'06 Rabbit Failed emissions
Gone But Not Forgotten
Yeah but those results say you fail though..........
So passes on VAG side and fails on OBD2?
What does 0x01-08-100 say?
   #22
nacg8or
The Windy City
C?ID=106971
No, both sides show failed.
Readiness Bits - 01101101
OBD status - 01000000
After over five minutes after engine start.
   #23
So you need to do each manual test for readiness and check each bit one at a time.
No good for CAT, SAI, EVAP/LDP, OXS and aged heated OXS....
Lets do LDP and Evap shared byte first.
0x01-04-071 ON ( LDP at idle )
0x01-04-070 ON ( Evap at idle ) at least operating temp I require please.
   #24
nacg8or
The Windy City
C?ID=106971
0x01-04-071 - system ok
0x01-04-070 - can't get a result. Switches between test on/test off. Been going for about 15 minutes.
   #25
This is leading me to believe your rear OXS sensors maybe faulty........a bad N80 or even a MAF
What's the duty cycle say in the fields ........please log?
What is the status of block 0x01-08-036 please?
nacg8or
The Windy City
C?ID=106971
0x01-08-36
bank 1 sensor 2 voltage = 0.470-0.475V
field 2 = test off
field 3 = blank
field 4 = blank
Sunday	14	February	2016	08:46:22:27338-VCID:364DF462412DB78E9B-8062	VCDS Version: Release 15.7.3 (x64)	Data version: 20151216
07K 906 032 P		2.5l R5/4V      G   UM04
	Group A:	'070				Group B:	 Not Running				Group C:	 Not Running
		Evap. Emissions	Oxygen Sensor	Evap. Emissions	Result
	TIME	Sol. Valve (Open)	Control Deviation	Sol. Valve (Flow)	Evap. Emissions	TIME					TIME
Marker	STAMP	 %	 %	 %		STAMP					STAMP
	0.11	0	0	99.2	Test OFF
	0.27	0	0	99.2	Test OFF
	0.4	0	0	99.2	Test OFF
	0.52	0	0	99.2	Test OFF
	0.64	0	0	99.2	Test OFF
	0.79	0	0	99.2	Test OFF
	0.92	0	0	99.2	Test OFF
	1.05	0	0	99.2	Test OFF
	1.18	0	0	99.2	Test OFF
	1.32	0	0	99.2	Test OFF
	1.45	0	0	99.2	Test OFF
	1.59	0	0	99.2	Test OFF
	1.72	0	0	99.2	Test OFF
	1.87	0	0	99.2	Test OFF
	2	0	0	99.2	Test OFF
	2.13	0	0	99.2	Test OFF
	2.26	0	0	99.2	Test OFF
	2.41	0	0	99.2	Test OFF
	2.53	0	0	99.2	Test OFF
	2.65	0	0	99.2	Test OFF
	2.78	0	0	99.2	Test OFF
	2.93	0	0	99.2	Test OFF
	3.06	0	0	99.2	Test OFF
	3.19	0	0	99.2	Test OFF
	3.33	0	0	99.2	Test OFF
	3.49	0	0	99.2	Test OFF
	3.62	0	0	99.2	Test OFF
	3.75	0	0	99.2	Test OFF
	3.87	0	0	99.2	Test OFF
	4.02	0	0	99.2	Test OFF
	4.15	0	0	99.2	Test OFF
	4.28	0	0	99.2	Test OFF
	4.4	0	0	99.2	Test OFF
	4.55	0	0	99.2	Test OFF
	4.68	0	0	99.2	Test OFF
	4.81	0	0	99.2	Test OFF
	4.93	0	0	99.2	Test OFF
	5.08	0	0	99.2	Test OFF
	5.22	0	0	99.2	Test OFF
	5.36	0	0	99.2	Test OFF
	5.5	0	0	99.2	Test OFF
	5.66	0	0	99.2	Test OFF
	5.79	0	0	99.2	Test OFF
	5.92	0	0	99.2	Test OFF
	6.04	0	0	99.2	Test OFF
	6.19	0	0	99.2	Test OFF
	6.32	0	0	99.2	Test OFF
	6.45	0	0	100	Test ON
	6.57	0	0	100	Test ON
	6.72	0	0	100	Test ON
	6.85	0	0	100	Test ON
	6.99	0	0	100	Test ON
	7.12	0	0	100	Test ON
	7.27	0	0	100	Test ON
	7.4	0	0	100	Test ON
	7.52	0	0	100	Test ON
	7.65	0	0	100	Test ON
	7.8	0	-0.8	100	Test ON
	7.93	0	0	100	Test ON
	8.06	0	0	100	Test ON
	8.2	0	0	100	Test ON
	8.36	0	0	100	Test ON
	8.49	0	0	100	Test ON
	8.62	0	0	100	Test ON
	8.74	0	0	100	Test ON
	8.89	0	0	100	Test ON
	9.02	0	0	100	Test ON
	9.15	0	0	100	Test ON
	9.27	0	0	100	Test ON
	9.42	0	0	100	Test ON
	9.55	0	0	99.2	Test ON
	9.68	2.7	0	99.2	Test ON
	9.8	2.4	0	99.2	Test ON
	9.95	3.1	0	99.2	Test ON
	10.08	3.1	0	99.2	Test ON
	10.21	3.1	0	99.2	Test ON
	10.34	3.1	0	99.2	Test ON
	10.5	0	0	99.2	Test ON
	10.63	0	0	99.2	Test OFF
	10.76	0	0	99.2	Test OFF
	10.9	0	0	99.2	Test OFF
	11.06	0	0	99.2	Test OFF
	11.19	0	0	99.2	Test OFF
	11.32	0	0	99.2	Test OFF
	11.46	0	0	99.2	Test OFF
	11.6	0	0	99.2	Test OFF
	11.72	0	0	99.2	Test OFF
	11.85	0	0	99.2	Test OFF
	11.97	0	0	99.2	Test OFF
	12.12	0	0	99.2	Test OFF
	12.25	0	0	99.2	Test OFF
	12.38	0	0	99.2	Test OFF
	12.5	0	0	99.2	Test OFF
	12.65	0	0	99.2	Test OFF
	12.78	0	0	99.2	Test OFF
	12.91	0	0	99.2	Test OFF
	13.03	0	0	99.2	Test OFF
	13.18	0	0	99.2	Test OFF
	13.31	0	0	99.2	Test OFF
	13.44	0	0	99.2	Test OFF
	13.56	0	0	99.2	Test OFF
	13.71	0	0	99.2	Test OFF
	13.85	0	0	99.2	Test OFF
	13.99	0	0	99.2	Test OFF
	14.13	0	0	99.2	Test OFF
	14.29	0	0	99.2	Test OFF
	14.42	0	0	99.2	Test OFF
	14.55	0	0	99.2	Test OFF
	14.67	0	0	99.2	Test OFF
	14.82	0	0	99.2	Test OFF
	14.95	0	0	99.2	Test OFF
	15.08	0	0	99.2	Test OFF
	15.2	0	0	99.2	Test OFF
	15.35	0	0	99.2	Test OFF
	15.48	0	0	99.2	Test OFF
	15.61	0	0	99.2	Test OFF
	15.73	0	0	99.2	Test OFF
	15.88	0	0	99.2	Test OFF
	16.02	0	0	99.2	Test OFF
	16.16	0	0	99.2	Test OFF
	16.3	0	0	99.2	Test OFF
	16.46	0	0	99.2	Test OFF
	16.59	0	0	99.2	Test OFF
	16.72	0	0	99.2	Test OFF
	16.84	0	0	99.2	Test OFF
	16.99	0	0	99.2	Test OFF
	17.12	0	0	99.2	Test OFF
	17.25	0	0	99.2	Test OFF
	17.39	0	0	99.2	Test OFF
	17.53	0	0	99.2	Test OFF
	17.65	0	0	99.2	Test OFF
	17.78	0	0	99.2	Test OFF
	17.9	0	0	99.2	Test OFF
	18.05	0	0	99.2	Test OFF
	18.18	0	0	99.2	Test OFF
	18.31	0	0	99.2	Test OFF
	18.43	0	0	99.2	Test OFF
	18.58	0	0	99.2	Test OFF
	18.72	0	0	99.2	Test OFF
	18.86	0	0	99.2	Test OFF
	19.16	0	0	99.2	Test OFF
	19.29	0	0	99.2	Test OFF
	19.42	0	0	99.2	Test OFF
	19.54	0	0	99.2	Test OFF
	19.69	0	0	99.2	Test OFF
	19.82	0	0	99.2	Test OFF
	19.95	0	0	99.2	Test OFF
	20.07	0	0	99.2	Test OFF
	20.22	0	0	99.2	Test OFF
	20.35	0	0	99.2	Test OFF
	20.48	0	0	99.2	Test OFF
	20.6	0	0	99.2	Test OFF
	20.75	0	0	99.2	Test OFF
	20.88	0	0	99.2	Test OFF
	21.01	0	0	99.2	Test OFF
	21.13	0	0	99.2	Test OFF
	21.28	0	0.8	99.2	Test OFF
	21.41	0	0.8	99.2	Test OFF
	21.53	0	0.8	99.2	Test OFF
	21.66	0	0.8	99.2	Test OFF
	21.83	0	0	99.2	Test OFF
	21.95	0	0	99.2	Test OFF
	22.09	0	0	99.2	Test OFF
	22.23	0	0	99.2	Test OFF
	22.39	0	0	99.2	Test OFF
	22.52	0	0	99.2	Test OFF
	22.64	0	0	99.2	Test OFF
	22.77	0	0	99.2	Test OFF
	22.92	0	0.8	99.2	Test OFF
	23.05	0	0.8	99.2	Test OFF
	23.18	0	0.8	99.2	Test OFF
	23.3	0	0.8	99.2	Test OFF
	23.45	0	0	99.2	Test OFF
	23.58	0	0	99.2	Test OFF
	23.71	0	0	99.2	Test OFF
	23.82	0	0	99.2	Test OFF
	23.97	0	0	99.2	Test OFF
	24.1	0	0	99.2	Test OFF
	24.23	0	0	99.2	Test OFF
	24.36	0	0	99.2	Test OFF
	24.51	0	0.8	99.2	Test OFF
	24.65	0	0.8	99.2	Test OFF
	24.78	0	0.8	99.2	Test OFF
	24.92	0	0.8	99.2	Test OFF
	25.08	0	0.8	99.2	Test OFF
	25.21	0	0.8	99.2	Test OFF
	25.34	0	0.8	99.2	Test OFF
	25.46	0	0.8	99.2	Test OFF
	25.62	0	0.8	99.2	Test OFF
	25.75	0	0.8	99.2	Test OFF
	25.87	0	0.8	99.2	Test OFF
	25.99	0	0.8	99.2	Test OFF
	26.14	0	0.8	99.2	Test OFF
	26.27	0	0	99.2	Test OFF
	26.41	0	0.8	99.2	Test OFF
	26.53	0	0.8	99.2	Test OFF
	26.67	0	0.8	99.2	Test OFF
	26.8	0	0.8	99.2	Test OFF
	26.93	0	0.8	99.2	Test OFF
	27.05	0	0.8	99.2	Test OFF
	27.2	0	0.8	99.2	Test OFF
	27.34	0	0.8	99.2	Test OFF
	27.47	0	0.8	99.2	Test OFF
	27.6	0	0.8	99.2	Test OFF
	27.75	0	0.8	99.2	Test OFF
	27.88	0	0.8	99.2	Test OFF
	28.01	0	0.8	99.2	Test OFF
	28.15	0	0.8	99.2	Test OFF
	28.31	0	0.8	99.2	Test OFF
	28.44	0	0.8	99.2	Test OFF
	28.58	0	0.8	99.2	Test OFF
	28.71	0	0.8	99.2	Test OFF
	28.86	0	0.8	99.2	Test OFF
	28.99	0	0.8	99.2	Test OFF
	29.11	0	0.8	99.2	Test OFF
	29.24	0	0.8	99.2	Test OFF
	29.38	0	0.8	99.2	Test OFF
	29.5	0	0.8	99.2	Test OFF
	29.63	0	0	99.2	Test OFF
	29.75	0	0	99.2	Test OFF
	29.9	0	0	99.2	Test OFF
	30.03	0	0	99.2	Test OFF
	30.16	0	0.8	99.2	Test OFF
	30.28	0	0.8	99.2	Test OFF
	30.43	0	0.8	99.2	Test OFF
	30.56	0	0.8	99.2	Test OFF
	30.69	0	0.8	99.2	Test OFF
	30.82	0	0.8	99.2	Test OFF
	30.98	0	0.8	99.2	Test OFF
	31.11	0	0.8	99.2	Test OFF
	31.24	0	0.8	99.2	Test OFF
	31.36	0	0.8	99.2	Test OFF
	31.51	0	0.8	99.2	Test OFF
	31.64	0	0.8	100	Test ON
	31.77	0	0.8	100	Test ON
	31.91	0	0.8	100	Test ON
	32.07	0	0.8	100	Test ON
	32.2	0	0.8	100	Test ON
	32.33	0	0.8	100	Test ON
	32.45	0	0.8	100	Test ON
	32.6	0	0.8	100	Test ON
	32.73	0	0.8	100	Test ON
	32.86	0	0.8	100	Test ON
	32.98	0	0.8	100	Test ON
	33.13	0	0.8	100	Test ON
	33.26	0	0.8	100	Test ON
	33.39	0	0.8	100	Test ON
	33.51	0	0.8	100	Test ON
	33.66	0	0.8	100	Test ON
	33.8	0	0.8	100	Test ON
	33.94	0	0.8	100	Test ON
	34.08	0	0.8	100	Test ON
	34.22	0	0.8	100	Test ON
	34.36	0	0.8	100	Test ON
	34.5	0	0.8	100	Test ON
	34.62	0	0.8	100	Test ON
	34.77	0	0.8	100	Test ON
	34.9	2.7	0.8	100	Test ON
	35.03	0	0.8	100	Test OFF
	35.15	0	0.8	100	Test OFF
	35.3	0	0.8	100	Test OFF
	35.43	0	0.8	100	Test OFF
	35.56	0	0.8	100	Test OFF
	35.68	0	0.8	100	Test OFF
	35.83	0	0.8	100	Test OFF
	35.96	0	0.8	100	Test OFF
	36.09	0	0.8	100	Test OFF
	36.22	0	0.8	100	Test OFF
	36.38	0	0.8	100	Test OFF
	36.51	0	0.8	100	Test OFF
	36.64	0	0.8	100	Test OFF
	36.78	0	0.8	100	Test OFF
	36.94	0	0.8	100	Test OFF
	37.07	0	0.8	100	Test OFF
	37.2	0	0.8	100	Test OFF
	37.34	0	0.8	100	Test OFF
	37.49	0	0.8	100	Test OFF
	37.62	0	0.8	100	Test OFF
	37.75	0	0.8	100	Test OFF
	37.89	0	0.8	100	Test OFF
	38.05	0	0.8	100	Test OFF
	38.18	0	0.8	100	Test OFF
	38.31	0	0.8	100	Test OFF
	38.45	0	0.8	100	Test OFF
	38.61	0	0.8	100	Test OFF
	38.74	0	0.8	100	Test OFF
	38.87	0	0.8	100	Test OFF
	39.01	0	0.8	100	Test OFF
	39.16	0	0.8	100	Test OFF
	39.29	0	0.8	100	Test OFF
	39.42	0	0.8	100	Test OFF
	39.56	0	0.8	100	Test OFF
	39.72	0	0.8	100	Test OFF
	39.85	0	0.8	100	Test OFF
	39.98	0	0.8	100	Test OFF
	40.12	0	0.8	100	Test OFF
	40.28	0	0.8	100	Test OFF
	40.41	0	0.8	100	Test OFF
	40.54	0	0.8	100	Test OFF
	40.66	0	0.8	100	Test OFF
	40.81	0	0.8	100	Test OFF
	40.94	0	0.8	100	Test OFF
	41.07	0	0.8	100	Test OFF
	41.21	0	0.8	100	Test OFF
	41.36	0	0.8	100	Test OFF
	41.49	0	0.8	100	Test OFF
	41.62	0	0.8	100	Test OFF
	41.76	0	0.8	100	Test OFF
	41.92	0	0.8	100	Test OFF
	42.05	0	0.8	100	Test OFF
	42.18	0	0.8	100	Test OFF
	42.3	0	0.8	100	Test OFF
	42.45	0	0.8	100	Test OFF
	42.58	0	0.8	100	Test OFF
	42.71	0	0.8	100	Test OFF
	42.85	0	0.8	100	Test OFF
	43.01	0	0.8	100	Test OFF
	43.14	0	0.8	100	Test OFF
	43.27	0	0.8	100	Test OFF
	43.39	0	0.8	100	Test OFF
	43.54	0	0.8	100	Test OFF
	43.67	0	0.8	100	Test OFF
	43.8	0	0.8	100	Test OFF
	43.94	0	0.8	100	Test OFF
	44.09	0	0.8	100	Test OFF
	44.22	0	0.8	100	Test OFF
	44.35	0	0.8	100	Test OFF
	44.49	0	0.8	100	Test OFF
	44.65	0	0.8	100	Test OFF
	44.78	0	0.8	100	Test OFF
	44.91	0	0.8	100	Test OFF
	45.05	0	0.8	100	Test OFF
	45.21	0	0.8	100	Test OFF
	45.34	0	0.8	100	Test OFF
	45.47	0	0.8	100	Test OFF
	45.59	0	0.8	100	Test OFF
	45.74	0	1.6	100	Test OFF
	45.88	0	1.6	100	Test OFF
	46.02	0	0.8	100	Test OFF
	46.16	0	0.8	100	Test OFF
	46.32	0	0.8	100	Test OFF
	46.45	0	0.8	100	Test OFF
	46.58	0	0.8	100	Test OFF
	46.69	0	0.8	100	Test OFF
	46.84	0	0.8	100	Test OFF
	46.97	0	0.8	100	Test OFF
	47.11	0	0.8	100	Test OFF
	47.23	0	0.8	100	Test OFF
	47.38	0	0.8	100	Test OFF
	47.51	0	0.8	100	Test OFF
	47.64	0	0.8	100	Test OFF
	47.75	0	0.8	100	Test OFF
	47.91	0	0.8	100	Test OFF
	48.04	0	0.8	100	Test OFF
	48.17	0	0.8	100	Test OFF
	48.29	0	0.8	100	Test OFF
	48.44	0	0.8	100	Test OFF
	48.57	0	0.8	100	Test OFF
	48.69	0	0.8	100	Test OFF
	48.81	0	0.8	100	Test OFF
	48.96	0	0.8	100	Test OFF
	49.1	0	0.8	100	Test OFF
	49.24	0	0.8	100	Test OFF
	49.39	0	0.8	100	Test OFF
	49.55	0	0.8	100	Test OFF
	49.68	0	0.8	100	Test OFF
	49.8	0	0.8	100	Test OFF
	49.93	0	0.8	100	Test OFF
	50.08	0	0.8	100	Test OFF
	50.2	0	0.8	100	Test OFF
	50.33	0	0.8	100	Test OFF
	50.46	0	0.8	100	Test OFF
	50.6	0	0.8	100	Test OFF
	50.74	0	0.8	100	Test OFF
	50.86	0	0.8	100	Test OFF
	50.98	0	0.8	100	Test OFF
	51.13	0	0.8	100	Test OFF
	51.26	0	0.8	100	Test OFF
	51.39	0	1.6	100	Test OFF
	51.51	0	0.8	100	Test OFF
	51.66	0	1.6	100	Test OFF
	51.8	0	1.6	100	Test OFF
	51.92	0	1.6	100	Test OFF
	52.04	0	1.6	100	Test OFF
	52.19	0	0.8	100	Test OFF
	52.33	0	0.8	100	Test OFF
	52.47	0	0.8	100	Test OFF
	52.61	0	0.8	100	Test OFF
	52.77	0	0.8	100	Test OFF
	52.9	0	0.8	100	Test OFF
	53.03	0	0.8	100	Test OFF
	53.15	0	0.8	100	Test OFF
	53.3	0	0.8	100	Test OFF
	53.43	0	0.8	100	Test OFF
	53.56	0	0.8	100	Test OFF
	53.68	0	0.8	100	Test OFF
	53.83	0	0.8	100	Test OFF
	53.96	0	0.8	100	Test OFF
	54.1	0	0.8	100	Test OFF
	54.21	0	0.8	100	Test OFF
	54.36	0	0.8	100	Test OFF
	54.49	0	0.8	100	Test OFF
	54.62	0	0.8	100	Test OFF
	54.75	0	0.8	100	Test OFF
	54.91	0	0.8	100	Test OFF
	55.04	0	0.8	100	Test OFF
	55.17	0	0.8	100	Test OFF
	55.29	0	0.8	100	Test OFF
	55.44	0	0.8	100	Test OFF
	55.57	0	0.8	100	Test OFF
	55.7	0	0.8	100	Test OFF
	55.84	0	0.8	100	Test OFF
	56.13	0	0.8	100	Test ON
	56.26	0	0.8	100	Test ON
	56.38	0	0.8	100	Test ON
	56.53	0	0.8	100	Test ON
	56.66	0	0.8	100	Test ON
	56.79	0	0.8	100	Test ON
	56.91	0	0.8	100	Test ON
	57.06	0	0.8	100	Test ON
	57.19	0	0.8	100	Test ON
	57.32	0	0.8	100	Test ON
	57.44	0	0.8	100	Test ON
	57.59	0	0.8	100	Test ON
	57.73	0	0.8	100	Test ON
	57.87	0	0	100	Test ON
	58.01	0	0	100	Test ON
	58.15	0	0.8	100	Test ON
	58.27	0	0.8	100	Test ON
	58.4	0	0.8	100	Test ON
	58.52	0	0.8	100	Test ON
	58.67	0	0.8	100	Test ON
	58.8	0	0.8	100	Test ON
	58.93	0	0.8	100	Test ON
	59.07	0	0.8	100	Test ON
	59.21	0	0.8	100	Test ON
	59.33	0	0.8	100	Test ON
	59.46	2.7	0.8	100	Test ON
	59.58	3.1	0.8	100	Test ON
	59.73	3.1	0	100	Test ON
	59.86	3.1	0.8	99.2	Test ON
	59.99	3.1	0.8	99.2	Test ON
	60.11	3.5	0.8	99.2	Test ON
	60.26	3.5	0.8	99.2	Test ON
	60.39	3.5	0.8	99.2	Test ON
	60.52	3.5	0.8	99.2	Test ON
	60.64	3.1	0.8	99.2	Test ON
	60.79	3.5	0.8	98.4	Test ON
	60.92	3.5	0.8	98.4	Test ON
	61.05	3.9	0.8	98.4	Test ON
	61.17	3.9	0.8	97.7	Test ON
	61.32	4.3	0.8	97.7	Test ON
	61.45	5.1	0.8	96.9	Test ON
	61.58	5.5	0.8	96.9	Test ON
	61.7	5.5	0.8	96.9	Test ON
	61.85	5.9	0.8	96.1	Test ON
	61.99	6.3	0.8	95.3	Test ON
	62.11	6.7	0.8	95.3	Test ON
	62.24	6.7	0.8	94.5	Test ON
	62.4	7.5	0.8	94.5	Test ON
	62.53	7.5	0.8	93.8	Test ON
	62.66	8.6	0.8	93	Test ON
	62.78	0	0	93	Test ON
	62.93	0	0	93	Test OFF
	63.06	0	0	93	Test OFF
	63.19	0	-0.8	93	Test OFF
	63.31	0	0.8	93	Test OFF
	63.46	0	0.8	93	Test OFF
	63.59	0	0.8	93	Test OFF
	63.72	0	0.8	93	Test OFF
	63.84	0	0.8	93	Test OFF
	63.99	0	0.8	93	Test OFF
	64.12	0	0.8	93	Test OFF
	64.25	0	0.8	93	Test OFF
	64.37	0	0.8	93	Test OFF
	64.52	0	0.8	93	Test OFF
	64.65	0	0.8	93	Test OFF
	64.78	0	0.8	93	Test OFF
	64.9	0	0.8	93	Test OFF
	65.05	0	0.8	93	Test OFF
	65.18	0	0.8	93	Test OFF
	65.31	0	0.8	93	Test OFF
	65.43	0	0.8	93	Test OFF
	65.58	0	0.8	93	Test OFF
	65.72	0	0.8	93	Test OFF
	65.86	0	0.8	93	Test OFF
	66	0	0.8	93	Test OFF
	66.16	0	0.8	93	Test OFF
	66.29	0	0.8	93	Test OFF
	66.42	0	0.8	93	Test OFF
	66.54	0	0.8	93	Test OFF
	66.69	0	0.8	93	Test OFF
	66.82	0	0.8	93	Test OFF
	66.95	0	0.8	93	Test OFF
	67.07	0	0.8	93	Test OFF
	67.22	0	0.8	93	Test OFF
	67.35	0	0.8	93	Test OFF
	67.48	0	0.8	93	Test OFF
	67.6	0	0.8	93	Test OFF
	67.75	0	0.8	93	Test OFF
	67.89	0	0.8	93	Test OFF
	68.03	0	0.8	93	Test OFF
	68.17	0	0.8	93	Test OFF
	68.33	0	0.8	93	Test OFF
	68.46	0	0.8	93	Test OFF
	68.59	0	0.8	93	Test OFF
	68.71	0	0.8	93	Test OFF
	68.86	0	0.8	93	Test OFF
	68.99	0	0.8	93	Test OFF
	69.12	0	0.8	93	Test OFF
	69.24	0	0.8	93	Test OFF
	69.39	0	0.8	93	Test OFF
	69.52	0	0.8	93	Test OFF
	69.65	0	0	93	Test OFF
	69.77	0	0	93	Test OFF
I assume that since field 1 never shows anything bu 0% that a valve is never opening and therefore faulty. Is that the N80?
Please change the N80 and do the test at 0x01-04-036 and log it before so.
   #28
nacg8or
The Windy City
C?ID=106971
I finally got the N80 replaced. Test 0x01-04-036 just shows between 0.435 and 0.445 in the first field. The second field just reads Test Off and the last two fields are blank just as before.
0x01-04-71 = system ok
0x01-04-70 = evap ok
Still showing four failed/incomplete modes.
Okay now these please one by one.
Please report current status with auto-scan.........
01-04-077-ON ( Secondary air test ) ( It is normal for this test to abort and may need to be done last on some controllers, however, always check DTC's after test )
01-04-028-ON ( Knock sensor test )
01-04-094/096-ON ( Vario cam timing test )
01-04-030-ON ( Heated OXS bin bits spec 111 front and 110 for rear )
01-04-034/035-ON ( Forward OXS test )
01-04-036-ON ( Rear OXS test )
01-04-037/038-ON ( Age test OXS )
01-04-041/042-ON ( Heater circuit resistance display )
01-04-043/044-ON ( Additional OXS test )
01-04-046-ON ( CAT test )
On stubborn cars!~
Additional tests can be seen from blocks 210 on up in ME7.1.1
Most use the standard Bosch test method for binary displays in field 4 last 3 bits ( 100 pass or 111/001/101 Testing active, FAILED TEST/NOT PREFORMED or DTC present )
   #30
nacg8or
The Windy City
C?ID=106971
here's the scan prior to going through the tests.
Saturday,20,February,2016,12:56:53:27338
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWCR71K26W177179   License Plate:
Mileage: 118230km-73464mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWCR71K26W177179   Mileage: 118230km-73464miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 P    HW: Hardware No
   Component: 2.5l R5/4V      G   UM04
   Revision: --------    Serial number: VWZ7Z0F3690851
   Coding: 0000001
   Shop #: WSC 00001 000 00000
   VCID: 364DF462412DB78E94-8062
Readiness: 0110 1001
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   Shop #: WSC 01316 785 00200
   VCID: 71C7077E68C3D0B681-8024
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 69F76F1E40132876C9-803C
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000077764
   Coding: 018D8F294004150000140000000000000029770F5C
   VCID: 2F43C106BE778646D7-807A
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 12345
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7F5042278
   VCID: 2B7BD5168A6FFA66FB-807E
            000 -  -
                    Fault Frequency: 9
                    Reset counter: 74
                    Mileage: 118102 km
                    Time: 06:27:17
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 5L AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD05HBD%
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 3957FF5E703358F679-806C
   Subsystem 1 - Part No: 1K0 959 339 D
   Component: BF-Gewichtsens. 006 0006
   Subsystem 2 - Serial number: 6332MSME0E69492FU
   Subsystem 3 - Serial number: 6342MSME106C16211
   Subsystem 4 - Serial number: 6352QSME0A06223DD
   Subsystem 5 - Serial number: 6362QSME0B2331457
   Subsystem 6 - Serial number: 63727SME09770B497
   Subsystem 7 - Serial number: 63827SME09770E6FJ
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000022
   Shop #: WSC 01279 785 00200
   VCID: 78D13A5A0BB981FE46-802C
   Part No: 1K0 920 953 C
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0007203
   Shop #: WSC 02132 444 77402
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010633005AF
   Coding: 3D3F0360070002
   VCID: 2A75D0128595E36E00-807E
   Component: IMMO            VDD 4312
   Shop #: WSC 57076 001 1048576
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2373
   Coding: 0001205
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 334BCD76525FA2A6B3-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 1AF8030C3E2C0488C80F048050CC
   VCID: 74C90E6A17D1E59E6A-8020
   Part No: 1K0 959 702 K
   Coding: 0001205
   VCID: 3753F96646274E868F-8062
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio PM6       016 0017
   Revision: 00016000    Serial number: VWZ5Z7F2060580
   Coding: 0040400
   VCID: 2061323AF3A9293E5E-8074
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2438
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 3449CE6A5751A59EAA-8060
End-------------------------(Elapsed Time: 01:17)--------------------------
Here are the results of the individual tests.
01-04-077 = test never starts. test off appears continually
01-04-028 = test never starts. test off appears continually
01-04-094 = system ok
01-04-095 = all fields blank
01-04-096 = all fields blank
01-04-030 = bank 1 sensor 1 = 00011, bank 1 sensor 2 = 0000 and flashes briefly 0100 from time to time
01-04-034 = 680 /min Engine Speed, 300.0°C Catalytic Converter Temperature, 0.961 Period Duration Sensor, Test OFF Result Lambda Aging
01-04-035 = all fields blank
01-04-036 = bank 1 sensor 2 0.715V, b1-s2 ok
01-04-037 = engine load 18%, voltage 0.735V, 0.000, tests on - the test never seems to conclude.
01-04-038 = all fields blank
01-04-042 = all fields blank
01-04-044 = all fields blank
01-04-046 = 680rpm, blank, 0.00, test off
I haven't looked at blocks 210 and up due to time constraint but wanted to post this in the mean time.
   #31
Maybe we should do a skype session with me remoting in and you following the orders?
Let me know.....
   #33
nacg8or
The Windy City
C?ID=106971
This is where we stand as of today. Down to two failed elements.
 Sunday,21,February,2016,16:32:40:27338
Readiness Status: 0000 1001
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Seconday Air Injection: Failed or Incomplete
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Just got back from grocery shopping and saw your PM.
I want you to take the car down the road and get the CATs temp up to at least 700c degrees or higher.
Select lower gears to do this.
Than once this is done, please start select test 0x01-04-046 and drive at slow speeds until you see the test start........ then hold that RPM.
Use 100 RPM increments at a time please, and wait for each at least .5 of a mile to see a test activate.
nacg8or
The Windy City
C?ID=106971
I'll see if I can get this done tonight.
Any thoughts on the SAI?
   #36
I want SAI done last.
Usually often enough...... it tests OK & is a withheld test from display, or being saved to eeprom; until the CAT 046/047 is preformed and saved via key cycle.
nacg8or
The Windy City
C?ID=106971
Ok. The cat shows passed in readiness status. I'm not sure how since it didn't seem the test ever started but maybe it cycled after I unplugged the battery to replace the N80. SAI is the only one left that shows failed.
   #38
Okay .........now that all of them are done, with exception of SAI.
I want you to cold start and immediately run the SAI test after you hit a temp of ECT 80 c.
0x01-04-077 PLEASE!
   #39
nacg8or
The Windy City
C?ID=106971
0x01-04-077 PLEASE!
Ran the test when the coolant reached 80°C but the test never seems to do anything. Secondary Air Injection always reads 0.0% and it always reads test off as it has every time I've tried.
   #40
You have to do all tests again one by one, and that one last in the same session.
Have you tried 0x01-04 binary tests in the upper 210> to 255 range?
