- May 16, 2014
- 5,469
- 5,968
- Melbourne, Australia
- C?ID=194404
Hi VCDS Gurus!
I need some help in understanding the procedure for modifying the speedometer reading on a Golf MkVII. In essence, I want to alter the speedo reading (which currently over-estimates my speed) to more accurately indicate "true road speed". I hope to be able to do this with a commercial GPS (not the whimpy VW SATNAV), a straight section of good Aussie road and my new best friend (i.e my trusty VCDS cable).
Anyhow, I've looked at a number of sites (both here and on other forums) that explain the importance the "distance impulse number" which resides (as I understand) in the Instrument control module. This all sounds quite within my limited capabilities except that there appears not to be such a thing in the Instrument control module for my car. At first I thought that the "tire circumference" setting (see URL link below) might be an alternative, but this appears to be a red-herring.
http://i.imgur.com/Zt6YuDg.png
I've also tried to find mention of "distance impulse number" on the other control modules on the car - alas without success.
I'm prepared to give my undying gratitude to anyone that can provide advice (single syllables, no TLAs-please) as to where to re commence further research on this matter.
btw: below is the auto-scan from my car. Please ignore the two faults; nail in back tire and quarrelsome gremlins residing in central locking switch on passenger side door-damn pests!
Monday,12,May,2014,16:03:23:03521
VCDS Version: 14.4.0.3
Data version: 20140411
VIN: WVWZZZAU_________ License Plate:
Mileage: 7731km Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAU_________ Mileage: 7731km-4803miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5272
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 00028 028 00079
ASAM Dataset: EV_ECM14TFS01104E906016G 002006
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 26431A2059EACC0B1A-8073
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4510
Revision: 00043014 Serial number: CU501212296246
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ200021_AU37.rod
VCID: 76E30A60C9CAFC8B6A-8023
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 P HW: 5Q0 907 379 D
Component: ESC H75 0434
Revision: 00000000 Serial number:
Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 4999B19CE8B4C373D7-801C
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 82
Mileage: 6921 km
Date: 2014.04.15
Time: 12:26:06
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120004200100011005000012101800
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 3561CD6C944CB793A3-8060
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011234701612
Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 4385A3B4CA9819231D-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A
Component: WWS 121120 042 0551
Serial number: 121206042218
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M01D03H20M05S37S1
Coding: 00A8DD
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231233000504
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3A7BDE50BD5258EB4E-806F
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R01UHNZ
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00061
VCID: 408FACB8DB8E023B00-8015
Subsystem 1 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 357670000007612C7C0W
Subsystem 2 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 358670000006332C7C0V
Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3516502AF0CD5EC471C+
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3526502B30CD5EC2136J
Subsystem 5 - Part No SW: ----------- HW: 480 401 112 12
Serial number: 3556502B30CD5EC4008M
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 08011304220489
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 79F9015CF8D493F307-802C
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A401082380000801087A00040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
VCID: 65C15D2C646C0713D3-8030
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000188941
Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_AU37.rod
VCID: 3365F3749A38A9A38D-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290300060291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3451678601
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000046453458
Coding: 003A02208001020000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 020B66B09502D02B56-8057
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000502227
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB.rod
VCID: 3D71D54CAC7C6FD36B-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000048027940
Coding: 003A00208E01020000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 010969BC9004CB334F-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000502825
Coding: 050000
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 84
Mileage: 1048574 km
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 039 0421
Serial number: V1F00501130081
Coding: 02730008FF00000011510001000900001F0100960100010247
Shop #: WSC 43847 000 1048576
ROD: EV_MUStd4CPASE_SE37.rod
VCID: 275D17245EE0D50321-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0022
Serial number: VWZ8Z9M3400KZM
Engine Control Module 2:
Subsystem 2 - Part No SW: 5G0 919 866 A HW: -----------
Component: ROW 2013 --- 0022
End ---------------------------------------------------------------------
