8520138 - Control Module for Battery Monitoring
swenak
Czech Republic
C?ID=236893
on friends Cupra 280 MY2016 I have this error:
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1223
Software Coding: 030100F42F085900FB0002F9880F00010001050000000000000000000000
Work Shop Code: WSC 00049 770 00104
ASAM Dataset: EV_GatewLear 013020 (SE37)
ROD: EV_GatewLear.rod
VCID: 75E66AF7D45788967E-8020
P1B02 00 [009] - Defective
Reset counter: 27
Mileage: 758 km
Date: 2015.11.10
Time: 06:37:27
What is wrong? Maybe 5Q0915181D is wrong?
Thanks.
DrPeter
16.4905° S, 151.7375° W
- Nice, a 2016 Seat Leon Cupra 280 with a defective fault code.
My first thought is, this should be covered under warranty.
If it was my vehicle, I would clear the code and see if it comes back.
After researching the fault code below, I do not see any information about this fault code in this vehicle. If the code will not clear or returns, I would take it back to the dealer.
P1B02 - Control Module for Battery Monitoring: Defective
Hope this helps,
drpeter
I think the Battery Monitoring Control Module should communicate as a subsystem in a MQB Gateway like this random example scan. If you need further assistance diagnosing and your buddy doesn't object to posting the complete scan with VIN here it would be helpful so we can check part catalog info in addition to a diagram.
Dana: I've always found the battery monitor to be a bit of an enigma on MQB platform cars - I'd be delighted to know more about this simple, but mysterious little beastie! You are indeed correct in your assertion, from the WD, it seems to communicate directly with the CAN Gateway and as such it appears as a slave module to this controller in the auto scan. I assume that the battery monitor is nothing more than some form of current transducer (perhaps a pick-up coil with a few passive electronic components to condition the signal).
Problem is that the simplicity of this device belies any attempts to fix error codes - what can one do with a control module that has two wires, no coding and no adaptation channels but check a couple of connectors in the wiring loom and/or replace it (if the error code persists- of course)?
swenak
Czech Republic
C?ID=236893
Thanks for answer, here is that scan, but car will be repaired in warranty, it was only question, because after car was after 9 month delivered, friend connect battery charger directly to car and trying to disable start/stop, so, he feared, that it was his mistake :-) After that, he ask dealer, and dealer told him, that he know, that on car was this error code, but he hope, that it will be cleared after few km of ride :-)
Wednesday,11,November,2015,20:07:03:38590
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: VSSZZZ5FZGR051581   License Plate:
Mileage: 873km-542mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 13 14 15 16 17 19 32 42 44 52 55 5F A9
VIN: VSSZZZ5FZGR051581   Mileage: 873km-542miles
Address 01: Engine (J623-CJXA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0B1900122444010B0000
   Shop #: WSC 00049 770 00129
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F_SE37.rod
   VCID: 316E9EE760BFE4B6E2-8064
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 62085000002471
   Coding: 19EE6B925425296D007C060841C46898D62A9400608216F6144150F1C008
   Shop #: WSC 00049 770 00104
   ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
   VCID: 4B92EC0FE253AE66F8-801E
   Part No SW: 5F0 907 044 J    HW: 5F0 907 044 J
   Component: Climatronic   H04 0911
   Revision: 00001K09
   Coding: 02000004200100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 2D5682977C878056C6-8078
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061525000040
   Coding: 08000A46C24102F343E04000400403281000000000000000000000000000
   Shop #: WSC 00049 770 00197
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 091E1607A8AFFC760A-805C
   Slave 1:
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150812  041 0574
   Serial number:         150825170311
   Coding: 0BC5FD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S2Y15M09D14H16M13S50
   Coding: 00095D
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391524703777
   Coding: 0071151001
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 4382C42FCA03662600-8016
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 03081503210895
   Coding: 00200200FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 3A7CB9CBBDC927EE53-806E
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 01091541350091
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377AA0FF8EDB3A86AC-8062
   Part No SW: 3Q0 959 655 AR    HW: 3Q0 959 655 AR
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SPPHG4PT0
   Coding: 98FCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SE37.rod
   VCID: 0E14251BD1C1DB4EDF-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 208 15
   Serial number: 3576U000000DC325F51L
   Subsystem 2 - Part No SW: -----------    HW: 454 002 008 15
   Serial number: 3586U00000093674D51E
   Subsystem 3 - Part No SW: -----------    HW: 454 801 308 15
   Serial number: 3516R60F2E2070000002
   Subsystem 4 - Part No SW: -----------    HW: 454 802 508 15
   Serial number: 3526RE1DA21080000006
   Subsystem 5 - Part No SW: -----------    HW: 454 801 808 15
   Serial number: 3556V9CA0D607000000L
   Part No SW: 5Q0 953 507 HA    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 17081508490268
   Coding: 6C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7CF07FD3F77DD9DE01-8028
   Part No SW: 5F0 920 863 F    HW: 5F0 920 863 F
   Component: KOMBI         203 6420
   Coding: 07AD11003D80000800883A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SE37.rod
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003966970
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0312190815
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001509031374
                    Reset counter: 28
                    Mileage: 828 km
                    Date: 2015.11.10
                    Time: 17:40:21
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00007.07.15
   Coding: 0101
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 479AD03FFE3B4A06DC-8012
   Component: TSG FS        010 0031
   Serial number: 0000165225954
   Coding: 00100320DC00040000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000007068299
   Coding: 310000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 397EA6C7B8CF2CF65A-806C
   Component: TSG BFS       010 0031
   Serial number: 0000165461204
   Coding: 00100320DE00040000001000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 4684DD3BF931530E27-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000007273910
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 0392030009000000
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   Part No SW: 5QA 035 824     HW: 5QA 035 824
   Component: MU-S--ER      H24 0245
   Serial number: SEZAZ2R0434345
   Coding: 04730300FF0A000011110001000808002F0302D40120010002
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SE37.rod
   VCID: 7DF672D7EC67D0D636-8028
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
   Component: ABTm_Std2  H43 1028
   Serial number: SEZ8Z9RFS00B98
   Part No SW: 5F0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0004
   Serial number: 150109201142
   VCID: 2C508F93479D895ED1-8078
End-------------------------(Elapsed Time: 04:15)--------------------------
NEtech
Denmark
C?ID=56995
Well did he try to disable it: 2015.11.10 / 17:40:21 ?
swenak
Czech Republic
C?ID=236893
It was before this date-time, but few times he cleared errors.
Thanks for the scan. I was concerned that the LIN wire (typically purple/white per Don's pic above) could be compromised -or- the alternator (on the same data line) was preventing the Battery Monitoring Control Module from communicating properly. Both are communicating in the scan so that doesn't appear to be the case.
The warranty replacement lead should resolve this.
swenak
Czech Republic
C?ID=236893
So, after few weeks of wainting for cable (we have Skoda factory 60km, so, it must be weeks and not days :-) ) was changed cable (5Q0915181D) and now it is correct. Thanks :-)
