Errors after installing aftermarket head lights into polo 6c
dean001
Australia
C?ID=277309
Been trialing a few different products on a new Polo 6C. i have installed a set of aftermarket headlights and found that there not like they said and throw a few codes, due to the modules being so new I am really struggling at removing the first 4 errors. Would anyone be able to assist?
Apologies in advance if i have not provided the right info. I also have a photo of the lights.
Saturday,20,August,2016,11:47:16:48703
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWZZZ6RZGY018111   License Plate: VU00D02
Mileage: 11814km-7340mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 02 03 08 09 14 15 17 19 44 5F A9
VIN: WVWZZZ6RZGY018111   Mileage: 11814km-7340miles
Address 01: Engine (J623-DAJB)       Labels: 06K-907-425-V1.clb
   Part No SW: 6C0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500122424010B0000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM18TFS0206C0906264 001004
   ROD: EV_ECM18TFS0206C0906264.rod
   VCID: 64C7D9676FE5806224-8030
   Part No SW: 0CW 300 049 A    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0610
   Revision: 00005005    Serial number: CU501505047324
   ROD: EV_TCMDQ200021.rod
   VCID: 3B75421BB2DB9F9AB5-806E
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08500425150527
   Coding: 24DD68858B2433C80915306A00522416D1CC900C0012E7098700
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 377D5E2B8EF3BBFA51-8062
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
   Component: Climatronic   H02 0201
   Serial number:  1505133A-0218
   Coding: 200020011001000001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_VW26.rod
   VCID: 224B9F7F3571CE5296-8076
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0084
   Serial number: 001378048977
   Coding: 0300184042530AFB0FA44080B127039810005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_VW26.rod
   VCID: 306F65376B9D6CC210-8064
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S3Y15M05D29H05M18S39
   Coding: 9038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU023031550822442
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU031031550900146
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY150822ZF2
   Serial number: 00000000000062248438
   Subsystem 7 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU021051551417723
   Coding: 1400A0
   Subsystem 8 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU022051551428938
   Coding: 0400A0
7 Faults Found:
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:17
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:18
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:17
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 59
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:28:17
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 59
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:28:17
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Fault Frequency: 58
                    Reset counter: 95
                    Mileage: 11552 km
                    Date: 2016.08.17
                    Time: 18:56:47
227080 - Turn Signal Switch
          B1144 29 [008] - Signal Implausible
                    Mileage: 7918 km
                    Date: 2016.06.18
                    Time: 16:17:52
Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
   Part No SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serial number: 23051502000151
   Coding: 80
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6ADBB75F8DC1D6121E-803E
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 G    HW: 6C0 959 655 G
   Component: VW20Airbag01M 001 0360
   Revision: --------    Serial number: 003RK0002U2+
   Coding: 88CCC000008000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   Subsystem 1 - Part No SW: -----------    HW: 410 823 105 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A91ABF950F32+
   Subsystem 2 - Part No SW: -----------    HW: 410 820 206 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00BD1AB1331231C
   Subsystem 3 - Part No SW: -----------    HW: 442 150 106 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A000629352E5F56C
   Subsystem 4 - Part No SW: -----------    HW: 442 150 106 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A000629352E7C5DJ
   Part No SW: 6C0 920 746 A    HW: 6C0 920 746 A
   Component: KOMBI         201 1420
   Coding: 272D09083180000800082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
   VCID: 2643836F59593272FA-8072
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0084
   Revision: --------    Serial number: 001378048977
   Coding: 030100046F00590071000028980000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65C1C46364DFF96A33-8030
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H03 0102
   Serial number: 27150000993810095195
   Coding: 31FFFF
   Subsystem 2 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 52133812484351087672
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Fault Frequency: 140
                    Reset counter: 98
                    Mileage: 6628 km
                    Date: 2016.05.26
                    Time: 12:45:37
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CF5U0913
   Coding: 800700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_VW26.rod
   VCID: 6ED3BB4FB1293A3242-803A
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 824 A    HW: 3Q0 035 824 A
   Component: MU-S--ER      H24 0240
   Serial number: VWZAZ2R0188290
   Coding: 02620000BE00000051510001000828001F0203D60120010003
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2B55725B42BB0F1A25-807E
   Subsystem 1 - Part No SW: 6C0 919 603 B    HW: 6C0 919 603 B
   Component: ABTm_Std2  H52 1028
   Serial number: VWZ8Z9REW00091
   Part No SW: 6C0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 150424201341
   VCID: 2959885348471D0AD7-807C
End-------------------------(Elapsed Time: 02:53)--------------------------
Dean: G'day cobber!! I'm not an expert on the Polo 6C, but I suspect the problem lies in the compatibility of the new fittings with the "Leuchte" channel settings in your car. If you have already made changes to these channels, can you post-up the information in the AdpLog.csv file - please. The file lives in the Ross-Tech/VCDS/Debug subdirectory on the computer that you used to make the changes. If you used the Beta software version to make the changes, then the directory path will be Ross-Tech/VCDS-Beta/Debug.
In the later versions of VCDS software, the nice folk at Ross Tech have kindly reformatted this file into a pure CSV structure. Kudos to RT for this modification - makes it much easier to parse into higher level applications like MS Excel/Access!!
If you haven't made changes to any adaptation channels, then I suspect that these will be necessary to tell the BCM in your car that some (all?) old incandescent lamps are now LEDs (and perhaps to reset the "Dimmwert" settings to values more appropriate to LED based fittings). Have you made an adaptation channel map of the BCM yet? If so, can you post it - please?
dean001
Australia
C?ID=277309
Hi Don,
No changes have been made yet to any adaptions. Here is the list of adaptions below.
;SW:6C0-937-089-C   HW:6C0-937-089 ---  Cent. Elect.
;Component:BCM PQ26 Hi4R H08 0084	 Coding:03001A4042530AFB0FA44080B127039810005B0257010000000000000000
;EV_BCMA0	5005
;Sunday	21
;VCDS Version: Release 16.8.0 (x64)  Data version: 20160803 DS255
;VCID: 306F65376B9D6CC210-8064
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG130235-Production mode-Entry_control	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1	not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition	keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	0 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart	kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	active
IDE02152-Characteristics in production mode	2000 ms
IDE02200-Component protection showroom mode	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl	not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl	not active
IDE02332-Deactivate production mode	0
IDE02488-DWA Interior monitoring	100%
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on	not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.50 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	180 °
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	120 °
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger	combined
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken	not active
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen	5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker	SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2	not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung	not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung	Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor	0.10%
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert	3.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht	active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren	not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	255 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	manual
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	72
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert	active
IDE04926-ENG126570-Comfort illumination-lho_zeit	10 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung	35.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung	35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung	0.0 s
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	time value
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	immidiat_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	not active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	not active
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0	34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1	3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10	0
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11	0
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12	0
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13	0
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14	0
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15	0
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16	0
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17	0
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18	0
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19	0
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2	35
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20	0
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21	0
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22	0
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23	0
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24	0
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25	0
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26	0
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27	0
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28	FF
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29	FA
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3	3F
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30	0
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31	0
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32	0
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33	0
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34	FF
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4	3A
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5	44
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6	36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7	40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8	0
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9	30
IDE05145-ENG115018-Light configuration-Dimming_AB_0	100
IDE05145-ENG115037-Light configuration-Dimming_AB_1	100
IDE05145-ENG114999-Light configuration-Dimming_AB_10	48
IDE05145-ENG115193-Light configuration-Dimming_AB_11	87
IDE05145-ENG115212-Light configuration-Dimming_AB_12	0
IDE05145-ENG114958-Light configuration-Dimming_AB_13	48
IDE05145-ENG115233-Light configuration-Dimming_AB_14	90
IDE05145-ENG115252-Light configuration-Dimming_AB_15	0
IDE05145-ENG115271-Light configuration-Dimming_AB_16	0
IDE05145-ENG115290-Light configuration-Dimming_AB_17	5
IDE05145-ENG115309-Light configuration-Dimming_AB_18	68
IDE05145-ENG115328-Light configuration-Dimming_AB_19	117
IDE05145-ENG115056-Light configuration-Dimming_AB_2	100
IDE05145-ENG115347-Light configuration-Dimming_AB_20	1
IDE05145-ENG115366-Light configuration-Dimming_AB_21	0
IDE05145-ENG115385-Light configuration-Dimming_AB_22	96
IDE05145-ENG115404-Light configuration-Dimming_AB_23	96
IDE05145-ENG115423-Light configuration-Dimming_AB_24	2
IDE05145-ENG115442-Light configuration-Dimming_AB_25	104
IDE05145-ENG115461-Light configuration-Dimming_AB_26	73
IDE05145-ENG115480-Light configuration-Dimming_AB_27	1
IDE05145-ENG115499-Light configuration-Dimming_AB_28	90
IDE05145-ENG115518-Light configuration-Dimming_AB_29	80
IDE05145-ENG115075-Light configuration-Dimming_AB_3	100
IDE05145-ENG115537-Light configuration-Dimming_AB_30	123
IDE05145-ENG115556-Light configuration-Dimming_AB_31	52
IDE05145-ENG115575-Light configuration-Dimming_AB_32	28
IDE05145-ENG115594-Light configuration-Dimming_AB_33	74
IDE05145-ENG115613-Light configuration-Dimming_AB_34	4
IDE05145-ENG115094-Light configuration-Dimming_AB_4	100
IDE05145-ENG114977-Light configuration-Dimming_AB_5	100
IDE05145-ENG115115-Light configuration-Dimming_AB_6	100
IDE05145-ENG115134-Light configuration-Dimming_AB_7	100
IDE05145-ENG115153-Light configuration-Dimming_AB_8	40
IDE05145-ENG115172-Light configuration-Dimming_AB_9	49
IDE05145-ENG115022-Light configuration-Dimming_CD_0	0
IDE05145-ENG115041-Light configuration-Dimming_CD_1	0
IDE05145-ENG115003-Light configuration-Dimming_CD_10	0
IDE05145-ENG115197-Light configuration-Dimming_CD_11	122
IDE05145-ENG115216-Light configuration-Dimming_CD_12	0
IDE05145-ENG114962-Light configuration-Dimming_CD_13	0
IDE05145-ENG115237-Light configuration-Dimming_CD_14	0
IDE05145-ENG115256-Light configuration-Dimming_CD_15	0
IDE05145-ENG115275-Light configuration-Dimming_CD_16	1
IDE05145-ENG115294-Light configuration-Dimming_CD_17	0
IDE05145-ENG115313-Light configuration-Dimming_CD_18	122
IDE05145-ENG115332-Light configuration-Dimming_CD_19	0
IDE05145-ENG115060-Light configuration-Dimming_CD_2	0
IDE05145-ENG115351-Light configuration-Dimming_CD_20	122
IDE05145-ENG115370-Light configuration-Dimming_CD_21	0
IDE05145-ENG115389-Light configuration-Dimming_CD_22	0
IDE05145-ENG115408-Light configuration-Dimming_CD_23	0
IDE05145-ENG115427-Light configuration-Dimming_CD_24	0
IDE05145-ENG115446-Light configuration-Dimming_CD_25	0
IDE05145-ENG115465-Light configuration-Dimming_CD_26	0
IDE05145-ENG115484-Light configuration-Dimming_CD_27	0
IDE05145-ENG115503-Light configuration-Dimming_CD_28	0
IDE05145-ENG115522-Light configuration-Dimming_CD_29	0
IDE05145-ENG115079-Light configuration-Dimming_CD_3	0
IDE05145-ENG115541-Light configuration-Dimming_CD_30	0
IDE05145-ENG115560-Light configuration-Dimming_CD_31	0
IDE05145-ENG115579-Light configuration-Dimming_CD_32	0
IDE05145-ENG115598-Light configuration-Dimming_CD_33	0
IDE05145-ENG115617-Light configuration-Dimming_CD_34	0
IDE05145-ENG115098-Light configuration-Dimming_CD_4	0
IDE05145-ENG114981-Light configuration-Dimming_CD_5	0
IDE05145-ENG115119-Light configuration-Dimming_CD_6	0
IDE05145-ENG115138-Light configuration-Dimming_CD_7	0
IDE05145-ENG115157-Light configuration-Dimming_CD_8	0
IDE05145-ENG115176-Light configuration-Dimming_CD_9	0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0	maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1	maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10	maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11	minimize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12	maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13	maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14	maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15	maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16	maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17	maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18	minimize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19	maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2	maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20	minimize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21	maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22	maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23	maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24	maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25	maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26	maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27	maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28	maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29	maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3	maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30	maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31	maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32	maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33	maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34	maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4	minimize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5	minimize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6	maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7	maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8	maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9	maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0	maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1	maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10	maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11	maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12	minimize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13	maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14	maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15	maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16	maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17	maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18	minimize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19	maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2	maximize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20	maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21	maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22	maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23	maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24	minimize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25	maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26	minimize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27	maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28	minimize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29	maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3	maximize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30	maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31	minimize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32	maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33	maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34	maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4	maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5	maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6	maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7	maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8	maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9	maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0	maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1	maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10	maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11	maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12	maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13	minimize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14	minimize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15	maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16	maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17	maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18	maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19	maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2	maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20	maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21	maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22	maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23	maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24	maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25	maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26	maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27	minimize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28	maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29	maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3	maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30	maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31	maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32	maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33	maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34	maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4	maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5	maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6	maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7	maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8	maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9	maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0	0
IDE05145-ENG115045-Light configuration-Dimming_EF_1	0
IDE05145-ENG115007-Light configuration-Dimming_EF_10	0
IDE05145-ENG115201-Light configuration-Dimming_EF_11	0
IDE05145-ENG115220-Light configuration-Dimming_EF_12	113
IDE05145-ENG114966-Light configuration-Dimming_EF_13	0
IDE05145-ENG115241-Light configuration-Dimming_EF_14	96
IDE05145-ENG115260-Light configuration-Dimming_EF_15	48
IDE05145-ENG115279-Light configuration-Dimming_EF_16	0
IDE05145-ENG115298-Light configuration-Dimming_EF_17	0
IDE05145-ENG115317-Light configuration-Dimming_EF_18	49
IDE05145-ENG115336-Light configuration-Dimming_EF_19	86
IDE05145-ENG115064-Light configuration-Dimming_EF_2	0
IDE05145-ENG115355-Light configuration-Dimming_EF_20	1
IDE05145-ENG115374-Light configuration-Dimming_EF_21	0
IDE05145-ENG115393-Light configuration-Dimming_EF_22	16
IDE05145-ENG115412-Light configuration-Dimming_EF_23	86
IDE05145-ENG115431-Light configuration-Dimming_EF_24	82
IDE05145-ENG115450-Light configuration-Dimming_EF_25	1
IDE05145-ENG115469-Light configuration-Dimming_EF_26	126
IDE05145-ENG115488-Light configuration-Dimming_EF_27	112
IDE05145-ENG115507-Light configuration-Dimming_EF_28	64
IDE05145-ENG115526-Light configuration-Dimming_EF_29	123
IDE05145-ENG115083-Light configuration-Dimming_EF_3	0
IDE05145-ENG115545-Light configuration-Dimming_EF_30	125
IDE05145-ENG115564-Light configuration-Dimming_EF_31	120
IDE05145-ENG115583-Light configuration-Dimming_EF_32	127
IDE05145-ENG115602-Light configuration-Dimming_EF_33	0
IDE05145-ENG115621-Light configuration-Dimming_EF_34	70
IDE05145-ENG115102-Light configuration-Dimming_EF_4	0
IDE05145-ENG114985-Light configuration-Dimming_EF_5	0
IDE05145-ENG115123-Light configuration-Dimming_EF_6	0
IDE05145-ENG115142-Light configuration-Dimming_EF_7	0
IDE05145-ENG115161-Light configuration-Dimming_EF_8	49
IDE05145-ENG115180-Light configuration-Dimming_EF_9	96
IDE05145-ENG115030-Light configuration-Dimming_GH_0	0
IDE05145-ENG115049-Light configuration-Dimming_GH_1	0
IDE05145-ENG115011-Light configuration-Dimming_GH_10	0
IDE05145-ENG115205-Light configuration-Dimming_GH_11	0
IDE05145-ENG115224-Light configuration-Dimming_GH_12	0
IDE05145-ENG114970-Light configuration-Dimming_GH_13	122
IDE05145-ENG115245-Light configuration-Dimming_GH_14	122
IDE05145-ENG115264-Light configuration-Dimming_GH_15	0
IDE05145-ENG115283-Light configuration-Dimming_GH_16	1
IDE05145-ENG115302-Light configuration-Dimming_GH_17	0
IDE05145-ENG115321-Light configuration-Dimming_GH_18	0
IDE05145-ENG115340-Light configuration-Dimming_GH_19	0
IDE05145-ENG115068-Light configuration-Dimming_GH_2	0
IDE05145-ENG115359-Light configuration-Dimming_GH_20	0
IDE05145-ENG115378-Light configuration-Dimming_GH_21	0
IDE05145-ENG115397-Light configuration-Dimming_GH_22	1
IDE05145-ENG115416-Light configuration-Dimming_GH_23	0
IDE05145-ENG115435-Light configuration-Dimming_GH_24	0
IDE05145-ENG115454-Light configuration-Dimming_GH_25	0
IDE05145-ENG115473-Light configuration-Dimming_GH_26	0
IDE05145-ENG115492-Light configuration-Dimming_GH_27	127
IDE05145-ENG115511-Light configuration-Dimming_GH_28	0
IDE05145-ENG115530-Light configuration-Dimming_GH_29	0
IDE05145-ENG115087-Light configuration-Dimming_GH_3	0
IDE05145-ENG115549-Light configuration-Dimming_GH_30	0
IDE05145-ENG115568-Light configuration-Dimming_GH_31	1
IDE05145-ENG115587-Light configuration-Dimming_GH_32	0
IDE05145-ENG115606-Light configuration-Dimming_GH_33	0
IDE05145-ENG115625-Light configuration-Dimming_GH_34	0
IDE05145-ENG115106-Light configuration-Dimming_GH_4	0
IDE05145-ENG114989-Light configuration-Dimming_GH_5	0
IDE05145-ENG115127-Light configuration-Dimming_GH_6	0
IDE05145-ENG115146-Light configuration-Dimming_GH_7	122
IDE05145-ENG115165-Light configuration-Dimming_GH_8	44
IDE05145-ENG115184-Light configuration-Dimming_GH_9	0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0	14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1	15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10	0
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11	0
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12	FA
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13	0
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14	0
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15	0
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16	0
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17	0
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18	FF
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19	0
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2	26
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20	0
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21	0
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22	0
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23	0
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24	0
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25	1
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26	FF
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27	0
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28	FA
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29	FA
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3	27
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30	0
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31	0
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32	0
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33	0
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34	0
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4	20
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5	21
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6	1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7	1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8	0
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9	36
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0	Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1	Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10	Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11	Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12	Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13	Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14	Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15	Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16	Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17	Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18	Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19	only_if_closed
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2	Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20	Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21	Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22	only_if_closed
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23	only_if_closed
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24	Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25	only_if_closed
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26	only_if_closed
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27	Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28	only_if_closed
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29	Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3	Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30	Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31	Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32	only_if_closed
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33	Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34	only_if_closed
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4	Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5	Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6	Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7	Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8	Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9	Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0	2
IDE05145-ENG115035-Light configuration-Light_Function_A_1	4
IDE05145-ENG114997-Light configuration-Light_Function_A_10	157
IDE05145-ENG115191-Light configuration-Light_Function_A_11	200
IDE05145-ENG115210-Light configuration-Light_Function_A_12	0
IDE05145-ENG114956-Light configuration-Light_Function_A_13	240
IDE05145-ENG115231-Light configuration-Light_Function_A_14	0
IDE05145-ENG115250-Light configuration-Light_Function_A_15	86
IDE05145-ENG115269-Light configuration-Light_Function_A_16	96
IDE05145-ENG115288-Light configuration-Light_Function_A_17	184
IDE05145-ENG115307-Light configuration-Light_Function_A_18	255
IDE05145-ENG115326-Light configuration-Light_Function_A_19	80
IDE05145-ENG115054-Light configuration-Light_Function_A_2	8
IDE05145-ENG115345-Light configuration-Light_Function_A_20	0
IDE05145-ENG115364-Light configuration-Light_Function_A_21	241
IDE05145-ENG115383-Light configuration-Light_Function_A_22	1
IDE05145-ENG115402-Light configuration-Light_Function_A_23	80
IDE05145-ENG115421-Light configuration-Light_Function_A_24	1
IDE05145-ENG115440-Light configuration-Light_Function_A_25	11
IDE05145-ENG115459-Light configuration-Light_Function_A_26	0
IDE05145-ENG115478-Light configuration-Light_Function_A_27	72
IDE05145-ENG115497-Light configuration-Light_Function_A_28	60
IDE05145-ENG115516-Light configuration-Light_Function_A_29	0
IDE05145-ENG115073-Light configuration-Light_Function_A_3	8
IDE05145-ENG115535-Light configuration-Light_Function_A_30	16
IDE05145-ENG115554-Light configuration-Light_Function_A_31	70
IDE05145-ENG115573-Light configuration-Light_Function_A_32	0
IDE05145-ENG115592-Light configuration-Light_Function_A_33	0
IDE05145-ENG115611-Light configuration-Light_Function_A_34	254
IDE05145-ENG115092-Light configuration-Light_Function_A_4	20
IDE05145-ENG114975-Light configuration-Light_Function_A_5	20
IDE05145-ENG115113-Light configuration-Light_Function_A_6	11
IDE05145-ENG115132-Light configuration-Light_Function_A_7	12
IDE05145-ENG115151-Light configuration-Light_Function_A_8	0
IDE05145-ENG115170-Light configuration-Light_Function_A_9	52
IDE05145-ENG115017-Light configuration-Light_Function_B_0	0
IDE05145-ENG115036-Light configuration-Light_Function_B_1	0
IDE05145-ENG114998-Light configuration-Light_Function_B_10	38
IDE05145-ENG115192-Light configuration-Light_Function_B_11	0
IDE05145-ENG115211-Light configuration-Light_Function_B_12	0
IDE05145-ENG114957-Light configuration-Light_Function_B_13	250
IDE05145-ENG115232-Light configuration-Light_Function_B_14	0
IDE05145-ENG115251-Light configuration-Light_Function_B_15	0
IDE05145-ENG115270-Light configuration-Light_Function_B_16	0
IDE05145-ENG115289-Light configuration-Light_Function_B_17	0
IDE05145-ENG115308-Light configuration-Light_Function_B_18	255
IDE05145-ENG115327-Light configuration-Light_Function_B_19	250
IDE05145-ENG115055-Light configuration-Light_Function_B_2	9
IDE05145-ENG115346-Light configuration-Light_Function_B_20	0
IDE05145-ENG115365-Light configuration-Light_Function_B_21	0
IDE05145-ENG115384-Light configuration-Light_Function_B_22	0
IDE05145-ENG115403-Light configuration-Light_Function_B_23	0
IDE05145-ENG115422-Light configuration-Light_Function_B_24	0
IDE05145-ENG115441-Light configuration-Light_Function_B_25	0
IDE05145-ENG115460-Light configuration-Light_Function_B_26	1
IDE05145-ENG115479-Light configuration-Light_Function_B_27	0
IDE05145-ENG115498-Light configuration-Light_Function_B_28	250
IDE05145-ENG115517-Light configuration-Light_Function_B_29	250
IDE05145-ENG115074-Light configuration-Light_Function_B_3	10
IDE05145-ENG115536-Light configuration-Light_Function_B_30	0
IDE05145-ENG115555-Light configuration-Light_Function_B_31	0
IDE05145-ENG115574-Light configuration-Light_Function_B_32	0
IDE05145-ENG115593-Light configuration-Light_Function_B_33	0
IDE05145-ENG115612-Light configuration-Light_Function_B_34	255
IDE05145-ENG115093-Light configuration-Light_Function_B_4	0
IDE05145-ENG114976-Light configuration-Light_Function_B_5	0
IDE05145-ENG115114-Light configuration-Light_Function_B_6	30
IDE05145-ENG115133-Light configuration-Light_Function_B_7	30
IDE05145-ENG115152-Light configuration-Light_Function_B_8	0
IDE05145-ENG115171-Light configuration-Light_Function_B_9	51
IDE05145-ENG115020-Light configuration-Light_Function_C_0	0
IDE05145-ENG115039-Light configuration-Light_Function_C_1	0
IDE05145-ENG115001-Light configuration-Light_Function_C_10	250
IDE05145-ENG115195-Light configuration-Light_Function_C_11	250
IDE05145-ENG115214-Light configuration-Light_Function_C_12	0
IDE05145-ENG114960-Light configuration-Light_Function_C_13	0
IDE05145-ENG115235-Light configuration-Light_Function_C_14	89
IDE05145-ENG115254-Light configuration-Light_Function_C_15	0
IDE05145-ENG115273-Light configuration-Light_Function_C_16	0
IDE05145-ENG115292-Light configuration-Light_Function_C_17	0
IDE05145-ENG115311-Light configuration-Light_Function_C_18	250
IDE05145-ENG115330-Light configuration-Light_Function_C_19	250
IDE05145-ENG115058-Light configuration-Light_Function_C_2	0
IDE05145-ENG115349-Light configuration-Light_Function_C_20	250
IDE05145-ENG115368-Light configuration-Light_Function_C_21	0
IDE05145-ENG115387-Light configuration-Light_Function_C_22	0
IDE05145-ENG115406-Light configuration-Light_Function_C_23	0
IDE05145-ENG115425-Light configuration-Light_Function_C_24	0
IDE05145-ENG115444-Light configuration-Light_Function_C_25	0
IDE05145-ENG115463-Light configuration-Light_Function_C_26	0
IDE05145-ENG115482-Light configuration-Light_Function_C_27	1
IDE05145-ENG115501-Light configuration-Light_Function_C_28	89
IDE05145-ENG115519-Light configuration-Light_Function_C_29	250
IDE05145-ENG115077-Light configuration-Light_Function_C_3	0
IDE05145-ENG115539-Light configuration-Light_Function_C_30	250
IDE05145-ENG115558-Light configuration-Light_Function_C_31	1
IDE05145-ENG115577-Light configuration-Light_Function_C_32	1
IDE05145-ENG115596-Light configuration-Light_Function_C_33	1
IDE05145-ENG115615-Light configuration-Light_Function_C_34	1
IDE05145-ENG115096-Light configuration-Light_Function_C_4	18
IDE05145-ENG114979-Light configuration-Light_Function_C_5	19
IDE05145-ENG115117-Light configuration-Light_Function_C_6	0
IDE05145-ENG115136-Light configuration-Light_Function_C_7	0
IDE05145-ENG115155-Light configuration-Light_Function_C_8	0
IDE05145-ENG115174-Light configuration-Light_Function_C_9	250
IDE05145-ENG115021-Light configuration-Light_Function_D_0	0
IDE05145-ENG115040-Light configuration-Light_Function_D_1	0
IDE05145-ENG115002-Light configuration-Light_Function_D_10	0
IDE05145-ENG115196-Light configuration-Light_Function_D_11	244
IDE05145-ENG115215-Light configuration-Light_Function_D_12	0
IDE05145-ENG114961-Light configuration-Light_Function_D_13	0
IDE05145-ENG115236-Light configuration-Light_Function_D_14	0
IDE05145-ENG115255-Light configuration-Light_Function_D_15	240
IDE05145-ENG115274-Light configuration-Light_Function_D_16	0
IDE05145-ENG115293-Light configuration-Light_Function_D_17	72
IDE05145-ENG115312-Light configuration-Light_Function_D_18	60
IDE05145-ENG115331-Light configuration-Light_Function_D_19	112
IDE05145-ENG115059-Light configuration-Light_Function_D_2	0
IDE05145-ENG115350-Light configuration-Light_Function_D_20	80
IDE05145-ENG115369-Light configuration-Light_Function_D_21	0
IDE05145-ENG115388-Light configuration-Light_Function_D_22	224
IDE05145-ENG115407-Light configuration-Light_Function_D_23	208
IDE05145-ENG115426-Light configuration-Light_Function_D_24	135
IDE05145-ENG115445-Light configuration-Light_Function_D_25	1
IDE05145-ENG115464-Light configuration-Light_Function_D_26	0
IDE05145-ENG115483-Light configuration-Light_Function_D_27	0
IDE05145-ENG115502-Light configuration-Light_Function_D_28	111
IDE05145-ENG115521-Light configuration-Light_Function_D_29	68
IDE05145-ENG115078-Light configuration-Light_Function_D_3	0
IDE05145-ENG115540-Light configuration-Light_Function_D_30	192
IDE05145-ENG115559-Light configuration-Light_Function_D_31	240
IDE05145-ENG115578-Light configuration-Light_Function_D_32	192
IDE05145-ENG115597-Light configuration-Light_Function_D_33	0
IDE05145-ENG115616-Light configuration-Light_Function_D_34	68
IDE05145-ENG115097-Light configuration-Light_Function_D_4	0
IDE05145-ENG114980-Light configuration-Light_Function_D_5	0
IDE05145-ENG115118-Light configuration-Light_Function_D_6	0
IDE05145-ENG115137-Light configuration-Light_Function_D_7	0
IDE05145-ENG115156-Light configuration-Light_Function_D_8	0
IDE05145-ENG115175-Light configuration-Light_Function_D_9	200
IDE05145-ENG115024-Light configuration-Light_Function_E_0	0
IDE05145-ENG115043-Light configuration-Light_Function_E_1	0
IDE05145-ENG115005-Light configuration-Light_Function_E_10	164
IDE05145-ENG115199-Light configuration-Light_Function_E_11	75
IDE05145-ENG115218-Light configuration-Light_Function_E_12	220
IDE05145-ENG114964-Light configuration-Light_Function_E_13	80
IDE05145-ENG115239-Light configuration-Light_Function_E_14	241
IDE05145-ENG115258-Light configuration-Light_Function_E_15	60
IDE05145-ENG115277-Light configuration-Light_Function_E_16	0
IDE05145-ENG115296-Light configuration-Light_Function_E_17	1
IDE05145-ENG115315-Light configuration-Light_Function_E_18	0
IDE05145-ENG115334-Light configuration-Light_Function_E_19	80
IDE05145-ENG115062-Light configuration-Light_Function_E_2	0
IDE05145-ENG115353-Light configuration-Light_Function_E_20	0
IDE05145-ENG115372-Light configuration-Light_Function_E_21	15
IDE05145-ENG115391-Light configuration-Light_Function_E_22	1
IDE05145-ENG115410-Light configuration-Light_Function_E_23	234
IDE05145-ENG115429-Light configuration-Light_Function_E_24	208
IDE05145-ENG115448-Light configuration-Light_Function_E_25	0
IDE05145-ENG115467-Light configuration-Light_Function_E_26	0
IDE05145-ENG115486-Light configuration-Light_Function_E_27	0
IDE05145-ENG115505-Light configuration-Light_Function_E_28	146
IDE05145-ENG115524-Light configuration-Light_Function_E_29	78
IDE05145-ENG115081-Light configuration-Light_Function_E_3	0
IDE05145-ENG115543-Light configuration-Light_Function_E_30	78
IDE05145-ENG115562-Light configuration-Light_Function_E_31	152
IDE05145-ENG115581-Light configuration-Light_Function_E_32	87
IDE05145-ENG115600-Light configuration-Light_Function_E_33	0
IDE05145-ENG115619-Light configuration-Light_Function_E_34	128
IDE05145-ENG115100-Light configuration-Light_Function_E_4	0
IDE05145-ENG114983-Light configuration-Light_Function_E_5	0
IDE05145-ENG115121-Light configuration-Light_Function_E_6	0
IDE05145-ENG115140-Light configuration-Light_Function_E_7	0
IDE05145-ENG115159-Light configuration-Light_Function_E_8	1
IDE05145-ENG115178-Light configuration-Light_Function_E_9	0
IDE05145-ENG115025-Light configuration-Light_Function_F_0	0
IDE05145-ENG115044-Light configuration-Light_Function_F_1	0
IDE05145-ENG115006-Light configuration-Light_Function_F_10	250
IDE05145-ENG115200-Light configuration-Light_Function_F_11	0
IDE05145-ENG115219-Light configuration-Light_Function_F_12	250
IDE05145-ENG114965-Light configuration-Light_Function_F_13	0
IDE05145-ENG115240-Light configuration-Light_Function_F_14	0
IDE05145-ENG115259-Light configuration-Light_Function_F_15	250
IDE05145-ENG115278-Light configuration-Light_Function_F_16	0
IDE05145-ENG115297-Light configuration-Light_Function_F_17	0
IDE05145-ENG115316-Light configuration-Light_Function_F_18	0
IDE05145-ENG115335-Light configuration-Light_Function_F_19	250
IDE05145-ENG115063-Light configuration-Light_Function_F_2	0
IDE05145-ENG115354-Light configuration-Light_Function_F_20	0
IDE05145-ENG115373-Light configuration-Light_Function_F_21	250
IDE05145-ENG115392-Light configuration-Light_Function_F_22	0
IDE05145-ENG115411-Light configuration-Light_Function_F_23	1
IDE05145-ENG115430-Light configuration-Light_Function_F_24	0
IDE05145-ENG115449-Light configuration-Light_Function_F_25	0
IDE05145-ENG115468-Light configuration-Light_Function_F_26	250
IDE05145-ENG115487-Light configuration-Light_Function_F_27	0
IDE05145-ENG115506-Light configuration-Light_Function_F_28	0
IDE05145-ENG115525-Light configuration-Light_Function_F_29	0
IDE05145-ENG115082-Light configuration-Light_Function_F_3	0
IDE05145-ENG115544-Light configuration-Light_Function_F_30	0
IDE05145-ENG115563-Light configuration-Light_Function_F_31	1
IDE05145-ENG115582-Light configuration-Light_Function_F_32	250
IDE05145-ENG115601-Light configuration-Light_Function_F_33	0
IDE05145-ENG115620-Light configuration-Light_Function_F_34	0
IDE05145-ENG115101-Light configuration-Light_Function_F_4	0
IDE05145-ENG114984-Light configuration-Light_Function_F_5	0
IDE05145-ENG115122-Light configuration-Light_Function_F_6	0
IDE05145-ENG115141-Light configuration-Light_Function_F_7	0
IDE05145-ENG115160-Light configuration-Light_Function_F_8	0
IDE05145-ENG115179-Light configuration-Light_Function_F_9	0
IDE05145-ENG115028-Light configuration-Light_Function_G_0	0
IDE05145-ENG115047-Light configuration-Light_Function_G_1	0
IDE05145-ENG115009-Light configuration-Light_Function_G_10	0
IDE05145-ENG115203-Light configuration-Light_Function_G_11	0
IDE05145-ENG115222-Light configuration-Light_Function_G_12	0
IDE05145-ENG114968-Light configuration-Light_Function_G_13	0
IDE05145-ENG115243-Light configuration-Light_Function_G_14	217
IDE05145-ENG115262-Light configuration-Light_Function_G_15	0
IDE05145-ENG115281-Light configuration-Light_Function_G_16	0
IDE05145-ENG115300-Light configuration-Light_Function_G_17	0
IDE05145-ENG115319-Light configuration-Light_Function_G_18	0
IDE05145-ENG115338-Light configuration-Light_Function_G_19	0
IDE05145-ENG115066-Light configuration-Light_Function_G_2	0
IDE05145-ENG115357-Light configuration-Light_Function_G_20	0
IDE05145-ENG115376-Light configuration-Light_Function_G_21	0
IDE05145-ENG115395-Light configuration-Light_Function_G_22	0
IDE05145-ENG115414-Light configuration-Light_Function_G_23	0
IDE05145-ENG115433-Light configuration-Light_Function_G_24	0
IDE05145-ENG115452-Light configuration-Light_Function_G_25	0
IDE05145-ENG115471-Light configuration-Light_Function_G_26	255
IDE05145-ENG115490-Light configuration-Light_Function_G_27	0
IDE05145-ENG115509-Light configuration-Light_Function_G_28	0
IDE05145-ENG115528-Light configuration-Light_Function_G_29	0
IDE05145-ENG115085-Light configuration-Light_Function_G_3	0
IDE05145-ENG115547-Light configuration-Light_Function_G_30	0
IDE05145-ENG115566-Light configuration-Light_Function_G_31	1
IDE05145-ENG115585-Light configuration-Light_Function_G_32	0
IDE05145-ENG115604-Light configuration-Light_Function_G_33	0
IDE05145-ENG115623-Light configuration-Light_Function_G_34	0
IDE05145-ENG115104-Light configuration-Light_Function_G_4	0
IDE05145-ENG114987-Light configuration-Light_Function_G_5	0
IDE05145-ENG115125-Light configuration-Light_Function_G_6	0
IDE05145-ENG115144-Light configuration-Light_Function_G_7	0
IDE05145-ENG115163-Light configuration-Light_Function_G_8	51
IDE05145-ENG115182-Light configuration-Light_Function_G_9	250
IDE05145-ENG115029-Light configuration-Light_Function_H_0	0
IDE05145-ENG115048-Light configuration-Light_Function_H_1	0
IDE05145-ENG115010-Light configuration-Light_Function_H_10	0
IDE05145-ENG115204-Light configuration-Light_Function_H_11	56
IDE05145-ENG115223-Light configuration-Light_Function_H_12	1
IDE05145-ENG114969-Light configuration-Light_Function_H_13	197
IDE05145-ENG115244-Light configuration-Light_Function_H_14	80
IDE05145-ENG115263-Light configuration-Light_Function_H_15	0
IDE05145-ENG115282-Light configuration-Light_Function_H_16	0
IDE05145-ENG115301-Light configuration-Light_Function_H_17	0
IDE05145-ENG115320-Light configuration-Light_Function_H_18	0
IDE05145-ENG115339-Light configuration-Light_Function_H_19	241
IDE05145-ENG115067-Light configuration-Light_Function_H_2	0
IDE05145-ENG115358-Light configuration-Light_Function_H_20	16
IDE05145-ENG115377-Light configuration-Light_Function_H_21	0
IDE05145-ENG115396-Light configuration-Light_Function_H_22	109
IDE05145-ENG115415-Light configuration-Light_Function_H_23	240
IDE05145-ENG115434-Light configuration-Light_Function_H_24	211
IDE05145-ENG115453-Light configuration-Light_Function_H_25	255
IDE05145-ENG115472-Light configuration-Light_Function_H_26	0
IDE05145-ENG115491-Light configuration-Light_Function_H_27	255
IDE05145-ENG115510-Light configuration-Light_Function_H_28	78
IDE05145-ENG115529-Light configuration-Light_Function_H_29	0
IDE05145-ENG115086-Light configuration-Light_Function_H_3	0
IDE05145-ENG115548-Light configuration-Light_Function_H_30	0
IDE05145-ENG115567-Light configuration-Light_Function_H_31	152
IDE05145-ENG115586-Light configuration-Light_Function_H_32	0
IDE05145-ENG115605-Light configuration-Light_Function_H_33	240
IDE05145-ENG115624-Light configuration-Light_Function_H_34	19
IDE05145-ENG115105-Light configuration-Light_Function_H_4	0
IDE05145-ENG114988-Light configuration-Light_Function_H_5	0
IDE05145-ENG115126-Light configuration-Light_Function_H_6	0
IDE05145-ENG115145-Light configuration-Light_Function_H_7	0
IDE05145-ENG115164-Light configuration-Light_Function_H_8	44
IDE05145-ENG115183-Light configuration-Light_Function_H_9	75
IDE05145-ENG115013-Light configuration-Type_Of_Load_0	Blinkleuchten
IDE05145-ENG115032-Light configuration-Type_Of_Load_1	Blinkleuchten
IDE05145-ENG115188-Light configuration-Type_Of_Load_11	not active
IDE05145-ENG115207-Light configuration-Type_Of_Load_12	not active
IDE05145-ENG114954-Light configuration-Type_Of_Load_13	not active
IDE05145-ENG115266-Light configuration-Type_Of_Load_16	LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115285-Light configuration-Type_Of_Load_17	not active
IDE05145-ENG115051-Light configuration-Type_Of_Load_2	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115342-Light configuration-Type_Of_Load_20	not active
IDE05145-ENG115380-Light configuration-Type_Of_Load_22	not active
IDE05145-ENG115418-Light configuration-Type_Of_Load_24	not active
IDE05145-ENG115070-Light configuration-Type_Of_Load_3	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115532-Light configuration-Type_Of_Load_30	not active
IDE05145-ENG115551-Light configuration-Type_Of_Load_31	not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32	not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115608-Light configuration-Type_Of_Load_34	not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG114973-Light configuration-Type_Of_Load_5	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115110-Light configuration-Type_Of_Load_6	Low beam
IDE05145-ENG115129-Light configuration-Type_Of_Load_7	Low beam
IDE05145-ENG115167-Light configuration-Type_Of_Load_9	z.B.LEDFußraumleuchten
IDE05822-DWA Vehicle inclination sensor	100%
IDE05823-DWA Interior monitoring parameter set	01 0A 08 00 43 63 0A 78 01 14 0A 03 C1 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 24 23 65 42 57 9B 25 44 3F 3A 69 35 95 2C 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 05 24 3F 3A 69 58 02 01 FFFFFF9C 00 65FFFF4A D1 1DBB2F 00 00 00 01 00 40067529 01 03 00 00 00 65FFFF4A D1 5F2550 00 B7FE044D 72184717 44CD5E0B 4A9061C6 549928E5 00 40404790 01 00 00 01 00 00 00 00 00 00 00 D00 00 D00 00 4004A671 01
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration	0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts	0
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	active
IDE08542-ENG115671-Access control 2-Regenschließen	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC	0
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0	not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1	not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10	not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11	not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12	not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13	not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14	not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15	not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16	not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17	not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18	not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19	not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2	not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20	not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21	not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22	not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23	not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24	not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25	not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26	not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27	not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28	not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29	not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3	not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30	not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31	not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32	not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33	not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34	not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4	not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5	not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6	not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7	not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8	not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9	not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand	0_Ohm
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC	0
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0	not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1	not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10	not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11	not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12	not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13	not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14	not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15	not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16	not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17	not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18	not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19	not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2	not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20	not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21	not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22	not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23	not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24	not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25	not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26	not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27	not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28	not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29	not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3	not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30	not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31	not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32	not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33	not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34	not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4	not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5	not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6	not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7	not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8	not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9	not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand	0_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs	not active
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung	Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung	Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit	0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit	24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein	not active
MAS01490-IDE07474-Energy management-Adapting for energy management	Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement	not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter	closed
MAS08233-ENG126575-other-mute_mode_aktiv	not active
MAS08233-ENG125011-other-pa_Funktion_2aus3	not installed
ENG05956-Adaptation_theft_protection_2	not active
ENG122925-DWA_Interior_Monitoring_Data_Set_Development	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 FFFFFF9C 00 68331386 D1 1DBB2F 00 00 00 01 00 40067529 01 03 00 00 00 68331386 D1 5F2550 00 B7FE044D 4DBCEB30
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	100.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	100.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	100.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	100.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	100.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0	100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0	0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0	maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0	maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0	maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0	0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0	0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0	14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0	34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0	Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0	Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0	not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0	not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0	not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0	not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0	not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0	not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0	not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0	Blinkleuchten
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10	0
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10	0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10	maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10	maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10	maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10	0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10	0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10	0
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10	0
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10	Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10	not active
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10	not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10	not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10	not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10	not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10	not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10	not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10	not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10	not active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11	100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11	0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11	maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11	maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11	maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11	0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11	0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11	0
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11	0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11	Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11	Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11	not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11	not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11	not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11	not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11	not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11	not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11	not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12	100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12	0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12	maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12	maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12	maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12	0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12	0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12	22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12	38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12	Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12	Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12	Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12	not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12	not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12	not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12	not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12	not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12	not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12	allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13	100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13	0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13	maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13	maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13	maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13	0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13	0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13	23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13	42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13	Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13	Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13	Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13	not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13	not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13	not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13	not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13	not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13	not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13	allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15	100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15	0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15	maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15	maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15	maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15	0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15	0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15	0
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15	0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15	Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15	SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15	not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15	not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15	not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15	not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15	not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15	not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15	not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	0
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	0
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Blinkleuchten
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17	100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17	0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17	maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17	maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17	maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17	0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17	0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17	0
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17	0
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17	Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17	Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17	not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17	not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17	not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17	not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17	not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17	not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17	not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17	LED Blinkleuchten
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18	100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18	0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18	maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18	maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18	maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18	0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18	0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18	16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18	8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18	Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18	Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18	not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18	not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18	not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18	not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18	not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18	not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18	not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18	Blinkleuchten
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19	100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19	0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19	maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19	maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19	maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19	0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19	0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19	18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19	18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19	Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19	Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19	not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19	not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19	not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19	not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19	not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19	not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19	not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19	Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1	100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1	0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1	maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1	maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1	maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1	0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1	0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1	15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1	3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1	Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1	Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1	not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1	not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1	not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1	not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1	not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1	not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1	not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1	Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20	100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20	0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20	maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20	maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20	maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20	0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20	0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20	2B
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20	9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20	Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20	Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20	not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20	not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20	not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20	not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20	not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20	not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20	not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20	Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21	100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21	0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21	maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21	maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21	maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21	0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21	0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21	2D
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21	19
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21	Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21	Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21	not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21	not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21	not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21	not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21	not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21	not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21	not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21	Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22	100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22	0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22	maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22	maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22	maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22	0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22	0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22	2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22	29
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22	Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22	Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22	not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22	not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22	not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22	not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22	not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22	not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22	not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22	LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23	60
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23	0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23	maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23	maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23	maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23	0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23	0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23	29
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23	0A
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23	Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23	Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23	Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23	not active
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23	not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23	not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23	not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23	not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23	not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24	60
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24	0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24	maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24	maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24	maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24	0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24	0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24	2A
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24	1A
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24	Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24	Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24	Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24	not active
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24	not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24	not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24	not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24	not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24	not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25	100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25	0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25	maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25	maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25	maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25	0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25	0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25	30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25	28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25	Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25	Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25	not active
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25	not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25	not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25	not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25	not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25	not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25	not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26	100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26	0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26	maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26	maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26	maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26	0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26	0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26	2F
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26	0C
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26	Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26	NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26	not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26	not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26	not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26	not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26	not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26	not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26	not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27	100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27	0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27	maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27	maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27	maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27	0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27	0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27	8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27	0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27	Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27	Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27	not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27	not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27	not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27	not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27	not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27	not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27	not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28	100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28	0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28	maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28	maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28	maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28	0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28	0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28	32
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28	1B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28	Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28	Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28	not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28	not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28	not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28	not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28	not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28	not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28	not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29	100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29	0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29	maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29	maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29	maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29	0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29	0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29	1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29	0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29	Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29	Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29	not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29	not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29	not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29	not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29	not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29	not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29	not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29	allgemeineGluehlampe12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2	100
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2	0
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2	maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2	maximize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2	maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2	0
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2	0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2	26
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2	35
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2	Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2	Parking light
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2	Parking light left
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2	not active
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2	not active
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2	not active
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2	not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2	not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2	not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2	allgemeineGluehlampe6W:auchH6W
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30	126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30	0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30	maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30	maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30	maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30	0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30	0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30	7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30	0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30	Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30	Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30	not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30	not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30	not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30	not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30	not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30	not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30	not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30	allgemeineGluehlampe12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31	0
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31	0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31	maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31	maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31	maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31	0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31	0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31	0
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31	0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31	Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31	not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31	not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31	not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31	not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31	not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31	not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31	not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31	not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31	not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32	0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32	0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32	maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32	maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32	maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32	0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32	0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32	0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32	0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32	Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32	not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32	not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32	not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32	not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32	not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32	not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32	not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32	not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32	not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33	0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33	0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33	maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33	maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33	maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33	0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33	0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33	0
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33	0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33	Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33	not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33	not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33	not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33	not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33	not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33	not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33	not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33	not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33	not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34	0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34	0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34	maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34	maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34	maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34	0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34	0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34	0
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34	0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34	Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34	not active
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34	not active
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34	not active
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34	not active
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34	not active
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34	not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34	not active
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34	not active
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34	not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3	100
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3	0
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3	maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3	maximize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3	maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3	0
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3	0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3	27
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3	3F
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3	Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3	Parking light
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3	Parking light right
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3	not active
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3	not active
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3	not active
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3	not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3	not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3	not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3	allgemeineGluehlampe6W:auchH6W
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4	100
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4	0
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4	minimize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4	maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4	maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4	0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4	0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4	20
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4	3A
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4	Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4	Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4	not active
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4	Nebellicht links
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4	not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4	not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4	not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4	not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4	not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4	allgemeineGluehlampe27W:auchH15-TFL
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5	100
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5	0
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5	minimize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5	maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5	maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5	0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5	0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5	21
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5	44
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5	Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5	Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5	not active
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5	Nebellicht rechts
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5	not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5	not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5	not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5	not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5	not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5	allgemeineGluehlampe27W:auchH15-TFL
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6	100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6	0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6	maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6	maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6	maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6	0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6	0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6	1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6	36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6	Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6	Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6	ComingHome LeavingHome
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6	not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6	not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6	not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6	not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6	not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6	not active
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6	Low beam
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7	100
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7	0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7	maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7	maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7	maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7	0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7	0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7	1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7	40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7	Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7	Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7	ComingHome LeavingHome
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7	not active
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7	not active
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7	not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7	not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7	not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7	not active
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7	Low beam
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8	100
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8	0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8	maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8	maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7	maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8	0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8	0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8	1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8	37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8	Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8	Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8	Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8	not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8	not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8	not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8	not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8	not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8	not active
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8	allgemeineScheinwerferohneAbschaltung
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9	100
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9	0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9	maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9	maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9	maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9	0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9	0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9	1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9	41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9	Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9	Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9	Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9	not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9	not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9	not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9	not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9	not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9	not active
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9	allgemeineScheinwerferohneAbschaltung
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14	100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14	0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14	maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14	maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14	maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14	0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14	0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14	0
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14	0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14	Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14	LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14	not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14	not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14	not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14	not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14	not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14	not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14	not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation	not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG122927-RLS_close_glazing	2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12 s
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s
ENG122929-RLS_LIN_Communication	4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
ENG122930-RLS_tunel_gateway_recognize	5 s
ENG122935-RLS_Washer_Front	15 s
ENG122926-RLS_wiper_position_parking	15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 FFFFFF9C 00 7AF2D219 D1 1DBB2F 00 00 00 01 00 40067529 01 03 00 00 00 7AF2D219 D1 5F2550 00 B7FE044D A5147AC8 6AC893F7 79432BD C59346F9 00 40404790 01 00 00 01 00 00 00 00 00 00 00 1600 00 1600 00 4004A671 01 03 00 36353150 37313133 00 00 7AF4AB58 FB9A 40404790 01 00 00 01 00 00 31363600 00 00 7AF4AB68 FB9A 40404790 01 00 00 01 00 00 00 01 00 4004F9D5 01 1600 00 40115A3A 01 403E2F22 01 7FFFFFEC 01 40404790 01 00 00 01 00 00 00 00 00 40081D87 01 01 00 1600 00 00 00 17D9ED 00 00 00 40080A22 01 295 00 40164690 01 295 00 9EFF1F1F 15B5E6DA 00 00 00 00 17D84E 00 403E3FA8 01 01 00 00 00 01 00 E7ECA803 7FFA 10C1060 00 5F2500 00 00 01 FFFFFFFE FFFFFFFF 00 00 4004CB6B 01 87 00 7AF2D26E D1 1DBB2F 00 403E2560 01 403E2060 01 4004C2CE 01 7AF2D26E D1 00 00 4019D0A8 01 4019D0A8 01 70E 22030800 55556816 5555 00 00 00 00 403E2560 01 4004BEE0 01 00 00 00 00 E111F250 7FFA E53A08F5 7FFA 404EDB50 01 4004BBD3 01 60956 00 7AF2B0AD D1 1DBB2F 00 00 00 3E 00 4007F9EC 01 00 00 7AF2B0AD D1 01 00 110 00 05 00 5F3FD0 00 F1 00 00 00 00 00 E53A5F0F 7FFA 40000000 00 00 00 00 00 5E9 00 01 00 5F26E0 00 5F26E0 00 01 00 110 00 400FA86D 01 5E9 00 5F3FD0 00 5F7550 00 5F26E0 00 5F3FD0 00 400FD9EA 01 60956 00 77EFF0 00 00 00 00 00 01 00 02 00 87 00 5F3FD0 00 D2 00 D3 00 5F3FD0 00 4000DA19 01 1668 00 5F2BE8 00 01 00 00 00 01 00 FFFFFFFF 00 3C6B150 00 CD011370 FFFFFFFF 00 01 74A 00 00 00 00 7FFA FFFFFFFE FFFFFFFF 00 00 CD011370 FFFFFFFF 8094E 00 48 00 01 01 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA F641A0DA 459 74A 00 74A 00 5F40C0 00 14E 00 E1101250 7FFA E53BA95A 7FFA E5390000 7FFA E1101250 7FFA 2B0744 00 14E 00 74A 00 00 00 00 00 00 00 110 00 E53C167B 7FFA 5F40C0 00 14E 00 74A 00 00 00 00 00 01 00 8094E 00 400FBB34 01 77EFF0 00 4010F798 01 401BF6F8 01 4010F798 01 00 00 5F40C0 00 00 00 400FBC9C 01 5F40C0 00 E7E95057 7FFA 74A 00 00 00 5F2920 00 00 00 00 00 400FEC4A 01 00 00 00 00 74A 00 77EFF0 00 00 FFFFFFFF 77EFF0 00 FFFFFFFE FFFFFFFF 40105084 01 2B0744 00 00 00 B0946 00 113 00 05 00 00 00 00 00 00 00 14E 00 00 00 400FEC70 01 400FECC9 01 E7945F30 48D9 00 00 14E 00 00 00 2B0744 00 00 00 5F2B40 00 E53A133C 7FFA 00 00 00 00 01 00 FFFFFFFF 00 1F0000 00 5F2AC8 00 00 01 74A 00 00 00 00 00 00 00 00 00 116BB30 00 0C 00 48 00 01 7FFA 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA 330037 29 FFFFFF0E 00 00 00 2B0744 00 00 00 400FEC70 01
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 FFFFFF9C 00 7B18B284 D1 1DBB2F 00 00 00 01 00 40067529 01 03 00 00 00 7B18B284 D1 5F2550 00 B7FE044D A5147AC8 6AC893F7 79432B2 6F93E3F9 00 40404790 01 00 00 01 00 00 00 00 00 00 00 1600 00 1600 00 4004A671 01 03 00 36353150 36393334 00 00 7AF4AB58 FB9A 40404790 01 00 00 01 00 00 31363600 00 00 7AF4AB68 FB9A 40404790 01 00 00 01 00 00 00 01 00 4004F9D5 01 1600 00 40115A3A 01 403E2F22 01 7FFFFFEC 01 40404790 01 00 00 01 00 00 00 00 00 40081D87 01 01 00 1600 00 00 00 17DEEC 00 00 00 40080A22 01 295 00 40164690 01 295 00 D7FF1F1F 75D6EFC6 00 00 00 00 17DD48 00 403E3FA8 01 01 00 00 00 01 00 E7ECA803 7FFA 10C1060 00 5F2500 00 00 01 FFFFFFFE FFFFFFFF 00 00 4004CB6B 01 87 00 7B18B304 D1 1DBB2F 00 403E2560 01 403E2060 01 4004C2CE 01 7B18B304 D1 00 00 4019D0A8 01 4019D0A8 01 70E 22030800 55556716 5555 00 00 00 00 403E2560 01 4004BEE0 01 00 00 00 00 E111F250 7FFA E53A08F5 7FFA 404EDB50 01 4004BBD3 01 60956 00 7B1890E5 D1 1DBB2F 00 00 00 3E 00 4007F9EC 01 00 00 7B1890E5 D1 01 00 110 00 05 00 5F3FD0 00 F1 00 00 00 00 00 E53A5F0F 7FFA 40000000 00 00 00 00 00 5E9 00 01 00 5F26E0 00 5F26E0 00 01 00 110 00 400FA86D 01 5E9 00 5F3FD0 00 5F7550 00 5F26E0 00 5F3FD0 00 400FD9EA 01 60956 00 77EFF0 00 00 00 00 00 01 00 02 00 87 00 5F3FD0 00 D2 00 D3 00 5F3FD0 00 4000DA19 01 1667 00 5F2BE8 00 01 00 00 00 01 00 FFFFFFFF 00 3C6B150 00 3B011390 00 00 01 74C 00 00 00 00 7FFA FFFFFFFE FFFFFFFF 00 00 3B011390 00 8094E 00 48 00 01 01 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA F641A0DA 459 74C 00 74C 00 5F40C0 00 14E 00 E1101250 7FFA E53BA95A 7FFA E5390000 7FFA E1101250 7FFA 2B0744 00 14E 00 74C 00 00 00 00 00 00 00 110 00 E53C167B 7FFA 5F40C0 00 14E 00 74C 00 00 00 00 00 01 00 8094E 00 400FBB34 01 77EFF0 00 4010F798 01 401BF6F8 01 4010F798 01 00 00 5F40C0 00 00 00 400FBC9C 01 5F40C0 00 E7E95057 7FFA 74C 00 00 00 5F2920 00 00 00 00 00 400FEC4A 01 00 00 00 00 74C 00 77EFF0 00 00 FFFFFFFF 77EFF0 00 FFFFFFFE FFFFFFFF 40105084 01 2B0744 00 00 00 B0946 00 113 00 05 00 00 00 00 00 00 00 14E 00 00 00 400FEC70 01 400FECC9 01 E7945F30 48D9 00 00 14E 00 00 00 2B0744 00 00 00 5F2B40 00 E53A133C 7FFA 00 00 00 00 01 00 FFFFFFFF 00 1F0000 00 5F2AC8 00 00 01 74C 00 00 00 00 00 00 00 00 00 116BB30 00 0C 00 48 00 01 7FFA 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA 330037 29 FFFFFF0E 00 00 00 2B0744 00 00 00 400FEC70 01
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 FFFFFF9C 00 7B3EC864 D1 1DBB2F 00 00 00 01 00 40067529 01 03 00 00 00 7B3EC864 D1 5F2550 00 B7FE044D A5147AC8 6AC893F7 79432BC FF927CF9 00 40404790 01 00 00 01 00 00 00 00 00 00 00 1600 00 1600 00 4004A671 01 03 00 36353150 37373635 00 00 7AF4AB58 FB9A 40404790 01 00 00 01 00 00 31363600 00 00 7AF4AB68 FB9A 40404790 01 00 00 01 00 00 00 01 00 4004F9D5 01 1600 00 40115A3A 01 403E2F22 01 7FFFFFEC 01 40404790 01 00 00 01 00 00 00 00 00 40081D87 01 01 00 1600 00 00 00 17E3ED 00 00 00 40080A22 01 295 00 40164690 01 295 00 C1FF1F1F 5EB2C8CA 00 00 00 00 17E24A 00 403E3FA8 01 01 00 00 00 01 00 E7ECA803 7FFA 10C1060 00 5F2500 00 00 01 FFFFFFFE FFFFFFFF 00 00 4004CB6B 01 87 00 7B3EC8E2 D1 1DBB2F 00 403E2560 01 403E2060 01 4004C2CE 01 7B3EC8E2 D1 00 00 4019D0A8 01 4019D0A8 01 70E 22030800 55556916 5555 00 00 00 00 403E2560 01 4004BEE0 01 00 00 00 00 E111F250 7FFA E53A08F5 7FFA 404EDB50 01 4004BBD3 01 60956 00 7B3EA8AC D1 1DBB2F 00 00 00 3E 00 4007F9EC 01 00 00 7B3EA8AC D1 01 00 110 00 05 00 5F3FD0 00 F1 00 00 00 00 00 E53A5F0F 7FFA 40000000 00 00 00 00 00 5E9 00 01 00 5F26E0 00 5F26E0 00 01 00 110 00 400FA86D 01 5E9 00 5F3FD0 00 5F7550 00 5F26E0 00 5F3FD0 00 400FD9EA 01 60956 00 77EFF0 00 00 00 00 00 01 00 02 00 87 00 5F3FD0 00 D2 00 D3 00 5F3FD0 00 4000DA19 01 1669 00 5F2BE8 00 01 00 00 00 01 00 FFFFFFFF 00 3C6B150 00 4C011314 00 00 01 74E 00 00 00 00 7FFA FFFFFFFE FFFFFFFF 00 00 4C011314 00 8094E 00 48 00 01 01 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA F641A0DA 459 74E 00 74E 00 5F40C0 00 14E 00 E1101250 7FFA E53BA95A 7FFA E5390000 7FFA E1101250 7FFA 2B0744 00 14E 00 74E 00 00 00 00 00 00 00 110 00 E53C167B 7FFA 5F40C0 00 14E 00 74E 00 00 00 00 00 01 00 8094E 00 400FBB34 01 77EFF0 00 4010F798 01 401BF6F8 01 4010F798 01 00 00 5F40C0 00 00 00 400FBC9C 01 5F40C0 00 E7E95057 7FFA 74E 00 00 00 5F2920 00 00 00 00 00 400FEC4A 01 00 00 00 00 74E 00 77EFF0 00 00 FFFFFFFF 77EFF0 00 FFFFFFFE FFFFFFFF 40105084 01 2B0744 00 00 00 B0946 00 113 00 05 00 00 00 00 00 00 00 14E 00 00 00 400FEC70 01 400FECC9 01 E7945F30 48D9 00 00 14E 00 00 00 2B0744 00 00 00 5F2B40 00 E53A133C 7FFA 00 00 00 00 01 00 FFFFFFFF 00 1F0000 00 5F2AC8 00 00 01 74E 00 00 00 00 00 00 00 00 00 116BB30 00 0C 00 48 00 01 7FFA 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF E53A1044 7FFA E53A133C 7FFA 330037 29 FFFFFF0E 00 00 00 2B0744 00 00 00 400FEC70 01
Elapsed Time: 04:03
Been trialing a few different products on a new Polo 6C. i have installed a set of aftermarket headlights and found that there not like they said and throw a few codes, due to the modules being so new I am really struggling at removing the first 4 errors. Would anyone be able to assist?
Apologies in advance if i have not provided the right info. I also have a photo of the lights.
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   7 Faults Found:
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:17
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:18
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [008] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:51:17
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 59
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:28:17
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 59
                    Mileage: 11814 km
                    Date: 2016.08.20
                    Time: 10:28:17
12307 - License Plate Light
          B12CA 01 [008] - Electrical Failure
                    Fault Frequency: 58
                    Reset counter: 95
                    Mileage: 11552 km
                    Date: 2016.08.17
                    Time: 18:56:47
227080 - Turn Signal Switch
          B1144 29 [008] - Signal Implausible
                    Mileage: 7918 km
                    Date: 2016.06.18
                    Time: 16:17:52
Dean: First, many thanks for the BCM admap - it's the first that I have seen for the Polo-6C. I'm very pleased to have access to the information (finally)!
So, I've taken your admap data and I've parsed it through MS Excel so as to strip-out all of the Leuchte channels (646 channels in total). I've also stripped-off the "Object tags" and I have arranged the channels in logical order( well... logical order from my perspective, at least). Finally, I've referenced each channel with it's lamp function based on information from my database (can't remember where I got the data, so I can't give attribution to the original author). You can download a copy of the revised data HERE.
I can't quite understand the impact of your changes, because I don't know anything about the nature of the new headlight fittings that you have installed. However, with the information in my spread-sheet and your knowledge of these fittings, it should be possible to rectify your DTC.
Basically, you will need to identify each lamp in the error report above with it's Leuchte-set (being, the group of related 19 x adaptation channels). For that Leuchte-set, the first adaptation channel in my list (which is known in mk7 parlance as lasttyp, but is called Type_Of_Load on your Polo 6C), change the setting to an LED value. I'm not sure that the Polo has the same options as my mk7, but it should be obvious which settings are incandescent and which are for LED lamps. Then just keep working down the error message list.
PS: I've shown the basic structure of a Leuchte-set on the first Leuchte-set in my spread-sheet The background colours in the table is deliberate: the colours are intended to show the embedded relationship between individual adaptation channels and the Leuchte-set as a whole. I hope this helps you to make-sense of the data!
PPS: I'm not sure what type of retrofit fittings you have installed. But if you have installed HID lamps where previously you had incandescent, you should make sure that the BCM is compatible with this type of lamp. If the BCM is incompatible with HIDs, making changes to the Leuchte-set won't help, because the "Shutter" pins won't be physically installed in the BCM connector (because the BCM can't accommodate the HID function). Some retrofit HIDs "cheat" by using a cross wiring loom to connect the main-beam (incandescent) lamp pins on the BCM to the HID Shutter connections on the headlight fittings. Incidentally, if you have installed HIDs, then you will likely need to use the "Xenon" setting for the Type_Of_Load channel on both low-beam Leuchte-sets to remove the DTC in your report.
PPPS: If the exercise fo changing the Type_Of_Load setting doesn't work, the other option is to just stop the BCM from monitoring the lamps. This is done by setting the Lampendefektbit_Position and Fehlerort_mittleres_Byte_DTC-DFCC channel settings for the allied Leuchte-set to zero (each channel)
Dutchie
C?ID=125479
Are these the OEM xenon headlights?
For the conceptualization of commonalities between different modules, I think that stripping off the tags might be a mistake.
Uwe: I understand your point which is entirely valid and I did contemplate retaining the original format!
Don't tell Dean, but my real motivation in undertaking the exercise was to compare at a detailed level, the Leuchte channels in my mk7 with the oddly built Polo 6C (I say "oddly" because as I understand the 6C is not MQB, but it appears to have a very MQB -ish style BCM). Perhaps it's because of the newness of the object tags, but they just seemed to distract from my objective!! However, I decided to retain the tag nomenclature in a separate column as reference - largely because of the point that you make!
The other unfortunate thing about retaining the object tags in this type of exercise is that sorting the Leuchte channels in tag-order results in a less intuitive structure - because the "Child" tag numbering sequence breaks the embedded relationships that I show via the background colours in my spreadsheet. Ordering the Leuchte channels as per my table makes it much easier to understand why the settings are as they are. When reading the flow of the programming sequence, the "Leuchte story" just seems to make logical sense with this ordering (well... it does to me)
I'm not sure who created the original reporting structure for the Leuchte channels (with the leading parenthesis numbering), but whoever it was, they certainly knew their stuff!!!
Yep, for the purposes you described, I think keeping them in a separate column so you can sort on channel names while also comparing tag names is probably a good idea. One thing to keep in mind is that the tag names should never change with differing data sets, whilst one of these days, we might decide to anglicize more of the texts that are currently still Teutonic, and of course, VCDS is also available in a dozen or so other languages...
..........................., whilst one of these days, we might decide to anglicize more of the texts that are currently still Teutonic, and of course, VCDS is also available in a dozen or so other languages...
Uwe: If I could extend the dialogue for just one more question-please. Apology Dean for hijacking your thread - but there's such a dearth of information on this topic that I eagerly seize every opportunity that I can to learn.
So Uwe, the most obvious observation in comparing mk7 and Polo 6C Leuchte channels is the very point that you make in your sentence above; the descriptors for the Polo-sets are anglicised and the mk7-sets are in the original "Teutonic" (what a great word!) form. Why: is this VW giving credence to the fact that that the world doesn't end at the German border - or is this the masterful hand of Ross-Tech?
Nope, not RT's doing. We've done very little with those texts up 'till now, 'cause without the object tags (that we didn't have in the past) it would be mighty confusing to change the text descriptors.
My guess is the Polo module (or at least the software in it) was implemented by a different supplier.
