- Mar 27, 2024
- 4
- 1
- Panama City, FL, USA
- C?ID=574801
Hello and thank you for taking your time to read this. I purchased this basket case Eos for my wife and steadily going through sorting it out. The main focus is the the ABS module. When I got the car home it had a fault for no com with the ABS module so nothing on the car worked, no speedo, trans wouldn't shift properly, top wouldn't go down and thee Christmas tree of lights were on. I swapped the ABS module for a used on from salvage car I wish I could remember the year but it was the same part number. Everything that wasn't working is working now but I need to code the module. I tried a couple codes that are already listed here but none of them would take. Please help. I have attached my auto scan.
Wednesday,27,March,2024,11:18:35:45322
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240322 DS351.0
VIN: WVWBA7AHXAV012440 License Plate: NA
Mileage: 185380km-115189mi Repair Order:
Chassis Type: AH-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 26 2E 42 44 46 52 56 62 63
65 72 77
VIN: WVWBA7AHXAV012440 Mileage: 185380km-115189miles
1C-Position Sensing -- Status: Malfunction 0010
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
63-Entry Assist,D -- Status: Malfunction 1010
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 021 B HW: 06J 906 021
Component: MED17.1 5868
Revision: E3H15--- Serial number:
Coding: 041C01081C070160
Shop #: WSC 00020 790 00000
VCID: 2411FBBB72D0EF8A6BB-8070
VINID: 9E69D2447458A119800421040082ECCE03
U1017 - 000 - - Intermittent
Mileage: 185387 km
Date: 2018.08.18
Time: 15:15:08
Temperature: 54.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Mileage: 185387 km
Date: 2018.08.18
Time: 20:05:19
RPM: 837 /min
Load: 34.1 %
Speed: 3.0 km/h
Temperature: 48.0°C
Temperature: 22.0°C
Readiness: 0110 0101
Part No SW: 02E 300 053 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00000911080407
Shop #: WSC 00020 000 90108
VCID: 1373A867A77E9832821-8046
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 7AADE5C3ACD4497A617-802E
Reset counter: 146
Date: 2018.08.18
Time: 16:24:40
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 41216
Fault Status: 01100101
Reset counter: 146
Mileage: 185387 km
Date: 2018.08.18
Time: 16:05:59
Count: 3
Count: 12
Count: 28672
Count: 279
Count: 41472
Count: 768
Reset counter: 146
Mileage: 185387 km
Date: 2018.08.18
Time: 16:05:59
Count: 3
Count: 12
Count: 28672
Count: 295
Count: 41472
Count: 768
Reset counter: 146
Mileage: 185387 km
Date: 2018.08.18
Time: 16:05:59
Count: 3
Count: 12
Count: 28672
Count: 270
Count: 41472
Count: 768
Part No SW: 5K0 907 044 CF HW: 5K0 907 044 CF
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
Shop #: WSC 00020 999 00000
VCID: 71BFC2EFF1220A22D0D-8024
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Bremsensteuergerät - kein Signal/Kommunikation]
Fault Frequency: 146
Reset counter: 186
Mileage: 185374 km
Date: 2024.03.27
Time: 03:03:16
13701488 - Function Restricted due to Missing Message(s)
[Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
Reset counter: 185
Mileage: 185387 km
Date: 2024.03.27
Time: 01:03:45
13701520 - Function Restricted due to Missing Message(s)
[Türsteuergerät hinten links - kein Signal/Kommunikation]
Reset counter: 185
Mileage: 185387 km
Date: 2024.03.27
Time: 01:03:45
13635840 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 00:01:36
Part No SW: 5K0 937 087 G HW: 5K0 937 087 G
Component: BCM PQ35 H+ 111 0128
Revision: BL111001
Coding: 6D000A1B92232A6480880085700005044101558641008D605C8020000000
VCID: 392F3ACFE952826228D-806C
Subsystem 1 - Part No: 1Q1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 08110 22 0512
Coding: 009795
11 Faults Found:
Fault Frequency: 100
Reset counter: 184
Voltage: 11.85 V
Fault Status: 00100001
Fault Frequency: 38
Reset counter: 182
Mileage: 185387 km
Date: 2018.08.18
Time: 00:00:42
Voltage: 14.10 V
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 00:01:39
Voltage: 7.85 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 16:03:17
Term 15 Off
Voltage: 12.25 V
Reset counter: 181
Mileage: 185387 km
Date: 2018.08.18
Time: 21:21:51
Voltage: 13.00 V
Fault Frequency: 175
Reset counter: 186
Mileage: 185374 km
Date: 2018.08.18
Time: 03:03:18
Voltage: 13.30 V
Reset counter: 185
Mileage: 185387 km
Date: 2018.08.18
Time: 00:33:44
Term 15 Off
Voltage: 12.45 V
Reset counter: 185
Mileage: 185387 km
Date: 2018.08.18
Time: 00:33:44
Term 15 Off
Voltage: 12.45 V
01598 - Drive Battery Voltage
Reset counter: 183
Mileage: 185387 km
Date: 2018.08.18
Time: 00:04:04
Voltage: 14.05 V
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 57
Reset counter: 146
Mileage: 185387 km
Date: 2018.08.18
Time: 00:33:34
Voltage: 13.35 V
02604 - Low Vehicle Voltage from Power Steering Control Module
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 00:06:52
Voltage: 11.90 V
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: AQ Airbag VW8C 0180
Revision: 92010018 Serial number: 003B3004NYE6
Coding: 0016721
VCID: 3A2D25C3E054897A217-806E
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 4WQVT
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332SRB409E48D1EIÿ†63
Subsystem 5 - Serial number: 48D1EIÿ†6342SRB409E09110Xÿ†63
Subsystem 6 - Serial number: 09110Xÿ†6372URB4047E94A9Iÿ†63
Subsystem 7 - Serial number: E94A9Iÿ†6382URB4047E954FKÿ
Subsystem 8 - Serial number: E954FKÿ
Reset counter: 186
Mileage: 185387 km
Date: 2018.08.18
Time: 17:19:58
Fault Status: 11100001
Mileage: 185387 km
Date: 2018.08.18
Time: 17:19:60
01221 - Crash Sensor Side Airbag; Driver Side (G179)
011 - Open Circuit - Intermittent - MIL ON
Fault Status: 10101011
Mileage: 185387 km
Date: 2018.08.18
Time: 20:08:16
Part No SW: 1K5 953 521 F HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0122
Revision: FF010E35 Serial number: 20091118200333
Coding: 088A140000
ASAM Dataset: EV_SMLSNGVOLWS A01002
ROD: EV_SMLSNGVOLWS.rod
VCID: 303907EB3AA8432A9F3-8064
365080 - Controls in Steering Wheel
U108E 00 [00001001] - No Communications
Reset counter: 144
Mileage: 185387 km
Date: 2024.03.27
Time: 00:22:57
Part No SW: 1Q0 920 974 N HW: 1Q0 920 974 N
Component: KOMBI H05 0305
Coding: 271F00
VCID: 3FDB54D7F7F6AC52169-806A
12648448 - Function Restricted due to Missing Message(s)
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 20:14:00
12648704 - Function Restricted due to Missing Message(s)
[Steuergerät für Getriebe: keine Kommunikation]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 20:13:29
12656896 - Function Restricted due to Missing Message(s)
[Steuergerät für Bremse: keine Kommunikation]
Reset counter: 186
Mileage: 185374 km
Date: 2024.03.27
Time: 03:03:14
12669184 - Function Restricted due to Missing Message(s)
[Steuergerät für Airbag: keine Kommunikation]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 20:14:00
13638912 - Function Restricted due to Missing Message(s)
[Steuergerät für Lenkhilfe: keine Kommunikation]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 20:13:29
[Supply voltage too low]
Reset counter: 184
Mileage: 185387 km
Date: 2024.03.27
Time: 11:28:40
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B1400C7
Coding: ED807F27041612005000
VCID: 698FAA8FD572F2E298D-803C
8 Faults Found:
Reset counter: 51
Mileage: 122140 km
Reset counter: 186
Mileage: 185374 km
00469 - Infotainment Databus in Single Wire Operation
Fault Status: 00101100
Reset counter: 180
Mileage: 185387 km
Reset counter: 184
Mileage: 185387 km
Reset counter: 185
Mileage: 185387 km
Reset counter: 185
Mileage: 185387 km
01312 - Powertrain Data Bus
Reset counter: 184
Mileage: 185387 km
02010 - Left Entry Assistance Control Module (J572)
Reset counter: 186
Mileage: 185387 km
Part No SW: 1Q0 919 965 A HW: 1Q0 919 965 A
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1350208TLA5D04
Coding: 0000002
Reset counter: 186
Mileage: 185387 km
Date: 2018.08.18
Time: 00:01:07
Component: IMMO H05 0305
VCID: 6A8DD583DCF4F9FA917-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 E HW: 1Q0 959 255 E
Component: Verdecksteuergeraet 0842
Revision: 0033100N Serial number: 092960223
Coding: 0655364
Fault Frequency: 15
Reset counter: 186
Mileage: 185387 km
Date: 2018.08.18
Time: 00:00:29
Voltage: 13.70 V
Voltage: 13.60 V
Voltage: 4.90 V
Error Code: 0
02364 - Closing Assistance
Fault Status: 00101110
Reset counter: 182
Mileage: 185387 km
Date: 2018.08.18
Time: 00:00:03
Voltage: 13.70 V
Voltage: 13.70 V
Voltage: 4.90 V
Error Code: 0
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 00:01:32
Voltage: 7.70 V
Voltage: 7.70 V
Voltage: 4.90 V
Error Code: 0
Reset counter: 185
Mileage: 185387 km
Date: 2018.08.18
Time: 01:03:47
Voltage: 13.80 V
Voltage: 13.80 V
Voltage: 4.90 V
Error Code: 0
Reset counter: 185
Mileage: 185387 km
Date: 2018.08.18
Time: 01:03:48
Voltage: 13.80 V
Voltage: 13.80 V
Voltage: 4.90 V
Error Code: 0
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667660388
VCID: 2615E1B308EC1D9A75F-8072
Reset counter: 184
Reset counter: 184
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2113
Coding: 0017591
VCID: 392F3ACFE552826228D-806C
01340 - Mirror Adjustment Switch
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 313F02EF3D224A2290D-8064
Fault Status: 00101101
Fault Frequency: 255
Reset counter: 186
Mileage: 185387 km
Date: 2018.08.18
Time: 15:14:10
Voltage: 14.00 V
DU
Temperature: 16.0°C
RPM: 752 /min
Speed: 3.0 km/h
Speed: 3.0 km/h
Fault Frequency: 99
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 20:13:60
Voltage: 14.13 V
DU
Temperature: 25.0°C
RPM: 1498 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Reset counter: 186
Mileage: 185387 km
Date: 2018.08.18
Time: 20:13:60
Voltage: 14.13 V
DU
Temperature: 25.0°C
RPM: 755 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0017590
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7J1131664
Coding: 0100040004
Shop #: WSC 53641 001 1048576
VCID: 619FB2AF2142BAA240D-8034
7 Faults Found:
Reset counter: 51
Mileage: 122140 km
Date: 2018.07.15
Time: 23:12:43
Reset counter: 155
Mileage: 124956 km
Date: 2018.08.18
Time: 00:15:04
Fault Frequency: 233
Reset counter: 186
Mileage: 151851 km
Date: 2018.08.18
Time: 00:43:15
Fault Frequency: 180
Reset counter: 186
Mileage: 161476 km
Date: 2018.08.18
Time: 17:43:30
00871 - Bass Speaker Front Right (R23)
Fault Frequency: 163
Reset counter: 186
Mileage: 166526 km
Date: 2018.08.18
Time: 16:15:35
Fault Frequency: 74
Reset counter: 185
Mileage: 175321 km
Date: 2018.08.18
Time: 21:05:52
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 11:27:13
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0602
Coding: 0000144
Shop #: WSC 00020 790 1012544
VCID: 353736FFC94A6602CC5-8060
01813 - Supply Voltage for Door Controller; Rear Left (J388)
02071 - Local Databus
Address 63: Entry Assist,D Labels: 1Q0-959-790.lbl
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H02000 Serial number: 5DS008646-01--
Coding: 0000002
Fault Frequency: 16
Mileage: 185387 km
Date: 2018.08.18
Time: 11:28:11
Fault Frequency: 27
Reset counter: 184
Mileage: 185387 km
Date: 2018.08.18
Time: 02:58:09
Fault Frequency: 36
Reset counter: 185
Mileage: 185387 km
Date: 2018.08.18
Time: 00:33:43
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
02903 - Hard Warning 2
Mileage: 172221 km
Date: 2018.08.18
Time: 21:01:40
Text: 3449087758
Pressure: 1.90 bar
Pressure: 2.30 bar
Temperature: 15.2°C
Text: 80
02801 - Hard Warning
Fault Status: 01100010
Mileage: 185387 km
Date: 2018.08.18
Time: 00:09:28
Text: 3449087756
Pressure: 1.70 bar
Pressure: 2.30 bar
Temperature: 17.2°C
Text: 80
02214 - Tire Pressure Warning
Mileage: 185387 km
Date: 2018.08.18
Time: 00:09:28
Text: 3449087756
Pressure: 1.70 bar
Pressure: 2.30 bar
Temperature: 17.2°C
Text: 80
02904 - Hard Warning 3
Mileage: 185387 km
Date: 2018.08.18
Time: 00:40:50
Text: 3449087736
Pressure: 1.90 bar
Pressure: 2.30 bar
Temperature: 22.0°C
Text: 00
Mileage: 185387 km
Date: 2018.08.18
Time: 17:19:19
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0000144
VCID: 363531F3D44C6D1AC5F-8062
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone
End----------(Elapsed Time: 01:32, VBatt start/end: 13.7V/13.6V)-----------
