- Sep 2, 2022
- 5
- 1
- Isanti, MN, USA
- C?ID=406383
Hi. Looking for some help here but can't seem to figure something out. My ACC Radar sensor has been on it's way with a intermittent Defective code for the past month or so and now it has finally decided enough was enough.
As a new sensor is an outrageous $1400, and used ones are scarce to find at all, I'm looking to delete/remove/disable this feature entirely until I find a used unit or crack and cough up the $1400.
I've tried changing 01 Engine to standard cruise with long coding, disabled ACC in 17 instruments coding successfully, and disabled/removed ACC in 19 Canbus feature list. But standard cruise doesn't work and I still get codes in 03 ABS and 19 Canbus for ACC no Comm, as well as a P1647 "Check Coding..." in 01 Engine.
I think these modules are the only ones holding me back maybe? Instruments is the only one that accepts that ACC is no longer installed.
Any help would be appreciated if this is even possible. I can only assume it is as I've seen retrofits of installing ACC. Will post auto scan here. I also did a level 2 debug full scan if any of those files/outputs are needed, but I forgot to plug my battery maintainer in as I was doing it so radio and info. elec. were in power management. If those 2 are needed I will do a full mapping of them.
**The Full auto scan I did was before the sensor completely died and I tried changing any long coding to disable the feature to gain normal cruise control**
***Also note that ACC worked great until it randomly stopped working and gave me the 2 codes shown, did try clearing them thinking it was maybe a fluke thing but still there***
Thanks!
Thanks!
Thursday,25,August,2022,23:00:40:27284
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
VIN: WAUMGAFL5AA085835 License Plate:
Mileage: 196080km-121838mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 1B 22 36 3C 42 46 47 52
53 55 56 5F 62 6C 72
VIN: WAUMGAFL5AA085835 Mileage: 196080km-121838miles
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H06 0003
Revision: --H06--- CVN: 32E2D379
Coding: 0104000A180F0228
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 323D1FA1C4A9C8DB09B-8066
VINID: 9D195D5D159C151440205203149F055962
6140 - Fan 1 Control Circuit
P0691 00 [037] - Short to GND
Mileage: 196087 km
Date: 2022.08.25
Time: 21:32:12
Engine RPM: 0.00 /min
Coolant temperature: 39 °C
Intake air temperature: 37 °C
Voltage terminal 30: 11.780 V
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 39.0 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.CLB
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 282D1A
VCID: 7AADF7815CD9F09B81B-802E
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.CLB
Part No SW: 8K0 907 064 DH HW: 8K0 907 064 DH
Component: BCM2 1.1 H02 0326
Coding: 0F0100
VCID: 79AFE88D59DFFB83881-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000075397009
Address 08: Auto HVAC (J255) Labels:. 8TX-820-043-3Z.CLB
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01061120090104
Coding: 66102000
VCID: 005985693A05AA4BCFF-8054
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.CLB
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H28 0380
Revision: 10028001 Serial number: 00000000382651
Coding: 260010910034AF313E00000300003D0DCF9C924800010161000000
VCID: 3C213199166D0EABD37-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 301009 H06 0070
Serial number: SWF09100305974
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10662108
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000002710091893
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.CLB
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940931400127
Coding: 20000D
VCID: 3E253B9100711CBBFD3-806A
Address 13: Auto Dist. Reg (J428) Labels: NONE
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H09 0080
Coding: 002B6E
Shop #: WSC 51543 823 56573
VCID: 6FBBD6D5179BA533265-803A
00234 - Sensor for Automatic Distance Regulation Misadjusted
Reset counter: 167
Mileage: 196087 km
Date: 2022.08.25
Time: 21:33:16
Temperature: 27.0°C
Voltage: 11.78 V
Bin. Bits: 01011
Hex Value: 0x0941
Hex Value: 0x0001
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
00003 - Control Module
Fault Status: 00111110
Reset counter: 198
Mileage: 195194 km
Date: 2022.08.17
Time: 08:36:44
Temperature: 27.0°C
Voltage: 13.57 V
Bin. Bits: 00011
Hex Value: 0x2A20
Hex Value: 0x0001
Speed: -3.6 km/h
Lateral Accel.: 0.25 m/s^2
Address 14: Susp. Elect. (J250) Labels: NONE
Part No SW: 8R0 907 364 B HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Serial number: 19100900440001
Coding: 070181
VCID: 392F288D195F3B83C81-806C
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD0564J.
Coding: 303836354230303030304A55304C384B3053
VCID: 42DD4F617409785B99B-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900003W4F
Serial number: 6334MSME4C504A73I
Serial number: 6344MSME4C537336H
Serial number: 6352QSME6241051C8
Serial number: 6362QSME6A41480AL
Serial number: 63732SME2E413034U
Serial number: 63832SME64420A34X
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.CLB
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372SCL0001O
Coding: 00001E
Shop #: WSC 06325 123 12345
VCID: 44D149796E9D766BAB7-8010
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-XXX-17.CLB
Part No SW: 8K0 920 981 A HW: 8K0 920 981 A
Component: KOMBIINSTR. H04 0255
Revision: 00000000 Serial number: CJA40CZA9
Coding: 835D0900B700D705020000
VCID: 313F10ADC12FF3C3701-8064
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.CLB
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0105
Revision: FB900055 Serial number: 5500F09A260053
Coding: 00C303
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 19095E65131009
Address 1B: Active Steering (J792) Labels: NONE
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 8C0000
Shop #: WSC 06324 000 00000
VCID: 303915A9CA25FACB7FF-8064
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 003010090001062
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
VCID: 6D87CCDD1D175723149-8038
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.CLB
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010020535
Coding: 00581B00000000000000
VCID: 3B23328513630993DAD-806E
Address 3C: Lane Change Labels: NONE
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0010
Revision: 00H01000 Serial number: 6PZ 009 014-82
Coding: 0000001
VCID: 3C2131991A6D0EABD37-8068
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F23.02.1000H010003C321901ÿ
Subsystem 4 - Serial number: 321901ÿ
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.CLB
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009573365
Coding: 011C13204E00410001
VCID: 45D7547D65A74F63BC9-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.CLB
Revision: 00002001 Serial number: 0120867477
Coding: 0106063A007A454500B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000181345
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
02106 - Rear Window Shade Motor (V91)
Reset counter: 167
Mileage: 196087 km
Date: 2022.08.25
Time: 21:34:36
014 - Defective
Fault Status: 01101110
Reset counter: 167
Mileage: 196087 km
Date: 2022.08.25
Time: 21:34:40
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.CLB
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882000231001
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.CLB
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009585071
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.CLB
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000486837
VCID: 343119B93E3DC6EB1B7-8060
Address 55: Headlight Range Labels: 8K0-907-357.CLB
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000005
VCID: 343119B9323DC6EB1B7-8060
Address 56: Radio
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.CLB
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102239560
Coding: 010C13204000210001
VCID: 42DD4F617489785B99B-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.CLB
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J9X90TW
Coding: 1001006
VCID: 38292D892E55228B37F-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.CLB
Component: TSG HR H10 0306
Revision: Serial number: 0000102242008
End(Elapsed Time: 84:57, VBatt start/end: 11.9V/11.8V. VIgn 11.8V, Deb=2)--
