Vw jetta 4 door 2.0 diesel automatic ross- tech codes today.
Vic72
Covington, TX, USA
C?ID=419103
My 2010 VW jetta tdi 2.0 sedan with 160,000 miles was traveling steep uphill, I heard a smooth metal to metal rubbing sound and it quit and wouldnt start when i removed the starter it was blue in color and autozone said its bad I replaced it it still cranks only 1/2 turn at a time and wont start . It had 4 tranny codes before the incident but now it has 8.
Vic72
Covington, TX, USA
C?ID=419103
The following is the transmission codes, before the incident there was 4 codes now there is 8:
   Part No SW: 02E 300 052 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2114
   Revision:    51112    Serial number: 00000912110108
   Shop #: WSC 02069 000 90108
   VCID: 2517FB4D69E1E853DC5-8070
8 Faults Found:
19143 - Unexpected / Implausible Mechanical Gear Disengagement
            P2711 - 004 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 7
                    Mileage: 247958 km
                    Date: 2016.01.07
                    Time: 14:11:35
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Mileage: 258405 km
                    Date: 2016.02.05
                    Time: 00:18:32
16988 - Internal Control Module
            P0604 - 000 - RAM Error - Intermittent
                    Reset counter: 8
18156 - Transmission Control Unit
            P1748 - 014 - Programming Error - Intermittent
                    Fault Status: 00101110
                    Reset counter: 8
01066 - Driving Despite Selector Lever Position N
                    Fault Status: 00100001
                    Reset counter: 8
                    Reset counter: 8
            P2711 - 003 -  - Intermittent
                    Fault Status: 00100011
                    Reset counter: 8
16987 - Internal Control Module
            P0603 - 000 - Non-Volatile Memory Error - Intermittent
                    Reset counter: 8
Vic72
Covington, TX, USA
C?ID=419103
a month ago I think this was the only transmission code it had on july 29, sometimes when Id put it in reverse i had to rev the gas for 30 seconds for reverse to kick in and i presumed maybe i was getting low on atf fluid or something
Reset counter: 34
Mileage: 247958 km
Date: 2016.14.10
Time: 14:11:35
Did you ever check or change the fluid?
Also, I would post a full and unedited Auto-scan.
Fred's Imports
Vermont, USA
C?ID=16454
Haaaaaa that IS funny.
There must have been a pile of parts behind that thing!!!!
Vic72
Covington, TX, USA
C?ID=419103
Thursday,16,September,2021,20:01:37:03815
VIN: 3VWRL7AJ7AM083811   License Plate: LKZ244
Mileage: 258400km-160562mi   Repair Order: 4
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRL7AJ7AM083811   Mileage: 258400km-160562miles
02-Auto Trans -- Status: Malfunction 1010
04-Steering Angle -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
25-Immobilizer -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1110
46-Central Conv. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 1010
   Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000AG  9971
   Revision: 12H02---    Serial number:
   Coding: 0050078
   Shop #: WSC 01313 444 84360
   VCID: 78A9E2398ED3A5BBB73-802C
009326 - Exhaust Gas Temperature Sensor 4 Bank 1
               P246E - 000 - Electrical Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 189837 km
                    Date: 2015.08.25
                    Time: 00:00:34
                    Voltage: 12.24 V
                    Temperature: 2.7°C
                    Temperature: 6.0°C
                    Temperature: 6.0°C
                    Temperature: 930.0°C
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Mileage: 191359 km
                    Date: 2015.08.27
                    Time: 20:48:42
                    RPM: 1748 /min
                    Speed: 87.0 km/h
                    Mileage: 1590 km
                        1.5
                        39.9
                    Pressure: 0 mbar
                    milliliters: 120 ml
               P246E - 001 - Electrical Malfunction - MIL ON
                    Fault Status: 11100001
                    Mileage: 247352 km
                    Date: 2016.01.06
                    Time: 11:12:25
                    Voltage: 13.15 V
                    Temperature: 80.1°C
                    Temperature: 204.0°C
                    Temperature: 156.0°C
008449 - Throttle Valve Actuator Control System
               P2101 - 000 - Malfunction - Intermittent
                    RPM: 989 /min
                    Voltage: 9.96 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
000257 - Mass Air Flow Sensor (G70)
               P0101 - 003 - Implausible Signal - MIL ON
                    Fault Status: 11100011
                    Mileage: 258404 km
                    Date: 2016.01.28
                    Time: 22:36:33
                    Voltage: 12.08 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 1100.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
050197 - Implausible Data Received from ABS Control Module
               U0415 - 014 -  - Intermittent
                    Mileage: 258405 km
                    Date: 2016.01.30
                    Time: 08:26:44
                    Voltage: 9.88 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 1 2 0 0 0
8 Faults Found:
                    Reset counter: 7
                    Mileage: 247958 km
                    Date: 2016.01.07
                    Time: 14:11:35
                    Mileage: 258405 km
                    Date: 2016.02.05
                    Time: 00:18:32
                    Reset counter: 8
                    Reset counter: 8
                    Reset counter: 8
                    Reset counter: 8
                    Reset counter: 8
                    Reset counter: 8
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B400C492A00FD881302E5921A0042310000
   Shop #: WSC 00066 000 00000
   VCID: 7AADF831BCDFB7ABC17-802E
10 Faults Found:
                    Reset counter: 9
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:41:54
                    Count: 32780
                    Count: 12800
                    Count: 8207
                    Count: 50688
                    Count: 768
                    Reset counter: 9
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:42:22
                    Count: 12
                    Count: 4096
                    Count: 8195
                    Count: 46080
                    Count: 768
                    Fault Status: 00101100
                    Fault Frequency: 74
                    Reset counter: 15
                    Mileage: 191522 km
                    Date: 2015.08.28
                    Time: 00:27:54
                    Count: 12800
                    Count: 273
                    Count: 50432
                    Count: 65280
                    Count: 768
                    Count: 6912
                    Reset counter: 15
                    Mileage: 189841 km
                    Date: 2015.08.25
                    Time: 01:25:51
                    Count: 32768
                    Count: 12800
                    Count: 148
                    Count: 50435
                    Count: 1
                    Count: 249
                    Count: 3584
01169 - Door Contact Switch Driver Side (F2)
                    Reset counter: 29
                    Mileage: 225534 km
                    Date: 2015.11.20
                    Time: 09:24:55
                    Count: 2
                    Count: 32770
                    Count: 20992
                    Count: 147
                    Count: 50989
                    Count: 511
                    Reset counter: 244
                    Mileage: 258405 km
                    Date: 2016.01.30
                    Time: 08:26:44
                    Count: 12
                    Count: 4096
                    Count: 51
                    Count: 36352
                    Count: 64514
                    Count: 1290
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Reset counter: 244
                    Mileage: 329737 km
                    Date: 2000.08.02
                    Time: 00:12:07
                    Count: 1802
                    Count: 147
                    Count: 7424
                    Count: 35
                    Count: 1536
                    Count: 37632
                    Count: 128
                    Count: 62467
                    Reset counter: 244
                    Mileage: 235800 km
                    Date: 2015.12.10
                    Time: 11:56:05
                    Count: 7
                    Count: 13
                    Count: 20480
                    Count: 128
                    Count: 29696
                    Count: 512
                    Count: 509
                    Reset counter: 237
                    Mileage: 258405 km
                    Date: 2016.02.05
                    Time: 00:18:33
                    Count: 16387
                    Count: 12
                    Count: 20480
                    Count: 166
                    Count: 45824
                    Count: 510
                    Count: 1024
                    Reset counter: 237
                    Date: 2059.04.00
                    Time: 16:05:12
                    Count: 256
                    Count: 48153
                    Count: 256
                    Count: 8213
                    Count: 8207
                    Count: 41993
                    Count: 288
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00186
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7EB0D9541D8D3AC5-8020
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 254
                    Mileage: 188853 km
                    Date: 2021.03.07
                    Time: 00:16:24
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 254
                    Mileage: 188853 km
                    Date: 2021.03.07
                    Time: 00:16:24
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                    Fault Frequency: 12
                    Reset counter: 214
                    Mileage: 188853 km
                    Date: 2021.03.07
                    Time: 01:20:03
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 252
                    Mileage: 188853 km
                    Date: 2021.03.07
                    Time: 00:16:25
   Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
   Component: BCM PQ35 B++  111 0128
   Revision: BI111001
   Coding: 2D200B1E902F3EE4800800854000000401000686510085605C8020000000
   Shop #: WSC 01313 444 53995
   VCID: 372B2105CF4D6AC37E9-8062
                    Fault Status: 01100010
                    Reset counter: 214
                        Term 15 Off
                    Voltage: 13.70 V
                    Fault Frequency: 38
                    Reset counter: 237
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 00:00:06
                        Term 15 Off
                    Voltage: 13.85 V
00927 - Terminal 30 (Right)
                    Reset counter: 214
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 00:08:37
                        Term 15 Off
                    Voltage: 8.80 V
                    Reset counter: 214
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 00:08:41
                        Term 15 Off
                    Voltage: 10.00 V
02391 - Terminal 30 Reference
                    Reset counter: 214
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 00:08:38
                        Term 15 Off
                    Voltage: 9.05 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM01ZRDH
   Coding: 0012340
   VCID: 6E85C461FC97EB0B6DF-803A
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME4D036B5DQ
   Subsystem 3 - Serial number: 6342MSME0A1931466
   Subsystem 4 - Serial number: 6351HSME1E116D1EI
   Subsystem 5 - Serial number: 6361HSME1E1071721
   Subsystem 6 - Serial number: 63727SME1E201630U
   Subsystem 7 - Serial number: 63827SME1E204B7FF
01589 - Igniter for Head-Airbag; Passenger Side (N252)
            007 - Short to Ground - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001731
   VCID: 76B5EC0184C7D3CBA5F-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5M0 920 970 G    HW: 5M0 920 970 G
   Component: KOMBI         H05 0305
   Coding: 271F00
   Shop #: WSC 00066 000 00148
   VCID: 34311609DEBB81DB5BB-8060
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 9
                    Mileage: 236539 km
                    Date: 2021.07.19
                    Time: 19:42:24
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Fault Frequency: 13
                    Reset counter: 237
                    Mileage: 258405 km
                    Date: 2021.09.14
                    Time: 00:18:33
13635840 - Supply voltage
          [Supply voltage too low]
                    Fault Frequency: 8
                    Reset counter: 22
                    Mileage: 235800 km
                    Date: 2021.07.19
                    Time: 11:23:29
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 021209F2001547
   Coding: ED807F07001602001002
   VCID: 698FB77DC5790C3338D-803C
16 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 8
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:42:22
                    Reset counter: 8
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:42:25
                    Fault Frequency: 13
                    Reset counter: 237
                    Mileage: 258405 km
                    Date: 2016.02.05
                    Time: 00:18:32
                    Reset counter: 2
                    Mileage: 189966 km
                    Date: 2015.08.26
                    Time: 06:11:32
                    Fault Frequency: 13
                    Reset counter: 237
                    Mileage: 258405 km
                    Date: 2016.02.05
                    Time: 00:18:32
                    Reset counter: 8
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:42:19
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 21:11:11
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 21:11:11
                    Reset counter: 9
                    Mileage: 237004 km
                    Date: 2015.12.11
                    Time: 06:28:43
                    Reset counter: 214
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 00:00:02
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 21:11:14
                    Reset counter: 8
                    Mileage: 236539 km
                    Date: 2015.12.10
                    Time: 19:42:19
                    Reset counter: 2
                    Mileage: 189966 km
                    Date: 2015.08.26
                    Time: 06:13:11
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 21
                    Mileage: 258405 km
                    Date: 2016.01.30
                    Time: 08:54:36
01304 - Radio
                    Reset counter: 0
                    Mileage: 189039 km
                    Date: 2015.08.11
                    Time: 00:00:06
                    Reset counter: 1
                    Mileage: 189837 km
                    Date: 2015.08.25
                    Time: 00:05:17
Address 1C: Position Sensing
   Component: IMMO          H05 0305
   VCID: 6A8DC871CCFF072B317-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000197502
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 270BF1451F6DFA43EE9-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004495216
   Coding: 000490
7 Faults Found:
65538 - Local Data Bus
          U10BA 00 [008] - No Communication
          [Front Timeout LIN Sub bus]
                    Reset counter: 10
                    Mileage: 237004 km
                    Date: 2021.07.20
                    Time: 06:18:27
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 222
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Fault Frequency: 155
                    Reset counter: 233
                    Mileage: 190650 km
                    Date: 2021.04.05
                    Time: 00:15:53
68098 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN KSG]
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2021.03.14
                    Time: 21:11:11
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN BSG]
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2021.03.14
                    Time: 21:11:11
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 10
                    Mileage: 237004 km
                    Date: 2021.07.20
                    Time: 06:11:26
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 225
Address 44: Steering Assist
Address 52: Door Elect, Pass.
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K3051741
   Coding: 0500040004
   VCID: 619FAF5D31494473E0D-8034
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 254
                    Mileage: 188869 km
                    Date: 2015.08.05
                    Time: 21:11:18
                    Reset counter: 215
                    Mileage: 189039 km
                    Date: 2015.08.11
                    Time: 03:06:01
                    Fault Status: 00101011
                    Reset counter: 237
                    Mileage: 189039 km
                    Date: 2015.08.11
                    Time: 10:27:22
                    Fault Frequency: 15
                    Reset counter: 22
                    Mileage: 189039 km
                    Date: 2015.08.11
                    Time: 10:29:47
00856 - Radio Antenna
                    Reset counter: 237
                    Mileage: 225671 km
                    Date: 2015.11.20
                    Time: 22:22:54
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 10
                    Mileage: 237004 km
                    Date: 2015.12.11
                    Time: 08:34:48
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
02904 - Hard Warning 3
                    Mileage: 214684 km
                    Date: 2015.10.26
                    Time: 16:08:43
                    Text: 3446669878
                    Pressure: 1.80 bar
                    Pressure: 2.40 bar
                    Temperature: 18.0°C
                    Text: E0
                    Speed: 103.0 km/h
02903 - Hard Warning 2
                    Mileage: 229489 km
                    Date: 2015.11.25
                    Time: 06:21:03
                    Text: 3437780476
                    Pressure: 0.10 bar
                    Pressure: 2.40 bar
                    Temperature: 42.0°C
                    Text: E0
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005102855
   Coding: 0013077
   VCID: 3A2D3831F05F77AB817-806E
                    Reset counter: 22
                    Mileage: 235800 km
                    Date: 2015.12.10
                    Time: 11:23:06
                    Reset counter: 22
                    Time Indication: 15
End----------(Elapsed Time: 01:21, VBatt start/end: 13.2V/13.2V)-----------
Vic72
Covington, TX, USA
C?ID=419103
I was gonna maintain the fluids n filter in this tranny but it looked different than the 10 yrs older ones I was used to, the YouTube videos didn't match what I was seeing and the manual said leave it to professionals
Threads merged.
VIN Number
3VWRL7AJ7AM083811
Make
VOLKSWAGEN
Model
Jetta
Model Year
2010
Drive Type
Manufacturer
VOLKSWAGEN GROUP OF AMERICA, INC.
Engine
1.968000
Style/Body
Sedan/Saloon
Age
9
Manufactured CompnayVOLKSWAGEN GROUP OF AMERICA, INC.
Plant Company Name
Vehicle TypePASSENGER CAR
Series-
Body ClassSedan/Saloon
Doors4
Engine (CI)120.094728378
Engine (CC)1968
Fuel TypeDiesel
Cylinders4
Vic72
Covington, TX, USA
C?ID=419103
01066 Driving despite selector Lever Position Neutral...??? what does this transmission code mean Is there a way I should adjust my shifter cable where it connects to top of transmission
Vic72
Covington, TX, USA
C?ID=419103
Threads merged.
In sept 17, 2021 i was writing about 2010 jetta with trunk now I writing about 2011 golf 4 door hatchback but both are 2.0 diesel, the 2011 golf Vin # is WVWDM7AJ9BW23906
