Hello
Anyone allready coded facelift superb for towbar? Is there any access problems?, which all modules need to be coded..? Thanks in advance for help.
Chassis Type: NP-SK48 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 4B 52 5F
6C 6D 75 A5 BB BC D6 D7
VIN: TMBJH9NP0L7023412 Mileage: 24123km-14989miles
Address 01: Engine (J623-DSRA) Labels: None
Part No SW: 05L 906 022 BJ HW: 05L 907 309 B
Component: R4 2.0l TDI H30 9737
Revision: E3H30--- CVN: 4FA4F72E644B2C53FDCF42ED644B2C5343FB2DAA
Coding: 011904120344050830000000000000000000000000000000
Shop #: WSC 00033 790 00158
ASAM Dataset: EV_ECM20TDI01105L906022BJ 006004
ROD: EV_ECM20TDI01105L906022BJ_006.rod
VCID: 70B9DAC94A23F9AB572-8024
VINID: 91D49A6097A001C1C008310108EB6D93A8
41157 - Reductant Level too Low
P203F 00 [047] - -
Mileage: 23326 km
Date: 2021.08.27
Time: 07:19:08
Engine RPM: 1313.50 /min
Normed load value: 89.0 %
Vehicle speed: 77 km/h
Coolant temperature: 97 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.060 V
Unlearning counter according OBD: 0
Outside temperature sensor 1: B1: raw value: 13.5 °C
Reducing agent pump module relative press.: calculated: 6691 hPa
Reducing agent fill level sensor: act. value: 51.0 mm
Sensor for reducing agent tank temperature: temperature: 14.5 °C
Reducing agent system pressurization release conditions-Bits 0-7: 2
Reducing agent system pressurization release conditions-Bits 0-7: 255
Reducing agent system: current status: COSCR_PRESSURECTL
Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 4
Part No SW: 5Q0 614 517 FA HW: 5Q0 614 517 BR
Component: ESC H82 0190
Revision: 00000000 Serial number: 62599000001041
Coding: 1E077A9C31223B6F477B060160C549785E8CDCE2600692753463F0F8D0824A0B0003000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B7EBDD3541DC83844-8020
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0527832133
Coding: 0F20000623
ROD: EV_KessyHellaMQBAB_004_SK25.rod
VCID: 45D75B1D25210C03D44-8010
Subsystem 1 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84622609
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 FC HW: 3V0 907 044 FC
Component: AC Automat H34 4803
Revision: 20K10000 Serial number: 00000E01457553
Coding: 1201010400241001100510010010102E
ASAM Dataset: EV_ACClimaPrehVW37X 002027
VCID: 7AADF8E11C5FB3FBE96-802E
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 92710613
Rear A/C control head:
Subsystem 2 - Part No SW: 3V0 907 049 D HW: 3V0 907 049 D
Component: E265KlimaHeck H02 0101
Serial number: 06051501850797
Part No SW: 5Q0 937 086 CF HW: 5Q0 937 086 BR
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: J53F010919003O
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 00598A097A83E92BA72-8054
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 190806 032 0121
Serial number: 00000001907310305833
Coding: 165DDD
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SAY19M09D12H23M08S10
Coding: 0088DF
Humidity sensor: interior:
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100050920190C205518
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419260
Coding: 0471155841
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000.rod
VCID: 50F97A49EA63D9AB772-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 R HW: 3Q0 907 567 A
Component: ACC BOSCH MQB H01 0771
Coding: 2A0460D251FFC728949C812460400600000000000000000046
ASAM Dataset: EV_ACCBOSCHVW416 003014
ROD: EV_ACCBOSCHVW416_003_VW48.rod
VCID: 46D55C111827071BDDE-8012
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 02091941350416
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 382922E962D361EB5F2-806C
Part No SW: 5Q0 959 655 CA HW: 5Q0 959 655 CA
Component: AirbagVW21 008 0403
Serial number: 003FPR5PLMT0
Coding: 98FCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 015F8F0D7189E023A8C-8054
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 3V0857701C0264T00176
Coding: 80000D
Right seat belt tensioner:
Component: BeltPretRevFR 106 1040
Serial number: 3V0857702C0264T00672
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 709 19
Serial number: 35700000000002BC904A
Subsystem 4 - Part No SW: ----------- HW: 480 001 409 19
Serial number: 358000000005235C3047
Subsystem 5 - Part No SW: ----------- HW: 480 401 009 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001C2F0A2E23255$
Subsystem 6 - Part No SW: ----------- HW: 480 401 609 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001BAF20D052C465
Subsystem 7 - Part No SW: ----------- HW: 480 401 609 19
Component: FrontSensor_D 005 6149
Serial number: 3550001BCF27DCC954F2
Part No SW: 3V0 920 751 E HW: 3V0 920 751 E
Component: KOMBI 303 6700
Coding: 07A509127F88000801886B0B1001000880000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
VCID: 36352CD168C7979B4DE-8062
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 24091910800947
Coding: 0B0100045F087300AB1002DE880F00010001070000000000000000000000
Shop #: WSC 00033 790 00138
GVL: 01463C000800060840DC800080024C0000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
Generator:
Component: 4-00-05-00-04
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0180
Serial number: 000000000E0794190919
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 3935642605
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
Component: U13DCAC H27 0810
Serial number: 2158779
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3Q0 909 059 G HW: 3Q0 909 059 A
Component: EBKV H06 0069
Serial number: BPA085050919013
Coding: 0102C500340000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
ROD: EV_BrakeBoostG2BoschVW48X_011_SK48.rod
VCID: 3B233DE553E54AF3B20-806E
108400 - Immobilizer Control Module
U0167 00 [032] - No Communications
[NoVINDetected]
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000243919005
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333315C57BB582B36A0-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007SGB27187
Coding: 0010000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3FDB49F547FD56D39E8-806A
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0149
Serial number: 00000525315194
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F27ED59D978E3A0C-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0149
Serial number: 00000526260161
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000388560907
Coding: 001D8920DE00028000001100
VCID: 4DC7633DFD51F4431C4-8018
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 957026 00
Coding: 0100001100400110
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2.rod
VCID: 2B030DA5A385DA73220-807E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 20091911602007
Coding: 00000007090008EA06003D13010000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B21D56FCD6E93568-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000389684235
Coding: 001D8120DE00028000001100
VCID: 4CC16E39064BFD4B0BA-8018
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 565 035 874 HW: 565 035 874
Component: MU-S-ND-ER H41 0477
Serial number: SKZAZ2W1033062
Coding: 03840201FF0000004111120100800A232F0208C401200500CE
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 5BE39D65B3A56AF3920-800E
Subsystem 1 - Part No SW: 3V0 919 605 D HW: 3V0 919 605 D
Component: ABT_Std-2_Nav H53 8130
Serial number: SKZ6ZHW2663664
Subsystem 2 - Part No SW: 5L0 051 236 BJ HW: -----------
Component: ECE AS 2020 --- 1310
Component: RVC Compact H18 0231
Coding: 0484020182002017000040
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 0D08
VCID: 48C952291233116B2F2-801C
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 03840201EA421A0D3F1C9E000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3D2733FD4DF144C38C4-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1030
Serial number: E33417008192570
Coding: 0002089811684028B09F00000030008001210000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BDD0C1442FCBBBA16-8026
Part No SW: 8W0 959 595 M HW: 8W0 959 595 J
Component: TSG HFS 010 0384
Serial number: 0000389967810
Coding: 001881208000028000001100
ROD: EV_DCU2RearDriveMAXHCONT_SK37.rod
VCID: 56F58C51C887B79BADE-8002
Component: TSG HBFS 010 0384
Serial number: 0000389959833
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_SK48.rod
VCID: 619FAF8D91C94023C8C-8034
131352 - Databus
U1121 00 [032] - Missing Message
[CAN message RLS_01 missing]
Component: LED1R H08 9002
End----(Elapsed Time: 01:54, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
