Night Vision retrofit problem..
remco_W
C?ID=823
Hi Guys,
I have retrofitted the Night vision system in my Audi Q7 2021 and used the Kufatec dongle to do the coding.
But my garage has ODIS officially, so they can change things if needed.
The garage did remove the CP protection of the modules and when I do a scan with VCDS I can see the modules react on address 84 and don't have an error.
But I can't turn it on under the MMI setting, it is greyed out and the switch to the right.
The only error I can see in the system is this:
Tuesday,27,February,2024,18:25:17:41872
VCDS Version: 23.11.0.0  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: WAUZZZ4M6MD004211   License Plate: NV
Mileage: 67439km-41904mi   Repair Order:
Chassis Type: 4M-AU73 (4K1)
Scan: 01 02 03 06 09 13 15 16 17 19 23 36 3C 42 44 46 51 52 5F 69
          6D 74 75 81 82 84 8C A5 BA BB BC C0 C5 C6 CA CF D6 D7 DB DC
          DE
VIN: WAUZZZ4M6MD004211   Mileage: 67439km-41904miles
82-Head Up Display -- Status: OK 0000
84-Night Vision -- Status: Malfunction 0010
8C-HV Battery -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DCBE)       Labels: None
   Part No SW: 4M0 907 559 H    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0005
   Revision: B8H11000    CVN: 6F519CBA73CF7741
   Coding: 2A2A4012257E040B34280900000000000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TFS0114M0907559H 001006
   ROD: EV_ECM30TFS0114M0907559H.rod
   VCID: 3C2033C486E19EEA33B-8068
   VINID: 9D196AAAA11D19D50000408104A5A1BDC4
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M1 723 523 D    HW: 4M1 723 523 D
   Component: J1115 - FFP  H01 0012
   Serial number: 74942518040820020100
   Clutch electronics 1:
   Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
   Component: J1128 CCU  H04 0034
Readiness: 1110 0001
   Part No SW: 4M0 927 158 CM    HW: 0D7 927 156 B
   Component: 0D7  30TSIRdW H05 0001
   Revision: --H05---    CVN: 313C766D00005592
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 015E8230A183330220D-8054
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 2007290554
   Part No SW: 4M6 907 379 AG    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0857
   Dataset Number: 4M0909504AC 0001 CVN: 8842232B
   Coding: 2C9814B232A20B9AD3A01D92187E52E6F5BAE934284CD0CBB8184A67AF5D97
   Shop #: WSC 17873 123 50804
   ROD: EV_ESP9BOSCHCMP_004_AU73.rod
   VCID: 025C8D3CA485281A397-8056
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 4M8 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0064
   Serial number: 00000417030010 Dataset Number: 4M0909866F  0030
   Coding: 0118B2000001B2A14860010101010000810000070700878700000000000000
   Shop #: WSC 31414 050 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3FDA44C897F785F2169-806A
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001050820402582D6
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ8001300720114700FA
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 4M0909864C  0007
   Coding: 07000140C13900DD070257889CFF9C78130B37100426009B09050A00993316810A450A020010100000000303004918185802400044010004000000000000000000
   Shop #: WSC 63853 004 104857
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017_VW53.rod
   VCID: 7AACF5DCCC5560DA617-802E
   Wiper motor control module:
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301918703573
   Coding: 7DC727
   Serial number: 25072925X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S07.08.2000692227
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z003102
   Coding: 210000
   Automatic dimming interior mirror:
   Subsystem 5 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE116032023610715
   Interior Light Module:
   Subsystem 6 - Part No SW: 4M0 947 135 EC    HW: 4M0 947 135 EC
   Component: Dachmodul  H42 0416
   Serial number: B01766662
   Coding: 0D0305
   Blower 1 for left front backrest:
   Subsystem 7 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK206A4430
   Blower 1 for left front seat cushion:
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK21385633
   Blower 1 for right front backrest:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK20552787
   Blower 1 for right front seat cushion:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK19969893
   Part No SW: 4M0 907 561 R    HW: 4K0 907 561
   Component: LRR4R         H12 0641
   Dataset Number: 4M0909863VG 0002
   Coding: 5765FFDC58082C00010380200000003E4A1246494401409E21
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACCBOSCHAU65X 002036
   ROD: EV_ACCBOSCHAU65X_AU73.rod
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 4KE 959 655 H    HW: 4KE 959 655 D
   Component: AirbagVW32    H42 3303
   Serial number: 0032BM004BKU Dataset Number: 4M0909602CA 0007
   Coding: AACCF0C00CA0000098F600FFF01D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: EV_AirbaVW31SMEAU65x_001_AU49.rod
   VCID: 53F278780B7F7192C21-8006
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2050
   Serial number: 4M0857705AB207U00190
   Coding: 880020
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2050
   Serial number: 4M0857706AB206U00946
   Coding: 880020
   Subsystem 3 - Part No SW: -----------    HW: 480 003 107 20
   Serial number: 357000000002D6281A4I
   Subsystem 4 - Part No SW: -----------    HW: 480 003 107 20
   Serial number: 35800000000B43281A4G
   Subsystem 5 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 351002C004C579105F4%
   Subsystem 6 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 352002C0095D7480EC3D
   Subsystem 7 - Part No SW: -----------    HW: 480 031 607 20
   Component: FrontSensor_D  002 014A
   Serial number: 355002C0486E51406A98
   Subsystem 8 - Part No SW: -----------    HW: 480 031 607 20
   Component: FrontSensor_P  002 014A
   Serial number: 356002C08D8DE870DFCA
   Center pedestrian protection crash sensor:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 307 20
   Component: PedP_Sensor_C  002 0149
   Serial number: 230002C08094BD210A2-
   Driver's side crash data pedestrian protection 2:
   Subsystem 10 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0M0000000045564C6C8
   Passenger's side crash data pedestrian protection 2:
   Subsystem 11 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0N0000000065664C6CC
   Part No SW: 4N0 907 129 LA    HW: 4N0 907 129 LA
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 7BA2F0D8C36F59D27A1-802E
   Part No SW: 4K0 920 794 D    HW: 4K0 920 794 D
   Component: FHybRDW------ H24 0058
   Dataset Number: 4N1909525A  0016
   Coding: 052457D47E8800080DA0EB70D314700008004000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU73.rod
   VCID: 323C1DFC54A5589AE97-8066
   Part No SW: 4K1 907 468 M    HW: 4K1 907 468 C
   Component: Gateway       H06 0506
   Serial number: F0454940597011 Dataset Number: 4M0909515T  0113
   Coding: 02010001000200C05481010000590132DCDA000018000000090000DF02000000
   Shop #: WSC 31414 029 00001
   GVL: F9553C088840000894FCC8009000C818110C0060000000000000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003210
   ROD: EV_Gatew31xAU65x_AU49.rod
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20200729064405 30078
   Serial number: 6046105005
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 4M0 909 059 J    HW: 4M0 909 059
   Component: J539 EBKV H11 0288
   Serial number:   085460011219 Dataset Number: 4M0909524M  0002
   ASAM Dataset: EV_BrakeBoostBOSCHCMP 001003
   ROD: EV_BrakeBoostBOSCHCMP_001_AU49.rod
   VCID: 3B2230D883EF99D23A1-806E
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 4M0 909 057 B    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0154
   Serial number: 05802861050820091114
   Component: MEM-FS        009 0064
   Serial number: 00000416683010 Dataset Number: 4M0909856F  0030
   Coding: 01189A000001B2A14883010101010000810000070700878700000000004000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001050820402582DA
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001300720114700EA
   Part No SW: 4N0 907 566 AM    HW: 4N0 907 566 A
   Component: MRR_HR H14 0588
   Dataset Number: 4M1909535C  0007
   Coding: 1FDC00
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_AU73.rod
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0384
   Serial number: 0000413663154  Dataset Number: 4M0909872L  0038
   Coding: 005D8F005200008200093030
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 48C85F14C239C24AA73-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Dataset Number: 4M0909852AD 0001
   Coding: B0170301010000
   Shop #: WSC 31414 162 00001
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010_AU49.rod
   Part No SW: 8W1 907 064 BH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0565
   Dataset Number: 4M0909501S  0086
   Coding: 01741E03802003E26309A0066C00D88203004000804F06502F0400000514803B001F06010D0A15
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018_AU49.rod
   VCID: 04508B24BE91262A0BB-8050
   Subsystem 1 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38098854
   Antenna for short-range communication:
   Subsystem 2 - Part No SW: 4M1 927 753     HW: 4M1 927 753
   Component: NFCTGS  H03 0010
   Serial number:            993212316
   Antenna 2 for short-range communication:
   Subsystem 3 - Part No SW: 4N0 959 428 B    HW: 4N0 959 428 B
   Component: NFCMIKO  H41 0036
   Serial number: 4420000041089024
   left tail lamp 2:
   Subsystem 4 - Part No SW: 4M0 945 429     HW: 4M0 945 429
   Component: SHL_li2  H08 0008
   Serial number: 54292006180000028873
   Right rear tail lamp 2:
   Subsystem 5 - Part No SW: 4M0 945 430     HW: 4M0 945 430
   Component: SHL_re2  H08 0008
   Serial number: 54302006170000027848
   Part No SW: 4M2 907 170     HW: 4M2 907 170
   Component: B6367226T300H25 0033
   Revision: --H25---    CVN: 4EAD0AB4
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCM08530214M2907170 001001
   ROD: EV_DMCM08530214M2907170.rod
   VCID: 6B82C098B30FC952EA1-803E
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0384
   Serial number: 0000416215440  Dataset Number: 4M0909873L  0038
   Coding: 005D8B005E00008200093030
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 47CA5C28CF27CD32AE9-8012
   Part No SW: 4M2 035 070 L    HW: 4M2 035 070
   Component: MU-TP-ND-EU   042 3853
   Serial number: GRO-63329.06.20 Dataset Number: 4M8909545J  0014
   Coding: 15360020804020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 2E04098C409D7C7A8DF-807A
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4M8 919 605 J    HW: 4M8 919 605 F
   Component: DU AU536 Top   H32 0055
   Serial number: INX00116042000150962
   Data carrier:
   Subsystem 2 - Part No: V03 959 822 FJ
   Component: MIB3_EU_       1090
   Compact disc data bank:
   Component: Gracenote2     1006
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4N0 919 603 J    HW: 4N0 919 603 F
   Component: DU AU651 Bot   H32 0054
   Serial number: INX00106062000170678
   Volume Control 1:
   Subsystem 5 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00004420000067246012
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: HHA-07331.07.2034860
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H10 0040
   Serial number: 000000000005512 Dataset Number: 8Y0909527B  0007
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4 Dataset Number: 4M0909541J  0028
   Coding: 00F0
   VCID: 34301BE4AEB156AAFBB-8060
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 0108200552  Dataset Number: 4M0909576AG 0003
   Coding: 98586080F862
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002_AU73.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132014850
   Coding: 303030
   Part No SW: 4KE 035 282 A    HW: 4KE 035 282 B
   Component: CB_H_ECE      039 0236
   Serial number: A970G0LS055829 Dataset Number: 4K0909612F  0011
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: 392E2AD089D3ABC228D-806C
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 20070360715164
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 270AFCA86F672D324E9-8072
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4M1 919 617 A    HW: 4M1 919 617 A
   Component: HeadupDisplay H07 5951
   Dataset Number: 4M0909463D  0013
   Coding: 5700E0
   Shop #: WSC 48497 006 1048576
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_AU73.rod
Address 84: Night Vision (J853)       Labels:* Redir Fail!
   Part No SW: 4M0 907 547 D    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0050
   Serial number: 646476200202052
   Coding: 202111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   VCID: 353626E0A5CB4FA2CC5-8060
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H07 0007
   Serial number: 639589400B2114400188
4107 - No Basic Setting
          B2010 00 [00001001] - -
          [NightVision ECU: basic settings are missing or not correct]
                    Reset counter: 156
                    Mileage: 67439 km
                    Date: 2024.02.27
                    Time: 18:20:09
                    Image processor: error number-Image processor: error number 2: 00 00 00 00
                    Image processor: error number-Image processor: error number 1: 52 60 00 01
                    Voltage terminal 15: 14.00 V
                    Dynamic calibration-Dynamic calibration: yaw angle offset: 0.00
                    Dynamic calibration-Dynamic calibration: pitch angle offset: -0.10
                    Dynamic calibration: status-Dynamic calibration: pitch angle offset: 0.00
                    Dynamic calibration: status-Dynamic calibration: OFF
                    Dynamic calibration: status-Distance traveled with active dynamic calibration: 0 km
                    Warning_data-Animal_warning_angle: -15.00
                    Warning_data-Corridor_width: 0.00 m
                    Warning_data-Time_to_impact: 0.00 s
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4M0 915 233 AA    HW: 4M0 915 233 J
   Component: BMC_PHEV_BYB  H15 0273
   Dataset Number: 4M0909107A  0001
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU49.rod
   VCID: 6A8CC59CBCF5D05A917-803E
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4M0 915 253 H    HW: 4M0 915 253 H
   Component: J990 SFT426D0  H22 0303
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 13:
   Subsystem 14 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 14:
   Subsystem 15 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 J    HW: 4K4 907 117
   Component: zFAS Var C    H09 0381
   Dataset Number: 4M1909466VA 0021
   Coding: 041104000000000000FBD60000FC4F1C5B9E5600000000D8000000000096D40100BBB8000000000000000080E0000000000000000000C000F98040000000000000009CD00080009000800080000000000080C00000E0
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ZFASAU516 003010
   ROD: EV_ZFASAU516_003_VW53.rod
   VCID: 363421ECB8CD44BAC5F-8062
65544 - Night Vision Assist
          C12DE F0 [00001001] - Status Feedback for HMI Implausible
                    Reset counter: 156
                    Mileage: 67439 km
                    Date: 2024.02.27
                    Time: 18:20:05
                    Profile master status night vision assistant-Nominal status: On
                    Profile master status night vision assistant-Actual status:: Initialization
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   Dataset Number: 4M0909578L  0001
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006_AU73.rod
   VCID: 303817F45AA96A8A9F3-8064
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0384
   Serial number: 0000415467669  Dataset Number: 4M0909897M  0039
   Coding: 004D89000000008200083020
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 4ACC651CDC35305AB17-801E
   Component: TSG HBFS      010 0384
   Serial number: 0000414784780  Dataset Number: 4M0909896M  0039
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4K0 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH07 0113
   Serial number: EN203057920000 Dataset Number: 4M0909470B  0005
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 629CADBC44C5881A597-8036
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 P    HW: 4M0 965 429 F
   Component: TME-Max       H08 0304
   Serial number: 0173610 Dataset Number: 4M0909476L  0028
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_002_AU49.rod
   VCID: 44D04B24FE11E62A4BB-8010
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Auxiliary Air Heater Control Module/PTC:
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR192363003810000240
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 D    HW: 4G0 816 797 D
   Component: J842 EKK es33  H04 0016
   Serial number: 00000000020040700537
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151408034
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 AT    HW: 5QE 915 681 AT
   Component: OBC Delta-ES  H74 2851
   Dataset Number: 4M0909811G  0001
   Coding: 11508B607000
   ASAM Dataset: EV_OBCTwoPhaseDT2MLBev14P 001002
   ROD: EV_OBCTwoPhaseDT2MLBev14P.rod
   VCID: 1E64D94C303DECFA3DF-804A
   Part No SW: 4K0 907 594 AA    HW: 4K0 907 594
   Dataset Number: 4M0909469K  0004
   Coding: 628000053602
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 73B2D8F8EB3F1192221-8026
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0588
   Dataset Number: 4M1909468C  0007
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_AU73.rod
   Part No SW: 4K0 941 592 AD    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H11 0040
   Dataset Number: 4M0909471F  0018
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BCDDFC9425189A297-8026
   Dataset Number: 4M0909472F  0018
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 AM    HW: 4N0 907 669 A
   Component: MRR_VR H14 0588
   Dataset Number: 4M1909482C  0007
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_AU73.rod
   VCID: 05569620B5AB1F221C5-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H14 0588
   Dataset Number: 4M1909483C  0007
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_AU73.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 B    HW: 4N0 035 773 B
   Component: WLC Front NFC H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 808000
   ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
   VCID: 2D060E804D9B0762B45-8078
End----------(Elapsed Time: 02:50, VBatt start/end: 13.8V/13.8V)-----------
Any idea's to check or code ?
Starting to think is needs parameters, but how to get the correct parameters?
It needs to be calibrated, but I don't recall having seen a procedure for that. I would think ODIS would have one when it sees that fault. Also, it wouldn't surprise me if additional special calibration tools are needed.
Go to 5F -> Adaptation and type night_vision into the Search/Filter box, then check the values in the respective channels.
MasterTommy
Amsterdam
C?ID=295586
I second this. I did this retrofit on an SQ7 MY2020 (facelift, same as yours) and the only two things i had to have the dealer donwere CP and the calibration. Calibration requires a special tool only used for calibrating the NV camera. Until you get it calibrated that button will stay grayed out.
remco_W
C?ID=823
A manual calibration was done by my garage, as the automatic calibration procedure is only on a A8. But after it still the same.... It has something to do with the Profile Master??
I have the feeling the radar module comes from a different Audi, A8 maybe. Not sure as I got it from Ebay, and the seller could not tell me. A big German junkyard seller.
Maybe someone could post their coding and mapping of the 5F and 84 module to compare.
MasterTommy
Amsterdam
C?ID=295586
If the correct calibration was done, there would be no basic settings fault in the night vision module. As I told you, I did this retrofit on the exact same generation Q7.
remco_W
C?ID=823
Last week the calibration was done, and there was no basic setting error in module 84 and had the same error in the 5F module.
The basic setting came after I have been playing with the adaptations, as it was done by a Kufatec coding dongle I was not sure all the coding was done correctly. Changed the Band end programming adaptations of the wheel house edge as they were all 0 on my module.
That looked not correct to me, as in another module they were having a values of:
Body height left front wheel house edge,420.70 mm,2
Body height right front wheel house edge,422.60 mm,2
Body height left rear wheel house edge,444.30 mm,2
Body height right rear wheel house edge,447.90 mm,2
@MasterTommy If you could post the coding of 84 and A5 you used and adaptations I can verify those are correct now here. And go to the garage again to calibrate it again, and hopefully that fixes the problems.
But to be clear this error was there also after the calibration:
Reset counter: 156
Mileage: 67439 km
Date: 2024.02.27
Time: 18:20:05
MasterTommy
Amsterdam
C?ID=295586
You can ignore the component protection fault in A5, this is a ghost-DTC that was the result of a package of updates at the dealer, with the DTC being expected and without effect according to the TPI/TSB.
Autoscan:
Friday,01,December,2023,13:35:21:43612
VCDS Version: 23.11.0.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20231027 DS351.0
VIN: WAUZZZ4M7LD002885   License Plate:
Chassis Type: 4M-AU73 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 32 36 3C 42 44 46 47 52 57 5F
          61 65 6D 74 81 82 84 A5 A9 AC BA BB BC C0 C4 CA CB CF D4 D5
          D6 D7 DB DC DE
VIN: WAUZZZ4M7LD002885   Mileage: 95650km-59434miles
C4-DC/DC Converter -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: OK 0000
D5-Roll Control 2 -- Status: OK 0000
Address 01: Engine (J623-DMVA)       Labels: None
   Part No SW: 4M0 907 409 F    HW: 057 907 309 B
   Component: 4.0l V8 TDI   H45 0001
   Revision: D1H45---    CVN: 28D403CD1FD8AF388947E11D8947E11DD6C3ECFE
   Coding: 2A2A4012056E050334280400000000000000000000000000
   Shop #: WSC 38991 004 1048576
   ASAM Dataset: EV_ECM40TDI0114M0907409F 001002
   ROD: EV_ECM40TDI011_AU73.rod
   VCID: 343A7181FEC1CA6AFBB-8160
   VINID: 9D196AAAA11D1DC5000022081411702EB0
   Electrical compressor:
   Subsystem 1 - Part No SW: 057 145 601 E    HW: 057 145 601 E
   Component: J1123 - EAV  H07 0007
   Serial number: VS5-2-ESC401-0009281
   Part No SW: 4M0 927 158 CG    HW: 0D6 927 156 K
   Component: 0D6  40TDIRdW H05 1001
   Revision: --H05---    CVN: CEDC1C3A
   Coding: 100000
   Shop #: WSC 31414 200 00001
   ASAM Dataset: EV_TCMALX52011 002015
   VCID: 7BA89ABD931FC5127A1-812E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Dataset Number: 4M0909504AA 0003 CVN: 394F2D1D
   Coding: 2C983AB230A20B9893A65D995C8216E6E5BAE9345C0CD0C9BA3A6867A75D97
   VCID: 7EAE93A9800DD03A5DF-812A
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000389795517 Dataset Number: 4M0909866E  0027
   Coding: 001832000001B2A14860010101010000810000070700878700000000000000
   Shop #: WSC 31414 049 00001
   VCID: 3D2C54A5CD8B0B22045-8168
   Serial number: SJ800122081940258914
   Coding: BF2F00
   Serial number: SJ800101091911470327
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Dataset Number: 4M1909514A  0008
   Coding: 07000340C13900DD070E77899CEB9C78131B37110406009B01050A001B3316810A450A0200100000000003030041081B5C020001C4030104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_VW53.rod
   VCID: 7BA89ABD936FC5127A1-802E
   Serial number: 904753F0301913501173
   Coding: 7DC727
   Serial number: 23554446X81A955555A0
   Coding: 0200FF
   Serial number: 14S13.09.1900691390
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00KE02
   Coding: 210000
   Serial number: GX1CE114061923310628
   Coding: 030000
   Component: Dachmodul  H42 0415
   Serial number: Q00798099
   Coding: 0D0305
   Adjustable Steering Column Control Module:
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA138792000072901604
   Coding: 0A0100
   Serial number: Q98BJ24664600
   Serial number: Q98BJ23469851
   Serial number: Q98BJ23471605
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Serial number: Q98BJ24664367
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001922000219
   Coding: 040000
   Part No SW: 4M0 907 561 P    HW: 4K0 907 561
   Component: LRR4R         H04 0500
   Dataset Number: 4M0909863VC 0001
   Coding: 3665FF5470082C00010320A00000003E4A1246484401509E11
   Shop #: WSC 20240 006 104857
   ASAM Dataset: EV_ACCBOSCHAU65X 002031
   Part No SW: 4KE 959 655 K    HW: 4KE 959 655 B
   Component: AirbagVW32    H44 3303
   Serial number: 003XRM00568I Dataset Number: 4M0909602VC 0002
   Coding: AAFCF0C00CC0000098F600FFF00D410000C5
   Shop #: WSC 20240 006 1048576
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   VCID: 56FEEB0948FDF87A25F-8102
   Component: BeltPretRevFL  205 2040
   Serial number: 4M0857705R0253T01343
   Coding: 88001B
   Component: BeltPretRevFR  205 2040
   Serial number: 4M0857706S0254T00664
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 000 209 19
   Serial number: 35700000000E1175BF3T
   Subsystem 4 - Part No SW: -----------    HW: 480 000 209 19
   Serial number: 3580000000068775BF3Z
   Subsystem 5 - Part No SW: -----------    HW: 480 030 609 19
   Serial number: 351001C245EB65601C02
   Subsystem 6 - Part No SW: -----------    HW: 480 030 609 19
   Serial number: 352001C245E3A6B0FD0K
   Subsystem 7 - Part No SW: -----------    HW: 480 030 908 19
   Serial number: 355001C245359190BB00
   Subsystem 8 - Part No SW: -----------    HW: 480 030 908 19
   Serial number: 356001C2453DD600CF3H
   Subsystem 9 - Part No SW: -----------    HW: 480 031 908 19
   Serial number: 230001C2453C1A313D5.
   Subsystem 10 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: I0M000000002E284EBBK
   Subsystem 11 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: I0N000000001E284EBBK
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   VCID: 79A480B59923F70268D-812C
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H12 0215
   Dataset Number: 4M0909525L  0012
   Coding: 858D80F67DA8000800A3E5649180580008003000
   Shop #: WSC 31414 246 00001
   ROD: EV_DashBoardAU65X_001_AU73.rod
   VCID: 2C0A69E126F192AAA3B-8178
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0054
   Revision: BD000001    Serial number: 018BD501919912 Dataset Number: 4M0909515R  0100
   Coding: 03010001008806407F070000005B0132FC9B0000BC000000097507CE10000000
   GVL: F15D3C5C8844000002FCC8001100C800110C0070000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AA69FB99C25FC1A617-812E
   Serial number: 20190905155432 31217
   Serial number: 4312722305
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 A    HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0070
   Revision: 5WK12700    Serial number: 605936403200407
   Coding: 0300
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22_AU49.rod
   VCID: 3A265FB9DCA53C1A217-816E
   Component: MEM-FS        009 0044
   Serial number: 00000389160660 Dataset Number: 4M0909856E  0027
   Coding: 00183A000001B2A14803010101010000810000070700878700000000004000
   Serial number: SJ8001260819402584F9
   Coding: BF2F00
   Serial number: SJ800130081911470136
   Component: MRR_HR H12 0588
   Coding: 0FFC00
   VCID: 0154E855F1F3AFC220D-8154
   Serial number: 0000388004650  Dataset Number: 4M0909872K  0037
   Coding: 005D8A015200008200093032
   VCID: 48C2357192495E8AA73-811C
   Dataset Number: 4M0909852AC 0001
   Coding: B2000301000100
   VCID: 3236779904D5C45AE97-8166
   Part No SW: 8W1 907 064 CP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0585
   Dataset Number: 4M0909501N  0081
   Coding: 01341E030FB113606309A0046C00980203004004806F06502F0400000514803B001F0184010A11
   ASAM Dataset: EV_BCM2HellaAU736 019017
   ROD: EV_BCM2HellaAU736_019_AU49.rod
   VCID: 0D4CC465BDABFBA2545-8158
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY192203DKW
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000587020
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4N0 907 133 A    HW: 4N0 907 133 A
   Component: J505-FSH  H20 0600
   Serial number: 19234001303021120081
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11943745
   Subsystem 5 - Part No SW: 4M1 927 753     HW: 4M1 927 753
   Serial number:            398453179
   Subsystem 6 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Serial number: 4419000026779012
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4M0 945 429     HW: 4M0 945 429
   Serial number: 54292109100000001280
   Subsystem 8 - Part No SW: 4M0 945 430     HW: 4M0 945 430
   Serial number: 54302108260000000733
   Part No SW: 4N0 035 466 C    HW: 4N0 035 466
   Component: A2PA-3-AU     H01 0033
   Revision: --01S---    Serial number: 2880031869 Dataset Number: 4M0909510E  0002
   Coding: 0135060800A2AAAAAAAAAA010000
   ASAM Dataset: EV_AMPMst24C2Gen2pBAO 001001
   ROD: EV_AMPMst24C2Gen2pBAO_AU73.rod
   VCID: 2D0C64E51D9B9BA2B45-8078
   Serial number: 0000388120631  Dataset Number: 4M0909873K  0037
   Coding: 005D8A015E00008200093030
   VCID: 47C0364D9F5751F2AE9-8112
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 4N0 919 191 D    HW: 4N0 919 191 A
   Component: DVB2CI        H08 1310
   Serial number: 261740240004290
   Coding: 0105200003010100000000
   ASAM Dataset: EV_TVTunerMIB2Plus 001005
   ROD: EV_TVTunerMIB2Plus_AU73.rod
   Card Reader for TV tuner:
   Subsystem 1 - Part No SW: 4N0 919 805     HW: 4N0 919 805
   Component: R204 CI CRU  H06 0130
   Serial number: 2617300600202402
   Part No SW: 4K0 035 063 G    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   054 2873
   Dataset Number: 4M2909545A  0008
   Coding: 0137660100000000C3111102C00800302F0001E403F008008E
   Shop #: WSC 31414 047 00001
   ROD: EV_MUHigGen2pALPI_AU37.rod
   VCID: 270096CD3F17B1F24E9-8172
   Data carrier:
   Subsystem 1 - Part No: V03 959 807 SR
   Component: MIB2P_EU_Q323  0680
   Subsystem 2 - Part No SW: 4M8 919 605 L    HW: 4M8 919 605 F
   Component: DU AU536 Top  H32 0053
   Serial number: INX00105071900150042
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004419000087710001
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00117061900170030
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900508373013
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0109
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   VCID: 290490F52903878258D-817C
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 40000000044233 Dataset Number: 4M0909850B  0006
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 2F307EED17E7E9B2869-817A
   Coding: 0070
   Serial number: 0409190194  Dataset Number: 4M0909576AF 0006
   Coding: 3E607058FA42
   VCID: 0256E759F4F5B4DA397-8156
   Serial number: 00000000004130712185
   Coding: 303030
   Revision: 0L0D5012    Serial number: 19073154227266
   Part No SW: 4M1 919 617     HW: 4M1 919 617
   Component: HeadupDisplay H07 3910
   Coding: 5700E2
   VCID: 73B8B29DBB4F8D52221-8126
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4KE 907 547 E    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H15 0400
   Serial number: 680384600202230
   Coding: 400112
   Shop #: WSC 126719 622 139864
   ASAM Dataset: EV_NightVisioG3AUTOLAU516 001003
   ROD: EV_NightVisioG3AUTOLAU516.rod
   VCID: 49C430758943A782B8D-811C
   Subsystem 1 - Part No SW: 4G0 980 552 B    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H09 0007
   Serial number: 639589400C2234600082
   Part No SW: 4K4 907 117 F    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0365
   Dataset Number: 4M1909466VF 0014
   Coding: 040108000000000000FBD60000F0C50C5B9F520000000000000000000096D401009BA8000000000000000080E00000000000000000000000F98040000000000000009CD00080009000800080000000000080400000E0
   VCID: 3236779904A5C45AE97-8066
15361024 - Component Protection
          U1101 00 [00001001] - Active
          [Component_protection_active_2]
                    Reset counter: 223
                    Mileage: 95650 km
                    Date: 2023.12.01
                    Time: 13:31:04
                    Counter of component protection malfunctions: 00 23
   Part No SW: 4M0 907 159 A    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 190207200658
   VCID: 3134789501D3FF4290D-8164
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 E    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0007
   ASAM Dataset: EV_RDCMINERGAU736 005014
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 3338729DFBCFCD52E21-8166
   VCID: 30327D910AD9F64A9F3-8164
   Serial number: 0000388668921  Dataset Number: 4M0909897K  0037
   Coding: 004D88000000008200083020
   VCID: 4AC60F798C45AC9AB17-811E
   Serial number: 0000388668918  Dataset Number: 4M0909896K  0037
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 4M0 907 160 A    HW: 4M8 907 160
   Component: SAS-GEN2.5AGA H11 0002
   Serial number: 190726200223
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 682     HW: 4K0 959 682
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19355000575 Dataset Number: 4M0909475F  0020
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_AU49.rod
   VCID: 76BE8B89A83D987A05F-8122
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_ Dataset Number: 4M0909904AA 0002
   Coding: 42240A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_AU73.rod
   VCID: 6FB0BEEDD767A9B2C69-813A
   Component: MRR_HL H12 0588
   Coding: 0FFC00
Address D4: Roll Control 1 (----)       Labels: None
   Part No SW: 971 907 156 T    HW: 971 907 156 L
   Component: EAWSH17 0311
   Serial number: 00120190724159 Dataset Number: 4M0909592H  0001
   ASAM Dataset: EV_EAWSSchaeFront 008001
   ROD: EV_EAWSSchaeFront_AU73.rod
Address D5: Roll Control 2 (----)       Labels: None
   Serial number: 00120190725170 Dataset Number: 4M0909593H  0001
   ASAM Dataset: EV_EAWSSchaeRear 008001
   Dataset Number: 4M0909471E  0017
   VCID: 72B6B799C455845A297-8126
   Dataset Number: 4M0909472E  0017
   Component: MRR_VR H12 0588
   Coding: 003000
   VCID: 055CFC45E5DB83E21C5-8150
   Component: MRR_VL H12 0588
   Coding: 003000
   Coding: 808000
   VCID: 2D0C64E51DEB9BA2B45-8178
End----(Elapsed Time: 03:52, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
I checked but I don't have an adaptation channel log from after the NV retrofit made with VCDS, I have one made with a different tool, so if you can list the channels you want to know i can share them?
Your fault code looks like unit 5F isnt configured properly for the NV system, there are multiple adaptation channels that need to be set. It makes sense that the kufatec channel didnt modify those since its yet another difference between the Q7 4M Facelift (MY2020>) and the Q7 4M Pre-Facelift (MY2016-2019), which I suspect is the cause of these issues.
remco_W
C?ID=823
@MasterTommy Super, going to look at it tomorrow, night time here. :) And if you could post every channel involving the NV would be great. Or even the scan from other tool, I have a VCP and OBDEleven.
remco_W
C?ID=823
Still no luck, the only thing left is to check the adpatations of A5 and 84. Or get a new module.. I spotted also a differenc in the numbers of the SW. Mine starts with 4M0 the one from the scan with 4KE.
MasterTommy
Amsterdam
C?ID=295586
A5:
;SW:4K4-907-117-F   HW:4N0-907-107-H ---  Frt Sens. Drv. Assist --- SA: 20103
;Component:zFAS Var C    H09 0365, Coding:040108000000000000FBD60000F0C50C5B9F5200000000000000000000969401009BA8000000000000000080C00000000000000000000000F98040000000000000009CD00080009000800080000000000080400000E0
;EV_ZFASAU516,003010,EV_ZFASAU516_003_VW53.rod
;Thursday,29,February,2024,16:12:16:43612
;VCDS Version: Release 23.11.0 (x64)  Data version: 20231027 DS351.0
;VCID: 3236779904A5C45AE97-8066
IDE00001-MAS14900-Production mode-Block laser beam,not active ,3
IDE00001-MAS15334-Production mode-Prevention of automatic parking,not active ,3
IDE00001-MAS15687-Production mode-Coding in two steps,not active ,3
IDE00001-MAS15689-Production mode-Deactivate crossing assistant,not active ,3
IDE00001-MAS15690-Production mode-Front camera: deactivate safety mechanisms,not active ,3
IDE00001-MAS16302-Production mode-Peripheral camera system: block partial function,not active ,3
IDE01165-Park assist activation tone,On ,1
IDE01167-Convertible offset for volume level 1,20 ,1
IDE01168-Increment for convertible volume levels,4 ,1
IDE01169-Audio lowering request,On ,1
IDE01170-Visual display for park assist,OPS display ,1
IDE03782-Switch-off speed for parking assist,30 km/h,1
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE05274-Acoustic warning for rear lid assistant,active ,1
IDE06425-Dynamometer mode: functional,not activated ,1
IDE07596-Personalization of lane dept. warning Cl. 15 on,activated ,1
IDE08418-Matrix light: total dimming,100.80 %,1
IDE10861-Perception module for light assistant: activation while parked,not activated ,1
IDE11965-MAS01632-Dimming thresholds for high beam assistance-Status,active ,5
IDE11965-MAS13656-Dimming thresholds for high beam assistance-Activate brightness,1.50 ,5
IDE11965-MAS13657-Dimming thresholds for high beam assistance-Deactivate brightness,6.00 ,5
IDE12645-Matrix headlights: switch-on effect,on engine start ,1
IDE12646-MAS09833-Headlights left: bit pattern high beam segment actuation-LED 1,OFF ,12
IDE12646-MAS09834-Headlights left: bit pattern high beam segment actuation-LED 2,OFF ,12
IDE12646-MAS09835-Headlights left: bit pattern high beam segment actuation-LED 3,OFF ,12
IDE12646-MAS09836-Headlights left: bit pattern high beam segment actuation-LED 4,OFF ,12
IDE12646-MAS09837-Headlights left: bit pattern high beam segment actuation-LED 5,OFF ,12
IDE12646-MAS09838-Headlights left: bit pattern high beam segment actuation-LED 6,OFF ,12
IDE12646-MAS09839-Headlights left: bit pattern high beam segment actuation-LED 7,OFF ,12
IDE12646-MAS09840-Headlights left: bit pattern high beam segment actuation-LED 8,OFF ,12
IDE12646-MAS09841-Headlights left: bit pattern high beam segment actuation-LED 9,OFF ,12
IDE12646-MAS09842-Headlights left: bit pattern high beam segment actuation-LED 10,OFF ,12
IDE12646-MAS09843-Headlights left: bit pattern high beam segment actuation-LED 11,OFF ,12
IDE12646-MAS09844-Headlights left: bit pattern high beam segment actuation-LED 12,OFF ,12
IDE12646-MAS09845-Headlights left: bit pattern high beam segment actuation-LED 13,OFF ,12
IDE12646-MAS09846-Headlights left: bit pattern high beam segment actuation-LED 14,OFF ,12
IDE12646-MAS09847-Headlights left: bit pattern high beam segment actuation-LED 15,OFF ,12
IDE12646-MAS09848-Headlights left: bit pattern high beam segment actuation-LED 16,OFF ,12
IDE12646-MAS09849-Headlights left: bit pattern high beam segment actuation-LED 17,OFF ,12
IDE12646-MAS09850-Headlights left: bit pattern high beam segment actuation-LED 18,OFF ,12
IDE12646-MAS09851-Headlights left: bit pattern high beam segment actuation-LED 19,OFF ,12
IDE12646-MAS09852-Headlights left: bit pattern high beam segment actuation-LED 20,OFF ,12
IDE12646-MAS09853-Headlights left: bit pattern high beam segment actuation-LED 21,OFF ,12
IDE12646-MAS09854-Headlights left: bit pattern high beam segment actuation-LED 22,OFF ,12
IDE12646-MAS09855-Headlights left: bit pattern high beam segment actuation-LED 23,OFF ,12
IDE12646-MAS09856-Headlights left: bit pattern high beam segment actuation-LED 24,OFF ,12
IDE12646-MAS09857-Headlights left: bit pattern high beam segment actuation-LED 25,OFF ,12
IDE12646-MAS09858-Headlights left: bit pattern high beam segment actuation-LED 26,OFF ,12
IDE12646-MAS09859-Headlights left: bit pattern high beam segment actuation-LED 27,OFF ,12
IDE12646-MAS09860-Headlights left: bit pattern high beam segment actuation-LED 28,OFF ,12
IDE12646-MAS09861-Headlights left: bit pattern high beam segment actuation-LED 29,OFF ,12
IDE12646-MAS09862-Headlights left: bit pattern high beam segment actuation-LED 30,OFF ,12
IDE12646-MAS09863-Headlights left: bit pattern high beam segment actuation-LED 31,OFF ,12
IDE12646-MAS09864-Headlights left: bit pattern high beam segment actuation-LED 32,OFF ,12
IDE12646-MAS09865-Headlights left: bit pattern high beam segment actuation-LED 33,OFF ,12
IDE12646-MAS09866-Headlights left: bit pattern high beam segment actuation-LED 34,OFF ,12
IDE12646-MAS09867-Headlights left: bit pattern high beam segment actuation-LED 35,OFF ,12
IDE12646-MAS09868-Headlights left: bit pattern high beam segment actuation-LED 36,OFF ,12
IDE12646-MAS09869-Headlights left: bit pattern high beam segment actuation-LED 37,OFF ,12
IDE12646-MAS09870-Headlights left: bit pattern high beam segment actuation-LED 38,OFF ,12
IDE12646-MAS09871-Headlights left: bit pattern high beam segment actuation-LED 39,OFF ,12
IDE12646-MAS09872-Headlights left: bit pattern high beam segment actuation-LED 40,OFF ,12
IDE12646-MAS09873-Headlights left: bit pattern high beam segment actuation-LED 41,OFF ,12
IDE12646-MAS09874-Headlights left: bit pattern high beam segment actuation-LED 42,OFF ,12
IDE12646-MAS09875-Headlights left: bit pattern high beam segment actuation-LED 43,OFF ,12
IDE12646-MAS09876-Headlights left: bit pattern high beam segment actuation-LED 44,OFF ,12
IDE12646-MAS09877-Headlights left: bit pattern high beam segment actuation-LED 45,OFF ,12
IDE12646-MAS11516-Headlights left: bit pattern high beam segment actuation-LED 46,OFF ,12
IDE12646-MAS11517-Headlights left: bit pattern high beam segment actuation-LED 47,OFF ,12
IDE12646-MAS11518-Headlights left: bit pattern high beam segment actuation-LED 48,OFF ,12
IDE12646-MAS11519-Headlights left: bit pattern high beam segment actuation-LED 49,OFF ,12
IDE12646-MAS11520-Headlights left: bit pattern high beam segment actuation-LED 50,OFF ,12
IDE12646-MAS11521-Headlights left: bit pattern high beam segment actuation-LED 51,OFF ,12
IDE12646-MAS11522-Headlights left: bit pattern high beam segment actuation-LED 52,OFF ,12
IDE12646-MAS11523-Headlights left: bit pattern high beam segment actuation-LED 53,OFF ,12
IDE12646-MAS11524-Headlights left: bit pattern high beam segment actuation-LED 54,OFF ,12
IDE12646-MAS11525-Headlights left: bit pattern high beam segment actuation-LED 55,OFF ,12
IDE12646-MAS11526-Headlights left: bit pattern high beam segment actuation-LED 56,OFF ,12
IDE12646-MAS11527-Headlights left: bit pattern high beam segment actuation-LED 57,OFF ,12
IDE12646-MAS11528-Headlights left: bit pattern high beam segment actuation-LED 58,OFF ,12
IDE12646-MAS11529-Headlights left: bit pattern high beam segment actuation-LED 59,OFF ,12
IDE12646-MAS11530-Headlights left: bit pattern high beam segment actuation-LED 60,OFF ,12
IDE12646-MAS11531-Headlights left: bit pattern high beam segment actuation-LED 61,OFF ,12
IDE12646-MAS11532-Headlights left: bit pattern high beam segment actuation-LED 62,OFF ,12
IDE12646-MAS11533-Headlights left: bit pattern high beam segment actuation-LED 63,OFF ,12
IDE12646-MAS11534-Headlights left: bit pattern high beam segment actuation-LED 64,OFF ,12
IDE12646-MAS11535-Headlights left: bit pattern high beam segment actuation-LED 65,OFF ,12
IDE12646-MAS11536-Headlights left: bit pattern high beam segment actuation-LED 66,OFF ,12
IDE12646-MAS11537-Headlights left: bit pattern high beam segment actuation-LED 67,OFF ,12
IDE12646-MAS11538-Headlights left: bit pattern high beam segment actuation-LED 68,OFF ,12
IDE12646-MAS11539-Headlights left: bit pattern high beam segment actuation-LED 69,OFF ,12
IDE12646-MAS11540-Headlights left: bit pattern high beam segment actuation-LED 70,OFF ,12
IDE12646-MAS11541-Headlights left: bit pattern high beam segment actuation-LED 71,OFF ,12
IDE12646-MAS11542-Headlights left: bit pattern high beam segment actuation-LED 72,OFF ,12
IDE12646-MAS11543-Headlights left: bit pattern high beam segment actuation-LED 73,OFF ,12
IDE12646-MAS11544-Headlights left: bit pattern high beam segment actuation-LED 74,OFF ,12
IDE12646-MAS11545-Headlights left: bit pattern high beam segment actuation-LED 75,OFF ,12
IDE12646-MAS11546-Headlights left: bit pattern high beam segment actuation-LED 76,OFF ,12
IDE12646-MAS11547-Headlights left: bit pattern high beam segment actuation-LED 77,OFF ,12
IDE12646-MAS11548-Headlights left: bit pattern high beam segment actuation-LED 78,OFF ,12
IDE12646-MAS11549-Headlights left: bit pattern high beam segment actuation-LED 79,OFF ,12
IDE12646-MAS11550-Headlights left: bit pattern high beam segment actuation-LED 80,OFF ,12
IDE12646-MAS11551-Headlights left: bit pattern high beam segment actuation-LED 81,OFF ,12
IDE12646-MAS11552-Headlights left: bit pattern high beam segment actuation-LED 82,OFF ,12
IDE12646-MAS11553-Headlights left: bit pattern high beam segment actuation-LED 83,OFF ,12
IDE12646-MAS11554-Headlights left: bit pattern high beam segment actuation-LED 84,OFF ,12
IDE12646-MAS11555-Headlights left: bit pattern high beam segment actuation-LED 85,OFF ,12
IDE12646-MAS11556-Headlights left: bit pattern high beam segment actuation-LED 86,OFF ,12
IDE12646-MAS11557-Headlights left: bit pattern high beam segment actuation-LED 87,OFF ,12
IDE12646-MAS11558-Headlights left: bit pattern high beam segment actuation-LED 88,OFF ,12
IDE12646-MAS11559-Headlights left: bit pattern high beam segment actuation-LED 89,OFF ,12
IDE12646-MAS11560-Headlights left: bit pattern high beam segment actuation-LED 90,OFF ,12
IDE12647-MAS09833-Headlights right: high beam segment actuation-LED 1,OFF ,12
IDE12647-MAS09834-Headlights right: high beam segment actuation-LED 2,OFF ,12
IDE12647-MAS09835-Headlights right: high beam segment actuation-LED 3,OFF ,12
IDE12647-MAS09836-Headlights right: high beam segment actuation-LED 4,OFF ,12
IDE12647-MAS09837-Headlights right: high beam segment actuation-LED 5,OFF ,12
IDE12647-MAS09838-Headlights right: high beam segment actuation-LED 6,OFF ,12
IDE12647-MAS09839-Headlights right: high beam segment actuation-LED 7,OFF ,12
IDE12647-MAS09840-Headlights right: high beam segment actuation-LED 8,OFF ,12
IDE12647-MAS09841-Headlights right: high beam segment actuation-LED 9,OFF ,12
IDE12647-MAS09842-Headlights right: high beam segment actuation-LED 10,OFF ,12
IDE12647-MAS09843-Headlights right: high beam segment actuation-LED 11,OFF ,12
IDE12647-MAS09844-Headlights right: high beam segment actuation-LED 12,OFF ,12
IDE12647-MAS09845-Headlights right: high beam segment actuation-LED 13,OFF ,12
IDE12647-MAS09846-Headlights right: high beam segment actuation-LED 14,OFF ,12
IDE12647-MAS09847-Headlights right: high beam segment actuation-LED 15,OFF ,12
IDE12647-MAS09848-Headlights right: high beam segment actuation-LED 16,OFF ,12
IDE12647-MAS09849-Headlights right: high beam segment actuation-LED 17,OFF ,12
IDE12647-MAS09850-Headlights right: high beam segment actuation-LED 18,OFF ,12
IDE12647-MAS09851-Headlights right: high beam segment actuation-LED 19,OFF ,12
IDE12647-MAS09852-Headlights right: high beam segment actuation-LED 20,OFF ,12
IDE12647-MAS09853-Headlights right: high beam segment actuation-LED 21,OFF ,12
IDE12647-MAS09854-Headlights right: high beam segment actuation-LED 22,OFF ,12
IDE12647-MAS09855-Headlights right: high beam segment actuation-LED 23,OFF ,12
IDE12647-MAS09856-Headlights right: high beam segment actuation-LED 24,OFF ,12
IDE12647-MAS09857-Headlights right: high beam segment actuation-LED 25,OFF ,12
IDE12647-MAS09858-Headlights right: high beam segment actuation-LED 26,OFF ,12
IDE12647-MAS09859-Headlights right: high beam segment actuation-LED 27,OFF ,12
IDE12647-MAS09860-Headlights right: high beam segment actuation-LED 28,OFF ,12
IDE12647-MAS09861-Headlights right: high beam segment actuation-LED 29,OFF ,12
IDE12647-MAS09862-Headlights right: high beam segment actuation-LED 30,OFF ,12
IDE12647-MAS09863-Headlights right: high beam segment actuation-LED 31,OFF ,12
IDE12647-MAS09864-Headlights right: high beam segment actuation-LED 32,OFF ,12
IDE12647-MAS09865-Headlights right: high beam segment actuation-LED 33,OFF ,12
IDE12647-MAS09866-Headlights right: high beam segment actuation-LED 34,OFF ,12
IDE12647-MAS09867-Headlights right: high beam segment actuation-LED 35,OFF ,12
IDE12647-MAS09868-Headlights right: high beam segment actuation-LED 36,OFF ,12
IDE12647-MAS09869-Headlights right: high beam segment actuation-LED 37,OFF ,12
IDE12647-MAS09870-Headlights right: high beam segment actuation-LED 38,OFF ,12
IDE12647-MAS09871-Headlights right: high beam segment actuation-LED 39,OFF ,12
IDE12647-MAS09872-Headlights right: high beam segment actuation-LED 40,OFF ,12
IDE12647-MAS09873-Headlights right: high beam segment actuation-LED 41,OFF ,12
IDE12647-MAS09874-Headlights right: high beam segment actuation-LED 42,OFF ,12
IDE12647-MAS09875-Headlights right: high beam segment actuation-LED 43,OFF ,12
IDE12647-MAS09876-Headlights right: high beam segment actuation-LED 44,OFF ,12
IDE12647-MAS09877-Headlights right: high beam segment actuation-LED 45,OFF ,12
IDE12647-MAS11516-Headlights right: high beam segment actuation-LED 46,OFF ,12
IDE12647-MAS11517-Headlights right: high beam segment actuation-LED 47,OFF ,12
IDE12647-MAS11518-Headlights right: high beam segment actuation-LED 48,OFF ,12
IDE12647-MAS11519-Headlights right: high beam segment actuation-LED 49,OFF ,12
IDE12647-MAS11520-Headlights right: high beam segment actuation-LED 50,OFF ,12
IDE12647-MAS11521-Headlights right: high beam segment actuation-LED 51,OFF ,12
IDE12647-MAS11522-Headlights right: high beam segment actuation-LED 52,OFF ,12
IDE12647-MAS11523-Headlights right: high beam segment actuation-LED 53,OFF ,12
IDE12647-MAS11524-Headlights right: high beam segment actuation-LED 54,OFF ,12
IDE12647-MAS11525-Headlights right: high beam segment actuation-LED 55,OFF ,12
IDE12647-MAS11526-Headlights right: high beam segment actuation-LED 56,OFF ,12
IDE12647-MAS11527-Headlights right: high beam segment actuation-LED 57,OFF ,12
IDE12647-MAS11528-Headlights right: high beam segment actuation-LED 58,OFF ,12
IDE12647-MAS11529-Headlights right: high beam segment actuation-LED 59,OFF ,12
IDE12647-MAS11530-Headlights right: high beam segment actuation-LED 60,OFF ,12
IDE12647-MAS11531-Headlights right: high beam segment actuation-LED 61,OFF ,12
IDE12647-MAS11532-Headlights right: high beam segment actuation-LED 62,OFF ,12
IDE12647-MAS11533-Headlights right: high beam segment actuation-LED 63,OFF ,12
IDE12647-MAS11534-Headlights right: high beam segment actuation-LED 64,OFF ,12
IDE12647-MAS11535-Headlights right: high beam segment actuation-LED 65,OFF ,12
IDE12647-MAS11536-Headlights right: high beam segment actuation-LED 66,OFF ,12
IDE12647-MAS11537-Headlights right: high beam segment actuation-LED 67,OFF ,12
IDE12647-MAS11538-Headlights right: high beam segment actuation-LED 68,OFF ,12
IDE12647-MAS11539-Headlights right: high beam segment actuation-LED 69,OFF ,12
IDE12647-MAS11540-Headlights right: high beam segment actuation-LED 70,OFF ,12
IDE12647-MAS11541-Headlights right: high beam segment actuation-LED 71,OFF ,12
IDE12647-MAS11542-Headlights right: high beam segment actuation-LED 72,OFF ,12
IDE12647-MAS11543-Headlights right: high beam segment actuation-LED 73,OFF ,12
IDE12647-MAS11544-Headlights right: high beam segment actuation-LED 74,OFF ,12
IDE12647-MAS11545-Headlights right: high beam segment actuation-LED 75,OFF ,12
IDE12647-MAS11546-Headlights right: high beam segment actuation-LED 76,OFF ,12
IDE12647-MAS11547-Headlights right: high beam segment actuation-LED 77,OFF ,12
IDE12647-MAS11548-Headlights right: high beam segment actuation-LED 78,OFF ,12
IDE12647-MAS11549-Headlights right: high beam segment actuation-LED 79,OFF ,12
IDE12647-MAS11550-Headlights right: high beam segment actuation-LED 80,OFF ,12
IDE12647-MAS11551-Headlights right: high beam segment actuation-LED 81,OFF ,12
IDE12647-MAS11552-Headlights right: high beam segment actuation-LED 82,OFF ,12
IDE12647-MAS11553-Headlights right: high beam segment actuation-LED 83,OFF ,12
IDE12647-MAS11554-Headlights right: high beam segment actuation-LED 84,OFF ,12
IDE12647-MAS11555-Headlights right: high beam segment actuation-LED 85,OFF ,12
IDE12647-MAS11556-Headlights right: high beam segment actuation-LED 86,OFF ,12
IDE12647-MAS11557-Headlights right: high beam segment actuation-LED 87,OFF ,12
IDE12647-MAS11558-Headlights right: high beam segment actuation-LED 88,OFF ,12
IDE12647-MAS11559-Headlights right: high beam segment actuation-LED 89,OFF ,12
IDE12647-MAS11560-Headlights right: high beam segment actuation-LED 90,OFF ,12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13160-MAS08824-Front camera: target position (static calibration)-Target 1: calibration mark 1: x-coordinate,2402.00 mm,26
IDE13160-MAS08825-Front camera: target position (static calibration)-Target 1: calibration mark 1: y-coordinate,732.00 mm,26
IDE13160-MAS08826-Front camera: target position (static calibration)-Target 1: calibration mark 1: z-coordinate,1694.00 mm,26
IDE13160-MAS08827-Front camera: target position (static calibration)-Target 1: calibration mark 2: x-coordinate,2400.00 mm,26
IDE13160-MAS08828-Front camera: target position (static calibration)-Target 1: calibration mark 2: y-coordinate,-732.00 mm,26
IDE13160-MAS08829-Front camera: target position (static calibration)-Target 1: calibration mark 2: z-coordinate,1694.00 mm,26
IDE13160-MAS08830-Front camera: target position (static calibration)-Target 1: calibration mark 3: x-coordinate,2402.00 mm,26
IDE13160-MAS08831-Front camera: target position (static calibration)-Target 1: calibration mark 3: y-coordinate,732.00 mm,26
IDE13160-MAS08832-Front camera: target position (static calibration)-Target 1: calibration mark 3: z-coordinate,1106.00 mm,26
IDE13160-MAS08833-Front camera: target position (static calibration)-Target 1: calibration mark 4: x-coordinate,2400.00 mm,26
IDE13160-MAS08834-Front camera: target position (static calibration)-Target 1: calibration mark 4: y-coordinate,-732.00 mm,26
IDE13160-MAS08835-Front camera: target position (static calibration)-Target 1: calibration mark 4: z-coordinate,1106.00 mm,26
IDE13160-MAS15814-Front camera: target position (static calibration)-Circle radius,0.00 mm,26
IDE13161-Front camera: vehicle axis angle (static calibration),0 ',1
IDE13162-MAS06929-Front camera: vehicle position (static calibration)-Axle offset front,0.00 mm,4
IDE13162-MAS06930-Front camera: vehicle position (static calibration)-Axle offset rear,0.00 mm,4
IDE13163-MAS15924-Front camera: bodywork height (static calibration)-Wheel house edge front left,794.75 mm,8
IDE13163-MAS15925-Front camera: bodywork height (static calibration)-Wheel house edge front right,793.25 mm,8
IDE13163-MAS15926-Front camera: bodywork height (static calibration)-Wheel house edge rear left,805.00 mm,8
IDE13163-MAS15927-Front camera: bodywork height (static calibration)-Wheel house edge rear right,803.50 mm,8
IDE13164-Front camera: target distance (static calibration),1500.00 mm,2
IDE13166-Front camera: end of line calibration: adjustment,only static calibration ,1
IDE13167-Front camera: target height (initial dynamic calibration),0.00 mm,2
IDE13168-Front camera: sideways Target separation (initial dynamic calibration),0.00 mm,2
IDE13169-Front camera: maximum driving distance (initial dynamic calibration),0 m,2
IDE13216-Wheel protection assistant,active ,1
IDE13230-Parking assistant: additional length of vehicle extensions,0 cm,1
IDE13231-Parking assistant: additional width of vehicle extensions,0 cm,1
IDE13232-Parking assistant: distance from curb,15 cm,1
IDE13233-Parking assistant: parking space fade-in,not activated ,1
IDE13234-Parking assistant: parking speed,Medium ,1
IDE13235-Parking assistant: parking speed menu,active ,1
IDE13325-Emergency assistant: status after switching on terminal 15,As prior to switching off terminal 15 (personalized) ,1
IDE13367-MAS16343-Automatic headlamp calibration: settings-Image quality threshold value,0 %,7
IDE13367-MAS16344-Automatic headlamp calibration: settings-Time limit total duration,0 ms,7
IDE13367-MAS16345-Automatic headlamp calibration: settings-Time-limit for image processing,0 ms,7
IDE13367-MAS16346-Automatic headlamp calibration: settings-Time-limit for headlamp positioning,0 ms,7
IDE13369-MAS16358-Automatic headlamp calibration: correction angle-Right headlamp: horizontal,-1.00 ∞,4
IDE13369-MAS16359-Automatic headlamp calibration: correction angle-Right headlamp: vertical,-1.00 ∞,4
IDE13369-MAS16360-Automatic headlamp calibration: correction angle-Left headlamp: horizontal,-1.00 ∞,4
IDE13369-MAS16361-Automatic headlamp calibration: correction angle-Left headlamp: vertical,-1.00 ∞,4
IDE13370-MAS16358-Auto. headlamp calibration: correction of standard deviations-Right headlamp: horizontal,-0.50 ,4
IDE13370-MAS16359-Auto. headlamp calibration: correction of standard deviations-Right headlamp: vertical,-0.50 ,4
IDE13370-MAS16360-Auto. headlamp calibration: correction of standard deviations-Left headlamp: horizontal,-0.50 ,4
IDE13370-MAS16361-Auto. headlamp calibration: correction of standard deviations-Left headlamp: vertical,-0.50 ,4
IDE13581-Lane departure warning: on state,Select via menu: default on ,1
IDE13582-Lane departure warning: on state vibration,Select via menu: default on ,1
IDE13583-Lane departure warning: intensity of the steering wheel vibration,Medium ,1
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,0.00 ∞,2
IDE13725-Automatic high beam: in operation,not active ,1
IDE13726-Lane assist moment of intervention,Select via menu: default late ,1
IDE14014-Lane assist: sportiness detection,OFF ,1
IDE14057-MAS17320-Left dipped beam setting-Horizontal dipped beam setting: value,-70.00 ,5
IDE14057-MAS17321-Left dipped beam setting-Vertical dipped beam setting: value,-105.00 ,5
IDE14057-MAS17322-Left dipped beam setting-Dipped beam setting: unit,Angular minute ,5
IDE14058-MAS17320-Right dipped beam position-Horizontal dipped beam setting: value,-70.00 ,5
IDE14058-MAS17321-Right dipped beam position-Vertical dipped beam setting: value,-105.00 ,5
IDE14058-MAS17322-Right dipped beam position-Dipped beam setting: unit,Angular minute ,5
IDE14660-Front camera: rotational angle compensation,0.00 ∞,1
IDE14960-Lane Assist: activation speed,65 km/h ,1
IDE14961-Lane Assist: deactivation speed,250 km/h ,1
IDE14972-Emergency assistant: begin warning flash,Data record ,1
MAS12129-Customer-oriented off-road trip,not activated ,1
MAS12579-IDE13023-Maneuvering assistant-Functional deactivation,not active ,1
MAS12579-MAS00086-Maneuvering assistant-active,active ,1
MAS12579-MAS05122-Maneuvering assistant-Braking intervention,active ,1
MAS12579-MAS14210-Maneuvering assistant-Steering intervention,active ,1
ENG153816-EA_preview_blindness_status,not active ,1
ENG153817-EA_preview_extraction_distance,-1000 ms,2
ENG153826-Emergency_assist_activation_override,EA_activation_over_menu ,1
ENG153829-FAS_PM_Active Lane Daparture Warning activation clearing,Aktivierung_erteilt ,1
ENG153830-FAS_PM_Crossing Assist activation clearing,Aktivierung_erteilt ,1
ENG153831-FAS_PM_Dead time after activation FAS Profile push button,500 ,2
ENG153832-FAS_PM_Distance Warner High activation clearing,Aktivierung_erteilt ,1
ENG153833-FAS_PM_Distance Warner Low activation clearing,Aktivierung_erteilt ,1
ENG153834-FAS_PM_Emergency Assist activation clearing,Aktivierung_erteilt ,1
ENG153835-FAS_PM_Exit Warner activation clearing,Aktivierung_erteilt ,1
ENG153836-FAS_PM_Local Emergency Warning activation clearing,Aktivierung_gesperrt ,1
ENG244878-FAS_PM_Logic FAS push button popup or toggle,Option 0 ,1
ENG153838-FAS_PM_Nightvision activation clearing,Aktivierung_erteilt ,1
ENG153839-FAS_PM_Number of minimum profile members,3 ,1
ENG153840-FAS_PM_Number of profile members,3 ,1
ENG153841-FAS_PM_Number of profiles,3 ,1
ENG153842-FAS_PM_Number of retries,3 ,1
ENG153843-FAS_PM_PreSense activation clearing,Aktivierung_erteilt ,1
ENG153844-FAS_PM_Side Assist activation clearing,Aktivierung_erteilt ,1
ENG153845-FAS_PM_Status Active Lane Daparture Warning after Kl.15 on,Fkt_Status_Last ,1
ENG153846-FAS_PM_Status Crossing Assist after Kl.15 on,Fkt_Status_Last ,1
ENG153847-FAS_PM_Status Distance Warner High after Kl.15 on,Fkt_Status_Last ,1
ENG153848-FAS_PM_Status Distance Warner Low after Kl.15 on,Fkt_Status_Last ,1
ENG153849-FAS_PM_Status Emergency Assist after Kl.15 on,Fkt_Status_Last ,1
ENG153850-FAS_PM_Status Exit Warner after Kl.15 on,Fkt_Status_Last ,1
ENG153851-FAS_PM_Status Local Emergency Warning after Kl.15 on,Fkt_Status_Last ,1
ENG153852-FAS_PM_Status Nightvision after Kl.15 on,Fkt_Status_Last ,1
ENG153853-FAS_PM_Status PreSense after Kl.15 on,Fkt_Status_Bus ,1
ENG153854-FAS_PM_Status Side Assist after Kl.15 on,Fkt_Status_Last ,1
ENG153855-FAS_PM_Status Tiredness Warning after Kl.15 on,Fkt_Status_Last ,1
ENG153856-FAS_PM_Status Traffic Jam Pilot after Kl.15 on,Fkt_Status_Last ,1
ENG153857-FAS_PM_Time for retry profile status,200 ,2
ENG153858-FAS_PM_Tiredness Warning activation clearing,Aktivierung_erteilt ,1
ENG153859-FAS_PM_Traffic Jam Pilot activation clearing,Aktivierung_gesperrt ,1
ENG153868-FV_HIL_mode_eyeq_startup_index,0 frames,4
ENG153869-IDE03355-FV_Static_calibration_result-Static calibration: yaw angle,-0.14 ∞,6
ENG153869-IDE03356-FV_Static_calibration_result-Static calibration: pitch angle,-0.53 ∞,6
ENG153869-IDE03357-FV_Static_calibration_result-Static calibration: roll angle,0.10 ∞,6
ENG153869-IDE03358-FV_Static_calibration_result-Static calibration: camera height,1541 mm,6
ENG153882-ENG245004-KA_Adaption_KA-Adaption_IntersectionAssist_BrakeJerk_Profile,0 ,30
ENG153882-ENG154884-KA_Adaption_KA-Adaption_IntersectionAssist_Criticality,0 ,30
ENG153882-ENG245005-KA_Adaption_KA-Adaption_IntersectionAssist_EgoInjection,0 ,30
ENG153882-ENG154886-KA_Adaption_KA-Adaption_IntersectionAssist_HMI_Info_left,Adaption_IntersectionAssist_HMI_Info_left_not_active ,30
ENG153882-ENG154887-KA_Adaption_KA-Adaption_IntersectionAssist_HMI_Info_right,Adaption_IntersectionAssist_HMI_Info_right_not_active ,30
ENG153882-ENG154888-KA_Adaption_KA-Adaption_IntersectionAssist_HMI_Warning,Adaption_IntersectionAssist_HMI_Warning_not_active ,30
ENG153882-ENG244969-KA_Adaption_KA-Adaption_IntersectionAssist_Ignore_ExternalErrors,00 00 00 00 ,30
ENG153882-ENG244950-KA_Adaption_KA-Adaption_IntersectionAssist_Ignore_InternalErrors,00 00 00 00 ,30
ENG153882-ENG245034-KA_Adaption_KA-Adaption_IntersectionAssist_IgnoreDTCs,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,30
ENG153882-ENG169620-KA_Adaption_KA-Adaption_IntersectionAssist_Init,Adaption_IntersectionAssist_noInit ,30
ENG153882-ENG154889-KA_Adaption_KA-Adaption_IntersectionAssist_Message,0 ,30
ENG153882-ENG154890-KA_Adaption_KA-Adaption_IntersectionAssist_ObjectInjection,0 ,30
ENG153882-ENG245020-KA_Adaption_KA-Adaption_IntersectionAssist_ObjectManipulation_TargetDeltaPosX,0.00 ,30
ENG153882-ENG154891-KA_Adaption_KA-Adaption_IntersectionAssist_OPS,Adaption_IntersectionAssist_OPS_not_requested ,30
ENG153882-ENG244970-KA_Adaption_KA-Adaption_IntersectionAssist_StandstillBrake_Deceleration,0.00 ,30
ENG153882-ENG154893-KA_Adaption_KA-Adaption_IntersectionAssist_State,0 ,30
ENG153883-ENG154892-KA_Adaption_PCS-Adaption_IntersectionAssist_PCS_Availability,Adaption_IntersectionAssist_PCS_Availability_init ,3
ENG153883-ENG244971-KA_Adaption_PCS-Adaption_PreCrashSide_PCS_zFAS_State,Adaption_PreCrashSide_PCS_zFAS_State_init ,3
ENG134931-MXB_Order_Reference_Run_Activation_Effect,no_addiction ,1
ENG153929-PP_GP_Deactivating_through_zFAS_Thermal_Helath_Status,not active ,1
ENG153930-PP_GP_limit_zFAS_Thermal_Helath_Status_function_abort,0 ,1
ENG153931-PP_GP_limit_zFAS_Thermal_Helath_Status_function_activation,0 ,1
Elapsed Time: 00:49
5F:
;SW:4K0-035-063-G   HW:4K0-035-063-A ---  Information Electr.
;Component:MU-H-LND-EU   054 2873, Coding:0137660100000000C3111102C00800302F0001E403F008008E
;EV_MUHigGen2pALPI,001001,EV_MUHigGen2pALPI_AU37.rod
;Thursday,29,February,2024,16:26:39:43612
;VCID: 270096CD3F67B1F24E9-8072
IDE00346-Summertime-automatic,automatic ,1
IDE00768-Country identification: country of sale,DE ,2
IDE00769-Call number 1 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE00845-Wheel circumference,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,Yes ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,Yes ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,Yes ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02122-Developer mode,activated ,1
IDE02330-Call number 2 for info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,31
IDE02476-ENG167402-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_lower_threshold,7 Ohm,31
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,31
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,31
IDE02476-ENG167403-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_upper_threshold,12 Ohm,31
IDE02476-ENG167404-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_lower_threshold,7 Ohm,31
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,31
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,31
IDE02476-ENG167405-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_upper_threshold,12 Ohm,31
IDE02476-ENG167406-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_lower_threshold,7 Ohm,31
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,31
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,31
IDE02476-ENG167407-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_upper_threshold,12 Ohm,31
IDE02476-ENG167408-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_lower_threshold,7 Ohm,31
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,31
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,31
IDE02476-ENG167409-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_upper_threshold,12 Ohm,31
IDE02476-ENG167410-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_lower_threshold,7 Ohm,31
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,31
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,31
IDE02476-ENG167411-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_upper_threshold,12 Ohm,31
IDE02476-ENG167412-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_lower_threshold,7 Ohm,31
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,31
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,31
IDE02476-ENG167413-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_upper_threshold,12 Ohm,31
IDE02502-Confirmation of installation change,D9 B3 ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,On ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,On ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,locked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,automatic_with_time_scaling ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,not installed ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,not installed ,30
IDE03471-ENG127492-Vehicle configuration-LGI,On ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,On ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,On ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,On ,30
IDE03471-ENG127495-Vehicle configuration-online_media,On ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,On ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,On ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,native_hmi_only ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,On ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,On ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,On ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,LVDS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,On ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,On ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,locked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,On ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,On ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,On ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,activated ,30
IDE03580-Country recognition for mobile network,0 ,2
IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04549-Telephone data service,On ,1
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE05111-Fee-based traffic information (TMC),32793 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,OFF ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,available. ,1
IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,OFF ,1
IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,OFF ,1
IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,8 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,7 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10480-MAS10743-Interface for external media: activation-Connection 3,activated ,4
IDE10480-MAS10744-Interface for external media: activation-Connection 4,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE10668-Internal SIM Card: Usage,automatic ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s,3
IDE11105-Brand-specific display of connect application,de.audi.myaudimobileassistant ,30
IDE11122-Country identification: country of sale HMI,-- ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,CAB_10 ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,Terminal 15 ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,Terminal 15 ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,Terminal 15 ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,Terminal 15 ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12266-Follow on time for telephone,activated ,1
IDE12353-Configuration of traffic light online functions,On ,1
IDE12363-ENG152467-Installation list DK-1 Systems-Chip_card_reader_control_module,No ,4
IDE12363-ENG152471-Installation list DK-1 Systems-Compact_disc_database,Yes ,4
IDE12363-ENG152464-Installation list DK-1 Systems-Data_medium,Yes ,4
IDE12363-ENG152465-Installation list DK-1 Systems-Display_unit_1_for_multimedia_system,Yes ,4
IDE12363-ENG167464-Installation list DK-1 Systems-Display_unit_2_for_multimedia_system,No ,4
IDE12363-ENG152521-Installation list DK-1 Systems-Display_unit_5_for_multimedia_system,Yes ,4
IDE12363-ENG152561-Installation list DK-1 Systems-Media_Connector,Yes ,4
IDE12363-ENG152520-Installation list DK-1 Systems-Media_Player_1,No ,4
IDE12363-ENG152524-Installation list DK-1 Systems-Multimedia_Extension,Yes ,4
IDE12363-ENG152470-Installation list DK-1 Systems-Multimedia_operating_unit,No ,4
IDE12363-ENG152462-Installation list DK-1 Systems-Operating_and_display_unit_1,No ,4
IDE12363-ENG152463-Installation list DK-1 Systems-Operating_and_display_unit_2,No ,4
IDE12363-ENG152523-Installation list DK-1 Systems-Radio_Control_Center,Yes ,4
IDE12363-ENG154318-Installation list DK-1 Systems-Reserved_10,No ,4
IDE12363-ENG99637-Installation list DK-1 Systems-Reserved_11,No ,4
IDE12363-ENG154355-Installation list DK-1 Systems-Reserved_12,No ,4
IDE12363-ENG154196-Installation list DK-1 Systems-Reserved_13,No ,4
IDE12363-ENG154298-Installation list DK-1 Systems-Reserved_14,No ,4
IDE12363-ENG154243-Installation list DK-1 Systems-Reserved_15,No ,4
IDE12363-ENG154297-Installation list DK-1 Systems-Reserved_16,No ,4
IDE12363-ENG99458-Installation list DK-1 Systems-Reserved_2,No ,4
IDE12363-ENG99668-Installation list DK-1 Systems-Reserved_3,No ,4
IDE12363-ENG154261-Installation list DK-1 Systems-Reserved_4,No ,4
IDE12363-ENG154330-Installation list DK-1 Systems-Reserved_5,No ,4
IDE12363-ENG154188-Installation list DK-1 Systems-Reserved_6,No ,4
IDE12363-ENG154256-Installation list DK-1 Systems-Reserved_7,No ,4
IDE12363-ENG154341-Installation list DK-1 Systems-Reserved_8,No ,4
IDE12363-ENG154185-Installation list DK-1 Systems-Reserved_9,No ,4
IDE12363-ENG152469-Installation list DK-1 Systems-Telephone_handset,No ,4
IDE12363-ENG152466-Installation list DK-1 Systems-Telephone_handset_2,No ,4
IDE12363-ENG152468-Installation list DK-1 Systems-Traffic_data_aerial,No ,4
IDE12363-ENG152522-Installation list DK-1 Systems-Volume_control_button,Yes ,4
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,00 ,10
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,MOST_high ,10
IDE12434-ENG249906-Vehicle menu operation: second generation: extension-menu_chassis_control,not activated ,60
IDE12434-ENG249907-Vehicle menu operation: second generation: extension-menu_chassis_control_after_disclaimer,not activated ,60
IDE12434-ENG249908-Vehicle menu operation: second generation: extension-menu_chassis_control_clamp_15_off,not activated ,60
IDE12434-ENG249909-Vehicle menu operation: second generation: extension-menu_chassis_control_over_threshold_high,not activated ,60
IDE12434-ENG249910-Vehicle menu operation: second generation: extension-menu_chassis_control_stillstand,not activated ,60
IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
IDE12434-ENG249911-Vehicle menu operation: second generation: extension-menu_convertible_top,not activated ,60
IDE12434-ENG249912-Vehicle menu operation: second generation: extension-menu_convertible_top_after_disclaimer,not activated ,60
IDE12434-ENG249913-Vehicle menu operation: second generation: extension-menu_convertible_top_clamp_15_off,not activated ,60
IDE12434-ENG249914-Vehicle menu operation: second generation: extension-menu_convertible_top_over_threshold_high,not activated ,60
IDE12434-ENG249915-Vehicle menu operation: second generation: extension-menu_convertible_top_stillstand,not activated ,60
IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions,not activated ,60
IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer,not activated ,60
IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off,not activated ,60
IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high,not activated ,60
IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand,not activated ,60
IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,activated ,60
IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,activated ,60
IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod,not activated ,60
IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer,not activated ,60
IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off,not activated ,60
IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high,not activated ,60
IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand,not activated ,60
IDE12434-ENG248744-Vehicle menu operation: second generation: extension-menu_ITM,not activated ,60
IDE12434-ENG248745-Vehicle menu operation: second generation: extension-menu_ITM_after_disclaimer,not activated ,60
IDE12434-ENG248746-Vehicle menu operation: second generation: extension-menu_ITM_clamp_15_off,not activated ,60
IDE12434-ENG248747-Vehicle menu operation: second generation: extension-menu_ITM_over_threshold_high,not activated ,60
IDE12434-ENG248748-Vehicle menu operation: second generation: extension-menu_ITM_stillstand,not activated ,60
IDE12434-ENG249916-Vehicle menu operation: second generation: extension-menu_lift,not activated ,60
IDE12434-ENG249917-Vehicle menu operation: second generation: extension-menu_lift_after_disclaimer,not activated ,60
IDE12434-ENG249918-Vehicle menu operation: second generation: extension-menu_lift_clamp_15_off,not activated ,60
IDE12434-ENG249919-Vehicle menu operation: second generation: extension-menu_lift_over_threshold_high,not activated ,60
IDE12434-ENG249920-Vehicle menu operation: second generation: extension-menu_lift_stillstand,not activated ,60
IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,activated ,60
IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,activated ,60
IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas,not activated ,60
IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer,not activated ,60
IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off,not activated ,60
IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high,not activated ,60
IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand,not activated ,60
IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
IDE14012-ENG244945-Ethernet: configuration-Ethernet_activation_1,Master ,2
IDE14012-ENG244946-Ethernet: configuration-Ethernet_activation_2,Deactivated ,2
IDE14012-ENG244947-Ethernet: configuration-Ethernet_activation_3,Deactivated ,2
IDE14012-ENG244948-Ethernet: configuration-Ethernet_activation_4,Deactivated ,2
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Tracking Data group selected ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic setting not recognized Guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with interest weighting,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,Display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,Display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Tracking Data group selected ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,Display ,3
MAS00951-Bluetooth,On ,1
MAS03690-Telephone,Data & language service active ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Terminal 15 ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Terminal 15 ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,CAB_10 ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Terminal 15 ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,CAB_10 ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,CAB_10 ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Infotainment data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4 ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Infotainment data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15 ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Infotainment data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Terminal 15 ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Terminal 15 ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_3 ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,CAB_4 ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,CAB_4 ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,CAB_4 ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Flexray databus ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Not available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Not available ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,1 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,10
ENG152376-ENG101574-Dimming_ambient_illumination_for_volume_control-X1,0 ,6
ENG152376-ENG99557-Dimming_ambient_illumination_for_volume_control-X2,100 ,6
ENG152376-ENG102140-Dimming_ambient_illumination_for_volume_control-X3,50 ,6
ENG152376-ENG99777-Dimming_ambient_illumination_for_volume_control-Y1,50 ,6
ENG152376-ENG100480-Dimming_ambient_illumination_for_volume_control-Y2,0 ,6
ENG152376-ENG100773-Dimming_ambient_illumination_for_volume_control-Y3,100 ,6
ENG152377-ENG101574-Dimming_illumination_for_display_unit_1_for_multimedia_system-X1,0 ,18
ENG152377-ENG99557-Dimming_illumination_for_display_unit_1_for_multimedia_system-X2,40 ,18
ENG152377-ENG102140-Dimming_illumination_for_display_unit_1_for_multimedia_system-X3,70 ,18
ENG152377-ENG102936-Dimming_illumination_for_display_unit_1_for_multimedia_system-X4,100 ,18
ENG152377-ENG103548-Dimming_illumination_for_display_unit_1_for_multimedia_system-X5,150 ,18
ENG152377-ENG113992-Dimming_illumination_for_display_unit_1_for_multimedia_system-X6,253 ,18
ENG152377-ENG99777-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y1,10 ,18
ENG152377-ENG100480-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y2,20 ,18
ENG152377-ENG100773-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y3,60 ,18
ENG152377-ENG100631-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y4,130 ,18
ENG152377-ENG102174-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y5,360 ,18
ENG152377-ENG113993-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y6,1000 ,18
ENG152378-ENG101574-Dimming_illumination_for_display_unit_2_for_multimedia_system-X1,0 ,18
ENG152378-ENG99557-Dimming_illumination_for_display_unit_2_for_multimedia_system-X2,40 ,18
ENG152378-ENG102140-Dimming_illumination_for_display_unit_2_for_multimedia_system-X3,70 ,18
ENG152378-ENG102936-Dimming_illumination_for_display_unit_2_for_multimedia_system-X4,100 ,18
ENG152378-ENG103548-Dimming_illumination_for_display_unit_2_for_multimedia_system-X5,150 ,18
ENG152378-ENG113992-Dimming_illumination_for_display_unit_2_for_multimedia_system-X6,253 ,18
ENG152378-ENG99777-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y1,10 ,18
ENG152378-ENG100480-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y2,20 ,18
ENG152378-ENG100773-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y3,60 ,18
ENG152378-ENG100631-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y4,130 ,18
ENG152378-ENG102174-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y5,360 ,18
ENG152378-ENG113993-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y6,1000 ,18
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG185703-HDCP_encryption,activated_dtla_key ,1
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG167432-ENG167528-RSE_function_configuration-RSE_navigation_coding,not activated ,10
ENG167432-ENG138661-RSE_function_configuration-RSE_software_component,not activated ,10
ENG117912-ENG117775-Select_Remote_Test_DAB_Service-Parameter_Adaption_Service_ID,Conditions not correct or request sequence error,10
ENG117912-ENG117776-Select_Remote_Test_DAB_Service-Parameter_Adaption_Subservice_ID,Conditions not correct or request sequence error,10
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,10
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,10
ENG117909-Shift_Remote_Test_Frequency_DAB,Conditions not correct or request sequence error,10
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,10
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
ENG124510-Video_audio_encryption,activated_dtla_key ,1
Elapsed Time: 00:48
84:
;SW:4KE-907-547-E   HW:4M0-907-547 ---  Night Vision
;Component:NV-ECU-Gen3   H15 0400, Coding:100112
;EV_NightVisioG3AUTOLAU516,001003,EV_NightVisioG3AUTOLAU516.rod
;Thursday,29,February,2024,16:28:31:43612
;VCDS Version: Release 23.11.0 (x64)  Data version: 20231027 DS351.0
;VCID: 49C430758933A782B8D-801C
IDE02155-Reset all counters,Unknown (0),1
IDE02516-IDE09056-Personalization 1-Last operating state,Conditions not correct or request sequence error,1
IDE02516-MAS02208-Personalization 1-Image brightness,Conditions not correct or request sequence error,1
IDE02516-MAS02209-Personalization 1-Image contrast,Conditions not correct or request sequence error,1
IDE02517-IDE09056-Personalization 2-Last operating state,Conditions not correct or request sequence error,1
IDE02517-MAS02208-Personalization 2-Image brightness,Conditions not correct or request sequence error,1
IDE02517-MAS02209-Personalization 2-Image contrast,Conditions not correct or request sequence error,1
IDE02518-IDE09056-Personalization 3-Last operating state,Conditions not correct or request sequence error,1
IDE02518-MAS02208-Personalization 3-Image brightness,Conditions not correct or request sequence error,1
IDE02518-MAS02209-Personalization 3-Image contrast,Conditions not correct or request sequence error,1
IDE02519-IDE09056-Personalization 4-Last operating state,Conditions not correct or request sequence error,1
IDE02519-MAS02208-Personalization 4-Image brightness,Conditions not correct or request sequence error,1
IDE02519-MAS02209-Personalization 4-Image contrast,Conditions not correct or request sequence error,1
IDE03199-Dynamic calibration,Unknown (0),1
IDE03216-MAS04607-Band end programming-Body height left front wheel house edge,0.00 ,19
IDE03216-MAS04608-Band end programming-Body height right front wheel house edge,0.00 ,19
IDE03216-MAS04609-Band end programming-Body height left rear wheel house edge,0.00 ,19
IDE03216-MAS04610-Band end programming-Body height right rear wheel house edge,0.00 ,19
IDE03216-MAS04612-Band end programming-Transverse position: vehicle: front axle,0.00 ,19
IDE03216-MAS04613-Band end programming-Transverse position: vehicle: rear axle,0.00 ,19
IDE03216-MAS04907-Band end programming-X-coordinate calibration field,0.00 ,19
IDE03216-MAS04908-Band end programming-Y-coordinate calibration field,0.00 ,19
IDE03216-MAS04909-Band end programming-Z-coordinate calibration field,0.00 ,19
IDE03216-MAS04910-Band end programming-Driving axis angle,0 ',19
IDE04283-Resetting of maximum temperatures of control module,Unknown (0),1
IDE04284-Resetting of maximum temperatures of camera,Unknown (0),1
IDE08250-Night Vision System: activation,On ,1
IDE12792-IDE09056-Personalization of user account 1-Last operating state,On ,3
IDE12792-MAS02208-Personalization of user account 1-Image brightness,0 ,3
IDE12792-MAS02209-Personalization of user account 1-Image contrast,0 ,3
IDE12792-MAS09885-Personalization of user account 1-Activation condition in MMI,active ,3
IDE12794-IDE09056-Personalization of user account 2-Last operating state,OFF ,3
IDE12794-MAS02208-Personalization of user account 2-Image brightness,0 ,3
IDE12794-MAS02209-Personalization of user account 2-Image contrast,0 ,3
IDE12794-MAS09885-Personalization of user account 2-Activation condition in MMI,active ,3
IDE12796-IDE09056-Personalization of user account 3-Last operating state,OFF ,3
IDE12796-MAS02208-Personalization of user account 3-Image brightness,0 ,3
IDE12796-MAS02209-Personalization of user account 3-Image contrast,0 ,3
IDE12796-MAS09885-Personalization of user account 3-Activation condition in MMI,active ,3
IDE12798-IDE09056-Personalization of user account 4-Last operating state,OFF ,3
IDE12798-MAS02208-Personalization of user account 4-Image brightness,0 ,3
IDE12798-MAS02209-Personalization of user account 4-Image contrast,0 ,3
IDE12798-MAS09885-Personalization of user account 4-Activation condition in MMI,active ,3
IDE12800-IDE09056-Personalization of user account 5-Last operating state,OFF ,3
IDE12800-MAS02208-Personalization of user account 5-Image brightness,0 ,3
IDE12800-MAS02209-Personalization of user account 5-Image contrast,0 ,3
IDE12800-MAS09885-Personalization of user account 5-Activation condition in MMI,active ,3
IDE12802-IDE09056-Personalization of user account 6-Last operating state,OFF ,3
IDE12802-MAS02208-Personalization of user account 6-Image brightness,0 ,3
IDE12802-MAS02209-Personalization of user account 6-Image contrast,0 ,3
IDE12802-MAS09885-Personalization of user account 6-Activation condition in MMI,active ,3
IDE12804-IDE09056-Personalization of user account 7-Last operating state,OFF ,3
IDE12804-MAS02208-Personalization of user account 7-Image brightness,0 ,3
IDE12804-MAS02209-Personalization of user account 7-Image contrast,0 ,3
IDE12804-MAS09885-Personalization of user account 7-Activation condition in MMI,active ,3
ENG105416-Calibration_Status,Calibrated KD ,1
ENG153943-Reset_clamp_15_counter,Resetting ,1
Elapsed Time: 00:08
MasterTommy
Amsterdam
C?ID=295586
Oh and let me state again, the NV will never work with the 'no basic setting' fault. Regardless of if you had it calibrated or not, the NV cam still needs to be calibrated. Its also possible the kufatec module did this.
remco_W
C?ID=823
Found a difference:
That was on mine Terminal 15, I will try a calibration again tomorrow. Fingers crossed. :)
Or I just need a different module...
remco_W
C?ID=823
Sadly, still the same problem after a new calibration, think the module software is the problem...
Monday,04,March,2024,20:29:03:41872
VCDS Version: 23.11.0.0  HEX-V2 CB: 0.4643.4
Data version: 20240205 DS351.0
VIN: WAUZZZ4M6MD004211   License Plate: NEW
Chassis Type: 4M-AU73 (4K1)
Scan: 01 02 03 06 09 13 15 16 17 19 23 36 3C 42 44 46 51 52 5F 69
          6D 74 75 81 82 84 8C A5 BA BB BC C0 C5 C6 CA CF D6 D7 DB DC
          DE
VIN: WAUZZZ4M6MD004211   Mileage: 67627km-42021miles
82-Head Up Display -- Status: OK 0000
8C-HV Battery -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DCBE)       Labels: None
   Part No SW: 4M0 907 559 H    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0005
   Revision: B8H11000    CVN: 6F519CBA73CF7741
   Coding: 2A2A4012257E040B34280900000000000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TFS0114M0907559H 001006
   ROD: EV_ECM30TFS0114M0907559H.rod
   VCID: 3C2033C486E19EEA33B-8068
   VINID: 9D196AAAA11D19D50000408104A5A1BDC4
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M1 723 523 D    HW: 4M1 723 523 D
   Component: J1115 - FFP  H01 0012
   Serial number: 74942518040820020100
   Clutch electronics 1:
   Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
   Component: J1128 CCU  H04 0034
17156 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 67627 km
                    Date: 2024.03.04
                    Time: 20:16:41
                    Engine RPM: 0.00 /min
                    Coolant temperature: 20  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 12.940 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s
Readiness: 1110 0001
   Part No SW: 4M0 927 158 CM    HW: 0D7 927 156 B
   Component: 0D7  30TSIRdW H05 0001
   Revision: --H05---    CVN: 313C766D00005592
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 015E8230A183330220D-8054
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 2007290554
   Part No SW: 4M6 907 379 AG    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0857
   Dataset Number: 4M0909504AC 0001 CVN: 8842232B
   Coding: 2C9814B232A20B9AD3A01D92187E52E6F5BAE934284CD0CBB8184A67AF5D97
   Shop #: WSC 17873 123 50804
   ROD: EV_ESP9BOSCHCMP_004_AU73.rod
   VCID: 025C8D3CA485281A397-8056
Address 06: Seat Mem. Pass (J521)       Labels:* None
   Part No SW: 4M8 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0064
   Serial number: 00000417030010 Dataset Number: 4M0909866F  0030
   Coding: 0118B2000001B2A14860010101010000810000070700878700000000000000
   Shop #: WSC 31414 050 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 3FDA44C897F785F2169-806A
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001050820402582D6
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ8001300720114700FA
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 4M0909864C  0007
   Coding: 07000140C13900DD070257889CFF9C78130B37100426009B09050A00993316810A450A030010100000000303004918185802400044010004000000000000000000
   Shop #: WSC 63853 004 104857
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017_VW53.rod
   VCID: 7AACF5DCCC5560DA617-802E
   Wiper motor control module:
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301918703573
   Coding: 7DC727
   Serial number: 25072925X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S07.08.2000692227
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z003102
   Coding: 210000
   Automatic dimming interior mirror:
   Subsystem 5 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE116032023610715
   Interior Light Module:
   Subsystem 6 - Part No SW: 4M0 947 135 EC    HW: 4M0 947 135 EC
   Component: Dachmodul  H42 0416
   Serial number: B01766662
   Coding: 0D0305
   Blower 1 for left front backrest:
   Subsystem 7 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK206A4430
   Blower 1 for left front seat cushion:
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK21385633
   Blower 1 for right front backrest:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK20552787
   Blower 1 for right front seat cushion:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK19969893
   Part No SW: 4M0 907 561 R    HW: 4K0 907 561
   Component: LRR4R         H12 0641
   Dataset Number: 4M0909863VG 0002
   Coding: 5765FFDC58082C00010380200000003E4A1246494401409E20
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACCBOSCHAU65X 002036
   ROD: EV_ACCBOSCHAU65X_AU73.rod
2342 - Databus
          U1123 00 [00001001] - Received Error Message
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 165
                    Mileage: 67627 km
                    Date: 2024.03.04
                    Time: 20:16:35
                    Control Module temperature: 31  C
                    Voltage terminal 15: 12.9 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s
                    Adaptive distance regulation: status: ACC_irreversible error
                    Steering_angle-Data: 26.900
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.425
                    Misalignment angle: horiz: fast algorithm: -0.500
                    Congestion pilot: status: OFF
                    Outside temperature: 12.00  C
                    Sensor blindness: radar: no blindness detected
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 4KE 959 655 H    HW: 4KE 959 655 D
   Component: AirbagVW32    H42 3303
   Serial number: 0032BM004BKU Dataset Number: 4M0909602CA 0007
   Coding: AACCF0C00CA0000098F600FFF01D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: EV_AirbaVW31SMEAU65x_001_AU49.rod
   VCID: 53F278780B7F7192C21-8006
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2050
   Serial number: 4M0857705AB207U00190
   Coding: 880020
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2050
   Serial number: 4M0857706AB206U00946
   Coding: 880020
   Subsystem 3 - Part No SW: -----------    HW: 480 003 107 20
   Serial number: 357000000002D6281A4I
   Subsystem 4 - Part No SW: -----------    HW: 480 003 107 20
   Serial number: 35800000000B43281A4G
   Subsystem 5 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 351002C004C579105F4%
   Subsystem 6 - Part No SW: -----------    HW: 480 033 007 20
   Serial number: 352002C0095D7480EC3D
   Subsystem 7 - Part No SW: -----------    HW: 480 031 607 20
   Component: FrontSensor_D  002 014A
   Serial number: 355002C0486E51406A98
   Subsystem 8 - Part No SW: -----------    HW: 480 031 607 20
   Component: FrontSensor_P  002 014A
   Serial number: 356002C08D8DE870DFCA
   Center pedestrian protection crash sensor:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 307 20
   Component: PedP_Sensor_C  002 0149
   Serial number: 230002C08094BD210A2-
   Driver's side crash data pedestrian protection 2:
   Subsystem 10 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0M0000000045564C6C8
   Passenger's side crash data pedestrian protection 2:
   Subsystem 11 - Part No SW: -----------    HW: 480 002 307 20
   Serial number: I0N0000000065664C6CC
   Part No SW: 4N0 907 129 LA    HW: 4N0 907 129 LA
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 7BA2F0D8C36F59D27A1-802E
   Part No SW: 4K0 920 794 D    HW: 4K0 920 794 D
   Component: FHybRDW------ H24 0058
   Dataset Number: 4N1909525A  0016
   Coding: 052557D47E8800080DA0EB72D314701008004000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU73.rod
   VCID: 323C1DFC54A5589AE97-8066
   Part No SW: 4K1 907 468 M    HW: 4K1 907 468 C
   Component: Gateway       H06 0506
   Serial number: F0454940597011 Dataset Number: 4M0909515T  0113
   Coding: 02010001000200C05481010000590132DCDA000018000000090000DF02000000
   Shop #: WSC 31414 029 00001
   GVL: F9553C088840000894FCC8009000C818110C0060000000000000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003210
   ROD: EV_Gatew31xAU65x_AU49.rod
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20200729064405 30078
   Serial number: 6046105005
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 4M0 909 059 J    HW: 4M0 909 059
   Component: J539 EBKV H11 0288
   Serial number:   085460011219 Dataset Number: 4M0909524M  0002
   ASAM Dataset: EV_BrakeBoostBOSCHCMP 001003
   ROD: EV_BrakeBoostBOSCHCMP_001_AU49.rod
   VCID: 3B2230D883EF99D23A1-806E
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 4M0 909 057 B    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0154
   Serial number: 05802861050820091114
   Component: MEM-FS        009 0064
   Serial number: 00000416683010 Dataset Number: 4M0909856F  0030
   Coding: 01189A400001BEA14883010101010000810000070700878700000000004000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001050820402582DA
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ8001300720114700EA
   Part No SW: 4N0 907 566 AM    HW: 4N0 907 566 A
   Component: MRR_HR H14 0588
   Dataset Number: 4M1909535C  0007
   Coding: 1FDC00
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_AU73.rod
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0384
   Serial number: 0000413663154  Dataset Number: 4M0909872L  0038
   Coding: 005D8F005200008200093030
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 48C85F14C239C24AA73-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Dataset Number: 4M0909852AD 0001
   Coding: B0170301010003
   Shop #: WSC 31414 162 00001
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010_AU49.rod
   Part No SW: 8W1 907 064 BH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0565
   Dataset Number: 4M0909501S  0086
   Coding: 01741E03C02003E26309A0066C00D88203004000804F06502F0400000514803B001F06010D0A15
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018_AU49.rod
   VCID: 04508B24BE91262A0BB-8050
   ID - sensor:
   Subsystem 1 - Part No SW: 4N0 959 754 CL    HW: 4N0 959 754 CL
   Component: ID-Geber  H11 0233
   Serial number: 3620000076011003
   Subsystem 2 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38098854
   Antenna for short-range communication:
   Subsystem 3 - Part No SW: 4M1 927 753     HW: 4M1 927 753
   Component: NFCTGS  H03 0010
   Serial number:            993212316
   Antenna 2 for short-range communication:
   Subsystem 4 - Part No SW: 4N0 959 428 B    HW: 4N0 959 428 B
   Component: NFCMIKO  H41 0036
   Serial number: 4420000041089024
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4M0 945 429     HW: 4M0 945 429
   Component: SHL_li2  H08 0008
   Serial number: 54292006180000028873
   Right rear tail lamp 2:
   Subsystem 6 - Part No SW: 4M0 945 430     HW: 4M0 945 430
   Component: SHL_re2  H08 0008
   Serial number: 54302006170000027848
   Part No SW: 4M2 907 170     HW: 4M2 907 170
   Component: B6367226T300H25 0033
   Revision: --H25---    CVN: 4EAD0AB4
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCM08530214M2907170 001001
   ROD: EV_DMCM08530214M2907170.rod
   VCID: 6B82C098B30FC952EA1-803E
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0384
   Serial number: 0000416215440  Dataset Number: 4M0909873L  0038
   Coding: 005D8B005E00008200093030
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 47CA5C28CF27CD32AE9-8012
   Part No SW: 4M2 035 070 L    HW: 4M2 035 070
   Component: MU-TP-ND-EU   042 3853
   Serial number: GRO-63329.06.20 Dataset Number: DA_05F_720D 0014
   Coding: 15360020804020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 2E04098C409D7C7A8DF-807A
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4M8 919 605 J    HW: 4M8 919 605 F
   Component: DU AU536 Top   H32 0055
   Serial number: INX00116042000150962
   Data carrier:
   Subsystem 2 - Part No: V03 959 822 FJ
   Component: MIB3_EU_       1090
   Compact disc data bank:
   Component: Gracenote2     1006
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4N0 919 603 J    HW: 4N0 919 603 F
   Component: DU AU651 Bot   H32 0054
   Serial number: INX00106062000170678
   Volume Control 1:
   Subsystem 5 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00004420000067246012
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: HHA-07331.07.2034860
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 A    HW: 8W1 907 383
   Component: Anhaenger     H10 0040
   Serial number: 000000000005512 Dataset Number: 8Y0909527B  0007
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4 Dataset Number: 4M0909541J  0028
   Coding: 00F0
   VCID: 34301BE4AEB156AAFBB-8060
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 0108200552  Dataset Number: 4M0909576AG 0003
   Coding: 98586080F862
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002_AU73.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132014850
   Coding: 303030
   Part No SW: 4KE 035 282 A    HW: 4KE 035 282 B
   Component: CB_H_ECE      039 0236
   Serial number: A970G0LS055829 Dataset Number: 4K0909612F  0011
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: 392E2AD089D3ABC228D-806C
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 20070360715164
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 270AFCA86F672D324E9-8072
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4M1 919 617 A    HW: 4M1 919 617 A
   Component: HeadupDisplay H07 5951
   Dataset Number: 4M0909463D  0013
   Coding: 5700E0
   Shop #: WSC 48497 006 1048576
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_AU73.rod
Address 84: Night Vision (J853)       Labels:* Redir Fail!
   Part No SW: 4M0 907 547 D    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0050
   Serial number: 646476200202052
   Coding: 400111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   VCID: 353626E0A5CB4FA2CC5-8060
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H07 0007
   Serial number: 639589400B2114400188
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4M0 915 233 AA    HW: 4M0 915 233 J
   Component: BMC_PHEV_BYB  H15 0273
   Dataset Number: 4M0909107A  0001
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU49.rod
   VCID: 6A8CC59CBCF5D05A917-803E
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4M0 915 253 H    HW: 4M0 915 253 H
   Component: J990 SFT426D0  H22 0303
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 13:
   Subsystem 14 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
   Cell module control module 14:
   Subsystem 15 - Part No SW: 4M0 915 115 C    HW: 4M0 915 115 A
H08 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 J    HW: 4K4 907 117
   Component: zFAS Var C    H09 0381
   Dataset Number: 4M1909466VA 0021
   Coding: 041104000000000000FBD60000FC4F1C5B9E5600000000D8000000000096D40100BBB8000000000000000080E0000000000000000000C000F98040000000000000009CD0008000B000800080000000000080C00000E0
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ZFASAU516 003010
   ROD: EV_ZFASAU516_003_VW53.rod
   VCID: 363421ECB8CD44BAC5F-8062
98332 - Databus
          [ACC06_ACC_Status_ACC]
                    Reset counter: 165
                    Mileage: 67627 km
                    Date: 2024.03.04
                    Time: 20:16:35
4108 - Databus
          [irreversibler_Fehler_im_ACC_System]
                    Reset counter: 165
                    Mileage: 67627 km
                    Date: 2024.03.04
                    Time: 20:16:35
65544 - Night Vision Assist
          C12DE F0 [00001001] - Status Feedback for HMI Implausible
                    Reset counter: 165
                    Mileage: 67627 km
                    Date: 2024.03.04
                    Time: 20:16:37
                    Profile master status night vision assistant-Nominal status: On
                    Profile master status night vision assistant-Actual status:: Initialization
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   Dataset Number: 4M0909578L  0001
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006_AU73.rod
   VCID: 303817F45AA96A8A9F3-8064
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0384
   Serial number: 0000415467669  Dataset Number: 4M0909897M  0039
   Coding: 004D89000000008200083020
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 4ACC651CDC35305AB17-801E
   Component: TSG HBFS      010 0384
   Serial number: 0000414784780  Dataset Number: 4M0909896M  0039
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4K0 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH07 0113
   Serial number: EN203057920000 Dataset Number: 4M0909470B  0005
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 629CADBC44C5881A597-8036
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 P    HW: 4M0 965 429 F
   Component: TME-Max       H08 0304
   Serial number: 0173610 Dataset Number: 4M0909476L  0028
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_002_AU49.rod
   VCID: 44D04B24FE11E62A4BB-8010
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Auxiliary Air Heater Control Module/PTC:
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR192363003810000240
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 D    HW: 4G0 816 797 D
   Component: J842 EKK es33  H04 0016
   Serial number: 00000000020040700537
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151408034
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 AT    HW: 5QE 915 681 AT
   Component: OBC Delta-ES  H74 2851
   Dataset Number: 4M0909811G  0001
   Coding: 11508B607000
   ASAM Dataset: EV_OBCTwoPhaseDT2MLBev14P 001002
   ROD: EV_OBCTwoPhaseDT2MLBev14P.rod
   VCID: 1E64D94C303DECFA3DF-804A
   Part No SW: 4K0 907 594 AA    HW: 4K0 907 594
   Dataset Number: 4M0909469K  0004
   Coding: 628000053602
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 73B2D8F8EB3F1192221-8026
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0588
   Dataset Number: 4M1909468C  0007
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_AU73.rod
   Part No SW: 4K0 941 592 AD    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H11 0040
   Dataset Number: 4M0909471F  0018
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BCDDFC9425189A297-8026
   Dataset Number: 4M0909472F  0018
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 AM    HW: 4N0 907 669 A
   Component: MRR_VR H14 0588
   Dataset Number: 4M1909482C  0007
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_AU73.rod
   VCID: 05569620B5AB1F221C5-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H14 0588
   Dataset Number: 4M1909483C  0007
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_AU73.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 B    HW: 4N0 035 773 B
   Component: WLC Front NFC H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 808000
   ROD: EV_Charg1MobilDevicAU651_004_AU37.rod
   VCID: 2D060E804D9B0762B45-8078
End----------(Elapsed Time: 03:05, VBatt start/end: 13.0V/13.0V)-----------
MasterTommy
Amsterdam
C?ID=295586
Your coding in 0084 appears to be different? (Edit: and incorrect for your model).
Is night vision enabled in the coding of A5?
remco_W
C?ID=823
Tried various codings in 84, and your coding ending with the 112 is not accepted by the ECU. NV is enabled in A5.
I have now ordered a new ECU with the 4KE-907-547-E SW. As I think that must be the problem. Fingers corssed.
MasterTommy
Amsterdam
C?ID=295586
Seems plausible, the ECU you had before was for the pre-facelift model, which had a completely different MMI and driver assist systems electrical design. Fingers crossed that your camera is also okay with the new arrangement.
remco_W
C?ID=823
It works ! :) Was indeed the software version of the ECU.
So now time to play around with settings and so on.
I am still missing a menu option in the mmi for setting the contrast of the nightvision... Think a adaptation in the 5F module is not correct, need to look into that.
And does anybody know the setting to also turn on the nightvision camera in daylight? Kufatec sells a dongle for the coding, so it should be possible.
MasterTommy
Amsterdam
C?ID=295586
Should be in adaptations of 17, the setting for daytime NV, 90% certain. Pedestrian and wildlife recognition does not work during daytime.
remco_W
C?ID=823
@MasterTommy Could you also post your adaptations of 17 ? Still playing around with settings.
And do you have a contrast menu in your MMI for the NightVision? I am missing that here.
