I'm looking for some assistance troubleshooting an issue with my car. The car was taken for an MOT on Wednesday morning. In the afternoon, the garage informed me that the car had passed, but the technician encountered a problem after returning from lunch. When he tried to move the car, multiple dashboard lights were activated, and the steering became heavy.
I have owned the car for two years, and the only persistent fault has been a rear left bass speaker open circuit, which seems unrelated to this issue.
This problem is persistent, and there has been no change in behavior since I retrieved the car from the garage. The dashboard lights now include the RED Power Steering, Traction Control, Engine, Headlight Range, and the Parking Sensors are flashing.
I am unable to access the Steering Assist module using VCDS under any circumstances. It appears other errors may be related to the Gateway's inability to communicate with this module.
The battery, a 2-year-old VARTA AGM, appears to be strong, but I will charge it tonight to eliminate any potential voltage drop issues.
My next step is to locate a wiring diagram and check the relevant relays. I need guidance on where to look next and how to find the relevant diagrams or technical manuals.
Actions I have taken:
Thanks,
Michael
- Checked the battery voltage: 12.4V idle and 14V running. The lowest voltage recorded was 11.9V during the ABS error. I plan to charge the battery overnight in my house.
- Ensured the chassis ground is tight and has a good connection.
- Inspected the engine bay fuses.
- Driven several miles, performing left and right turns.
- Disconnected the battery for a few hours.
Wednesday,24,April,2024,16:47:38:60553
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
VIN: VSSZZZ5FZDR028882 License Plate: CN13WXX
Mileage: 231797km-144031mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZDR028882 Mileage: 231797km-144031miles
44-Steering Assist -- Status: Cannot be reached 0100
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H83 4941
Revision: 00H83H22 CVN: 5CB944E2
Coding: 01190012032501090000
Shop #: WSC 53614 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79AFFEC269579A5268D-802C
VINID: 9A38EAAAA156A94880088208082AB3997E
17273 - No Communications with Power Steering Control Module
U0131 00 [00101111] - -
Mileage: 231796 km
Date: 2024.04.24
Time: 00:00:22
Engine RPM: 0.00 /min
Coolant temperature: 58 °C
Intake air temperature: 54 °C
Voltage terminal 30: 12.460 V
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [00101111] - -
Mileage: 231796 km
Date: 2024.04.24
Time: 00:00:21
Voltage terminal 30: 12.520 V
Limitation: accelerator pedal: 126.7 Nm
selected gear-Bits 0-7: 0
17158 - Databus
U1123 00 [00101111] - Received Error Message
Mileage: 231796 km
Date: 2024.04.24
Time: 00:00:24
Engine RPM: 904.50 /min
Normed load value: 18.4 %
Intake air temperature: 53 °C
Voltage terminal 30: 12.220 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Acceleration: 0.000 m/s²
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 A HW: 5Q0 907 379 A
Component: ESC H75 0333
Revision: 00000000 Serial number:
Coding: 20EE8A9220220A74007F060801C5240451045000608024F200690020C0
Shop #: WSC 00049 770 00106
ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
ROD: EV_Brake1UDSContiMK100ESP_008.rod
VCID: 3A2D21CE2CD1514A217-806E
0166 - Steering angle sensor
B1168 31 [00001001] - No Signal
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:14
8238 - Databus
[FCAN: LH_EPS_01 message is not received]
Fault Frequency: 16
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:14
8242 - Databus
[FCAN: LH_EPS_03 message is not received]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:14
C1146 02 [10001001] - Signal Failure
Fault Frequency: 13
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:24
Address 08: Auto HVAC (J255) Labels:. 5G0-907-044.clb
Part No SW: 5F0 907 044 HW: 5F0 907 044
Component: Climatronic H02 0503
Revision: 00001K05
Coding: 00100104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002_SE37.rod
VCID: 6393BCAAFBDB7082521-8036
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0122
Serial number: 00011410100625 Dataset Number: V03935195CH 0001
Coding: 0B000A42C24100DB0BA44000B11C07281000000000000000000000000000
Shop #: WSC 53087 001 1048576
ROD: EV_BCMBOSCH_012.rod
VCID: 7BA3E4CA636BA8427A1-802E
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 121113 041 0574
Serial number: 121119094149
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY12319200V
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000056030679
Humidity sensor: interior:
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20275956
555285 - Databus
[LWI_01_alt aktiv]
Fault Frequency: 15
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 14.0 V
Outside temperature: 12.0 °C
556053 - Databus
[LH_EPS_02_alt aktiv]
Fault Frequency: 15
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
CAN-Bus_aktiv: On
OFF: operated
Voltage: 14.0 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231301719781 Dataset Number: V03935140HK 0023
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW26.rod
13637426 - Databus
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
13638913 - Databus
[Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
13638914 - Databus
[Steuergerät für Lenkhilfe-J500 - LWI_01 - kein Signal/keine Kommunikation]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
Part No SW: 3Q0 959 655 R HW: 3Q0 959 655 R
Component: Airbag VW20 011 0186
Revision: -------- Serial number: 003NPP2Y0D84 Dataset Number: V03935170KD 0005
Coding: 98CCC000000000005C0000CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 4DC77A128D5FD6F2945-8018
Subsystem 1 - Part No SW: ----------- HW: 454 000 502 13
Serial number: 3576U000000252142C0-
Subsystem 2 - Part No SW: ----------- HW: 454 000 502 13
Serial number: 3586U000000C33642C08
Subsystem 3 - Part No SW: ----------- HW: 454 802 201 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R178AF9000000006
Subsystem 4 - Part No SW: ----------- HW: 454 802 201 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R0E84F9000000007
Subsystem 5 - Part No SW: ----------- HW: 454 801 301 13
Component: FrontSensor_D 114 0149
Serial number: 3556V8246CD000000009
1050112 - Databus
[NWD: 0x086 LWI_01 Timeout]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:14
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Revision: -------- Serial number: 26021304221745 Dataset Number: ----------
Coding: 9400
ROD: EV_SMLSKLOMQB_009.rod
VCID: 77ABF8FA5F438C221E9-8022
Part No SW: 5F0 920 970 G HW: 5F0 920 970 G
Component: KOMBI 336 0556
Coding: 27A502002980260001087A00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 2D071A92ED9FF6F2B45-8078
16776978 - Databus
[LH_EPS_01 keine Kommunikation]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000423824 Dataset Number: V03935132HG 0020
Coding: 030100F40B087300EF0006C8080F00010001000000000000000000000000
GVL: 01543C0000000000400C10000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 34310FF60EB5A73AFBB-8060
Generator:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0100
Serial number: 000000000A0216230113
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004050266678
131602 - Power Steering Control Module
U101D 00 [00001001] - No Communication
[Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:14
Terminal 30 power supply: 13.9 V
Terminal 15: On
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000050917691 Dataset Number: V03935172UH 0001
Coding: 00100220DC01020000001000
Shop #: WSC 00049 770 00125
VCID: 025D992E0481D98A397-8056
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000096030
Coding: 2D0000
Address 44: Steering Assist
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000049677707 Dataset Number: V03935172UG 0001
VCID: 015F96220187C29220D-8054
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000082296
Coding: 350000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: -------------- Dataset Number: V03935177SD 0001
Coding: 048C000001000000
VCID: 75B7F2F2454FFE320C5-8020
13705474 - Databus
U1121 00 [10001001] - Missing Message
[LWI_01 Datenbus fehlende Botschaft]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 12:37:13
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 858 HW: 5F0 035 858
Component: MU-S-ND-ER 039 0151
Serial number: E5F01902130778 Dataset Number: V03935171LU 0006
Coding: 04730001D70A000021111101000800002F0101060100010046
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE.rod
VCID: 6889AB8602FD13DA873-803C
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0020
Serial number: SEZ8Z9M56009Q1
Subsystem 2 - Part No SW: 5F0 919 866 C HW: -----------
Component: ECE 2013 --- 0021
0527 - Rear Left Bass Speaker
B1065 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung]
Reset counter: 225
Mileage: 231796 km
Date: 2024.04.24
Time: 00:00:09
Voltage terminal 30: 12.4 V
End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.4V)-----------
Thanks,
Michael
