2015 VW Sportwagen S TDI, 2.0, manual
salauns
C?ID=247843
Windows Based VAG/VAS Emulator
VCDS Version: Release 14.10.2(x64) Data version: 20150311
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,25,May,2015,12:02:16:05815
VIN: 3VWFA7AU6FM501317 License Plate: 3329
Mileage: 3749km-2329mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWFA7AU6FM501317 Mileage: 3749km-2329miles
Address 01: Engine (J623-CRUA) Labels: None
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2,0L EDC H23 8412
Revision: 85H23---
Coding: 01190012032410081000
Shop #: WSC 61626 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021C 001012
ROD: EV_ECM20TDI01104L906021C.rod
VCID: 2541B1AD24F7B1093D9-8070
Self-Diagnosis Log
Page 2
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53644000000328
Coding: 04FA6AA12420096D007A020181CA2520562490004081A4B200630050C002
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 479D1B25FEBB4319EF5-8012
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0355865222
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7B72D1BD492EF160B-806F
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
VCID: 0501D12D843791095D9-8050
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 087 Q HW: 5Q0 937 087 Q
Revision: -------- Serial number: 86581701151602
Coding: 000108424041804169E44000000403001800000000000000000000000000
Shop #: WSC 00066 790 00195
ROD: EV_BCMBOSCH_VW37.rod
VCID: 49991D1DE8AFB569F91-801C
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119
Component: WWS 141110 043 0581
Serial number: 150130165441
Self-Diagnosis Log
Page 4
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR010K5+
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1400025TWB0K
Coding: 303138
Subsystem 2 - Part No SW: ----------- HW: 480 001 411 14
Serial number: 35700000000FE9F8E116
Subsystem 3 - Part No SW: ----------- HW: 480 001 312 14
Serial number: 35800000000AF02D321J
Subsystem 4 - Part No SW: ----------- HW: 480 400 512 14
Serial number: 3510002A31811B94B24X
Subsystem 5 - Part No SW: ----------- HW: 480 400 512 14
Serial number: 3520002A31811B92934V
Subsystem 6 - Part No SW: ----------- HW: 480 400 212 14
Serial number: 3550002C518B3AB303D9
Subsystem 7 - Part No SW: ----------- HW: 480 400 212 14
Component: FrontSensor_P 001 6149
Serial number: 3560002C518B3AB4B2EM
Self-Diagnosis Log
Page 5
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141215500778
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 0407CC298F0DA8014A7-8051
Part No SW: 5G1 920 841 HW: 5G1 920 841
Component: KOMBI 243 4270
Coding: 0BA412122180CF0502086A001000000000000000
Shop #: WSC 07455 444 00000
ROD: EV_DashBoardVDDMQBAB_VW37.rod
VCID: 65C1F1AD64777109FD9-8030
Self-Diagnosis Log
Page 6
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 25121410000059
Coding: 0901000800087300EF000008080F00000001050000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewConti_VW37.rod
VCID: 71E995FDA0BFADA9911-8024
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
Component: E221__MFL-DC1 H16 0101
Serial number: 27150000094300075036
Coding: 28FFFF
Inverter power receptacle:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0019276
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000354426004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 34675CE99F2DD881BA7-8061
Self-Diagnosis Log
Page 7
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 110115060502ON
Coding: 003013200000040000000000
VCID: 3E737EC1A16102D15C3-806B
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000512573
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
Shop #: WSC 00066 790 00202
ROD: EV_SteerAssisMQB.rod
VCID: 43850F35CA836F3933D-8016
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 1701150605023P
VCID: 3D7179CDAC6719C9459-8068
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000514430
Coding: 091000
Self-Diagnosis Log
Page 8
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0645
Serial number: V7B00812141510
Coding: 02730200FF00000021220001001800001F0100140100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64C7ECA96F4D0801EA7-8031
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS50112Z
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02730002C2821A017F1E06000000
Shop #: WSC 00066 790 00122
ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:36)--------------------------
Nice, thanks!
But please use [Copy] or [Save] rather than [Print] to post data here; Print is formatted for a printer and produces less than optimal results for the forum.
