I hope you guys can help save me and my family a $2000 repair. A few weeks after we put new tires on the Tig the steering wheel light began to come on intermittently. Soon after the steering would go completely out but only when the car was started up. Sometimes it would come back after a re-start. I came to Ross-Tech and found a steering reset procedure that worked, but only for a short time. We took the car to a local mechanic who said the steering assist motor was completely burned out and the entire steering rack would have to be replaced for $2000!! Something didn'
t feel right so I bought VAGCOM and looked into it myself. Since the steering is working off and on the motor could not be "completely burned out" as the mechanic had said. The information from the autoscan appears to indicate a loose wire somewhere or a bad connection. I put on a new starter, a new battery, and re-installed the battery cables to ensure a tight connection. I looked for any connectors and plugs and made sure they were firmly connected. I cannot gain access to the steering module since it is buried in the chassis behind the engine. I would appreciate any suggestions you may have as to the cause or any procedure that I can perform to reset something that will give us back our car. Thanks. Below is the autoscan from VCDS.
Thursday,21,May,2015,21:21:23:19481
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WVGAV75N89W003401 License Plate: NEUZA2
Mileage: 225320km-140007mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 4F 52 53 56 62
65 72
VIN: WVGAV75N89W003401 Mileage: 225320km-140007miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 026 L HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 0608
Revision: AAH03--- Serial number: VWX7Z0H23NB0L4
Coding: 0423010A19070160
Shop #: WSC 57420 001 1048576
VCID: 3D717E29643DB7C9459-8068
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Mileage: 225323 km
Time: 08:13:04
RPM: 314 /min
Load: 80.8 %
Temperature: 91.0°C
Temperature: 56.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.430 V
Part No SW: 09G 927 750 GG HW: 09G 927 750 GG
Component: AQ 250 6F 1174
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 01324 785 00200
VCID: 7CF7B32D3FA77EC1327-8029
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 L HW: 5N0 614 517 L
Component: J104 C2 450 V2 0006
Revision: --H11--- Serial number: 00000000963676
Coding: 0002329
VCID: 377D6C0146019D999F5-8062
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008146956
Coding: 118C8FA340041C0047190000140000000068F7475C400104390000000000
VCID: 71E9921968E503A9911-8024
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 060308 012 0203
Coding: 00038805
Shop #: WSC 01324
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0277696
Coding: 0000100
VCID: 33655811527971B9A3D-8066
Reset counter: 209
Mileage: 225213 km
Time: 09:38:52
Part No SW: 5N0 959 655 B HW: 5N0 959 655 B
Component: J234__200 VW10 HI 1815
Revision: 19013000 Serial number: 0039EP4G56TP
Coding: 0012336
VCID: 3C77732D7F27BEC1727-8069
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000000CVY
Subsystem 3 - Serial number: 0006.02.080000100000630015ÿ†63
Subsystem 4 - Serial number: 630015ÿ†6333FTS620210528 ÿ†63
Subsystem 5 - Serial number: 10528 ÿ†6343FTS618310528 ÿ†63
Subsystem 6 - Serial number: 10528 ÿ†6353ETS6KQ1LSVNP ÿ†63
Subsystem 7 - Serial number: LSVNP ÿ†6363ETS628OLSVNP ÿ†63
Subsystem 8 - Serial number: LSVNP ÿ†6373JTS6OKSKSVNP ÿ†63
Subsystem 9 - Serial number: KSVNP ÿ†6383JTS6JJLKSVNP ÿ
Subsystem 10 - Serial number: KSVNP ÿ
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0100
Coding: 0012022
VCID: 78FFAF3D0B9F52E156F-802D
Component: E0221 002 0010
01750 - Multi-Function Switch in Steering Wheel (E440); Left
01751 - Multi-Function Switch in Steering Wheel(E441); Right
01426 - Controls in Steering Wheel (E221)
Part No SW: 5N0 920 970 E HW: 5N0 920 970 E
Component: KOMBIINSTRUMENT VDD 2222
Revision: V0004000 Serial number: VWX7Z0H23NB0L4
Coding: 0007204
Shop #: WSC 07208 444 57704
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H06 0052
Revision: H06 01 Serial number: 270208F1001351
Coding: FD807F070013036002
VCID: 326B5D15AD6378B1A8B-8067
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2SG403
VCID: 7DF1BE2924BD77C9059-8028
Component: IMMO VDD 2222
Part No SW: 5N0 959 701 HW: 5N0 959 701
Component: Tuer-SG 006 1205
Coding: 0001205
VCID: 72EB9D156DE338B168B-8027
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 G HW: 5N1 909 148 E
Component: J500__APA-BS KL.050 0401
Revision: 1AH01247 Serial number: 00080390009601
Coding: 0000258
VCID: 36636105410B6491843-8063
03375 - Steering Motor
Fault Status: 00100111
Reset counter: 253
Mileage: 225323 km
Time: 08:13:15
RPM: 930 /min
Speed: 7.0 km/h
(no units): 14.0
Voltage: 11.00 V
Reset counter: 253
Mileage: 225325 km
Time: 08:20:50
Voltage: 0.10 V
Voltage: 10.50 V
Voltage: 10.60 V
Not Occup.
Not Occup.
16352 - Control Module - Electrical Error
Fault Status: 00101100
Reset counter: 253
Mileage: 225325 km
Time: 08:20:57
RPM: 1408 /min
Speed: 9.0 km/h
(no units): 14.0
Voltage: 11.10 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0222
Revision: 00052000 Serial number: 00000000000000
Coding: 9380078852832C1B1B04058FB0880F0C88DCA0
Shop #: WSC 01730 111 29999
VCID: 0407CBCD475706014A7-8051
Address 4F: Centr. Electr. II (J533) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 66C3F145912BD411F43-8033
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB09 H01 0170
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB09 H01 0170
Part No SW: 5N0 959 702 HW: 5N0 959 702
Coding: 0001204
VCID: 73E5981112F931B963D-8026
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H08 Serial number: 00000000043976
Coding: 0000057
VCID: 2E534965B95B5C51CC3-807B
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 019 0035
Revision: 00019000 Serial number: VWZ5Z7H2216097
Coding: 0040401
VCID: 2959BA7980B53B69191-807C
Reset counter: 210
Mileage: 225223 km
Time: 10:08:37
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5N0 959 703 A HW: 5N0 959 703 A
Component: Tuer-SG 006 1301
Coding: 0001168
Shop #: WSC 01324 785 1012552
VCID: 356166095C0D6F898D9-8060
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5N0 959 704 A HW: 5N0 959 704 A
Coding: 0001168
End-------------------------(Elapsed Time: 02:28)--------------------------
