Installed a used ABS Pump and module in this 2021 Tiguan to repair a brake locking issue. Need to complete basic settings of steering angle but not in 03 Address, in 44 address but will not allow me to preform. Even after entering VCDS security access in 44. Does vehicle need SVM with odis? Thank you.
Tuesday,05,March,2024,14:52:06:36683
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: 3VV3B7AX9MM001096 License Plate:
Mileage: 101437km-63030mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 52 5F 6C 75 BB BC
CA
VIN: 3VV3B7AX9MM001096 Mileage: 101437km-63030miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTEA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 F HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0002
Revision: 1DH31000 CVN: 481B24EC
Coding: 012A00122464012F34000000000000000000000000000000
Shop #: WSC 00066 790 00448
ASAM Dataset: EV_ECM20TFS01183A907115F 001004
ROD: EV_ECM20TFS01183A907115F.rod
VCID: 2904913DE971D6F258D-807C
VINID: 0E698348746825D74000100918B9930A98
17158 - Implausible Data Received from ESP Control Module
U0416 00 [00100111] - -
Mileage: 101437 km
Date: 2024.03.04
Time: 14:50:35
Engine RPM: 0.00 /min
Coolant temperature: 97 C
Intake air temperature: 47 C
Voltage terminal 30: 12.540 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Acceleration: 0.000 m/s
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 09P-927-749-V1.clb
Part No SW: 09G 927 158 FM HW: 09G 927 158
Component: AISIN AQ8 206 3757
CVN: 5BEE8C68
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00438
ROD: EV_TCMAQ450031_VW37.rod
VCID: 0358E3952B9DECA2321-8056
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 51560000000009
Coding: 0BFA6BA450201B6DC5770209A2C949D0D60AD8A34045927038415058D2824A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049.rod
VCID: 7EAE9261407F814A5DF-802A
0295 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 117
Mileage: 101437 km
Date: 2024.03.04
Time: 14:41:37
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0550733454 Dataset Number: V03935294AC 0001
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45DC3D8D652912925C5-8010
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NN 907 044 AF HW: 5NN 907 044 AF
Component: AC Automat H36 4901
Revision: 20K04000 Serial number: 00000D00602361
Coding: 0002002420011C001004000012111416
ASAM Dataset: EV_ACClimaPrehVW37X 002030
VCID: 1072DCD96AEB873ABF3-8044
Part No SW: 5Q0 937 085 CF HW: 5Q0 937 085 CF
Component: BCM MQBAB MNA H42 0411
Serial number: 0221046202 Dataset Number: V03935335T0001
Shop #: WSC 00066 790 00276
ASAM Dataset: EV_BCMMQB 021001
ROD: EV_BCMBOSCH_021_VW27.rod
VCID: 7F506F6547758842569-802A
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 200812 034 0373
Serial number: 20081021018750
Humidity sensor: interior:
Subsystem 2 - Part No SW: 5Q0 907 504 HW: 5Q0 907 504
Component: HSS 051 0001
Serial number: S7Y20M07D21H15M12S14
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 GA HW: 5Q1 953 569 D
Component: Lenks.Modul H04 0180
Serial number: 0300060920200C200303
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000460608420163 Dataset Number: V03935315D0001
Coding: 8471155811
ASAM Dataset: EV_EPHVA18AU3700000 009053
VCID: 53F813D59B7DBC22C21-8006
13637426 - Databus
Reset counter: 117
Mileage: 101437 km
Date: 2024.03.04
Time: 14:41:37
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0383
Dataset Number: V03935331DQ 0001
Coding: 3200071210FF8728749C810530409700000000000000000014
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 117
Mileage: 101437 km
Date: 2024.03.04
Time: 14:41:36
Voltage terminal 15: 13.0 V
Control Module temperature: 43 C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s
Adaptive distance regulation: status: ACC_irreversible error
0928 - Databus
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Reset counter: 117
Mileage: 101437 km
Date: 2024.03.04
Time: 14:41:36
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 117
Mileage: 101437 km
Date: 2024.03.04
Time: 14:41:36
Voltage terminal 15: 12.9 V
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 008 0403
Serial number: 003FGM0AER2N Dataset Number: V03935282LS 0001
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 0C4AC8A906C3A3DA43B-8058
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000EBXFSI
Coding: 303451
Subsystem 2 - Part No SW: ----------- HW: 480 002 906 20
Serial number: 35700000000036680A49
Subsystem 3 - Part No SW: ----------- HW: 480 002 606 20
Serial number: 358000000007953D884U
Subsystem 4 - Part No SW: ----------- HW: 480 401 803 20
Component: SideSensor_Dr 004 6149
Serial number: 35100010A62EA502910Q
Subsystem 5 - Part No SW: ----------- HW: 480 401 803 20
Component: SideSensor_Pr 004 6149
Serial number: 35200010E62FCAD4E65Q
Subsystem 6 - Part No SW: ----------- HW: 480 402 007 20
Component: FrontSensor_D 004 6149
Serial number: 35500012C637A292921-
Subsystem 7 - Part No SW: ----------- HW: 480 402 007 20
Component: FrontSensor_P 004 6149
Serial number: 35600012C637A292A3A5
Part No SW: 5NA 920 850 E HW: 5NA 920 850 E
Component: KOMBI 344 8400
Coding: 0BA4090A2788CF0502886A0914010000A0600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
VCID: 41D4299D71013EB260D-8014
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 30072000840605 Dataset Number: V03935325RE 0001
Coding: 030100347F085900FA000258180F00010001070000000000000000000000
GVL: 01443C0000000400404C80008002C80010000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 74BAB0497E33DB1A3BB-8020
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 1981910541400910FJ2B
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 6807807400
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 11230025305240 Dataset Number: V03935321CR 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 3924417D19D1667228D-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 11230025323433
Part No SW: 5Q4 959 393 N HW: 5Q4 959 393 N
Component: TSG FS 008 0820
Serial number: 99028024401015 Dataset Number: V03935321ZQ 0001
Coding: 003013200000048000000000
Shop #: WSC 01383 790 50316
VCID: 4ECE02A1B05FD1CAEDF-801A
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000006372372
Coding: 011000
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Dataset Number: V03935302RN 0001
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 51F419DDA161CE32F0D-8004
Part No SW: 5Q4 959 392 N HW: 5Q4 959 392 N
Component: TSG BFS 008 0820
Serial number: 00028024101051 Dataset Number: V03935322BB 0001
VCID: 4DCC05ADBD59EAD2945-8018
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000006395897
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 842 HW: 3G5 035 842
Component: MU-O-NS-US H56 0813
Serial number: WG8LGM220720000 Dataset Number: V03935335UA 0001
Coding: 23260000002000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 659CDD0DC5E93292BC5-8030
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 261 8214
Serial number: VWZ6ZMX2425125
Subsystem 2 - Part No SW: V03 959 809 CR HW: -----------
Component: NAR 2021 --- 5041
Component: RVC Compact H18 0231
Dataset Number: V03935295MP 0001
Coding: 0123060122002017300040
Part No SW: 5WA 035 285 B HW: 5WA 035 285
Component: OCUGen3High H12 0318
Serial number: 0000000008VIBB2 Dataset Number: V03935334XY 0001
Coding: 023260201968AC209005460160102607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 46DE3A81582F198A55F-8012
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935300SR 0001
Coding: 00804073260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75BC8D4D7549C2120C5-8020
End----------(Elapsed Time: 01:19, VBatt start/end: 12.9V/12.3V)-----------
