Hello All!
Currently looking to move forward on the process of swapping a pre facelift audi a3 steering wheel to a facelift version and adding the functionality of the dsg paddle shifters.
So far the car already has been swapped with the new wheel with the paddle shifters installed. The button layout for the wheel is the correct layout with all functions working properly the airbag has also been swapped to correct year corresponding bag and horn is working. The only issue is that the dsg paddles are not activated and working. I have read that there are some discrepancies on weather or not coding is required and most people state that it is plug and play and I believe this is true for retrofitting paddles onto correct generation pfl to fl cars but not going up from pfl to fl wheel. I am looking to see if anyone has any information on how to activate the coding to get the paddle shifters to work, I also have read that because the airbag was swapped that it may also need to be coded into the car aswell which would make sense. Any and all help is very much appreciated.
Complete Autoscan of car below with the new wheel and airbag installed everything working minus paddle shifters.
Sunday,21,April,2024,20:11:58:36430
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUEFGFF3F1137507 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F BB BC
VIN: WAUEFGFF3F1137507 Mileage: 189988km-118053miles
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 9C0 BB0 1 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13--- CVN: 9134A00C
Coding: 0A1D00124426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G09C0BB01 001003
ROD: EV_ECM20TFS0205G09C0BB01.rod
VCID: 3D2C5026FDF94A02045-8068
VINID: 9D19555975960D60410C71401C296CBD74
17178 - Databus
U1123 00 [00101100] - Received Error Message
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:17
Engine RPM: 0.00 /min
Coolant temperature: 64 °C
Intake air temperature: 40 °C
Voltage terminal 30: 12.363 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
15059 - Fuel Rail/System Pressure
P0087 00 [01100000] - Too Low
Mileage: 188879 km
Date: 2024.04.08
Time: 12:10:12
Engine RPM: 1282.75 /min
Normed load value: 33.3 %
Vehicle speed: 28 km/h
Coolant temperature: 96 °C
Intake air temperature: 42 °C
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 9
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 39 s
MAP_MES_SAE: 79 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.910 V
FAC_TPS_1_SAE: 19.531250 %
FUP_H_SAE: 430.0 kPa
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4513
Revision: 05853104 Serial number: TFK01503300234 CVN: 0000B878
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1E6EB7AA503F311A3DF-804A
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 61025000000105
Coding: 13FF6A9234230A73017C030081CA29C8562C5080C08194B4024100588208
VCID: 48C231F2A23B1FAAA73-801C
0297 - Steering angle sensor
B1168 16 [00001000] - Voltage Too Low
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:18
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 203
Mileage: 189094 km
Date: 2024.04.12
Time: 23:07:04
16412 - Display for Tire Pressure Monitoring
C1146 02 [00001000] - Signal Failure
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:28
16413 - Display for Tire Pressure Monitoring
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:28
Revision: 00021000 Serial number: 0365040944 Dataset Number: 8V0909577C 0009
Coding: 030C0C
VCID: 3A265B3AECD77D3A217-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000621779
Coding: 03000014010000000000000000001400
VCID: 3338761ECBBD8C72E21-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 07C8CE97000000000001
329475 - Motor for Fresh Air / Recirculated Air Flap
B108B 13 [00001001] - Open Circuit
Reset counter: 153
Mileage: 188772 km
Date: 2024.04.08
Time: 08:30:12
Voltage terminal 30: 14.3 V
Inside temperature: 11.8 °C
Outside temperature: 9 °C
Fresh air/recirculating air/back pressure door specified value: 644
Actual value for fresh air/recirculation air flow flap: 91.5 %
Actual value for fresh air/recirculation air flow flap: 806
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [00001001] - Actuator Stuck
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:25:14
Voltage terminal 30: 12.2 V
Inside temperature: 30.2 °C
Outside temperature: 12 °C
Fresh air/recirculating air/back pressure door specified value: 876
Actual value for fresh air/recirculation air flow flap: 807
329989 - Motor for Defroster Flap
B1090 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:24:52
Voltage terminal 30: 12.3 V
Defrost door - Specified value: 932
Defroster flap: actual value: 100.0 %
Defroster flap: actual value: 933
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011509200714 Dataset Number: 8V0909514L 0083
Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79A48436A951B62268D-802C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150413 042 0585
Serial number: 150416171950
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23884238
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 02 02 2015 00000962
Serial number: 00000000000032274025
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST0008LLGU00000
Coding: 101F00
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01TE8O Dataset Number: 8V0909602F 0005
VCID: 47C032CEAF2510D2AE9-8012
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B16041541500
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B17041570021
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y150001BJX00.
Coding: 303139
Subsystem 4 - Part No SW: ----------- HW: 480 001 104 15
Serial number: 357000000000C125E31A
Subsystem 5 - Part No SW: ----------- HW: 480 001 104 15
Serial number: 358000000007C125E31I
Subsystem 6 - Part No SW: ----------- HW: 480 400 804 15
Serial number: 3510002A91A8786341E6
Subsystem 7 - Part No SW: ----------- HW: 480 400 904 15
Serial number: 3520002B31A87862F153
Subsystem 8 - Part No SW: ----------- HW: 480 400 902 15
Serial number: 3550002B1198E152723-
Subsystem 9 - Part No SW: ----------- HW: 480 400 902 15
Component: FrontSensor_P 001 6149
Serial number: 35600029B196FF52117C
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:18
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 15041508491038
Coding: A018
ROD: EV_SMLSKLOMQB_017.rod
VCID: 0A46CBFAFCB7ADBA717-805E
Part No SW: 8V0 920 971 D HW: 8V0 920 971 D
Component: KOMBI H02 4292
Coding: 0BE518192B80D7050200E8001800000000000000
Shop #: WSC 12345 123 61029
VCID: 3E2E572AF0FF511A1DF-806A
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 11041510800745 Dataset Number: 8V0909515F 0060
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
GVL: 01D03C0000000600400C10000000C80000000000000000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72B6B31AF427C57A297-8026
Generator:
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20171009165959 22024
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00011.03.15 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 46DE3FCAA82F09DA55F-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000092826005
Coding: 5D00000000000000
VCID: 343A7502CEB38B4AFBB-8060
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: TSG FS 020 0028
Serial number: 260315BCP15586 Dataset Number: 8V0909872F 0032
Coding: 00101F204000048000000002
VCID: 40D229D28A0B27EA6F3-8014
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Dataset Number: 8V0909852K 0022
Coding: 0102
VCID: 43D826DE9B1D3CF2721-8016
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Component: TSG BFS 020 0028
Serial number: 250315BCN04623 Dataset Number: 8V0909873F 0032
Coding: 001017204000048000000002
VCID: 3FD02A2EF7F55812169-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0039
Coding: 012A000101000000
VCID: 75BC88068549D2420C5-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 G HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302D0FB011993 Dataset Number: 8V2909545F 0045
Coding: 01730102FF0A000021220001041A00102F000205010001047E
ROD: EV_MUHig6C3HBAS_VW48.rod
VCID: 38224132D2DB6F2AD73-806C
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY202WVY
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000023031500030201
Compact disc data bank:
Component: Gracenote --- 3006
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:24:59
Voltage terminal 30: 12.4 V
Satellite radio tuner status-Audio Signal: available.
Satellite radio tuner status-Reception quality: optimum_signal
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Component: TSG HFS 020 0028
Serial number: 310315CCU05422 Dataset Number: 8V0909897D 0018
Coding: 000017204000048000000002
VCID: 42D623DA840735FA797-8016
Component: TSG HBFS 020 0028
Serial number: 310315CCU05425 Dataset Number: 8V0909896D 0018
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.1V)-----------
17178 - Databus
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:17
Mileage: 188879 km
Date: 2024.04.08
Time: 12:10:12
STATE_LS_SAE[1]: CL
T_AST_SAE: 39 s
MAP_MES_SAE: 79 kPa
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:18
Reset counter: 203
Mileage: 189094 km
Date: 2024.04.12
Time: 23:07:04
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:28
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:28
Coding: 030C0C
Reset counter: 153
Mileage: 188772 km
Date: 2024.04.08
Time: 08:30:12
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:25:14
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:24:52
Coding: 0A47F7
Coding: 00006C
Coding: 101F00
Coding: 333135
Coding: 333135
Coding: 303139
1050117 - Databus
Reset counter: 225
Mileage: 188852 km
Date: 2024.04.08
Time: 11:10:18
Coding: A018
Generator:
Coding: 0001
Coding: 0102
Reset counter: 146
Mileage: 188666 km
Date: 2024.04.02
Time: 12:24:59
