Made a stupid mistake because I was in a hurry and when I had a dead battery I used my battery booster to jump my 2012 GTI. Unfortunately for me I didn't pay close enough attention to the polarity and had reversed the leads to the battery which has induced what seems to be multiple abstract failures within my baby.
So far, I have verified that all fuses (in cabin & engine compartment) are good and the battery (which was dead at the time) has been replaced with a brand new one. The relays inside the engine compartment fuse box are also good (check operation and resistance).
Symptoms:
Put key in and turn to ACC, standard operation, lights on dash come on, flash, etc. as usual. When turning to key to crank there is no difference from ACC. In other words the car does not attempt to turn over. It appears to do nothing at all. I have checked the headlights' intensity (as well as the dome lights) when performing this as there is no dimming taking place which leads me to believe that wiring is good.
All that being said, I am a new VCDS user (with a small bit of experience previously) but an avid VW fan. I have chipped my previous VW and am very familiar/comfortable with tweaking engines for performance. I am a web developer so I am also familiar with coding and programming logic and I was an Electronics Technician in the Navy so I have a very good understanding of technical jargon.
Below are my results from my autoscan. I certainly appreciate anyone's time in advance that can point me in the direction that I need to go regarding my next steps as far as deciphering these results and proceeding with the repair. Thank you guys for taking the time to read this.
Symptoms:
Saturday,09,January,2016,14:00:09:40722
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 15.7.3.0 (x64)
Data version: 20151216
Dealer/Shop Name: Price House
VIN: WVWHD7AJ6CW3xxxxx License Plate: DVW
Mileage: 99320km-61714mi Repair Order: January-2016
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
VIN: WVWHD7AJ6CW3xxxxx Mileage: 99320km-61714miles
Address 01: Engine Labels:
VCID: 55E24A7CAC9E449672-FFFF
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 R HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3115
Revision: 05551213 Serial number: 00001203231314
VCID: 281C33889B6C097E19-807D
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Fault Frequency: 255
Reset counter: 40
Mileage: 99323 km
Date: 2016.01.04
Time: 00:01:45
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C49230002880B06E592210041B70800
VCID: 7BB63CC4FA7A72E624-802F
02214 - Tire Pressure Warning
Reset counter: 173
Mileage: 93450 km
Date: 2015.10.27
Time: 12:02:02
Count: 32768
Count: 4608
Count: 16401
Count: 50176
Count: 512
Count: 256
Reset counter: 61
Mileage: 99323 km
Date: 2016.01.04
Time: 13:16:50
Count: 3
Count: 15
Count: 28672
Count: 16390
Count: 34048
Count: 509
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
VCID: 004C4B289B9C113E71-8055
Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 6F180A1A90272AC4008800C170000D4448052086434D8D20E48420240040
VCID: 3D32F2DCA4EEBCD65A-8069
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 30031 26 0512
Coding: 009795
7 Faults Found:
Reset counter: 99
Mileage: 99229 km
Date: 2016.01.03
Time: 13:23:21
Term 15 Off
Voltage: 11.80 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 13:17:59
Term 15 Off
Voltage: 8.10 V
Term 50 Off
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 00:00:14
Term 15 Off
Voltage: 7.90 V
Term 50 Off
01259 - Fuel Pump Relay (J17)
Fault Status: 00101001
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 06:09:54
Term 15 Off
Voltage: 12.40 V
Term 50 Off
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 01:57:09
Term 15 Off
Voltage: 12.20 V
Term 50 Off
02391 - Terminal 30 Reference
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 01:58:00
Term 15 Off
Voltage: 12.20 V
Term 50 Off
01516 - Terminal 30; Left
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 00:01:41
Term 15 Off
Voltage: 12.20 V
Term 50 Off
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1Z789
Coding: 00003131
VCID: 3FCE88D4A6E2AEC648-806B
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002NDA00
Serial number: 3572MSME7B28746DZZZ8
Serial number: 3582MSME0222626CZZZQ
Serial number: 3512QSME74510F40ZZZR
Serial number: 3522QSME42570F49ZZZ
Serial number: 35527SME6A4A322CZZZP
Serial number: 35627SME4C72322CZZZL
13635840 - Supply voltage
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 13:17:50
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 13:17:06
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LCQ000YQ
Coding: 189A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76A02DF0C9582F8E5B-8023
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Serial number: 0007204
Coding: 830000
Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
Component: KOMBI H03 0607
Coding: 270F01
VCID: 3620EDF089D86F8E9B-8063
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 270312F1002413
Coding: 350002
VCID: 3A38F9C0B5C08BEE7F-806F
Component: IMMO H03 0607
VCID: 6A9809808DE0FB6ECF-803F
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662257640
Coding: 020000
VCID: 291A368C4066307606-807D
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H35 0265
Serial number: VWZAZ2M4213046
Coding: 04000401040005000000100A
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: 230624A42A4AEA264C-8077
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
1048580 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 101
Mileage: 99323 km
Date: 2016.01.04
Time: 13:17:10
1048584 - Function limitation due to excessive temperature
B1050 00 [008] - -
Reset counter: 74
Mileage: 98131 km
Date: 2015.12.21
Time: 14:09:59
1048653 - CD ROM Drive
B1100 07 [008] - Mechanical Failure
Reset counter: 18
Mileage: 95879 km
Date: 2015.11.24
Time: 12:07:31
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 2
Mileage: 7898 km
Date: 2012.12.22
Time: 08:45:26
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2105
Coding: 0001204
VCID: 373EE0F446D2968680-8063
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 6.5 V
PD
Temperature: 29.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3228D1E0ADB073AEB7-8067
Component: AFS-Steuergeraet 0148
Coding: 1446940
VCID: 3424D7F857A47D9EA5-8061
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3522EAFC5CDE649692-8061
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 3620EDF041D86F8E9B-8063
End-------------------------(Elapsed Time: 01:43)--------------------------
Control Module Part Number: 02E 300 057 R HW: 02E 927 770 AL
Component and/or Version: GSG DSG AG6 512 3115
Software Coding: 0000020
Work Shop Code: WSC 01357 011 00200
U0235 - 000 -
Reset counter: 40
Mileage: 99323 km
Date: 2016.01.04
Time: 00:01:45
U0235 - 000 -
Reset counter: 40
Mileage: 99323 km
Date: 2016.01.04
Time: 00:01:45
