Can anyone help/suggest what to do with these fault codes please
Wednesday,25,November,2015,18:10:33:17628
VCDS Version: 15.7.1.0
Data version: 20150904
Dealer/Shop Name: TDMCK
VIN: WAUZZZ8TX8A023465 License Plate: A5 LAST AFTER
Mileage: 155600km-96685mi Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 77
VIN: WAUZZZ8TX8A023465 Mileage: 155600km-96685miles
Address 01: Engine (J623-CAPA) Labels: 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0114002C180F0118
Shop #: WSC 18207 000 1048576
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5.rod
VCID: 2E594FE17153994EFF-807A
5188 - Diesel Particulate Filter (Bank 1)
P242F 00 [167] - Restricted/Clogged
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:37
4996 - Glow Plug Control Module (J179)
P0684 00 [101] - Implausible Signal
Mileage: 155606 km
Date: 2007.08.01
Time: 00:18:01
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:37
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 L HW: 8K0 907 379 L
Component: ESP8 quattro H03 0170
Coding: 1B0500
Shop #: WSC 06325 123 12345
VCID: 42810B51DDCB0D2E0B-8016
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0251
Revision: 00003002
Coding: 031000
Shop #: WSC 06325 000 00000
VCID: 39736CBDB01D4EF65A-806C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H35 0052
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Part No SW: 8T2 820 043 M HW: 8T2 820 043 M
Component: KLIMA 3 ZONEN H05 0120
Revision: D0000000 Serial number: 0121.11.070384
Coding: 36060000
VCID: 3C7D75A9BF2F7BDE41-8068
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:33
Temperature: 11.0°C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:33
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0252
Revision: 04021001 Serial number: 00000000049151
Coding: 260050914014AF010009000000005D5D001D038800010141000000
VCID: 2F6752E57E599046F4-807A
Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 061107 H11 0040
Coding: 00FD11
Component: RLS H04 0002
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
01232 - A/C Compressor Regulator Valve (N280)
Fault Status: 00101100
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:17:00
014 - Defective
Fault Status: 01101110
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:00
014 - Defective
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:14:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330733400359
VCID: 387569B98B1757FEA5-806C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD121C8O
Coding: 30323433363030303030554A305238543053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D75A9B72F7BDE41-8068
Serial number: 6334MSME2832232FA
Serial number: 6344MSME283606469
Serial number: 6352QSME47443957K
Serial number: 6362QSME4507233DF
Serial number: 63732SME464C3D413
Serial number: 63832SME4427445B+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90315GKL0001O
Coding: 000016
VCID: 3D7B78ADA43572D676-8068
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H26 0214
Revision: 00000000 Serial number: 71Y16DT97
Coding: 2F05010002002600010000
VCID: 3B7F76B5BA217CE648-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
Component: GW-BEM 5CAN H04 0084
Revision: GA801030 Serial number: 3000G07A14814F
Coding: 000003
Shop #: WSC 00899 210 89303
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
Component: TSG FA H09 0146
Revision: Serial number: bg
Coding: 0110022240012201
VCID: 3E797FA1A93369CE6F-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00003002 Serial number: 0107196337
Coding: 011B068200390440002000
Component: DWA-Sensor H02 0030
02737 - Bulb for Tail/Fog Light; Right
Fault Status: 11101100
Reset counter: 134
Mileage: 155606 km
Date: 2007.08.01
Time: 00:17:49
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 J HW: 8T0 035 223
Component: DSP STD H07 0210
Revision: S1700000
Coding: 0203010102
VCID: 356B608D9C05AA96BE-8060
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
Component: TSG BF H09 0146
Revision: Serial number: ‡d
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000032746
Part No: 8K0 907 357 A
VCID: 336F5E955271B4A690-8066
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 B HW: 8T2 035 186 B
Component: Concert3 H11 0130
Revision: 00000511 Serial number: AUZ5Z6G1007451
Coding: 0002008201048D00035B070000
VCID: 37776A8586095886AC-8062
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Part No SW: 8T0 862 335 B HW: 8T0 862 335 B
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005028521
Coding: 0010320
VCID: 39736CBD701D4EF65A-806C
End-------------------------(Elapsed Time: 03:07)--------
