Resolved A6 C7 2.0 TDI Air Con Basic Settings
Resolved
Keyser Soze 75
N. Ireland
C?ID=74438
Hi,
Firstly I would like to thank Ross Tech for the development & support of this fantastic piece of diagnostic software & hardware and all the users for their contributions over the years.
I have been using VCDS for a very long time (even going back as far as aka vagcom), it has served me very well over the years with diagnosis, repair, retrofits & servicing, not only for my own cars but also for family & friends, saving a fortune over the years.
I have run into a problem though where I need some help if anyone would be kind enough to assist.
Background;
Last week my air con started blowing warm air at me, I thought ok simple enough maybe it needs re-gassed.
Booked it into the local garage, they carried out a leak test (passed no issues) & re-gassed.
AC would not run & button LED would not stay on after re-gassing (LED stayed on before re-gassing), mechanic proceeds to scan with his diagnostic equipment (snap-on I believe), he said 2 faults coming up but couldn't work out what they where & asked me to book in again in a couple of weeks so they could investigate.
I said no issue, I have VCDS & will scan myself to see what comes up.
Carried out an autoscan & discovered fault with G395 pressure sensor, new genuine OEM pressure sensor purchased & installed (4H0 959 126B).
Followed the advice on this thread as symptoms were nearly identical to my own;
https://forums.ross-tech.com/index.php?threads/32284/
I am able to carry out the basic calibration settings as per the thread & case study (engine running at idle) & everything finishes successfully.
Air con light stays on & nice cold air blowing from the vents.
But I cannot clear the fault code, am I doing something incorrectly or is there another step I'm missing?
Any help would be greatly appreciated, my OCD is driving me nuts knowing there's a fault code I can't clear lol!
Latest autoscan from yesterday afternoon;
Sunday,11,June,2023,13:33:17:21850
VCDS Version: 23.3.1.0 (x64)
VIN: WAUZZZ4G4DN120186   License Plate: XXXXXXX 11.6.23 FULL SCAN 2
Mileage: 163615km-101665mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ4G4DN120186   Mileage: 163615km-101665miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9977
   Revision: 45H25---    CVN: 95A81E56
   Coding: 0A194012242401080000
   Shop #: WSC 41232 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LA 003011
   ROD: EV_ECM20TDI01103L906018GT.rod
   VCID: 74E70274DFEE7533DF-8020
   VINID: 9D196AAAA1171147810800481890A571D7
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 06A087016005E1809B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3663F87C8912272321-8062
   Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
   Component: BCM2 2.0      H33 0433
   Coding: 03B83006000000000000
   VCID: 77FD3578C6981E2BFA-8022
   Serial number: 2313000021312013
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
   Component: KLIMA 2 ZONEN H11 0086
   Serial number: 22021300111789
   Coding: 34210008A1
   ASAM Dataset: EV_AirCondiBasisUDS 002044
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 60CF7E247B16F993AB-8034
0272 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 237
                    Mileage: 163615 km
                    Date: 2023.06.11
                    Time: 12:02:13
                    Basic setting of flap motors-Recirculation flap motor: OK
                    Basic setting of flap motors-Left center vent motor: OK
                    Basic setting of flap motors-Right center vent motor: OK
                    Basic setting of flap motors-Left footwell temperature flap motor: OK
                    Basic setting of flap motors-Right footwell temperature flap motor: OK
                    Basic setting of flap motors-Rear temperature door motor: OK
                    Basic setting of flap motors-Defroster flap motor: OK
                    Basic setting of flap motors-Left temperature flap positioning motor: OK
                    Basic setting of flap motors-Right temperature flap positioning motor: OK
                    Basic setting of flap motors-Fresh air door motor: OK
0292 - Running-in regulation
          B10C6 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 22
                    Mileage: 163615 km
                    Date: 2023.06.11
                    Time: 13:45:47
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001417559
   Coding: 2600201141348F600481008300001D0C0F9D830827090201000004602100
   VCID: 6ED3101CB9C25FE329-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 121106  H36 0080
   Serial number:         121114194509
   Coding: 0045F7
   Serial number: 21013914
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 21 02 2013  00000297
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: C6880596000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061305701398
   Coding: 08C206
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E90B60A0FC401B34-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00C1JVF Dataset Number: 4G0909602G  0014
   Coding: 30323436313230303235554A305234473053
   Serial number: 3575HRB400C50D1UDPPV
   Serial number: 3585HRB400E50CQ0H9B2
   Serial number: 3515JRB400M50ENAL8U-
   Serial number: 3525JRB401250ENAFPLK
   Serial number: 3554VRB400850DEE7P8C
   Serial number: 3564VRB401A50DLU99M$
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130225001492
   Coding: 000014
   VCID: 306FCE64637609137B-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 950 N    HW: 4G8 920 950 N
   Component: MDieGb        H34 0306
   Revision: 26450232    Serial number: 658220213592007
   Coding: 33A508000B412600010000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   VCID: 3A7BEC4CBD0AC343C5-806E
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000837160 Dataset Number: 4G0909515C  0065
   Coding: 00CD074400
   GVL: BDA1C800DC6060010000
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 4032110103
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 121214000000000003D5
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H02 0056
   Revision: --------    Serial number: EJ1BPA7203AJC4 Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3365C1689A60320B06-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 479D85B8F6F8AEAB4A-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0029231058 Dataset Number: 4G0909852H  0026
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326BC46C657A3B030D-8066
   Revision: 00002001    Serial number: 0301840392
   Coding: 011F062200B900408320080400010E000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Component: TSG BF        H03 0507
   Coding: 011C16004401620002080002
   VCID: 468388BCF1F2B7A3B1-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001882415
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3169CB60607C001B74-8064
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130225-0002-132
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: 2D51D7107C4464FB50-8078
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G0 035 193 F    HW: 4G0 035 193 D
   Component: RMC Cnct Nav  H54 0801
   Coding: 0101000101415B47082B060301010000010000
   VCID: 2643283C51B257A391-8072
   Subsystem 1 - Part No: 8X0 919 884 E
   Component: P18-50-12.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 A    HW: 4G0 919 603 A
   Component: DU6 Basic  H43 0084
   Serial number: 9464BZ0D2575282
   Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MBR0005R
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49998380E0EC58DB5C-801C
   Component: TSG HR        H03 0507
End-------------------------(Elapsed Time: 04:08)--------------------------
Jef
HQ
The B10C6 code is flagged at "Intermittent", it should clear out. :confused:
The case study example was a 4 zone system where as yours is a 2 zone system.... but I don't think that should matter.
Go into Advance Measuring Values and see what "IDE00965 -Compressor shut-off condition" has to say.
Keyser Soze 75
N. Ireland
C?ID=74438
Hi Jef,
Thanks for the help!
AC button on;
Tuesday,13,June,2023,19:26:13:21850
VIN: WAUZZZ4G4DN120186   License Plate: XXXXXXX - IDE00965
                Address 08: Auto HVAC  (4G0 820 043 AC)
19:25:50
  IDE00965   Compressor shut-off condition Compressor active: no shut-off condition is present
Jef
HQ
Hmmm... so generally when there is no shut down code, as in all systems go, and you've got no AC, it is a bad compressor. :(
Keyser Soze 75
N. Ireland
C?ID=74438
But I do have AC, it's blowing cold air with no issues.
Does that not indicate the compressor is functioning?
Jef
HQ
Meds wearing thin on me...
Try Basic Settings IDE01546 - Adapt door end stops, if that give you "Finished Correctly", then see if you can clear DTCs.
csz
China
C?ID=68202 (LP)
如果空调伺服电机有数据偏差,则无法进行基本设置,查看哪个伺服电机数据错误,并在基本设置中替换。
If the air conditioner servo motor has data deviation, the basic settings cannot be performed, check which servo motor data is wrong, and replace it in the basic settings.
PLEASE POST IN ENGLISH.
Keyser Soze 75
N. Ireland
C?ID=74438
Adapt door end stops IDE01546 = Finished Correctly.
Cleared DTCs through Address 08 HVAC = successful.
Took a short 5 min drive, carried out a full scan & no DTCs!
Hopefully that's it cleared for good now, I'll check again tomorrow just to be sure & probably a few more times just to satisfy my OCD!
I had carried out the basic calibration "adapt door end stops & ac compressor" numerous times before as per the case study thread & they always finished correctly, cleared the fault codes but they came back immediately!
Thanks Jef for your suggestion on just adapt door end stops.
Wednesday,14,June,2023,22:06:09:21850
VIN: WAUZZZ4G4DN120186   License Plate: XXXXXXX 14.6.23 FULL SCAN
Mileage: 163710km-101724mi   Repair Order:
VIN: WAUZZZ4G4DN120186   Mileage: 163710km-101724miles
   Coding: 34210008A1
   Coding: 0045F7
   Coding: 02006D
   Coding: 08C206
   Coding: 000014
   Coding: 00CD074400
   Voltage stabilizer:
   ROD: EV_SARA2.rod
End-------------------------(Elapsed Time: 04:09)--------------------------
Jef
HQ
Thank you for the follow up Auto-Scan.:thumbs:
