2017 Audi Q7 4M - Adaptations, Coding & Modifications
JOEREZ
C?ID=282825
I just received a new 2017 Audi Q7 4M with Prestige Package and has the following options 21'' Rims, Drivers Assistance, Adaptive Chassis, Cold Weather, Towing Packages, Rear Seat Entertainment Preparation, Rear Side Airbags and Night Vision Assistant. I would like to have this post only have confirmed Adaptations and Long Coding and Access Codes that have been verified to work on the Audi Q7 4M model. Here are some modifications I made that work.
Mods Completed: 2017 Audi Q7
Enable ACC Default Distance In MMI (VCDS 16.6 or newer required) - Allows you set the default distance
1. Auto Dist. Reg 13
2. Adaptation - 10
3. Select "Distance basic setting option" in dropdown
4. Select "On" from New value drop down
Disable Seat Belt Chime - Disables seat belt reminder
1. Instruments 17
2. Adaption 10
3. In drop down menu choose Deactivate seat belt chime
4. Change Deactivate seat belt from NO to YES
Needle Sweep In Virtual Cockpit
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
5. Bit 0 activate/check
Enable lap timer
1. Instruments 17
2. Coding 07
3. Long coding
4. Byte 1
5. Bit 3 activate/check
Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display
1. Instruments 09 - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS display
2. MOD - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS 360°
Change the Parking Assist shutdown speed threshold - Camera will stay on until 12-MPH instead of 6-MPH
3. ORIGINAL - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 10
3. MOD - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 20 - (20 IS MAX VALUE ACCEPTED = 12MPH)
Change ventilated seat cooling fan speeds for each of the 3 setting - Max increase is 10% over the default setting - You can hear and feel the difference especially stage 3, I increased all by 10%
4. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
Stored value 0 %
4. MOD - UDS Adaptation Channel: IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3
Stored value 10 % - (10% IS MAX VALUE)
5. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
Stored value 0 %
5. MOD - UDS Adaptation Channel: IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2
6. ORIGINAL - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
Stored value 0 %
6. MOD - UDS Adaptation Channel: IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1
Modifies the threshold of when the lane assist shuts off due to no steering input by the driver - I would like be able to remove the deactivation completely if possible.
1. Frt Sens. Drv. Assist A5 - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Medium
2. MOD - UDS Adaptation Channel: IDE05984-Directional stabilization assist driver inact deactiv threshold
Stored value Late
I'm not sure about this one, I believe it make lane assist that keeps you centered move the wheel with more force - I didn't feel too much difference - I have to test drive some more to confirm
3. ORIGINAL - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
Stored value Medium
3. MOD - UDS Adaptation Channel: IDE05986-Directional stab. assist.; intensity; power steering support
Stored value Strong
Share any mods that you've done with Ross-Tech Tool or any physical modifications or improvements that you've made to the New 2017 Q7 4M
JOEREZ
C?ID=282825
Allows you to change the Heated Seats Plus or Minus 5 degrees in each stage
2. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1
Stored value 0 °C ( 5 DEGREES + OR - IS MAX VALUE)
3. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 2
4. ORIGINAL - UDS Adaptation Channel: IDE10321-MAS01364-Seat heater: micro adjust.-Stage 3
Allows the Air Re-circulation button to recall the last state, So if the button is pressed on it will stay on default until turned off.
1. 08 Auto HVAC
2. MOD - UDS Adaptation Channel: IDE01476-Store recirculation air setting for terminal 15 off
Stored value save
JOEREZ
C?ID=282825
Seat Symmetry:
I have memory seats, just on the drivers side.
Anyone who tries this code respond if it works - I used another program to do it and compared the long coding afterwards to reveal two bits changed in two modules
Under Vehicle Settings - Seats - Front Passengers Seat you'll now see Adjust Seat Position, when clicked your driver seat controls will move passenger seat. There will also be an option to Align / Drivers Seat you press and hold the Set Now button and it begins to align passenger seat to drivers seat.
Module 06
Byte 2
Check Bit 5
Byte 6
Check Bit 1
Module 36
Byte 2
Check Bit 5
Byte 6
Check Bit 1
andyhud
C?ID=32695
Seat Symmetry:
Module 06
Byte 2
Check Bit 5
Byte 6
Check Bit 1
Module 36
Byte 2
Check Bit 5
Byte 6
Check Bit 1
I can confirm that coding works JoeRez.
Andy
BGB
Norway
C?ID=264865 (?) (NRRT)
Is it possible to deactivate the rear wiper when the rain sensor is on?
BGB
Norway
Anyone?
I dont have the car here so I haven't checked but maybe it is in the adaptation list in 09 or can I be so lucky that we can find it under long coding?
andyhud
C?ID=32695
Anyone?
Had a quick look through Adaption Maps of 09 and 46... couldnt see anything that jumped out relating to that sadly.. might be long coding...
Reactions: BGB
BGB
Norway
Thank you so much for looking!
acowabunga
C?ID=98198
On my B8 S5, I enabled the display in the DIS to show what gear the car was in, which was especially helpful when needing to downshift via the steering wheel paddles. I’ve found that the coding is the same for the 2018 Q7 and wanted to pass it along to add to the other great coding shares.
a. [02 – Auto Trans]
b. [Adaptation – 10]
c. Select “Single Gear Display” from top channel drop down menu
d. “Select “D on/S on” from New Value drop down menu
e. Select “Do It!”
f. Note: You may have to select “Do It! A few times to save the change.
hadez16
C?ID=289891
I think!!!!...the following could work:
Unit 09
Byte 12
Bit 6 set to 0
Bit 7 set to 1
BrandonKasch
C?ID=298837
Does anybody know if the Hex-V2 will work on these cars (2017+ Q7)? I have read some threads that VCDS only works on these cars with Hex-Net.
TBAx
C?ID=287144
HEX-V2 will do the same. It is only important to have a current generation interface, such as HEX-V2 and HEX-NET.
BrandonKasch
C?ID=298837
Thanks.
I am not sure why, but the first time I hooked up the HEX-V2 it was having some sort of communication issue that was preventing it from going into most of the different portions. Second time it had no issues.
BrandonKasch
C?ID=298837
Has anybody figured out how to extend the time limit for when the car shuts down the Wifi hotspot after the car is shut off? It seems to be around 25 minutes, and I would like it to be set to around 1 hour. Its annoying when it shuts down when I am waiting in the car while my kids are in after school activities.
DJR4266
C?ID=332701
Also, Does anyone know if its possible to disable the Auto start/stop function from being defaulted ON every time the car is started? (using a HEX-NET on a 2017 Q7)
hadez16
C?ID=289891
It is only possible to disable StartStop completely, no memory or invers possible here.
Westbury, UK
DJR4266
C?ID=332701
thanks for the reply. So how can I disable start/stop completely?
