This car got its nose out of joint in an altercation with the trailer hitch on a Jeep Cherokee. The damage was largely cosmetic, except for ACC sensor 2. The cosmetics have been repaired, but the dealer was missing some of the tools needed to re calibrate the ACC, so it hasn't been done yet.
Auto-Scan with happy systems have been snipped for brevity:
For laughs, I poked around in these modules today and look at what I found in the measuring values.
Sensor 1:
Address 13: Auto Dist. Reg (7P6 907 561 C)
17:02:16
015 Horizontal angle deviation 0.89 °
017 Misalignment angle 0.04 °
018 Misalignment angle; fast algorithm 0.02 °
025 Vertical angle deviation -0.06 °
Sensor 2:
Address 8B: Adaptive Cruise 2 (7P6 907 541 C)
17:01:25
003 Horizontal angle deviation -1.00 °
004 Misalignment angle 2.50 °
005 Misalignment angle; fast algorithm 2.48 °
012 Vertical angle deviation -0.36 °
Does anyone know what the acceptable Misalignment values are, and on what basis the module calculates them?
I'm told there are mechanical adjusters on the sensor.
There's a Basic Setting in these modules named "Reset misalignment angle" but I didn't try it -- yet.
Tuesday,27,October,2015,16:45:22:42678
VCDS Version: 15.8.4.0
Data version: 20150904
Workshop Code: 444 03743 000001
VIN: WVGEP9BP9FD003413 License Plate: 15.8.4-HNAP
Mileage: 10917km-6783mi Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP9FD003413 Mileage: 10917km-6783miles
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Coding: 3701010101
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526.rod
VCID: BC3B37AB37CD91DE7F-80E8
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 52
Mileage: 10909 km
Date: 2015.10.27
Time: 12:03:22
Control Module temperature: 18 °C
Voltage terminal 15: 14.823 V
Longitudinal_acceleration_vehicle_reference: 0.08 m/s²
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526.rod
VCID: BA3731B33DF9AFEE6D-80EE
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 52
Mileage: 10909 km
Date: 2015.10.27
Time: 12:03:28
Control Module temperature: 19 °C
Voltage terminal 15: 14.772 V
Longitudinal_acceleration_vehicle_reference: 0.07 m/s²
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 52
Mileage: 10909 km
Date: 2015.10.27
Time: 12:03:28
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 52
Mileage: 10909 km
Date: 2015.10.27
Time: 12:03:28
Sensor 1:
17:02:16
Sensor 2:
17:01:25
