here's the scan prior to going through the tests.
Saturday,20,February,2016,12:56:53:27338
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWCR71K26W177179 License Plate:
Mileage: 118230km-73464mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWCR71K26W177179 Mileage: 118230km-73464miles
03- Brakes -- Status: OK 0000
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 P HW: Hardware No
Component: 2.5l R5/4V G UM04
Revision: -------- Serial number: VWZ7Z0F3690851
Coding: 0000001
Shop #: 00001 000 00000
VCID: 364DF462412DB78E94-8062
Readiness: 0110 1001
Address 03: Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
Shop #: 01316 785 00200
VCID: 71C7077E68C3D0B681-8024
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
Shop #: 00000 000 00000
VCID: 69F76F1E40132876C9-803C
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000077764
Coding: 018D8F294004150000140000000000000029770F5C
Shop #: 12345 123 12345
VCID: 2F43C106BE778646D7-807A
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: 12345
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7F5042278
VCID: 2B7BD5168A6FFA66FB-807E
Fault Frequency: 9
Reset counter: 74
Mileage: 118102 km
Time: 06:27:17
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD05HBD%
Coding: 0013644
Shop #: 01269 785 00200
VCID: 3957FF5E703358F679-806C
Subsystem 1 - Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Subsystem 2 - Serial number: 6332MSME0E69492FU
Subsystem 3 - Serial number: 6342MSME106C16211
Subsystem 4 - Serial number: 6352QSME0A06223DD
Subsystem 5 - Serial number: 6362QSME0B2331457
Subsystem 6 - Serial number: 63727SME09770B497
Subsystem 7 - Serial number: 63827SME09770E6FJ
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000022
Shop #: 01279 785 00200
VCID: 78D13A5A0BB981FE46-802C
Part No: 1K0 920 953 C
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007203
Shop #: 02132 444 77402
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010633005AF
Coding: 3D3F0360070002
VCID: 2A75D0128595E36E00-807E
Component: IMMO VDD 4312
Shop #: 57076 001 1048576
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2373
Coding: 0001205
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 334BCD76525FA2A6B3-8066
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 1AF8030C3E2C0488C80F048050CC
VCID: 74C90E6A17D1E59E6A-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001205
VCID: 3753F96646274E868F-8062
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7F2060580
Coding: 0040400
VCID: 2061323AF3A9293E5E-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2438
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3449CE6A5751A59EAA-8060
End-------------------------(Elapsed Time: 01:17)--------------------------
Here are the results of the individual tests.
01-04-077 = test never starts. test off appears continually
01-04-028 = test never starts. test off appears continually
01-04-094 = system ok
01-04-095 = all fields blank
01-04-096 = all fields blank
01-04-030 = bank 1 sensor 1 = 00011, bank 1 sensor 2 = 0000 and flashes briefly 0100 from time to time
01-04-034 = 680 /min Engine Speed, 300.0°C Catalytic Converter Temperature, 0.961 Period Duration Sensor, Test OFF Result Lambda Aging
01-04-035 = all fields blank
01-04-036 = bank 1 sensor 2 0.715V, b1-s2 ok
01-04-037 = engine load 18%, voltage 0.735V, 0.000, tests on - the test never seems to conclude.
01-04-038 = all fields blank
01-04-042 = all fields blank
01-04-044 = all fields blank
01-04-046 = 680rpm, blank, 0.00, test off
I haven't looked at blocks 210 and up due to time constraint but wanted to post this in the mean time.
