- Apr 7, 2024
- 8
- 0
- Green Lane, PA, USA
- C?ID=51832
Hi all, this is my first post here.
I have always messed with alh's, but this is my first attempt at CR emissions diag. As a heavy truck mechanic I do have a considerable amount of experience with emissions systems for mack and cummins, so I do understand the sytems very well.
I am working on a 2010 jetta. It has just shy of 108,000 miles on it. The DPF light is on. The only emissions code I have is the following:
006744 - NOx Catalyst
P1A58 - 000 - Regeneration Required
Filter oil ash volume was 0.0, calculated soot load was 0.6, measured soot was 0.0.
I first did a regen while driving with VCDS. I am not sure what good temps are for a regen on these, so I don't know if it was necessarily a good regen. The highest I saw pre-turbo was around 600C, pre-filter was staying in the 400 range, and post filter was getting above 600c. This was yesterday, and I admittedly don't remember anything more specific than that. Calculated soot load went down to 0.3, the others remained at 0.0
After this I cleared codes, and still had the same code present as before, light is still on.
Then I did 2 parked regens with some time in between. These were both successful, and took approximately 20-30 minutes each. Pre-turbo temps were a bit above 600c, I don't remember what the pre-filter temps were. The post filter temps at one point were over 900c. From my experience with heavy truck, that is ridiculously high. Am I right with that? No change to the ash or soot numbers after these regens.
That being said, cleared the codes, same code is still present, and the light is still on.
Is it time to replace the DPF? that is my thought, but I don't want to just throw parts at it.
Thanks for the help!
EDIT: i just saw the "how to do a great first post", and saw about including an autoscan. I will get that tomorrow
Here are my codes throughout the process
Saturday,06,April,2024,16:07:03:02546
VCDS Version: 22.9.0.0 (x64)
VIN: 3VWRL7AJ4AM026482 License Plate:
Mileage: Repair Order: sandy
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 K HW: 03L 906 022 TS
Component and/or Version: R4 2.0l TDI G001AG 9983
Software Coding: 0050078
Work Shop Code: WSC 43164 005 1048576
VCID: 36689C53414E8F3DA9-8062
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0 C
Fault Frequency: 21
Mileage: 172462 km
Date: 2033.14.12
Time: 21:48:57
Pressure: 992.2 mbar
Temperature: 8.1 C
Mass Air / Rev.: 1100.0 mg/str
Temperature: 23.4 C
Address 01: DTCs cleared
Address 01,03L 997 030 K,channel 13,adapted from,0,to,1,
Mileage: 172817 km
Date: 2033.14.22
Time: 04:18:32
RPM: 828 /min
Temperature: 9.9 C
Mass Air / Rev.: 235.0 mg/str
Temperature: 23.4 C
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 -
Mileage: 172830 km
Date: 2033.14.22
Time: 04:41:31
RPM: 2070 /min
Speed: 65.0 km/h
Load: 19.6 %
(no units): 255.0
(no units): 255.0
Bin. Bits: 00000000
Address 01: Engine Labels: 03L-906-022-CBE.CLB
Fault Codes have been Erased
Mileage: 172859 km
Date: 2033.14.22
Time: 06:26:06
RPM: 828 /min
Temperature: 10.8 C
Mass Air / Rev.: 255.0 mg/str
Temperature: 26.1 C
