Need some help with fault codes 2023 Audi Rs6
TwistedRealm
FL, USA
C?ID=325517
Hi guys, not sure what has happened, she's been stage 2 for a few months, haven't driven her in a few weeks and today I fire it up and get a check end code. cleared codes and come back instantly.. Car is stage 2 with high flow cats. They aren't the best after market catted dp's but for over 1k miles since and we haven't had any cell related dp's code ever! But I'm thinking this is different since its not stating rich, but both at the same time going bad doesn't make sense. Or do I have another issue? checked wiring and connectors all look great, I mean she only has 2500 miles. Also have a few other fault that make no sense not sure if related.. Any help would be much appreciated.
TwistedRealm
FL, USA
C?ID=325517
Sunday,25,February,2024,10:03:33:05557
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
VIN: WUA1CBF26PN906119   License Plate:
Mileage: 3897km-2421mi   Repair Order:
Chassis Type: F2-AU58 (4KL)
Scan: 01 02 03 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 65
          6D 74 75 81 82 A5 A9 BB BC C4 CA CB CC CF D6 D7 DB DC DD DE
          8107
VIN: WUA1CBF26PN906119   Mileage: 3897km-2421miles
82-Head Up Display -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DWLA)       Labels: Redir Fail!
   Part No SW: 4K0 907 557 H    HW: 0P2 907 309 A
   Component: V8 4.0l TFSI  H31 0001
   Revision: 72H31000    CVN: E67FFD67
   Coding: 122A0012256E010E342C6000000000000000000000000000
   ASAM Dataset: EV_ECM40TFS0114K0907557H 001002
   ROD: EV_ECM40TFS0114K0907557H.rod
   VCID: 3829D5DE02D2D09AD73-806C
   VINID: 9E54414D25821A0789006041243FBB713B
17141 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [11101101] - Malfunction / Open Circuit
                    Mileage: 3897 km
                    Date: 2024.02.25
                    Time: 09:53:47
                    Engine RPM: 1450.50 /min
                    Normed load value: 0.8 %
                    Coolant temperature: 98 �C
                    Intake air temperature: 75 �C
                    Voltage terminal 30: 12.580 V
                    Heated oxygen sensor bank 1: sensor 1: resistance: 2378.5 Ohm
                    Heated oxygen sensor bank 1: sensor 1: activation: 92.249 %
                    Outside air temperature via CAN: 1.5 �C
                    Oxygen sensor 1 bank 1 ceramic temp: 550.00 �C
23619 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
          P0056 00 [11101101] - Malfunction / Open Circuit
                    Mileage: 3897 km
                    Date: 2024.02.25
                    Time: 09:53:47
Readiness: 1110 0101
   Part No SW: 4K0 927 158 BG    HW: 0D6 927 156 H
   Component: 0D6 40FSINAR  H06 0001
   Revision: --H06---    CVN: D3C38C58D85BE3D8
   Coding: 100000
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 78A915DE4252109A173-802C
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AB    HW: 0D7 321 281 D
   Component: V552 ATFP  H02 0623
   Serial number: 2303241333
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M8 907 379 G    HW: 4M8 907 379 G
   Component: ESP9 Premium  H06 0051
   Dataset Number: 4K2909504B  0003 CVN: C4AC1D44
   Coding: 34AA6A9731A20B9C139F4D925A8691E2F43A892C568CD0C8B25A89472F5C91
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 43D3B2324B148342721-8016
   Part No SW: 4N0 907 063 ME    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H12 0751
   Dataset Number: 4K0909514N  0047
   Coding: 07000363C0291CDD170E57899CEF9C28130B37510426009701050A001B33160108690A028010000000000303004308180802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 019005
   ROD: EV_BCM1BOSCHAU651_018_VW53.rod
   VCID: 7DA704CA6D7035B2445-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 4K1 955 119 B    HW: 4K1 955 119
   Component: J400FRWISCH  065 0760
   Serial number: 00000002304270401733
   Coding: 7DC727
   Subsystem 2 - Part No SW: 81A 955 555 B    HW: 81A 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 21533157X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H10 0090
   Serial number: 19S01.02.2300691885
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00SN02
   Coding: 250000
   Automatic dimming interior mirror:
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR121022323310635
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 BE    HW: 4K0 947 135 BE
   Component: Dachmodul  H42 0419
   Serial number: A01279830
   Coding: 0D0101
   Adjustable Steering Column Control Module:
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H09 0210
   Serial number: WA161592000134482652
   Coding: 0A0700
   Blower 1 for left front backrest:
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BP118A4075
   Blower 1 for left front seat cushion:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BP11465207
   Blower 1 for right front backrest:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BP118A4076
   Blower 1 for right front seat cushion:
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BP11465193
   Part No SW: 4K0 907 561 Q    HW: 4K0 907 561
   Component: LRR4R         H14 0641
   Dataset Number: 4K0909863AD 0004
   Coding: D7659F5478082C00010360E00000083E4A1146484401409E97
   ASAM Dataset: EV_ACCBOSCHAU65X 002036
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 3C21C9CE36EAFCBA33B-8068
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 4N0 959 655 AC    HW: 4N0 959 655 AC
   Component: AirbagVW31    H05 2844
   Serial number: 0031JM00TAYW Dataset Number: 4K0909602BD 0002
   Coding: BFFCFCC000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   ROD: EV_AirbaVW31SMEAU65x_001_VW53.rod
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2023083066100000
   Coding: 04F001
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2023089373700000
   Coding: 04F001
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH0000D23000KCPI60G
   Coding: 303233
   Subsystem 4 - Part No SW: -----------    HW: 480 000 205 23
   Serial number: 35700000000FC6D8186+
   Subsystem 5 - Part No SW: -----------    HW: 480 000 205 23
   Serial number: 3580000000062110086/
   Subsystem 6 - Part No SW: -----------    HW: 480 031 408 22
   Serial number: 351003C08C9AAE611A8R
   Subsystem 7 - Part No SW: -----------    HW: 480 031 308 22
   Serial number: 352003C08BB4C420D89L
   Subsystem 8 - Part No SW: -----------    HW: 480 030 405 23
   Component: FrontSensor_D  002 0149
   Serial number: 355003C18A9B89702F7T
   Subsystem 9 - Part No SW: -----------    HW: 480 030 405 23
   Component: FrontSensor_P  002 0149
   Serial number: 356003C18A9381802F2A
   Part No SW: 4N0 907 129 ML    HW: 4N0 907 129 ML
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 074B66223FAC6F626E9-8052
   Part No SW: 4K0 920 890 F    HW: 4K0 920 890 F
   Component: FBenUSA------ H28 0118
   Coding: 0B4F49F17EA8CF05029067649800531008002000
   ASAM Dataset: EV_DashBoardAU65X 002027
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 313FE8FAE1A801D290D-8064
   Part No SW: 4KL 907 468 J    HW: 4K1 907 468 C
   Component: Gateway       H08 0632
   Serial number: F0167811749741 Dataset Number: 4K0909515S  0070
   Coding: 02030001000406405496000000590132FC9A00C8980002000900008E04000000
   GVL: F1597C580800000002DC88008100C800110C0070010000040000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003291
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 57EB7662AF8C3FE23E9-8002
   Subsystem 1 - Part No SW: 4K0 951 523 P    HW: 4K0 951 523 P
   Component: E221__MFL  H06 0010
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186314002305040855
   Steering Wheel Touch Recognition Control Module:
   Subsystem 3 - Part No SW: 4K0 419 508 E    HW: 4K0 419 508 E
   Component: J1158 KLR  H03 0020
   Serial number: 23067022304S0020H034
   Part No SW: 4N0 907 144 D    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0803
   Serial number: 30303030303030 Dataset Number: 4K0909848H  0001
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2F3BEE82F79C1722869-807A
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163 A    HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0070
   Revision: 5WK12701    Serial number: 605315611201407
   Coding: 0300
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22_AU58.rod
   VCID: 3A2DCFD63CDEC28A217-806E
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000499147956 Dataset Number: 4K8909856D  0020
   Coding: 015C1A400000B4010083010101010000000000000000000000000000004000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006013
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   VCID: 7BA30AD273643B827A1-802E
   Part No SW: 4N0 907 566 AM    HW: 4N0 907 566 A
   Component: MRR_HR H28 0588
   Dataset Number: 4K8909535G  0028
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 015F783A1188515220D-8054
   Part No SW: 4M1 959 793 K    HW: 4M1 959 793 K
   Component: TSG FS        004 0463
   Serial number: YE007WCU03737 Dataset Number: 4K8909872D  0048
   Coding: 005DCB0152001280A009A032
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 47CBA6227F2CAF62AE9-8012
   Part No SW: 4N0 909 144 G    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0507
   Dataset Number: 4K0909852N  0001
   Coding: E1132301010001
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010_VW53.rod
   VCID: 3431E1EE1EBA34FAFBB-8060
   Part No SW: 4N0 907 064 GP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H16 0264
   Dataset Number: 4K8909501R  0060
   Coding: 013463004FB100C0650FA0066C0D880203004000810426502F0400000F04823F151E06810D1F35
   ASAM Dataset: EV_BCM2CONTIAU651 013009
   ROD: EV_BCM2CONTIAU651_013.rod
   VCID: 035372320B944342321-8056
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 177 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  004 0403
   Serial number: 000000000ZL231140870
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000051697693
   left tail lamp 1:
   Subsystem 4 - Part No SW: 4K0 945 217 A    HW: 4K0 945 217 A
   Component: SHL_li1  006 0002
   Serial number: 00000000000004703780
   Subsystem 5 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 44222400
   Rear spoiler control module:
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4K5 945 093 E    HW: 4K5 945 093 E
   Component: SHL_li2  004 0002
   Serial number: 00000000000004550611
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4K0 945 218 A    HW: 4K0 945 218 A
   Component: SHL_re1  006 0002
   Serial number: 00000000000004848682
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4K5 945 094 E    HW: 4K5 945 094 E
   Component: SHL_re2  004 0002
   Serial number: 00000000000005015344
65673 - Sensor for Rear Lid/Hatch Opening
          B1303 4A [00001001] - Incorrect Component(s) Installed
                    Reset counter: 99
                    Mileage: 3897 km
                    Date: 2024.02.25
                    Time: 09:52:45
                    Supply voltages-Terminal 30 power supply: 12.471 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.409 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.381 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 �C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 �C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
   Part No SW: 4M1 959 792 K    HW: 4M1 959 792 K
   Component: TSG BFS       004 0463
   Serial number: YE007WCR02691 Dataset Number: 4K8909873D  0048
   Coding: 005DCB015E001280A009A030
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 46D5AB267826B66A55F-8012
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 4M2 035 092 L    HW: 4M2 035 092 A
   Component: MU-TP-NS-US   044 3809
   Serial number: GRO-63308.05.23 Dataset Number: 4K1909545M  0039
   Coding: 15820000804100000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 323DE7F6E4AE3ACAE97-8066
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4K0 919 605 M    HW: 4K0 919 605 M
   Component: DU AU58x Top   H41 0060
   Serial number: INX00109022300220205
   Data carrier:
   Subsystem 2 - Part No: V03 959 820 LE
   Component: MIB3_NA_       1076
   Compact disc data bank:
   Component: Gracenote2     3007
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4K0 919 603 M    HW: 4K0 919 603 M
   Component: DU AU58x Bot   H41 0060
   Serial number: INX00127032300240263
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008323000070489006
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
007 0007
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 4M2 035 466 B    HW: 4M2 035 466 B
   Component: B_A_3_A_A_AU   H09 0120
   Serial number: HHA-07308.03.2342960
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 D    HW: 4N0 915 105 D
   Component: BMS_48V_LiIon H09 0207
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 2B03FA92C3846B02AA1-807E
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0010
   Serial number: 30000000195981 Dataset Number: 4K0909850A  0016
   ROD: EV_RDKHUFAU736_AU38.rod
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 4M8 959 107 A    HW: 4M8 959 107 A
   Component: HDSG-Modul    H06 0335
   Revision: --------    Serial number: A2-C765-5001-2 Dataset Number: 4K0909541F  0020
   Coding: 1270
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_AU37.rod
   VCID: 392FD0DA39D8C99228D-806C
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4K0 907 777 CA    HW: 4K0 907 777 C
   Component: Fahrwerk-SG   H53 2135
   Serial number: 0805231658  Dataset Number: 4K0909576R  0001
   Coding: 746C5840FA64
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002_AU58.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004134207995
   Coding: 303030
   Part No SW: 4KE 035 283 G    HW: 4KE 035 283 B
   Component: CB_H_NAR      042 0481
   Serial number: A971E0P3048761 Dataset Number: 4K0909612K  0019
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: 40D9BD3E5A02985A6F3-8014
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K1 713 041 L    HW: 4K1 713 041 H
   Component: GSM-LL H16 0056
   Serial number: 23.080 41172
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2C01F98EC68A6C3AA3B-8078
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4K1 919 617 D    HW: 4K1 919 617 D
   Component: HeadupDisplay H20 6117
   Coding: 4700E2
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 3537DCEA15C02DF2CC5-8060
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 L    HW: 4K4 907 117
   Component: zFAS Var C    H09 0383
   Dataset Number: 4K0909466AJ 0061
   Coding: 020188000000000000FBD60000FCD50E139FD200000000D8000000000096D40101BBB8008000000000000080C00000000000000000000000F980400000000000000098D0008000B000800080000000000080E08000E0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003_VW53.rod
98341 - Cancellation of Park/Steering Assist
          B187A 00 [00001000] - -
                    Reset counter: 139
                    Mileage: 3897 km
                    Date: 2024.02.25
                    Time: 09:53:53
   Part No SW: 4K0 907 159 E    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 230320291560
   VCID: 3333E2F21BB433C2E21-8066
   Part No SW: 4M1 959 795 K    HW: 4M1 959 795 K
   Component: TSG HFS       006 0462
   Serial number: YE007WCJ11526 Dataset Number: 4K8909897F  0050
   Coding: 004DC90100001280E008A020
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: 49CFA01A69385912B8D-801C
   Component: TSG HBFS      006 0462
   Serial number: YE007WCJ28009 Dataset Number: 4K8909896F  0050
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC23156000573 Dataset Number: 4K0909475B  0011
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75B71CEA55406DF20C5-8020
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Dataset Number: 4K0909469J  0023
   Coding: 268040058203
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_ Dataset Number: 4K0909904J  0003
   Coding: 4224C200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N0 903 028 R    HW: 4N0 903 028 R
   Component: BSG-HP1-65    H19 0527
   Serial number: 03052300030156
   Coding: 30000400000000
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H28 0588
   Dataset Number: 4K8909468G  0028
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
   Part No SW: 4K0 941 592 AG    HW: 4K0 941 592 A
   Component: LMS_MLBevo    H20 0132
   Dataset Number: 4K0909471L  0021
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   Dataset Number: 4K0909472L  0021
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 AM    HW: 4N0 907 669 A
   Component: MRR_VR H28 0588
   Dataset Number: 4K8909482E  0025
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 05576C2A05A07D721C5-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H28 0588
   Dataset Number: 4K8909483E  0026
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Dataset Number: 4K0909581C  0011
   Coding: 229000058204
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_VW37.rod
   VCID: 76B51BE6484666EA05F-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: 20191DBEBA42B85A0F3-8074
Address 8107: Antenna (JX3)       Labels:* None
   Part No SW: 4N0 035 503 AR    HW: 4N0 035 503 AR
   Component: DDA_Gen2      H03 0207
   Coding: E2CA
   ASAM Dataset: EV_DigitRoofAntenAU651 002003
   ROD: EV_DigitRoofAntenAU651_002_AU58.rod
End----------(Elapsed Time: 02:48, VBatt start/end: 13.1V/12.1V)-----------
2kaa52
Ceska Republica, Praha
C?ID=319193
Check connectors.
If OK, Check with original Maps.
TwistedRealm
FL, USA
C?ID=325517
Thanks, did both no dice :-( what i don't understand is how could both be bad or open unless its a linked circuit (if ones bad both are bad)? BTW i search the rear lid open and changed the coding, wow that was cool now that codes are clear, just this 02 sensor open link is what I have to address. Don't mind purchasing new sensors if need be but at 2500 miles, wow that is crazy.
TwistedRealm
FL, USA
C?ID=325517
So according to the faults both back (down stream) 02's would be bad, how strange it would be both..
TTT
C?ID=547002
Why? If both under same fuse and that’s tripped due to a short? Is then still odd? Rodents do some stuff as well.
TwistedRealm
FL, USA
C?ID=325517
Not sure I follow you, assuming we'd both agree this isn't a fuse related issue since I'd have tons of other things if a fuse went. Unless your saying a spike in voltage killed both 02 sensors....
TTT
C?ID=547002
Faults are for heating elements of the oxygen sensors. I would not be surprised if the’re both supplied by the same fuse. But easier for you to check on car?
LE: I can’t follow you either, why would a circuit with 2 heating elements supply anything else as well? They pull each what .. 5A when cold? 10A then?
TwistedRealm
FL, USA
C?ID=325517
Wow that would be awesome if it was something as simple as a fuse!!
TwistedRealm
FL, USA
C?ID=325517
Going to check.
TwistedRealm
FL, USA
C?ID=325517
Don't have a fuse in the a1 location even though it said 2020-2023 does have one. A 15 was check and its fine. Will check the rest of the fuses.
TwistedRealm
FL, USA
C?ID=325517
Well I did find a fuse that was blown, is a 15a micro fuse and its states "engine component" lol. Hopefully this is it, don't have any so have to get some.
TwistedRealm
FL, USA
C?ID=325517
Thanks TTT for suggesting a fuse, that was it! Back up and running with out a check engine light or 02 sensor malfunction. Assuming something is up with one of them, if it happens again will have to look into one of the sensors being faults. hopefully this helps others if it happens, heck didn't even know there was a fuse box under the rest peddle lol.
TTT
C?ID=547002
Nice, now the difficult question comes: why did it blew? A heater element is either defect or not. So I am suspecting wiring damage, either rodents if that is a known issue in the area, or cable loom rubbing against metal, when engine torques.
TwistedRealm
FL, USA
C?ID=325517
Thinking the same, don't believe its rodents based on where its stored as well as have a lift and check out everywhere on the motor bay. No wires or connectors look odd, my guess would be a "on the verge" 02 sensor ready to go.
