How perform test by VCDS Lite EGR, MAF, Block 032 Fuel trim
nadir khan
Verified VCDS-Lite User
C?ID=260968
I am currently buy VCDS Lite :-
Please need information :-
My Car has black smoke when i Accelerator. (VW GOLF TDI 1.9 2002 diesel (MK4)
i have USB Cable KKL VAG-COM.
1) how i perform test EGR value in Lite version
2) how i perform MAF test Lite
3) Perform test GROUP block 032 Lite
4) fuel trim
nadir khan
C?ID=260968
VCDS-Lite Version: Release 1.2
Wednesday, 14 October 2015, 20:13:38:48752
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: 038-906-019-AJM.LBL
   Controller: 038 906 019 HJ
   Component: 1,9l R4 EDC G000SG  1490
   Coding: 00002
   Shop #: WSC 00046
   VCID: 66BF8BEB117F
   WVWZZZ1JZ2B134987     VWZ6Z0B0058310
Readiness: N/A
Address 03: ABS Brakes       Labels: 1C0-907-37x-ASR.LBL
   Controller: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00046
   VCID: 321727BBED37
00287 -  ABS Wheel Speed Sensor; Rear Right (G44)
            012 -  Electrical Fault in Circuit
Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
   Controller: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00046
   VCID: 2135D8F7B8D1
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 00046
   VCID: 2237D7FBBDD7
00532 -  Supply Voltage B+
            07-10 -  Signal too Low - Intermittent
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J0 920 926 CX
   Component: KOMBI+WEGFAHRSP VDO V20
   Coding: 00414
   Shop #: WSC 00098
   VCID: 8277377B9D17
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   VCID: F0936DB3A3BB
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00046
   VCID: 361F1BAB015F
01336 -  Data Bus for Comfort System
            80-00 -  Single-Wire Operation
00932 -  Electric Window Motor; Drivers Side (V147)
            62-00 -  No or Incorrect Adjustment
End   --------------------------------------------------------------------------------------------------
Compare specified and actual MAF readings in MVB 003. If specified and actual MAF readings do not diverge much, then EGR is working as designed. If they do diverge substantially, then there is a problem with your EGR system.
Log the actual MAF reading during a full-throttle run through second gear, from as low an RPM and you can to the engine's redline.
4) fuel trim
It seems to me that you are trying to apply information/procedures that are specific to petrol-fueled engines to your diesel. Your diesel engine management system does not use the concept of fuel trim, and your ECU does have fuel trim data in MVB 032.
nadir khan
C?ID=260968
need help
My car generate smocks and change some sound when car temperature going normal after driving 20 min, i change MAF, same condition, what test i will do like boost leak?
Regards
