B8.5 A4 P0016 Correlation Code
calandraphoto
Maryland, USA
C?ID=524359
I've had a P0016 code on my B8.5 for about 2 weeks, and I'm trying to rule out what the issue is.
The car runs like normal, and I don't hear any strange sounds. It's not as quick as it used to be, which is probably from the VVT being locked at 28 degrees (found this out in VCDS, maybe the car does this as a "limp mode"?). The car has a hard time starting, but if I clear the P0016 code and start the car, it will crank and start like normal. I've looked at the "Camshaft Deviation from Reference" stat from VCDS and it gives me a different degree each time (ranging from -23 to -3). The same goes for the "Camshaft adaptation intake bank 1" stat. Maybe the camshaft sensor is bad?
I was able to confirm that the crankshaft sensor and camshaft sensors are getting power. I also checked the VVT solenoid and did not find the pin to be sticking out. I changed the oil using Pennzoil 0W-40 about 1k miles ago. Today, I changed the spark plugs and coil packs, which made the car run/idle smoother but the code is still there.
I find it hard to believe that the timing chain is the issue since it runs like normal (besides the locked VVT) and will start like normal if I clear the code first. Any suggestion on what I should check would be greatly appreciated.
calandraphoto
Maryland, USA
C?ID=524359
Thursday,15,September,2022,16:05:33:53012
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
VIN: License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C 72
VIN: Mileage: 168290km-104570miles
Address 01: Engine (0-----CAEB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0007
   Revision: ECH09---    CVN: F70685C3
   Coding: 4A190013242600062000
   Shop #: WSC 15684 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115C 001008
   ROD: EV_ECM20TFS0118K5907115C.rod
   VCID: 323D1759E4A390DB217-8066
   VINID: 9D195859159C2547800C30820C3CFAC9DD
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [039] - Incorrect Correlation
                    Mileage: 168293 km
                    Date: 2022.09.15
                    Time: 16:02:28
                    Engine RPM: 773.00 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 43 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 13.428 V
                    selected gear-Bits 0-7: 0
Readiness: 1110 0101
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 071D18
   Shop #: WSC 02391 785 00200
   VCID: 045181810E17EE6BC3B-8050
   Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
   Component: BCM2 2.0      H11 0621
   Coding: 0B814000000000000000
   VCID: 00598D911A0FF24BE73-8054
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0512000074885006
   Serial number: 2312000255427008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Revision: C1000000    Serial number: 01201120120401
   Coding: 6400208000
   VCID: 392F207539556383E0D-806C
   Revision: 08016001    Serial number: 00000513927502
   Coding: 26000015863CAF800000480300003D0D0F1C1208A2090221000008000000030100000030000000
   VCID: 78A9E57142DFBA8BDF3-802C
   Component: WWS 201112  H07 0080
   Serial number: SWF12110205212
   Coding: 00F511
   Serial number: 20754549
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001311124106
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3X6L02
   Serial number: 8C084B56000000000001
   Serial number: 003KJD913WX4
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 57894 001 1048576
   VCID: 4ACD6FB96C33F81B797-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R120000BZA6
   Serial number: 6334MSME73042123
   Serial number: 6344MSME75204E5AL
   Serial number: 6352QSME63240F48J
   Serial number: 6362QSME332321765
   Serial number: 63732SME78262648%
   Serial number: 63832SME4C262E5EG
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LKJ001NG
   Coding: 000016
   VCID: 43D3429D4B992953BA1-8016
   Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
   Revision: 00000000    Serial number: UVN42KFCD
   Coding: 8BBC09000301D705020000
   VCID: 35372C45154D87E3045-8060
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y12B1480A2
   Coding: 80C303FF00
   VCID: 4ACD6FB96CB3F81B797-801E
   Serial number: 8644678501
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000044063265
   Coding: 00581300000000000000
   VCID: 3B233A7D33695193F21-806E
   Component: TSG FA        H09 0304
   Coding: 011C03204E00410001
   VCID: 56F58BC9A80BACFBEDF-8002
   Revision: 00001000    Serial number: 0005025571
   Coding: 100000000001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343111411EB79EEB33B-8060
   Revision: 00002001    Serial number: 0188152854
   Coding: 0106023A00FA404480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000607388
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Component: TSG BF        H09 0304
   VCID: 55F78CC5B50DA7E3E45-8000
   Revision: --------    Serial number: 10000000130858
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829257102DF7A8B1F3-806C
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Revision: AB001007    Serial number: 156KD0C7668819
   Coding: 020007020100000001
   VCID: 2411E101AED70E6BA3B-8070
   Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0624
   Revision: --------    Serial number: 204KB0H7578494
   Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
   Shop #: WSC 24113 003 1048576
   VCID: 372B264D0F4175F3169-8062
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130K30C2589667
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001333242
   Component: CD-Database  4949
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C03204000210001
   VCID: 59EF80F5D9158383C0D-800C
   Revision: --H07---    Serial number: 525PA8-J2X92VQ
   Coding: 1000006
   VCID: 382925710E5F7A8B1F3-806C
   Component: TSG HR        H07 0304
End----------(Elapsed Time: 01:47, VBatt start/end: 13.6V/14.3V)-----------
ka_rai
France
C?ID=102276
what you mean saying "Your cam timing is out" ?
is sensor or phase shift pulley
any shematic maybe is better
The Cam G40 and crank G28 sensors are sending out a signal and the ECU can see these are not occurring in sync so the cam timing is out, the CAEB suffers terrible problems with chain wear and jumping especially pre 2012.
  • Agree
DrPeter
16.4905° S, 151.7375° W
Yep, check timing, plus 100,000 miles, it is time.
Given the high rate of failure, I think Volkswagen and Audi should have a "recommend timing chain/tensioner replacement" as part of the maintenance schedule, say every 80~100k miles. :p
You can check the timing chain wear by following the procedure here...
Also you can remove the little plastic/rubber cap on the front engine cover to view the chain tensioner..
Do not ignore this warning! Catastrophic engine failure can and will occur!
EDIT: We do have a Ross-Tech wiki page you will also want the have a look at:
Hope this helps,
drpeter
calandraphoto
Maryland, USA
C?ID=524359
Yep it helped, thanks for the help. I ended up doing the timing chain and balance shaft, and the chain had indeed jump timing. The chain was also stretched out. Been a month since I did the job and no issues since then
tibcab
France
C?ID=82094
Sorry for barging into your thread, I can of course create my own if needed but I figured I'd just ask here :
I have the same code on my 2009 Q5 2.0 TFSI (CDNC engine). The previous tensioned failed, skipped timing, 16 bent valves and so on.
I had the head re-done by a specialist and put it together a few days ago. Timing was done using the proper tools, the engine ran great at first.
Couple of days later, it sometimes had a very rough idle, and after doing a fault scan I only had this P0016 code.
I re-checked timing using a comparator in cylinder 1 (to rule out any misaligment of the damper pulley) and the timing is spot on.
What else could trigger this code ? A faulty camshaft or crankshaft sensor ?
I plan on taking the spool valve out and check its internal condition, from outside and based on this very thorough wiki page, it seems OK.
I can of course post an auto-scan if needed, thanks a lot!
To me P0016 can only be the result of incorrect timing.
tibcab
France
C?ID=82094
I am also of this opinion, but the problem is : I have 63mm between the center lip and the intake camshaft timing mark and 125mm between exhaust and intake camshaft timing marks when piston #1 is at TDC...
What really annoys me is that the engine sometimes runs like crap (mainly at idle), and other times runs smoothly. I am pissed off at myself for not checking the spool valve thoroughly before putting it back in.
Another addition : the screen in the valve brige was removed before I reinstalled it, it was damaged as expected and the mesh leftovers were found in the cylinder head and obviously removed (the head went into the washing machine at the machine shop).
Have you had the inlet manifold off to check for carbon on the backs of the inlet valves?
tibcab
France
C?ID=82094
Well the head has been completely redone with brand new valves and stem seals.
It looked like that before I put it back in :
Reactions: JMR
Nice quality work. I have to keep coming back to timing.
Indorile
Belgrade, Serbia
C?ID=447205
I've had that issue and it went out with new timing chain and guides. But cam phasing was still high -2.x degrees which it shouldn't be for a new chain. Good used camshafts later and everything was fine (phasing went to low -0.x).
Have you reset the chain length adaptations?
tibcab
France
C?ID=82094
Thanks for your replies.
Cam phasing is in the 0.x range so I do not know it the adjuster can be the culprit here... At idle though the cam adjuster specified value remains at 28°, the actual is also around 28°.
@Crasher , what do you mean by "chain length adaptations" ? I performed basic settings in the engine ECU after the whole repair, unfortunately not with VCDS for what it's worth. Is that what you meant ?
I checked the condition of the spool valve, it is in perfect condition. No debris inside, moves completely freely.
In the Baic Settings on some versions I have seen a chain wear adaption reset after replacement but not all have it.
