Sunday,25,February,2024,10:03:33:05557
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WUA1CBF26PN906119 License Plate:
Mileage: 3897km-2421mi Repair Order:
Chassis Type: F2-AU58 (4KL)
Scan: 01 02 03 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 65
6D 74 75 81 82 A5 A9 BB BC C4 CA CB CC CF D6 D7 DB DC DD DE
8107
VIN: WUA1CBF26PN906119 Mileage: 3897km-2421miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DWLA) Labels: Redir Fail!
Part No SW: 4K0 907 557 H HW: 0P2 907 309 A
Component: V8 4.0l TFSI H31 0001
Revision: 72H31000 CVN: E67FFD67
Coding: 122A0012256E010E342C6000000000000000000000000000
ASAM Dataset: EV_ECM40TFS0114K0907557H 001002
ROD: EV_ECM40TFS0114K0907557H.rod
VCID: 3829D5DE02D2D09AD73-806C
VINID: 9E54414D25821A0789006041243FBB713B
17141 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 00 [11101101] - Malfunction / Open Circuit
Mileage: 3897 km
Date: 2024.02.25
Time: 09:53:47
Engine RPM: 1450.50 /min
Normed load value: 0.8 %
Coolant temperature: 98 �C
Intake air temperature: 75 �C
Voltage terminal 30: 12.580 V
Heated oxygen sensor bank 1: sensor 1: resistance: 2378.5 Ohm
Heated oxygen sensor bank 1: sensor 1: activation: 92.249 %
Outside air temperature via CAN: 1.5 �C
Oxygen sensor 1 bank 1 ceramic temp: 550.00 �C
23619 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0056 00 [11101101] - Malfunction / Open Circuit
Mileage: 3897 km
Date: 2024.02.25
Time: 09:53:47
Readiness: 1110 0101
Part No SW: 4K0 927 158 BG HW: 0D6 927 156 H
Component: 0D6 40FSINAR H06 0001
Revision: --H06--- CVN: D3C38C58D85BE3D8
Coding: 100000
Shop #: WSC 02664 785 00200
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011_VW53.rod
VCID: 78A915DE4252109A173-802C
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AB HW: 0D7 321 281 D
Component: V552 ATFP H02 0623
Serial number: 2303241333
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M8 907 379 G HW: 4M8 907 379 G
Component: ESP9 Premium H06 0051
Dataset Number: 4K2909504B 0003 CVN: C4AC1D44
Coding: 34AA6A9731A20B9C139F4D925A8691E2F43A892C568CD0C8B25A89472F5C91
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 43D3B2324B148342721-8016
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 ME HW: 4N0 907 063 AE
Component: BCM1 MLBevo H12 0751
Dataset Number: 4K0909514N 0047
Coding: 07000363C0291CDD170E57899CEF9C28130B37510426009701050A001B33160108690A028010000000000303004308180802000044010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 019005
ROD: EV_BCM1BOSCHAU651_018_VW53.rod
VCID: 7DA704CA6D7035B2445-8028
Subsystem 1 - Part No SW: 4K1 955 119 B HW: 4K1 955 119
Component: J400FRWISCH 065 0760
Serial number: 00000002304270401733
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 21533157X81A955555B0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 C HW: 4K1 941 501 C
Component: E1 - LTM H10 0090
Serial number: 19S01.02.2300691885
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00SN02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR121022323310635
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 BE HW: 4K0 947 135 BE
Component: Dachmodul H42 0419
Serial number: A01279830
Coding: 0D0101
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H09 0210
Serial number: WA161592000134482652
Coding: 0A0700
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BP118A4075
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BP11465207
Subsystem 10 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BP118A4076
Subsystem 11 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BP11465193
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 Q HW: 4K0 907 561
Component: LRR4R H14 0641
Dataset Number: 4K0909863AD 0004
Coding: D7659F5478082C00010360E00000083E4A1146484401409E97
ASAM Dataset: EV_ACCBOSCHAU65X 002036
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 3C21C9CE36EAFCBA33B-8068
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 AC HW: 4N0 959 655 AC
Component: AirbagVW31 H05 2844
Serial number: 0031JM00TAYW Dataset Number: 4K0909602BD 0002
Coding: BFFCFCC000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
ROD: EV_AirbaVW31SMEAU65x_001_VW53.rod
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2023083066100000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2023089373700000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H14 0022
Serial number: IBH0000D23000KCPI60G
Coding: 303233
Subsystem 4 - Part No SW: ----------- HW: 480 000 205 23
Serial number: 35700000000FC6D8186+
Subsystem 5 - Part No SW: ----------- HW: 480 000 205 23
Serial number: 3580000000062110086/
Subsystem 6 - Part No SW: ----------- HW: 480 031 408 22
Component: SideSensor_Dr 002 0149
Serial number: 351003C08C9AAE611A8R
Subsystem 7 - Part No SW: ----------- HW: 480 031 308 22
Component: SideSensor_Pr 002 0149
Serial number: 352003C08BB4C420D89L
Subsystem 8 - Part No SW: ----------- HW: 480 030 405 23
Component: FrontSensor_D 002 0149
Serial number: 355003C18A9B89702F7T
Subsystem 9 - Part No SW: ----------- HW: 480 030 405 23
Component: FrontSensor_P 002 0149
Serial number: 356003C18A9381802F2A
Part No SW: 4N0 907 129 ML HW: 4N0 907 129 ML
Component: Lenks.Modul H03 0009
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 074B66223FAC6F626E9-8052
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 890 F HW: 4K0 920 890 F
Component: FBenUSA------ H28 0118
Coding: 0B4F49F17EA8CF05029067649800531008002000
ASAM Dataset: EV_DashBoardAU65X 002027
ROD: EV_DashBoardAU65X_002_AU58.rod
VCID: 313FE8FAE1A801D290D-8064
Part No SW: 4KL 907 468 J HW: 4K1 907 468 C
Component: Gateway H08 0632
Serial number: F0167811749741 Dataset Number: 4K0909515S 0070
Coding: 02030001000406405496000000590132FC9A00C8980002000900008E04000000
GVL: F1597C580800000002DC88008100C800110C0070010000040000000000006700
ASAM Dataset: EV_Gatew31xAU65x 003291
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 57EB7662AF8C3FE23E9-8002
Subsystem 1 - Part No SW: 4K0 951 523 P HW: 4K0 951 523 P
Component: E221__MFL H06 0010
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 74186314002305040855
Subsystem 3 - Part No SW: 4K0 419 508 E HW: 4K0 419 508 E
Component: J1158 KLR H03 0020
Serial number: 23067022304S0020H034
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 D HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0803
Serial number: 30303030303030 Dataset Number: 4K0909848H 0001
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2F3BEE82F79C1722869-807A
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 A HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0070
Revision: 5WK12701 Serial number: 605315611201407
Coding: 0300
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22_AU58.rod
VCID: 3A2DCFD63CDEC28A217-806E
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 00000499147956 Dataset Number: 4K8909856D 0020
Coding: 015C1A400000B4010083010101010000000000000000000000000000004000
VCID: 7BA30AD273643B827A1-802E
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 AM HW: 4N0 907 566 A
Component: MRR_HR H28 0588
Dataset Number: 4K8909535G 0028
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001022
ROD: EV_RearRadarS1DelphAU651_VW53.rod
VCID: 015F783A1188515220D-8054
Part No SW: 4M1 959 793 K HW: 4M1 959 793 K
Component: TSG FS 004 0463
Serial number: YE007WCU03737 Dataset Number: 4K8909872D 0048
Coding: 005DCB0152001280A009A032
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 47CBA6227F2CAF62AE9-8012
Part No SW: 4N0 909 144 G HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0507
Dataset Number: 4K0909852N 0001
Coding: E1132301010001
ROD: EV_EPSVWBSAU426_010_VW53.rod
VCID: 3431E1EE1EBA34FAFBB-8060
Part No SW: 4N0 907 064 GP HW: 4N0 907 064 P
Component: BCM2 MLBevo H16 0264
Dataset Number: 4K8909501R 0060
Coding: 013463004FB100C0650FA0066C0D880203004000810426502F0400000F04823F151E06810D1F35
ASAM Dataset: EV_BCM2CONTIAU651 013009
ROD: EV_BCM2CONTIAU651_013.rod
VCID: 035372320B944342321-8056
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 A HW: 5Q0 951 172 B
Component: Sensor, DWA 004 0403
Serial number: 000000000ZL231140870
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000051697693
left tail lamp 1:
Subsystem 4 - Part No SW: 4K0 945 217 A HW: 4K0 945 217 A
Component: SHL_li1 006 0002
Serial number: 00000000000004703780
Subsystem 5 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 44222400
Rear spoiler control module:
left tail lamp 2:
Subsystem 7 - Part No SW: 4K5 945 093 E HW: 4K5 945 093 E
Component: SHL_li2 004 0002
Serial number: 00000000000004550611
Right rear tail lamp 1:
Subsystem 8 - Part No SW: 4K0 945 218 A HW: 4K0 945 218 A
Component: SHL_re1 006 0002
Serial number: 00000000000004848682
Right rear tail lamp 2:
Subsystem 9 - Part No SW: 4K5 945 094 E HW: 4K5 945 094 E
Component: SHL_re2 004 0002
Serial number: 00000000000005015344
65673 - Sensor for Rear Lid/Hatch Opening
B1303 4A [00001001] - Incorrect Component(s) Installed
Reset counter: 99
Mileage: 3897 km
Date: 2024.02.25
Time: 09:52:45
Supply voltages-Terminal 30 power supply: 12.471 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.409 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.381 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 �C
general_additional_freeze_frame-interior_temperature: -50.0 �C
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Part No SW: 4M1 959 792 K HW: 4M1 959 792 K
Component: TSG BFS 004 0463
Serial number: YE007WCR02691 Dataset Number: 4K8909873D 0048
Coding: 005DCB015E001280A009A030
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 46D5AB267826B66A55F-8012
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 4M2 035 092 L HW: 4M2 035 092 A
Component: MU-TP-NS-US 044 3809
Serial number: GRO-63308.05.23 Dataset Number: 4K1909545M 0039
Coding: 15820000804100000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_VW53.rod
VCID: 323DE7F6E4AE3ACAE97-8066
Multimedia System 1:
Subsystem 1 - Part No SW: 4K0 919 605 M HW: 4K0 919 605 M
Component: DU AU58x Top H41 0060
Serial number: INX00109022300220205
Subsystem 2 - Part No: V03 959 820 LE
Component: MIB3_NA_ 1076
Compact disc data bank:
Component: Gracenote2 3007
Multimedia System 5:
Subsystem 4 - Part No SW: 4K0 919 603 M HW: 4K0 919 603 M
Component: DU AU58x Bot H41 0060
Serial number: INX00127032300240263
Volume Control 1:
Subsystem 5 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00008323000070489006
Media socket:
Subsystem 6 - Part No: 4N1 035 736
007 0007
Digital Sound System Control Module 2:
Subsystem 7 - Part No SW: 4M2 035 466 B HW: 4M2 035 466 B
Component: B_A_3_A_A_AU H09 0120
Serial number: HHA-07308.03.2342960
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 D HW: 4N0 915 105 D
Component: BMS_48V_LiIon H09 0207
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 2B03FA92C3846B02AA1-807E
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000195981 Dataset Number: 4K0909850A 0016
ROD: EV_RDKHUFAU736_AU38.rod
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 4M8 959 107 A HW: 4M8 959 107 A
Component: HDSG-Modul H06 0335
Revision: -------- Serial number: A2-C765-5001-2 Dataset Number: 4K0909541F 0020
Coding: 1270
ASAM Dataset: EV_DeckLidCONTIAU536 001002
ROD: EV_DeckLidCONTIAU536_AU37.rod
VCID: 392FD0DA39D8C99228D-806C
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4K0 907 777 CA HW: 4K0 907 777 C
Component: Fahrwerk-SG H53 2135
Serial number: 0805231658 Dataset Number: 4K0909576R 0001
Coding: 746C5840FA64
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002_AU58.rod
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004134207995
Coding: 303030
Part No SW: 4KE 035 283 G HW: 4KE 035 283 B
Component: CB_H_NAR 042 0481
Serial number: A971E0P3048761 Dataset Number: 4K0909612K 0019
Coding: 01E0E0F9C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_VW53.rod
VCID: 40D9BD3E5A02985A6F3-8014
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 L HW: 4K1 713 041 H
Component: GSM-LL H16 0056
Serial number: 23.080 41172
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 2C01F98EC68A6C3AA3B-8078
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 4K1 919 617 D HW: 4K1 919 617 D
Component: HeadupDisplay H20 6117
Coding: 4700E2
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 3537DCEA15C02DF2CC5-8060
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4K4 907 117 L HW: 4K4 907 117
Component: zFAS Var C H09 0383
Dataset Number: 4K0909466AJ 0061
Coding: 020188000000000000FBD60000FCD50E139FD200000000D8000000000096D40101BBB8008000000000000080C00000000000000000000000F980400000000000000098D0008000B000800080000000000080E08000E0
ASAM Dataset: EV_ZFASAU516 003008
ROD: EV_ZFASAU516_003_VW53.rod
98341 - Cancellation of Park/Steering Assist
B187A 00 [00001000] - -
Reset counter: 139
Mileage: 3897 km
Date: 2024.02.25
Time: 09:53:53
Part No SW: 4K0 907 159 E HW: 81A 907 159 A
Component: SAS-GEN 2.5 H08 0001
Serial number: 230320291560
VCID: 3333E2F21BB433C2E21-8066
Part No SW: 4M1 959 795 K HW: 4M1 959 795 K
Component: TSG HFS 006 0462
Serial number: YE007WCJ11526 Dataset Number: 4K8909897F 0050
Coding: 004DC90100001280E008A020
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
VCID: 49CFA01A69385912B8D-801C
Component: TSG HBFS 006 0462
Serial number: YE007WCJ28009 Dataset Number: 4K8909896F 0050
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 663 HW: 4K0 959 663
Component: DCDC_GEN_2 H20 0307
Serial number: DC23156000573 Dataset Number: 4K0909475B 0011
ASAM Dataset: EV_DCDC48VFLEXAU581 004001
ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
VCID: 75B71CEA55406DF20C5-8020
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 4K0909469J 0023
Coding: 268040058203
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4N0 909 145 K HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0398
Revision: -------- Serial number: CCC_098_B_9056_ Dataset Number: 4K0909904J 0003
Coding: 4224C200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Address CC: Starter-Generator (C29) Labels:* None
Part No SW: 4N0 903 028 R HW: 4N0 903 028 R
Component: BSG-HP1-65 H19 0527
Serial number: 03052300030156
Coding: 30000400000000
ASAM Dataset: EV_Start48VAU651 002007
ROD: EV_Start48VAU651_002.rod
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H28 0588
Dataset Number: 4K8909468G 0028
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001022
ROD: EV_RearRadarS2DelphAU651_VW53.rod
Part No SW: 4K0 941 592 AG HW: 4K0 941 592 A
Component: LMS_MLBevo H20 0132
Dataset Number: 4K0909471L 0021
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
Dataset Number: 4K0909472L 0021
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 AM HW: 4N0 907 669 A
Component: MRR_VR H28 0588
Dataset Number: 4K8909482E 0025
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
VCID: 05576C2A05A07D721C5-8050
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H28 0588
Dataset Number: 4K8909483E 0026
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392) Labels:* None
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_2 006 0002
Dataset Number: 4K0909581C 0011
Coding: 229000058204
ASAM Dataset: EV_SunRoof2CONTIPO623 009011
ROD: EV_SunRoof2CONTIPO623_VW37.rod
VCID: 76B51BE6484666EA05F-8022
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 20191DBEBA42B85A0F3-8074
Address 8107: Antenna (JX3) Labels:* None
Part No SW: 4N0 035 503 AR HW: 4N0 035 503 AR
Component: DDA_Gen2 H03 0207
Coding: E2CA
ASAM Dataset: EV_DigitRoofAntenAU651 002003
ROD: EV_DigitRoofAntenAU651_002_AU58.rod
End----------(Elapsed Time: 02:48, VBatt start/end: 13.1V/12.1V)-----------
