352QSME0B56367DS
Subsystem 5 - Serial number: 6362QSME0B661A0DP
Subsystem 6 - Serial number: 63734SME0B370843.
Subsystem 7 - Serial number: 63834SME09593265+
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H02000 Serial number: 90054060490265
Coding: 0002241
Shop #: WSC 02323 785 00200
VCID: 275DA0F2964BEB7ACF-8072
Component: E0221 H07 0090
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H17 0660
Revision: 00200000 Serial number: 4PY16LN26
Coding: 2129263
Shop #: WSC 91416 999 100822
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008062258164
Coding: 6CFE73CD1B3904
Shop #: WSC 08165 444 53974
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
Shop #: WSC 02334 785 00200
VCID: 61C9FEEAB8EF554AC1-8034
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355BW067562766
VCID: 387F738E4BF5748256-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: 8@
Coding: 0035563
Shop #: WSC 02327 785 00200
VCID: 2C575FDE8FADC82222-8078
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01011224540000
Coding: 4618301
VCID: 2E5355D6B9B1BA320C-807A
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 18
Mileage: 220537 km
Date: 2005.09.23
Time: 15:36:13
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000205993
Coding: 0000016
VCID: 1C378F1EDF0D38A252-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000018539
Coding: 0002114
VCID: 5EB3C51689916AB2FC-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: 9
Coding: 0035563
Part No SW: 4F0 910 801 A HW: 4F0 907 801
Component: EPB CA3C0040 H03 0040
Revision: --H03---
Coding: 0005022
Shop #: WSC 02324 785 00200
VCID: 1E338516C9112AB2BC-804A
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394B/067637867
Coding: 0000002
VCID: 2345B4E2E273075A93-8076
Reset counter: 56
Mileage: 220538 km
Date: 2016.08.31
Time: 17:16:11
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000032973
Shop #: WSC 08148 444 84013
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1602150136
Coding: 344630393135313035432056413031363032313530313336
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0035370
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700018469
Coding: 0062221
VCID: 224BB1E6FD690E5298-8076
Fault Status: 11100100
Fault Frequency: 56
Reset counter: 240
Mileage: 213002 km
Date: 2015.09.28
Time: 18:18:28
(no units): 40.0
Voltage: 13.80 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Fault Frequency: 253
Mileage: 220022 km
Date: 2016.05.08
Time: 20:01:49
(no units): 63.0
Temperature: 11.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007530884
Coding: 0010970
End-------------------------(Elapsed Time: 02:39)--------------------------
Thanks!
