I´m trying to solve a problem with the Reductant-system.
I get fault on Output Module 1, i have measured the heaters both resistance and power when giving them 12v and everything looks good. I have changed the one on output 1 to be sure, i have checked the main b+ in the wires and when i do output test, i get signal to the control unit and it gives out signal to both heaters. Put when i start the car i get the same fault. So i cant find any problems, and everything works when doing output test, when not when i start the car. What have i missed? I can´t find any TPI on the problem. Something is wrong...
Monday,07,November,2022,15:37:50:63210
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Dealer/Shop Name:
Workshop Code:
VIN: WV1ZZZ7HZKH169395 License Plate:
Mileage: 50720km-31515mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 13 15 17 18 19 22 25 5F 61 69 6E 0B
VIN: WV1ZZZ7HZKH169395 Mileage: 50720km-31515miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CXHA) Labels: None
Part No SW: 04L 906 056 RK HW: 04L 907 445
Component: R4 2.0l TDI H02 6751
Revision: 23002001
Coding: 0019401C432601090000
Shop #: WSC 40296 001 1048576
ASAM Dataset: EV_ECM20TDI03004L906056RK 004002
ROD: EV_ECM20TDI03004L906056RJ.rod
VCID: 074B9D067FA25A938E5-8052
VINID: 9E606AAAA1D8A9B6011890C914B3FECB59
31169 - Output Module 1 for Heating of Reductant
P148B 00 [035] - Malfunction
Mileage: 50708 km
Date: 2022.11.07
Time: 16:34:49
Engine RPM: 0.00 /min
Coolant temperature: 33 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.593 V
Outside temperature sensor 1: B1: raw value: 17.5 °C
Exhaust temperature bank 1: S1/S2/S3/S4: / ---/---/---/22 °C
Sensor for reducing agent tank temperature: temperature: 0.0 °C
Reducing agent metering system heating circuit 2: actual current: 1.624 A
Reducing agent metering system heating circuit 1: actual current: 5.351 A
Reducing agent fill level sensor: act. value: 66 mm
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 61849000001565
Coding: 517E8098256884878A78017FA48721A678F100
Shop #: WSC 00012 790 50316
VCID: 3FDB45E667F2D253F65-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 04071913470898
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F8E220781B5BBD3-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AD HW: 7E0 907 047 AD
Component: Climatic-T5 H23 0708
Revision: 00001003
Coding: 0000000003
ROD: EV_ClimaT5Basis.rod
VCID: 6C81C2AA460499CB037-8038
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8602 178190706
Coding: A0A8393A0A61341393284F742CEB8F548F94710F60446D60330400230840
Shop #: WSC 66305 000 1745928
VCID: 2C0102AA860459CB437-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 280619 05 50 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 004 0653
Serial number: KU0KU003071991844307
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 004 0653
Serial number: KU0KU003071991841066
Coding: 1400A0
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H02 0103
Serial number: 39190001023000069234
Coding: B0FFFF
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 2506190439A72E
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361.rod
VCID: 363520C248C8131B253-8062
Part No SW: 7E0 959 655 K HW: 7E0 959 655 K
Component: VW10Airbag01R 010 0018
Revision: -------- Serial number: 003EM003NPEI
Coding: 000000000000000000000000000000003152
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3E2538E260F8DB5BFD3-806A
Serial number: 3495ZRB40695RVOEDPE8
Serial number: 3505ZRB404T5RKPA699J
Part No SW: 7E0 920 871 A HW: 7E0 920 871 A
Component: KOMBI H03 2050
Coding: 150F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 2809FEBA927C75EBA7F-807C
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 5D01
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B0301B6838A5EF34AD-807E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0402
Serial number: 00000000000000732388
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 042205
VCID: 6889BEBA527CB5EB67F-803C
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00003.06.19
Coding: 0501
VCID: 54F17A4AFE74210B3B7-8000
Component: IMMO H03 2050
Coding: 000002
VCID: 6A8DC4B24CF087FB71B-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 G HW: 1K8 035 150 G
Component: MU-E--ER 070 7205
Serial number: 03061900010207
Coding: 065700003C00000041110001000000001F0000D40000010001
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 290FFBBE89764CE3B81-807C
Part No SW: 7E0 907 534 HW: 7E0 937 090 D
Component: Batt.regelung H82 0762
Coding: 330B1A73
Shop #: WSC 00012 790 00057
Subsystem 1 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Serial number: 758852020019062408CD
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000520959600
Coding: 410D000103000000
VCID: 323D1CD2A4200F3B09B-8066
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 J HW: 7E5 919 037 J
Component: Dachdisplay H17 0200
Revision: 1010013S Serial number: 620480
Coding: 000103
Shop #: WSC 00012 790 00072
VCID: 38292EFA425CE56B37F-806C
End----(Elapsed Time: 02:00, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Address 01: DTCs cleared
