Another success story here, as far as I have read, this might be the first Golf GTE hybrid 2015 with PLA 3.0 retrofitted, thank you for the information here!
My car had PLA 2.0 from factory, so it was the easiest retrofit I ever done, just the module swap (
5Q0 919 298 F to
5QA 919 298 D), very easy accessible, only 1 screw away under the wheel. Total cost for used module: 100€ from ebay.de shipped. I was looking for a Golf one, to have the dataset already loaded. Bracket does NOT need to be changed, the new, bigger module just clips back in.
I only had to code 10 Park Assist, 17 Instruments - byte 5 bit 4 unchecked (PLA2.0 off) and byte 13 bit 0 checked (not bit 1, as for other clusters)
and then on , byte 27 bit 1 unchecked (PLA2), but for byte 24 nothing was changed, because I already had all bit 3-7 checked, strange (, Front Assist and Trailer from factory).
PS: If I want to upgrade to an 3Q0 , is there an MK100OMG version for hybrid too? I want to go for the Predictive retrofit.
PS2: not sure if/how to test the auto braking function, seems to be active, but not sure my supports it.
Here is the scan before:
Monday,12,September,2022,17:17:38:53964
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 22.9.0.0 (x64)
VIN: WVWZZZAUZFW802248 License Plate: IF52SAS
Mileage: 204227km-126900mi Repair Order:
Chassis Type: AU-VW37 (5QE)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 51 52 55 5F 69 75
8C A5 A9 C6
VIN: WVWZZZAUZFW802248 Mileage: 204227km-126900miles
Address 01: Engine (J623-CUKB) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 M HW: 04E 907 309 F
Component: R4 1.4l TFS H20 9257
Revision: X3H20--- CVN: 9ACE123D
Coding: 011D0012647405082000
Shop #: WSC 55217 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906023M 005016
ROD: EV_ECM14TFS01104E906023AF_005.rod
VCID: 2A50C4434D2DE5DD3D-807F
VINID: 9E69EAAAA465A969C8002084205F9A4D4F
Part No SW: 0DD 300 045 K HW: 0DD 927 770 A
Component: GSG DQ400E H30 1601
Revision: 00030021 Serial number: TFK01411190004 CVN: 343B05AC
Shop #: WSC 00200 935 01530
ROD: EV_TCMDQ400021.rod
VCID: 2F66D55776CF80F5EA-807B
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AE HW: 5Q0 907 379 H
Component: ESC H31 0808
Revision: 00000000 Serial number: 63334000000493 CVN: E04C564D
Coding: 01FA40A13820316E0379060441CB2980021C8CC0608294F3F8A1507AC202
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 7F06C517E62FB0753A-802B
Part No SW: 5GE 907 044 S HW: 5GE 907 044 S
Component: Climatronic H02 1104
Revision: 00001K07
Coding: 00021014200100010105000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 005132
VCID: 4C9CA2DBE719DBEDEF-8019
Subsystem 3 - Part No SW: 12E 963 231 E HW: 12E 963 231 E
Component: J848 HV-PTC H09 0205
Serial number: T143493003805000100
Air quality sensor:
A/C compressor sub:
H02
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011434503293
Coding: 00121E46C35122F36BEC5080B11C07281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 000446EB9BD1CF8D43-8055
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 141127 043 0551
Serial number: 141204070051
Component: RLHS 037 0059
Serial number: S4Y14M12D15H15M15S56
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143212FYX
Serial number: 00000000000031303216
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H02 0003
Serial number: 0000FST0001OZ2Q00000
Coding: 181901
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431434500653
Coding: 1031161151
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 42808CE3D55D1D9D15-8017
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 16111403270023
Coding: 001C1F00FE0739
VCID: 3874EE0B8381474DBB-806D
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 009 0870
Serial number: 003MFR00AMFS
Coding: 98FCC0C0002000005C5400CF004800000065
VCID: 50A4B6AB0B31FF0D93-8005
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B10121440569
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B10121471669
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 412 14
Serial number: 35700000000C1BD0321F
Subsystem 4 - Part No SW: ----------- HW: 480 000 412 14
Serial number: 358000000009F3410218
Subsystem 5 - Part No SW: ----------- HW: 480 400 412 14
Serial number: 3510002C518B3AB572FF
Subsystem 6 - Part No SW: ----------- HW: 480 400 512 14
Serial number: 3520002AF18B3AB152BE
Subsystem 7 - Part No SW: ----------- HW: 480 400 412 14
Serial number: 3550002B118B3AB53182
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 08121404220164
Coding: 0C10
VCID: 7BFE3107F237AC5516-802F
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
617752 - ROD - Unknown Error Code
- 00 [024]
Reset counter: 13
Mileage: 204086 km
Date: 2022.09.11
Time: 11:42:51
Part No SW: 5G1 920 754 HW: 5G1 920 754
Component: KOMBI 306 4300
Coding: 07251B086FD4000800886A131600000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009042
VCID: 68D47E4B93A117CDEB-803D
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 C HW: 5QE 907 530 A
Component: GW MQB EV 312 3203
Revision: -------- Serial number: 30111410802027
Coding: 0201001726716400FF00527E5C1F00000001050100010000000000000000
GVL: 01543C1000000008D08C90008000C81800000000000000000000000000000000
ASAM Dataset: EV_GatewEVConti 011020
ROD: EV_GatewEVConti_011.rod
VCID: 468890F3F97521BD39-8013
Subsystem 1 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0038
Serial number: 29140002602700034485
Coding: 2DFFFF
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 3969494803
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 A HW: 5QE 909 059 A
Component: EBKV H12 0160
Serial number: 085430010501
Coding: 02720100331900020002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
ROD: EV_BrakeBoostBoschMQBOMG_002.rod
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 A HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0140
Serial number: 05802861021214203802
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 291114BKT01667
Coding: 003F0720D000048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004641982
Coding: 110000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: D302
VCID: 438E89E7CA4714951E-8017
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 C
Component: VW370P3815010 H04 4492
Revision: 00H04000 CVN: 3A7DD219
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 28543E4B5321D7CD2B-807D
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 021214BL100691
Coding: 003F0120DE00048000801000
VCID: 418283EFD05B06850C-8015
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000004728683
Coding: 090000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029A00104F010200
VCID: 408486EBDB510F8D03-8015
Subsystem 1 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 900000
Subsystem 2 - Part No SW: 3D0 941 329 D HW: 3D0 941 329 D Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 900000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 000 020 E HW: 5G0 035 020 D
Component: MU-H-ND-EU H43 0376
Serial number: A310L0E7512011
Coding: 02730001FF00000011111201000802031F0209D40100010097
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 132E79A7FAA74415EE-8047
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H61 0031
Serial number: VWZ8Z9PS10152R
Subsystem 2 - Part No SW: V03 959 806 F HW: -----------
Component: ECE 2019/2020 --- 0177
Compact disc data bank:
Component: Gracenote --- 1010
Part No SW: 5Q0 907 383 F HW: 5Q0 907 383 C
Component: Anhaenger H14 0137
Revision: 8B001001 Serial number: 0355112896
Coding: 0100000202000000
VCID: 3A70F403BD8D555D4D-806F
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 284 A HW: 5QE 035 284 A
Component: OCULowMQBEU 008 0559
Coding: 027390011082BA0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 E HW: 5Q0 915 182 C
Component: BECM H05 1101
Serial number: XC160051 CVN: ACC81AF8C05121EDB797EC16B797EC16B797EC16B797EC16B797EC16B797EC16
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006042
ROD: EV_BECM06020115C6915182_AU37.rod
VCID: 356AE73F9493BA25A0-8061
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D1 H14 0481
Serial number: V013C19C1430071
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D2 H14 0481
Serial number: V013C19C1430070
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D3 H14 0481
Serial number: V013C19C1430072
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D4 H14 0481
Serial number: V013C19C1430069
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D5 H14 0481
Serial number: V013C19C1430081
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D6 H14 0481
Serial number: V013C19C1430073
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D7 H14 0481
Serial number: V013C19C1430076
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D8 H14 0481
Serial number: V013C19C1430075
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000180812
Coding: 0101020001020303000400000100000101
Shop #: WSC 37229 001 1048576
ROD: EV_MFKBoschAU370.rod
VCID: 3B7EF107B2B76C5556-806F
Part No SW: 5G0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0016
Serial number: 141121201420
VCID: 2E58C85371C589FDE1-807B
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AA HW: 5QE 915 682 K
Component: OBC KOSTAL H51 3018
Revision: -------- Serial number: 0412140KP0007U
Coding: 115068222000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0C1C62DBA7999BED2F-8059
14746880 - LED Module for Charging Socket A
P31C9 00 [009] - Electrical Malfunction
Reset counter: 227
Mileage: 204084 km
Date: 2022.09.10
Time: 17:18:23
End-------------------------(Elapsed Time: 05:46)--------------------------
and here is the scan after retrofit, all errors cleared:
Friday,07,October,2022,21:51:09:58756
VCDS Version: 22.9.0.0 (x64) HEX-NET2 CB: 0.4623.4
VIN: WVWZZZAUZFW802248 License Plate: PLA3.0-OK
Mileage: 205324km-127582mi Repair Order:
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 3C 42 44 51 52 55 5F 69
75 8C A5 A9 C6
VIN: WVWZZZAUZFW802248 Mileage: 205324km-127582miles
VCID: 2A066A8A0C71711B997-807E
Readiness: 1110 0001
VCID: 2F307B9E379314334E9-807A
Coding: 01FA40A13820316E0379060441CB2980021C8CC0608294F3F8A15078C282
VCID: 7F506BDEA77324B39E9-802A
Revision: 00001K07
VCID: 4CCA0C12A6454F2B4BB-8018
Air quality sensor:
A/C compressor sub:
H02
VCID: 0052E822DA8D5B4BE73-8054
Coding: 00A8DD
Coding: 181901
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417319131
Coding: 1271165151
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51F41D66416762C338D-8004
VCID: 382240C2C2DDD38B1F3-806C
VCID: 50F218624A6D6BCB373-8004
Coding: 333135
Coding: 333135
Coding: 0C10
VCID: 7BA89FCEB36B3893B21-802E
Coding: 07251B086FCC000800887A1B1601000000000000
VCID: 6882D082D2FD830B4F3-803C
GVL: 01543C1000000008D0CC90008000C81800000000000000000000000000000000
VCID: 46DE3E3AB829B57B9DF-8012
Coding: 2DFFFF
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0399463807
Coding: 02032103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C2A5CD2F6E5FFABFBB-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0399258882
Coding: 020321
VCID: 42D6222A9401895BB17-8016
Coding: 110000
Coding: D302
VCID: 43D8272E8B1B8053BA1-8016
VCID: 28029082127D430B8F3-807C
VCID: 41D42D2691079243A8D-8014
Coding: 090000
VCID: 40D228229A0D9B4BA73-8014
Coding: 900000
Coding: 900000
VCID: 1378D76EBBFBD0D34A1-8046
VCID: 3A265ACAFCD1C19BE97-806E
Coding: 00000000
VCID: 353C49F6D5CF2EE3045-8060
Coding: 0101020001020303000401010100000101
VCID: 3B285FCEF3EBF893F21-806E
VCID: 2E0E669A30991D3B45F-807A
VCID: 0C4ACC12E6C50F2B8BB-8058
End----------(Elapsed Time: 02:24, VBatt start/end: 13.2V/13.4V)-----------
Control Module Part Number: 5QA 919 298 D
Component and/or Version: PLA 3.0 12KH07 0050
Software Coding: 1271165151
Work Shop Code: WSC 01357
Advanced Identification/FAZIT
Identification: ATW-001
Date: 14.05.19
Manufacturer number: ED03
Test stand number: 0745
Flash Status
Programming Attempts(application): 1/0
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 00.01.01
Flash Tool Code(data): 00200 011 01357
Misc.
Hardware number: 5QA 919 298 A
Workshop System Name: J791
Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
Dataset Number: V03935287MZ
Dataset Version: 0001
ASAM Dataset Revision: 009041
VCDS Info:
Labels: 5Q0-919-298.clb
UDS Adaptation Channel (1B): MAS12843-Maneuvering brake function
Stored value activated
