All,
I have a 2010 VW CC. Here's the deal...I bought the car as a flood vehicle. The shop that sold me the car put everything together so I'm not completely sure about all that was done.
Anyway I was originally having (and still am) issues with the DSG. No issues after I first bought the car but then months later it started bucking when I came to a stop. Shortly thereafter I was coming home after the car sat for several hours and I got a transmission overheat warning. I read about the G509 sensor so I changed it out and all was good for a short time. However the problem soon reappeared...bucking when shifting into or out of D, then the overheat warning and being stranded
I just got VAGCOM and started looking into what the heck was going on. After speaking with one of the techs at Ross-Tech I was advised that the sensor might have been a bad part. I was seeing the G509 sensor go to 200C which was triggering the overheat warning. So, I put another sensor in the car and the overheat is now fixed. However the bucking issue is still there. I have now twice done the adaptation to no avail. While monitoring the Valve Current and Main Pressure-Valve current 1 and 2 I found that when shifting into D the values jump all over the place while it is bucking...the values finally settle down and the bucking stops. This also happens when shifting out of D and into N or P. I'm thinking mechatronic...not sure but I think it might be connected to the other issues.
The other issues are that I am now getting a lot of other random faults. Here's the scan
So, I'm thinking there's something going on electrically that is causing all of this. I did just do an LED light install so that might be the reason for the interior light fault but I bought them from a reputable shop and they aren't supposed to trip any codes. The engine fault happened after the G509 install and the rest of the codes did as well. Maybe I bumped something but I noticed the main harness that leads into the cabin from the engine bay is loose and can easily be moved with my hand.
What I'm trying to figure out is how all of the modules communicate. If the J533 is where everything comes together maybe there is something going on there or maybe it's something completely different. I've checked all the grounds (to include removing the wires, cleaning them and reinstalling) so I don't think that's the issue...
If anyone has anything to contribute and can maybe get me on the right path I'd appreciate it. I'm not afraid to tear the dash apart if need be but I don't want to do that if there's nothing to be found there...
Thanks!
Tuesday,18,August,2015,23:06:36:06166
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WVWMN7AN9AE545401 License Plate:
Chassis Type: AN (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65
72 77
VIN: WVWMN7AN9AE545401 Mileage: 130720km-81225miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 026 DA HW: 06J 906 026 DA
Component: MED17.5 TFSI 2,0 6987
Revision: AAH15--- Serial number: VWZCZ000000000
Coding: 0404010A1C070160
Shop #: WSC 05666 444 12371
VCID: 6CF9331F4F93E15E9A-8038
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction
Mileage: 130708 km
Date: 2015.08.18
Time: 22:46:34
RPM: 1436 /min
Load: 11.0 %
Speed: 72.0 km/h
Temperature: 98.0°C
Temperature: 43.0°C
Absolute Pres.: 1010.0 mbar
Readiness: 0100 0100
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 053 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2106
Revision: 51112 Serial number: 00001002030119
Shop #: WSC 05311 000 00000
VCID: 130B48E3326D9EA6FB-8046
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000104033482
Coding: 0000380
VCID: 62E55D27BD57A72E20-8036
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 05311 115 00000
ROD: EV_ClimaBasis_VW36.rod
VCID: 75CF167BD4D9209675-8020
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003631607
Coding: F1848F8B40041A0047970F00170000000028FB475C40017C174000000000
Shop #: WSC 05124 000 00000
VCID: 334BE863522D7EA69B-8066
Subsystem 1 - Part No: 3C8 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 141209 022 0613
Coding: 00046997
Shop #: WSC 05124
Component: RLS 040210 054 0403
Coding: 00209133
Shop #: WSC 05124
02399 - Control Circuit for Terminal 30 for Interior Illumination
Fault Status: 00111001
Reset counter: 176
Mileage: 130664 km
Voltage: 12.80 V
Fault Status: 00101100
Reset counter: 176
Mileage: 130664 km
Voltage: 13.60 V
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__30S VW10 HI 1918
Revision: 22014000 Serial number: 003JZP67EMSU
Coding: 0012371
VCID: 4BBB90832ADD0666F3-801E
Subsystem 1 - Part No: 3C8 959 339 A
Subsystem 2 - Serial number: 00000000003FM7
Subsystem 3 - Serial number: 0009.03.110000300000660077ÿ†63
Subsystem 4 - Serial number: 660077ÿ†6332MTS601363429 ÿ†63
Subsystem 5 - Serial number: 63429 ÿ†6342MTS662033439 ÿ†63
Subsystem 6 - Serial number: 33439 ÿ†6351HTS6BJQ286KJ ÿ†63
Subsystem 7 - Serial number: 286KJ ÿ†6361HTS68BO386KJ ÿ†63
Subsystem 8 - Serial number: 386KJ ÿ†63727TS6I1J6U9KR ÿ†63
Subsystem 9 - Serial number: 6U9KR ÿ†63827TS6GEU7U9KJ ÿ
Subsystem 10 - Serial number: 7U9KJ ÿ
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0122
Revision: FF010035 Serial number: 20100130100119
Coding: 098A270002
ASAM Dataset: EV_VW360SteerWheelUDS A03002
VCID: 6BFB3003829DE66693-803E
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 M HW: 3C8 920 970 M
Component: KOMBI H03 0305
Coding: 240F00
Shop #: WSC 05314 115 00000
VCID: 364DD177895F6B8EBC-8062
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P102020187
Coding: FD807F06001612009002
Shop #: WSC 05314 123 12345
VCID: 2F43E413BE055A46FF-807A
Reset counter: 136
Mileage: 130655 km
Part No SW: 3C8 919 965 HW: 3C8 919 965
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1614128T1J2702
Coding: 0000002
Shop #: WSC 05314 000 00000
VCID: 75CF167B1CD9209675-8020
Part No SW: 3C0 959 433 AP HW: 3C0 959 433 AP
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
VCID: 78D11F4F0BCB5DFE6E-802C
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667742293
VCID: 266D013751FF1B0E0C-8072
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0501
Revision: 12110009 Serial number: 0002610350
Coding: 0004B7
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DFF3E1BBC89E8568D-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001282294
Coding: 000490
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.141 0703
Revision: 1AH03726 Serial number: 00093280408002
Coding: 0000258
VCID: 3A55C54775478FEE58-806E
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 052 0412
Coding: 13910F8001862E521204141FF08A0F0E085801
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0000396309
Coding: 0004B6
ROD: EV_DCU52BrosePasseSide.rod
VCID: 79D71A4BF8C144F611-802C
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001261638
Coding: 000490
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 176
Mileage: 130669 km
Date: 2015.08.17
Time: 18:50:26
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000292046
Coding: 0021057
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K1107818
Coding: 0100040004
VCID: 61E7522B7851BC3639-8034
Reset counter: 134
Mileage: 130655 km
Date: 2015.08.17
Time: 04:19:33
Component: RDK 0453
Coding: 0100101
Fault Status: 01110100
Mileage: 130675 km
Date: 2015.08.18
Time: 00:43:15
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669671225
Coding: 0A00000000010100
Shop #: WSC 00015 115 00000
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 62E55D277557A72E20-8036
B104F 13 [009] - Short to GND
Fault Frequency: 20
Reset counter: 138
Mileage: 130655 km
Date: 2015.08.17
Time: 04:20:04
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Reset counter: 135
Mileage: 130655 km
Date: 2015.08.17
Time: 04:20:04
End-------------------------(Elapsed Time: 02:00)--------------------------
Thanks!
