Friday,19,April,2024,16:10:14:56970
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
VIN: TMBBE7NE8J0094055 License Plate: HT17 ODG
Mileage: 69971km-43477mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 4B 52 5F A5 A9
D6 D7
VIN: TMBBE7NE8J0094055 Mileage: 69971km-43477miles
Address 01: Engine (J623-CHHA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 P HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13--- CVN: 6AF9A852
Coding: 0C1D00124424010B1000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
ROD: EV_ECM20TFS0205G0906259P.rod
VCID: 3B2231E383E848723A1-806E
VINID: 91D49254779521A00024400514A413B39D
17178 - Databus
U1123 00 [00100000] - Received Error Message
21322 - Implausible Data Received from ABS Control Module
U0415 00 [00100000] - -
21323 - Implausible Data Received from ABS Control Module
23130 - Implausible Data Received from ABS Control Module
23131 - Implausible Data Received from ABS Control Module
Readiness: 0010 0001
Part No SW: 0D9 300 043 F HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5204
Revision: 06454104 Serial number: TFK01704102260 CVN: 0000DD48
ROD: EV_TCMDQ250021.rod
VCID: 1D66DF7B3D3C2642245-8048
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 61407000000426
Coding: 24079391542921704077060540C82924C92A8402600294762041F070C029430000000012121212B8586C384E4484EE
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 0058860FAA8EEBAA2F3-8054
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0442405805 Dataset Number: V03935253VG 0001
Coding: 032C0C
Shop #: WSC 73430 790 00063
VCID: 3C2032FF86E64F4A33B-8068
Part No SW: 5E0 907 044 AS HW: 5E0 907 044 AS
Component: Climatronic H04 2001
Revision: 00001K00
Coding: 0111000400011001100500090010102A
VCID: 76B4E0D7F84AD51A05F-8022
Air quality sensor:
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001713801261 Dataset Number: V03935259NV 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 094E9B2B99B4AAE278D-805C
Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 170411 051 0915
Serial number: 887253F0401710100386
Coding: 164DDD
Component: RLHS 042 0105
Serial number: S4Y17M05D17H03M35S38
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY170444JBE
Serial number: 00000000000069320303
204802 - Remote key 3
B147B 18 [00001001] - Current Too Low
Reset counter: 72
Mileage: 66488 km
Date: 2023.11.24
Time: 14:31:27
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.4 V
Outside temperature: 11.5 C
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617111 Dataset Number: V03935256AD 0001
Coding: 0471051051
VCID: 4BC26123D348F8F28A1-801E
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0702
Revision: -------- Serial number: 003W4P7ZGW4T Dataset Number: V03935260FW 0001
Coding: 98CCC000000000005C5400CC008800000065
VCID: 0556971BB5ACCE821C5-8050
Subsystem 1 - Part No SW: ----------- HW: 454 000 905 17
Serial number: 357000000009FA9C942%
Subsystem 2 - Part No SW: ----------- HW: 454 000 905 17
Serial number: 35800000000BCAFCD429
Subsystem 3 - Part No SW: ----------- HW: 454 801 005 17
Serial number: 35100E000E50F000000E
Subsystem 4 - Part No SW: ----------- HW: 454 800 705 17
Serial number: 352004584E00F000000H
Subsystem 5 - Part No SW: ----------- HW: 454 802 504 17
Serial number: 35500121D76100000001
Part No SW: 5Q0 953 507 HQ HW: 5Q0 953 549 E
Revision: -------- Serial number: 25051704220286
Coding: 1410
VCID: 0C40A23F96C6BFCA43B-8058
Part No SW: 5E0 920 956 E HW: 5E0 920 956 E
Component: KOMBI 302 0310
Coding: 27A5011869808600010A6B021001000000000000
VCID: 2E0408B7409AADDA8DF-807A
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 433 4303
Revision: -------- Serial number: 0006367378 Dataset Number: V03935258RY 0001
Coding: 030100047F085900EB00026A1C0F00010001070000000000000000000000
GVL: 01563C1000000600408C00000000C80000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 333219C3ABB88032E21-8066
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000D1843140417
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75886000001705181077
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000126922010
Coding: 5D00000000000000
VCID: 34301ADFAEB6870AFBB-8060
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000258166189 Dataset Number: V03935252QV 0001
Coding: 001D0020D001040000001100
VCID: 47CA5D13CF201C92AE9-8012
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 005 0007
Serial number: 00000000000014834116
Coding: 1D0200
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Dataset Number: V03935242GS 0001
Coding: 9107
Shop #: WSC 73430 790 00000
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2C34E78CD2717A217-806E
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1HJE01X8TX Dataset Number: V03935242LX 0001
Coding: 0373010000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59EE8B6B69949A6208D-800C
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 21051710523294 Dataset Number: V03935256SC 0001
Coding: 000000070100046E00003D01010000000000000000000000000000000000
VCID: 72BCDCC79422C93A297-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000258717134 Dataset Number: V03935252QY 0001
VCID: 46D45017C82A059A55F-8012
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 005 0007
Serial number: 00000000000014883538
Coding: 050200
Part No SW: 565 035 020 E HW: 565 035 020
Component: MU-H-ND-EU H54 1440
Serial number: A855E0HS023302 Dataset Number: V03935263XV 0001
Coding: 037351010000000051111202008800002F0101E601200500FF
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 0F7AB533E7D084D2A69-805A
Subsystem 1 - Part No SW: 5E0 919 606 D HW: 5E0 919 606 D
Component: ABT_High-2 H50 9120
Serial number: SKZ6ZHT1431111
Subsystem 2 - Part No SW: V03 959 810 C HW: -----------
Component: ECE 2022 --- 0195
Compact disc data bank:
Component: Gracenote2 --- 1016
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 14051711K21264 Dataset Number: V03935262MB 0001
Coding: 0203070100000401000223408150A80084000E200000
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 170426200495
VCID: 698EBBABB9F40AE298D-803C
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EA4F8F7D07A9D5A5DF-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.0V)-----------
