I just received a new 2017 Audi Q7 4M with Prestige Package and has the following options 21'' Rims, Drivers Assistance, Adaptive Chassis, Cold Weather, Towing Packages, Rear Seat Entertainment Preparation, Rear Side Airbags and Night Vision Assistant. I would like to have this post only have confirmed Adaptations and Long Coding and Access Codes that have been verified to work on the Audi Q7 4M model. Here are some modifications I made that work.
Mods Completed: 2017 Audi Q7
Enable ACC Default Distance In MMI (VCDS 16.6 or newer required) - Allows you set the default distance
1. Auto Dist. Reg 13
2. Adaptation - 10
3. Select "Distance basic setting option" in dropdown
4. Select "On" from New value drop down
Disable Seat Belt Chime - Disables seat belt reminder
1. Instruments 17
2. Adaption 10
3. In drop down menu choose Deactivate seat belt chime
4. Change Deactivate seat belt from NO to YES
Needle Sweep In Virtual Cockpit
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
5. Bit 0 activate/check
Enable lap timer
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
5. Bit 3 activate/check
Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display
1. Instruments 09 - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS display
2. MOD - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS 360°
Change the Parking Assist shutdown speed threshold - Camera will stay on until 12-MPH instead of 6-MPH
3. ORIGINAL - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 10
3. MOD - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 20 - (20 IS MAX VALUE ACCEPTED = 12MPH)
Change ventilated seat cooling fan speeds for each of the 3 setting - Max increase is 10% over the default setting - You can hear and feel the difference especially stage 3, I increased all by 10%
4. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
Stored value 0 %
4. MOD - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
Stored value 10 % - (10% IS MAX VALUE)
5. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
Stored value 0 %
5. MOD - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
6. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
Stored value 0 %
6. MOD - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
Modifies the threshold of when the lane assist shuts off due to no steering input by the driver - I would like be able to remove the deactivation completely if possible.
1. Frt Sens. Drv. Assist A5 - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Medium
2. MOD - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Late
I'm not sure about this one, I believe it make lane assist that keeps you centered move the wheel with more force - I didn't feel too much difference - I have to test drive some more to confirm
3. ORIGINAL - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
Stored value Medium
3. MOD - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
Stored value Strong
Share any mods that you've done with Ross-Tech Tool or any physical modifications or improvements that you've made to the New 2017 Q7 4M
2. Adaptation - 10
1. Instruments 17
2. Adaption 10
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
Enable lap timer
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
Stored value 10
Stored value 0 %
Stored value 0 %
Stored value 0 %
Stored value Medium
Stored value Late
Stored value Medium
Stored value Strong
