Audi A5 3.0 TDi V6 DPF Fault codes
TD&MCK Car Sales
C?ID=160148
Can anyone help/suggest what to do with these fault codes please
Wednesday,25,November,2015,18:10:33:17628
VCDS Version: 15.7.1.0
Data version: 20150904
Dealer/Shop Name: TDMCK
VIN: WAUZZZ8TX8A023465   License Plate: A5 LAST AFTER
Mileage: 155600km-96685mi   Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 77
VIN: WAUZZZ8TX8A023465   Mileage: 155600km-96685miles
Address 01: Engine (J623-CAPA)       Labels: 059-907-401-V1.clb
   Part No SW: 8K0 907 401 F    HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0002
   Revision: --H01---
   Coding: 0114002C180F0118
   Shop #: WSC 18207 000 1048576
   ASAM Dataset: EV_ECM30LTDIA5 A02002
   ROD: EV_ECM30LTDIA5.rod
   VCID: 2E594FE17153994EFF-807A
5188 - Diesel Particulate Filter (Bank 1)
          P242F 00 [167] - Restricted/Clogged
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:37
4996 - Glow Plug Control Module (J179)
          P0684 00 [101] - Implausible Signal
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:18:01
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:37
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 L    HW: 8K0 907 379 L
   Component: ESP8 quattro  H03 0170
   Coding: 1B0500
   Shop #: WSC 06325 123 12345
   VCID: 42810B51DDCB0D2E0B-8016
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0251
   Revision: 00003002
   Coding: 031000
   Shop #: WSC 06325 000 00000
   VCID: 39736CBDB01D4EF65A-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H35 0052
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D0000000    Serial number: 0121.11.070384
   Coding: 36060000
   VCID: 3C7D75A9BF2F7BDE41-8068
                    Fault Status: 01101000
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:33
                    Temperature: 11.0°C
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:33
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0252
   Revision: 04021001    Serial number: 00000000049151
   Coding: 260050914014AF010009000000005D5D001D038800010141000000
   VCID: 2F6752E57E599046F4-807A
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 061107  H11 0040
   Coding: 00FD11
   Component: RLS  H04 0002
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
01232 - A/C Compressor Regulator Valve (N280)
                    Fault Status: 00101100
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:17:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:00
            014 - Defective
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:14:00
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330733400359
   VCID: 387569B98B1757FEA5-806C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD121C8O
   Coding: 30323433363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C7D75A9B72F7BDE41-8068
   Serial number: 6334MSME2832232FA
   Serial number: 6344MSME283606469
   Serial number: 6352QSME47443957K
   Serial number: 6362QSME4507233DF
   Serial number: 63732SME464C3D413
   Serial number: 63832SME4427445B+
   Component: Lenks.Modul   H10 0012
   Revision: --------    Serial number: 90315GKL0001O
   Coding: 000016
   VCID: 3D7B78ADA43572D676-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
   Component: KOMBIINSTR.   H26 0214
   Revision: 00000000    Serial number: 71Y16DT97
   Coding: 2F05010002002600010000
   VCID: 3B7F76B5BA217CE648-806E
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA801030    Serial number: 3000G07A14814F
   Coding: 000003
   Shop #: WSC 00899 210 89303
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
   Component: TSG FA        H09 0146
   Revision:             Serial number: bg
   Coding: 0110022240012201
   VCID: 3E797FA1A93369CE6F-806A
   Revision: 00003002    Serial number: 0107196337
   Coding: 011B068200390440002000
   Component: DWA-Sensor  H02 0030
02737 - Bulb for Tail/Fog Light; Right
                    Fault Status: 11101100
                    Reset counter: 134
                    Mileage: 155606 km
                    Date: 2007.08.01
                    Time: 00:17:49
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010102
   VCID: 356B608D9C05AA96BE-8060
   Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
   Component: TSG BF        H09 0146
   Revision:             Serial number: ‡d
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0040
   Revision: 00000003    Serial number: 00000000032746
   Part No: 8K0 907 357 A
   Coding: 0000002
   VCID: 336F5E955271B4A690-8066
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 B    HW: 8T2 035 186 B
   Component: Concert3      H11 0130
   Revision: 00000511    Serial number: AUZ5Z6G1007451
   Coding: 0002008201048D00035B070000
   VCID: 37776A8586095886AC-8062
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 8T0 862 335 B    HW: 8T0 862 335 B
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005028521
   Coding: 0010320
   VCID: 39736CBD701D4EF65A-806C
End-------------------------(Elapsed Time: 03:07)--------
Robski
Yorkshire
C?ID=111643
it seems beyond you this type of stuff from what I read & with the money you've spent so far would have probably paid an Indy to diagnose/fix. Read the fault descriptions then apply a test plan to prove what they are telling you or not ........... if you don't understand the system either employ someone that does or learn from the correct documentation.
TD&MCK Car Sales
C?ID=160148
Only way to learn !!!!
Robski
Yorkshire
C?ID=111643
no it is not, there are things called courses what Tech's go on to further advance knowledge/diagnostic skills, you're a car salesman are you not ?
Gone But Not Forgotten
Well, personally I see nothing wrong with learning here, or asking questions; as long as clear initiatives have been made, such as reference to material in the repair manual or WIKI.
????????????? Have you taken the DPF off inspected it, and or cleaned it?
TD&MCK Car Sales
C?ID=160148
Here are the figures for dpf when engine not running
When engine running
Do these tell you anything please jack ?
Tried to do a force regen but no joy
TD&MCK Car Sales
C?ID=160148
All fixed....Physical work included an angle grinder,hammer and chisel...then a ecu tweak and now runs like a dream with no warning lights..thanks for all your help Jack, much appreciated
