Hi all,
Over the last few days i first noticed a lumpy cold startup, once moving it smoothes out.
It has since developed into a rough idle even when warm. Once revs goes over 1k the roughness fades out and is not aparent after 1.5k rpm.}
As a side note since this started i have poped some Wyns gold in with my last fuel topup yesterday.
I popped on today and did some digging, there is no engine errors, however measuing injection deviation and rail pressure calibration point i have found cylinder 6 is way way out of spec.
Attached is the calibration point, I did note injector 6 was the only with a positive value.
The graph shows the injection deviation for all 6 cylinders through the rev range from idle "750" to "2.5k".
It does also show the same signs that the deviation levels out once acheiving 1.8k rpm roughly
What is your thoughts, i would say bad/dirty injector. Its just odd how it performs in spec when revs go up.
Tuesday,28,June,2022,17:21:58:12972
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Address 01: Engine (4G0 907 589 A)
17:21:40
IDE01387 Injector 1: rail pressure calibration point 1 -11.10 µs
IDE01388 Injector 1: rail pressure calibration point 2 -28.40 µs
IDE01389 Injector 1: rail pressure calibration point 3 -0.70 µs
IDE01396 Injector 4: rail pressure calibration point 1 -16.95 µs
IDE01397 Injector 4: rail pressure calibration point 2 -16.10 µs
IDE01398 Injector 4: rail pressure calibration point 3 -6.85 µs
IDE01402 Injector 6: rail pressure calibration point 1 -10.65 µs
IDE01403 Injector 6: rail pressure calibration point 2 33.80 µs
IDE01404 Injector 6: rail pressure calibration point 3 -6.80 µs
