Bug182
New Member
- Sep 13, 2022
- 8
- 0
- Lancaster, CA, USA
- HUC-2H
I am trying to get my 2003 jetta GLI ready to pass smog, I know that all the monitors are able to get ready except the SAI.
We found out that it was cause the car was running lean due to old 02 sensors so we changed them out and reset the DTCs and now im able to get the SAI to run a test in the basic settings, but whenever i try to use the set readiness it appears blank.
the image i attached shows what happens when i get to the SAI step in the set readiness.
Sunday,25,September,2022,05:15:35:63581
VCDS Version: 22.9.0.0 (x64)
VIN: 3VWVH69M93M191391 License Plate: CLEARED
Mileage: 137260km-85289mi Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
75 76
VIN: 3VWVH69M93M191391 Mileage: 137260km-85289miles
Address 01: Engine Labels: 022-906-032-BDF.lbl
Part No: 022 906 032 CS
Component: MOTRONIC ME7.1.1G 0005
Coding: 00032
Shop #: WSC 00066
VCID: 5EB84D39DACFC87D11-50E6
3VWVH69M93M191391 VWZ7Z0C7557777
17987 - Throttle Actuator (J338)
P1579 - 35-10 - Adaptation Not Started - Intermittent
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 346CCF9154C3322D97-50E6
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 275628DDC51549B522-50C8
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V65
Coding: 07234
VCID: 2F66C0FDEDE511F5EA-50E6
01039 - Coolant Temperature Sensor (G2)
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: 70E40381305B4E0DB3-50E6
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 3776F89D15B5D935B2-4ACE
Component: 1H Tõrsteuer.FS KLO 0010
Component: 1H Tõrsteuer.BF KLO 0009
Component: 1H Tõrsteuer.HL KLO 0202
Component: 1H Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: RADIO 3CP 0005
Coding: 00031
Shop #: WSC 00066
VCID: 224039C9AE37AC9D75-50C8
35-00 - -
End-------------------------(Elapsed Time: 05:21)--------------------------
